Can Everything be Reduced to Pure Physics?
In summary: I think that this claim is realistic. It is based on the assumption that we have a complete understanding of physical reality, and that all things can be explained in terms of physical processes. I think that this assumption is reasonable, based on our current understanding of physical reality. Does our ability to mathematically describe physical things in spacetime give us sufficient grounds to admit or hold this claim? Or is there more to physical reality than a mere ability to matheamtically describe things?I don't really know. I think that there could be more to physical reality than a mere ability to mathematically describe things. It is possible that there is more to physical reality than just a description in terms of physical processes. In summary,
In which other ways can the Physical world be explained?
  • By Physics alone?
    Votes: 144 48.0%
  • By Religion alone?
    Votes: 8 2.7%
  • By any other discipline?
    Votes: 12 4.0%
  • By Multi-disciplinary efforts?
    Votes: 136 45.3%
  • Total voters
    300
  • #701
quantumcarl said:
A gene is modified by the trials and errors that are inherent in its interaction with the environment. The modifications take place during the sequence of the gene's production, reproduction and subsequent resulting generations. The outcome is that only those modifications will survive in the gene that produce a survival trait or have a benign influence on an organism. Any other modifications will result in the supression or elimination of the gene.
This reminds me of the way wind can wear away at sand leaving a natural sculpture of slightly compressed sand.
No, no, no! The gene is not selectively modified by the environment. That is Lamarckism! The genes vary randomly, mostly by simple substitution of one of the four bases by its conjugate base (A <-> T, C <-> G, I believe, though I may have it backward :rolleyes: ). The resulting change in the genome can make a change in the offspring (although it need not, see neutral evolution). The change may make the offspring more likely to produce viable offspring of their own. If it does, that change will be carried on. Conversely, changes that cause the next generation to be less likely to produce viable offspring will be lost. The test that tells which is the interaction of the organism with the environment.
  • #702
CronoSpark said:
I am not sure if you are referring to everything as in everything including the past of the universe. Right now there is a possibility that physics might explain it. To boldly state that it can is something that is highly questionable.
Well, even if physics is not making this claim itself, that's what the reductive activities tend towards. I been joining everyone and blindly debating with everyone up to this page without ever really thinking about the underlying value of 'reducing everything to physics', So, why? Well, there many good reasons for this:
Nanotechnology and the notion of Structural and functional Perfection. This is the claim that by rearranging atoms at the nano-structural level, we could improve the structural and functional qualities of things.
Genetic Engineering and the notion of structural perfection. This is the claim in biological science, which says that by genetically engineering things you can improve their structural and functional qualities. Eugenics or Race biology is a good example of this.
Costs naturally reduce if we know things and their relations to their finest details.
And so on. So, reductionism to the level of physics does have unigue intellectual and meterial advantages.
Our own perception toward things in the universe may hinder our explanations.
Yes, substantially so, but this does not rule out the possibility that we can explain and know things. It's just that some things naturally range over COP (Critical Observation Point). And I get very irritated when some scientists appear to abandon Logic at COP during routine observations and measurements in experiments. Yes, we are perceptually or visually limited, yet this is no license for us to give up scientifically at points of difficulties.
If it includes the past, then if physics can prove that "something" can be produced by "nothing", then I would say yes it explains everything about the universe.
I am intellectually allegic to the term 'nothing' as I currently believe it has no conncetion to 'reality' or 'something'.
  • #703
selfAdjoint said:
What you have called ignorance could also be called indifference.
Not really as the connotations of "indifference" and "ignorance" are quite different. "Indifference" expresses a lack of interest, whereas "ignorance" expresses a lack of knowledge. Now I know ignorance carries the idea that the information might be available if you went after it but that connotation is easily removed by using the adjective "enforced".
selfAdjoint said:
It is not the case that there is an origin around here somewhere but we don't know where it is; rather we can put the origin wherever we like and it won't make any difference to the physics.
