- #141
DrChinese
- 1,959
heusdens said:I.
If the detectors have an equal setting, then the results are either ++ or --. The positive correlation (= same result from detectors) is 100% (or 1).
{Question:
a. can we still assume that each individual detector produces a really random result?
b. does the correlation only hold for exactly simultanious results?
c. the cances of either ++ or -- are 50% each ??
It would be weird if b and/or c does not hold and a still holds...
Second remarkable thing:
II.
If the detectors have an unequal setting, then we find that results of +- and -+ , that is negative correlation (= unequal result from detectors) happening with a change of 25% (or .25).
{Same questions as above, but for c now: chances of +- or -+ are 50% each??}
a. Each detector sees a random pattern, always.
b. There is a coincidence window used for detections, and the setup is calibrated so the middles of the windows are equivalent. But it does not actually matter at all if the detections are simultaneous.
c. The likelihood of + or - at any detector is always 50%. Just to be specific: when we have Type I PDC entangled photons, then we have perfect correlations (at identical settings). So you get ++ or -- almost all of the time.
In the II.c. case, there are 4 permutations: ++/-- and +-/-+ ) i.e. matches and non-matches. Matches can drop as low as 25% for certain settings (usually specified as 0, 120, 240 degrees).
