- #246
DrChinese
- 1,921
calamero said:Looking at the 1st post i think what the guy is saying is if bob measures the angle of spin at a and mary when measuring the spin at b finds out there the same result then after getting results over time that always gives corelation at an observed angle then mary is no longer needed becuse if bobs measured angle at a is same as it was the last 100 timres he did it with mary then he pretty damn sure he knows what the outcome will be at point b without having mary there to tell him the result as he already knew by seeing what the reultat a was...bells theorem says that in order to have realism or an epr outcome them there must be hidden variables WHY?..Surely when the particle pair leave the source on there way to points a and b at the time of leaving they have a definite spin ,angle or whatever and although we don't knowthere state at that time we know if we measure there state at one of the 2 popints then we willknow both states..the result at a doesn't change the result at b or vice versa it just is that's thee way it played out ..no hidden varialbes or instruction sets that's nature...as i say qm's problem is it doesn't "learn" from past events it just throws everything learned away and starts from scraych again..nature reality isn't like that imo...reason i got into physics was to try and understand electrons and the slit expirament and i began to thinkthat elecrons or anything at the quantum level had a "history"..now I am thinking maybe he problem is not nature itself keeping a record but the way qm looks at it ...?
Hi Calamero, and welcome to PhysicsForums.
QM does not "ignore" the history. There simply isn't any. Each and every observation puts a particle into a new eigenstate. Once that happens, the particle has no "memory" of earlier states. I know that does not sound reasonable. Neither is it "reasonable" that a pair of entangled particles do NOT have definite spin at the time they are created.
That is why Bell's Theorem is so important. I will repeat the generally accepted conclusion of Bell:
No physical theory of local Hidden Variables can ever reproduce all of the predictions of Quantum Mechanics.
Keep in mind that experiments support the predictions of Quantum Mechanics and do NOT support the predictions of local Hidden Variables. You must abandon your assumptions about either locality (speed of light is an upper limit) or realism (particles have definite attributes at all times).
I hope this helps.