Oh, don't worry, I understand exactly what you are saying; however, in my opinion you have it exactly backwards. There is a very important philosophical point here: from your statement of the relationship you are required to make the assumption that "it won't make any difference to the physics". If your purpose is to establish the foundations on which to build physics, the defense of the assumption becomes circular. And secondly, from your perspective, you have thrown out the possibility that "there is an origin around here somewhere but we don't know where it is". Another assumption! Oh, I won't argue that you can't make some excellent arguments to defend your assumption but it violates my original purpose. I expressed my position on the scientific method and clarified that position with a post to "What is evidence?"
And we can argue about the necessity of your comment #2 after you understand where I am going. That is the standard approach to the Noether argument and not the approach I am headed for. For the moment, what is important is the realization that "symmetry" is a statement defining a specific lack of information; a perspective on symmetry quite different from the standard. The important point is that the "ignorance" perspective is consistent with being scientifically objective:
Doctordick said:
What I am talking about is the importance of creating methods of attack which will keep one's options open.
The perspective that "I am ignorant" is objective in that sense!
Have fun -- Dick
  • #704
I can see that the reduction have advanced quite drastically over these past years, and may reduce even further in the future. Yet it still does not rule out that it is a possibility ATM.
The world is flat. :biggrin:
It should not have any connection to "something". But I guess what I was implying was: where (how, why, when... who?) did "something" (or this "reality") come from?
  • #705
I'm not sure that I indicated a gene is "selectively" modified by its environment. A gene will selectively be expressed or repressed when conditions in the environment stimulate either function.
Believe me, in order to have "A" conjoined with "T" and "G" conjoined with "C" in a strong bond and diverse fashion you need certain elements in your diet. Diets are a type of environment. The diet requires certain minerals etc.. to arrive at a healthy mixture of neucliotides, amino acids etc... thus increasing the probablity of producing a functional gene.
If there are minerals missing in the diet that support the development of certain gene types, the gene type will go recessive or be elimantated. This scenario could be construed as environmental modification of a gene but not a "selective" or deliberate modification of a gene.
I am wrong here?!?
  • #706
This is absolutely wrong. Every cell in your body contains your DNA. Within that DNA are the bases A, C, T, and G in different triples coding for different proteins, plus other arrangements for control. They are connected by chemical bonds of different types, and as long as you are alive, indeed long after, they will continue to be. Random mutations apart, they and their sequence were established at your conception, and do not vary causally because of your diet or anything of that kind. Strong invasions of chemicals or radiation can modify the DNA in individual cells, but nothing short of dissolution will modify the DNA in ALL you cells.
You are talking about stuff you don't know anything about.
  • #707
Symmetry
Symmetry & conserved quantities
The relationship between symmetries and conserved quantities was laid out in detail through a theorem proved by http://www-groups.dcs.st-and.ac.uk/~history/Mathematicians/Noether_Emmy.html sometime around 1915.
Mmm, very interesting stuff. I did electronical engineering, so I didn't know this theory yet.
Symmetry & ignorance
What I would like to point out is that any symmetry is essentially an expression of a specific ignorance. For example, mirror symmetry means that there is no way to tell the difference between a given view of a problem and its mirror image: in effect you are in a state of enforced ignorance as to which view is being presented.
I was thinking about this, this weekend. You extended my concept of symmetry, until now I thought only 1 & 2:
  1. Symmetry as a property of an entity; a predicate
  2. Symmetry as non-informational overhead; reducable according Shannon's or Kolgomorov's definitions of 'information'
  3. Symmetry as lack of knowledge about the difference between (a part of) an entity and it's symmetrical counterpart.
Your definition - if I did state it well enough - does let it look as a perceptional quality (observing differences) and a conceptual quality (having to do with knowledge). Immediately does arise the question: "Does 'real' symmetry occur?"
[Question] Symmetry & (non-)existence of specific knowledge
And if symmetry is an expression of a specific ignorance; does this entail that there exist a specific knowledge about the very thing? Can we see symmetry as a lack of knowledge about differences, if there are no differences, and so knowledge about differences can not exist. I agree with you, although I don't know where you want it to use for yet. Are definitions as: "Groups denote lack of knowledge about the non-simularities of their elements." or "Edible are these things of which we are ignorant about its poisonous character." also valid? In what aspect do these sentences differ?
Information & ignorance
The above [conserved quantities] can be seen as a means of obtaining information from ignorance. This is why it is called the most powerful argument which can be made. But let's think about that for a moment. Noether's theorem is a mathematical result and, as such, cannot produce anything which is not contained in the axioms. Ignorance cannot be the true source of our result; it must be arising from some other source.
I do not really understand you. There is a fundamental observation: symmetry, which denotes a lack of knowledge, what can be solved by using the concept 'conserved quantities'. In what way is such a concept not an axiom? An axiom like: there exists a thing as angular momentum. Or an axiom like: we don't know the centre of our universe.
I look forward to your other observations.
  • #708
To whom it may concern,
I just received an email from Dr. Dick in which he asked me to do him a favor. To make sure I convey everything I know about his plight, here is the verbatim text he sent me:
"I am blocked off the Physics Forum
because of the required password change (long story
how that happened). At any rate, I can't get any of
the automatic e-mail answers from them so I can't seem
to get anything straighted out.
I have been posting on the "Metaphysics &
Epistemology" section to the "Can Everything be
Reduced to Pure Physics?" thread. "saviormachine" has
just answered my last post and I would like to let him
know that I can't get on the forum. If you would drop
him a private note or post a comment as to my problem
on the thread, I would appreciate it a lot."
I hope someone can help him.
Paul
  • #709
Hi SelfAdjoint.
A diet for your genes
It comes as no surprise to hear that our diet can affect our general health, but the idea that different foods can influence health by targeting specific genes is more difficult to imagine. Yet scientists at the Institute of Food Research on the Norwich Research Park are setting out to find out how the food we eat might alter the activity of our genes. In the long-term they hope to be able to help the Government give better advice on how to improve our chances of a healthy life through the food we eat.
Our genes act as the blueprint that our bodies follow to develop and function properly. But not all of our thousands of genes are active at the same time, as genes are turned on and off at different stages in our growth and in different parts of our bodies. And the IFR scientists are wondering if our diet can also affect which of our genes are active. If they are right, it could pave the way for understanding exactly how diet can affect the health of our bodies.
Iron Deficiency Sends Cells Into Tailspin
THURSDAY, Jan. 13 (HealthDayNews) -- Iron deficiency forces cells to preserve what little iron they have and to maintain essential functions by dramatically reducing the activity of more than 80 different genes.
That's the conclusion of a Duke University Medical Center study in the Jan. 14 issue of Cell.
"We discovered that iron deprivation actually reprograms the metabolism of the entire cell. Literally hundreds of proteins require iron to carry out their proper function, so without this nutrient, there is a complete reorganization of how cellular processes occur," researcher Dennis J. Thiele, a professor of pharmacology and cancer biology, said in a prepared statement.
Some of the genes affected by iron deficiency are known to play important roles in generating energy, aging, protecting the cell from free radicals and copying the cell's genetic code. But the function of many of the affected genes is unknown, meaning that some side effects caused by iron deficiency may go unrecognized.
From: http://www.medicinenet.com/script/main/art.asp?articlekey=41463
And on and on into about 283,000 matches to a search on “diet affecting genes” for your records.
I must admit I made a calculated guess with my statement but, it turns out that I know what I’m guessing about! :smile: In actual fact I was only trying to define the environment of a gene and the effects the environment has on a gene. In the end the gene is the environment as well.
I know some of what I speak of because I have worked with world class geneticists and it has rubbed off.
It may even have altered my genes to a degree.
Bold statements like "you don't know what you're talking about" do not a mentor become. Try to take a more positive taque, at least when your mentoring the younger students, eh? :!)
  • #710
DoctorDick (by Paul Martin) said:
I am blocked off the Physics Forum because of the required password change (long story how that happened). At any rate, I can't get any of the automatic e-mail answers from them so I can't seem to get anything straighted out.
I have been posting on the "Metaphysics & Epistemology" section to the "Can Everything be Reduced to Pure Physics?" thread. "saviormachine" has just answered my last post and I would like to let him know that I can't get on the forum. If you would drop him a private note or post a comment as to my problem on the thread, I would appreciate it a lot.
Oh, take your time. I'll check every week or so. Maybe you can another pseudoniem, doctordick. Thanks for your time till now.
  • #711
Well, I am back, sorry I missed you.
I have no idea why what happened happened. Computers are strange things sometimes: apparently it never reset my password or sent me an e-mail. I kept trying variations on what I thought I had used and suddenly one worked :blushing:
So: my response to "saviormachine"!
I think you should be aware of the difference between "a theorem" and "a theory". A "theorem" can be proved, a "theory" can not, it can only be defended. :biggrin:
Two and three are opposite sides of the same coin so to speak; one is entirely equivalent to the other. :approve:
I could be wrong but it seems to me that you are confusing the two different issues: the symmetry (a representation of some particular mode ignorance – or indifference, per selfAdjoint's perspective) and the deduced conserved quantity required to enforce or accommodate that symmetry (a requirement established by internal self consistency). :confused:
I don't know that I would use the phrase "symmetry denotes a lack of knowledge"; I would rather express it as "symmetry can be seen as a lack of knowledge". But of course, my main complaint is the vagueness of English anyway so I am not really aware of what relationships are implied in your head when you use the phrase. Thus it is that anything I say on the actual meaning of your comment is no more than an opinion. The symmetry and the conserved quantity are related through the necessity of maintaining that "non-informational overhead" you referred to in #2 above. As you said, the representation must be reduceable and the mathematical constraint which provides that reduction is the conserved quantity. :cool:
Take for example, the consequences of not knowing the "center of our universe" (the origin of the coordinate system used to represent positions in our problem solving). If we don't know where the origin is, we don't know the particular value of any position. It follows that there is a different solution for every possible position of that origin. The other side of the coin is, if we are able to find a solution (say x as a function of t) we can clearly take that particular solution and deduce exactly where the origin was. :devil:
Since we now have information which was not available in the original problem given to us, something here is logically inconsistent. :bugeye: Conservation of momentum is a mathematical relationship on that solution which makes all the various solutions (the collection of solutions, each of which would independently allow deduction of a different origin) equivalent to one another. It is the relationship which provides the required reduction in information. What I am giving you is no more than a different perspective on Noether's theorem. :cool:
My purpose in stating things in such a strange way is to bring out the obvious inconsistencies implied by presuming we know things we cannot possibly know (setting up a coordinate axis when we don't know where the origin is). Remember, my sole purpose is to establish the parameters on my thoughts which will assure me that I am not inadvertently presuming information I do not have. Noether's theorem is an excellent example of how easy such a thing can happen and I don't think the common presentation brings the most important issue to the forefront.
The axiom is: we are ignorant of something. When we set up our coordinate system, that ignorance is not explicitly displayed: blind usage of the coordinate system ignores the embedded ignorance. It follows that we must have a constraint which will yield up that same ignorance in our final results. It is the relationship I am trying to bring to your attention, not the solution.
At the moment, let me list what I have presented to date: :wink:
1)The existence of "squirrel thought" (intuition, zen, fundamental knowledge) which is not a process amenable to logical analysis because of the extreme limits on logical analysis but, none the less appears to provide very effective solutions to very important problems. This is the only source of solutions to any conceivable problems and we must keep its failings in mind. :smile:
2)The existence of "mathematics", a mental construct capable of extending logical relations far beyond what can be held consciously available for logical analysis. It constitutes a "very effective solution" (i.e., an intuitive construct) which has acquired far reaching agreement as to meaning and internal consistency. It is the only collection definitions which are accepted widely enough to provide anything close to "exact" communication. If a science wants to be exact, it must present its ideas with the same exactitude expected of mathematics. :devil:
3)That any representation of information in a mathematical form makes presumptions which must be carefully analyzed. We must make sure our ignorance is maintained in our analysis (we must not claim or imply that we know things we cannot know). :biggrin:
The next thing I would like to bring forth is apparently very difficult to communicate and I beg your indulgence. I tried to get people to think about this issue when I posted a simple question back in May of 2004. I totally failed and I am quite sure the fault was mine for not putting it in a form they could identify with. The original question was buried in a large post to Russell E. Rierson but is more easily discovered through a post on that thread by baffledMatt. If you want to look at my earlier attempt, a quick perusal of that thread might be a place to start. The original question was, "how does one tell the difference between an electron and a Volkswagen?" The point was that context is the single most important piece of information required to answer the question, a piece of information seldom even considered as significant. :cry:
In order for you to comprehend what I am getting at, consider the following steps. Your purpose is to examine an event which took place at the point in space referred to as (x,y,z,ict) (if we are to be exact, your approach must be general relativistically correct and we will use Einstein's picture). Your problem is to identify the object which was present at the event (for the fun of it we will make the answer to the question very simple; it was either an electron or a Volkswagen). :-p First, can you go and look at the event? Of course you cannot; to do so would require you to have a time machine. :bugeye: Exactly what information do you normally have to go by in the situation where such a question might arise? :confused:
It should be clear to you that what you really know (or at least presume to know) is the collection of events which immediately surround the event of interest. :cool: If the object were a Volkswagen, the significant surrounding events might include a road, a driver, maybe some trees or a building. If the object were an electron, a more reasonable set of surrounding events might include and "electron gun" or perhaps a wire or maybe a lab table. So the first step is to identify the most significant of these surrounding events. :rolleyes: But that is just a restatement of the original problem. Again, you can't go look; you must depend on what you already know. Fundamentally, you need to know the distribution of events in the vicinity of (x,y,z,ict). :approve:
For the moment, let us not worry about the process by which you come to know the existence of those events in the vicinity of (x,y,z,ict). What is important is the distribution of events themselves. What I am getting at is the fact that identification of any event is essentially a presumption of what distribution of surrounding events will be accepted as a valid set. :rolleyes: In other words, if I were to give you a specific distribution of events the distribution itself would express the identity of its various parts. :approve:
What is important here is that the presumptive necessity of identifying the fundamental entities making up a particular situation it totally erroneous. :devil: If I were to give you a mathematical expression (a function of many variables) which yielded the probability of finding a specific distribution of events as a function of time (that distribution being the collection of variables looked at as coordinates, [x,y,z,ict], of specific unnamed events) then that expression itself fundamentally characterizes the identity of all those events. :cool:
This is a very simple concept with very far reaching consequences; particularly if we wish to keep our minds open to all possibilities. As I said, identification of a particular event is paramount to establishing a very large set of acceptable and unacceptable peripheral events which are, in the final analysis, only vaguely specified. This is a very poor basis for "exact objective analysis". One should not label things first and then attempt to explain the labeled things behavior; one should examine and attempt to explain the behavior itself: when, where and under what circumstance the behavior occurs. "When" and "where" is coordinate specification and "under what circumstance" is a specification of associated behavior found at a related "when" and "where". o:)
Let me know if this perspective on the problem confronting scientific investigation makes any sense to you at all! :confused:
Have fun -- Dick
  • #712
Hi DoctorDick, you're back again! New mind-boggling thoughts! :smile:
Ignorance
I totally agree with you. Better to define, than to presume.
Identity
Question: Do you mean that the various parts do have there own identity ("the identity of its various parts")?
What is important here is that the presumptive necessity of identifying the fundamental entities making up a particular situation is totally erroneous. :devil: If I were to give you a mathematical expression (a function of many variables) which yielded the probability of finding a specific distribution of events as a function of time (that distribution being the collection of variables looked at as coordinates, [x,y,z,ict], of specific unnamed events) then that expression itself fundamentally characterizes the identity of all those events. :cool:
And, there exist an infinite amount of mathematical expressions that will characterize this specific distribution...
Question: Do you mean, that with reductionism the identity of the whole will be destroyed ("identifying fundamental entities ... is totally erroneous")?
Off-topic?: In a particular situation we observe - no object but - for example "periodicity";
  • what for us - human - is a meaningful concept
  • what we - human - can observe in other particular situations too
I guess this concept [periodicity] can be seen as part of a specific distribution too, but not in the coordinate system of 'reality' [x,y,x,ict], but in the semantical world itself {constancy, periodicity, heterogeneity, variety, multiplicity, linearity, irregularity, complexity}. Can you point out the flaw in me identifying this (semantical) concept? I think that would clearify it a lot.
Understood: Identifying occurs by embedding 'something' in an acceptible set / distribution of surrounding events / concepts.
I agree.
  • #713
Hi Savior,
Glad to see you back. You seem to be the only person interested in my "crackpot" perspective. :!) If you haven't seen it, I have a new "intellectual" adversary: according to him, I am solving a pseudo problem and pseudo problems have many pseudo solutions. :-p
Very well put! I "squink" you understand. :wink:
Not really. What I mean is that if one is going to give identity (i.e., label in some way) the various collections of events which establish the identity sought for (i.e., the original label for the event at [x,y,z,ict]) then those identities are established in the exactly the same manner. That is, the significant collection must be looked at as a holistic entity. As I said earlier, the labels originally attached to these "events" are actually a presumed constraints as to what associated events are acceptable. All discussions essentially use definition as a mechanism to compartmentalize your thoughts. One can think of the identities of things as a shorthand for what is or is not the behavior under discussion. :redface:
As far as the behavior of "events" is concerned, in Einstein's perspective the concept is an oxymoron; events are a location in his space time. Events either exist or don't exist. It is the dynamic pattern of events (often called the time line of an entity) which gives meaning to the word "behavior". Now this "time line" can be seen as a collection of events related to the original event under scrutiny; and thus the "behavior" yields the identity of the event (and that behavior is a collection of events in the vicinity of the original event of interest). :devil:
No; what I meant was that the presumptive necessity of identifying the fundamental entities is erroneous. The current approach to physics is to think of the behavior of identified entities as the fundamental essence of reality. I am pointing out that they have made a presumption that this identification is a necessary aspect of explaining reality. I am saying that, from the very structure of Einstein's space time continuum, this step is clearly unnecessary: i.e., this "presumptive necessity is in error". :rolleyes:
Now, I am not saying it is not a valuable assumption! Without that valuable shorthand, we could not bring the circumstances of interest to us into a form which can be analytically analyzed. :approve: That is what most all of physics is about: analyzing behavior of real or hypothesized entities. But, as I said way back when I started this discussion, I want to do my very best to assure that I do not preemptively shut out a possible solution. My only point is that identifying events is such an unnecessary preemptive assumption. :cool:
There is no error in your identification. Definition can always be seen as a label identifying when and where usage of the label is acceptable. In fact, a dictionary entry can be seen as a specific description of the usage of the symbol (word, label, Idea, -- whatever you want to call it). In essence, words can be thought of as lossy data compression mechanism. This idea applies just as well to "real objects". :rolleyes:
Understood: Identifying occurs by embedding 'something' in an acceptable set / distribution of surrounding events / concepts.
I wouldn't quite put it that way; in my head that sort of confuses the horse and the cart. Langauge is vague because of our limited ability to provide definitions. If we wish to be exact, we should do our best to avoid closing the door on exactly what these definitions should be. :frown: Essentially, I am suggesting we work with the holistic information itself and leave introducing identity until we fully understand the range of behavior possible and how it might be represented. o:)
This is actually a very abstract perspective and difficult for most people to follow. In my opinion the problem is that their interest is in finding easy methods of solving important questions. My answer to that interest is, just go with your intuition, "squink" away at it; it's probably the best and easiest approach available to you. Presume all the authorities have already found the most convenient solutions and use them. My interest, on the other hand, is in understanding things at a fundamental level. :-p
If all that is clear to you then I can step off to the next fundamental issue which should be examined carefully. That issue is also quite straight forward but seldom if ever discussed in detail. It has to do with what exists and what rules it obeys. The scientific community seems to hold that these two things are of great interest to them but they never seem to show any interest in the relationship between the two. When one looks at the big picture, especially with a historic perspective, it is quite evident that the two are intimately related. That is, changing the rules influences what must exist and changing what will be accepted as existing influences what the rules must be. There is most definitely a duality here. :bugeye:
It has been the practice of the authorities throughout history to hold that their understanding of one or the other of these two facets is correct and that the search should be constrained to the other. Either they know what exists and are searching for the rules or they know what the rules must be and they are searching for what exists. If you stick with me, I will show you that "what exists" and "what the rules are" are essentially orthogonal concepts and there is not a single possible correct answer but rather a relational answer (the rules are related to what exists and visa versa). For the moment, the only issue I want to get across to you is that the interdependence of these two is a fundamental issue worthy of thought; very like position and momentum or time and energy. :biggrin:
Have fun -- Dick
  • #714
To identify => to relate
Yes, I agree; to identify is to relate (with events in same context).
Event - Location in space-time?
Do you really mean that "event" and "location in (Einstein's) space-time" are equal? Does this mean e.g. that: "Locations in space time exist or don't exist"? Intuitively I would rather interchange "event" for "translocation" (in space time). Would that be fine for you, or do I miss the point?
Recap: An entity will 'endure' a pattern of (space time) translocations / events, called its "(space)time line", or its "behaviour". A specific event can be seen as exemplar of the whole set of events. Identification occurs by investigating a subset of this set (events in space time vicinity of event).
I agree.
Circularity in defining prerequisites to call something 'existing'
If all that is clear to you then I can step off to the next fundamental issue which should be examined carefully. That issue is also quite straight forward but seldom if ever discussed in detail. It has to do with what exists and what rules it obeys. The scientific community seems to hold that these two things are of great interest to them but they never seem to show any interest in the relationship between the two. When one looks at the big picture, especially with a historic perspective, it is quite evident that the two are intimately related. That is, changing the rules influences what must exist and changing what will be accepted as existing, influences what the rules must be. There is most definitely a duality here. :bugeye:
I am curious. :smile:
  • #715
A point in spacetime is specified by a spatial point (3 coordinates) and a time coordinate, thus "on the sidewalk under the Marshall Fields clock at 3:00 PM". It was traditional to call such a 4-D point, an event. Whether it corresponds to someone else's concept of an event is a question. Perhaps for this reason, the locution seems to have fallen out of favor during my lifetime.
  • #716
Aha, I understand. I thought of it, as "something that happens in a given place and time plane" in stead of "something that exists* at a given place and time".
Correction: It is location and no translocation.
Recap: An entity will 'follow' a pattern of (space time) locations / events, called its "(space)time line", or its "behaviour". A specific event can be seen as exemplar of the whole set of events. Identification occurs by investigating a subset of this set (events in space time vicinity of event).
* If it is about existence, than it's easy to mix up 'causation' with 'causation of existence'. If an object is defined as a pattern of events ([x,y,z,ict] locations), than I need help to define 'existence' and 'cause' in this context - and maybe some other concepts that become contra-intuitive.
  • #717
Yes, this is good, except that the term "space time line" is not used. It is universally called the world line of the object. Maybe in another post or thread we can discuss how causal structures work in relativity.
  • #718
Shows one how far out of touch I am: I didn't know it had fallen out of favor. :blushing: However, in my head, an "event" existed: i.e., my mental picture was more analogous to saviormachine's "something that exists at a given place and time". That is, Einstein's space-time-continuum was a coordinate system within which one could identify locations where things existed. I guess the idea that the "space-time-continuum" was supposed to be "real" never really occurred to me. I always took it as intended to be a "valid" way of representing physical phenomena; not unnecessarily the only valid way. :redface:
Central to my current mental image of the situation is the fact that "infinity" is not a number (it is instead, a label for a process which cannot be completed). This means that the "time line" can not be a valid representation of our current knowledge at any time. Whatever means by which we came to "know" of that "time line", the fundamental information available to us can, at best, consist of a finite number of points in that space-time-continuum. That these points should be considered an entity (so identified and labeled) is an assumption and not a fact. What I am getting at here is that it cannot be a defendable fact as the defense would require proof of existence of an infinite number of points. On the other hand, the existence of a finite number of points could perhaps be defended (at least it seems reasonable that the validity of that issue is best laid aside for the moment).
It is the essence of my position that specification of the relevant space-time-continuum points is, at worst, equivalent to specification of a set of labeled identities and, in the final analysis, capable of representing any circumstance. From a physicalists perspective, the "universe" is referred to by simply making all events relevant; however, I will show later that the fundamental mode of representation goes far beyond physicalism.
I presume, from your response to selfAdjoint, that you understand what I mean when I say identification is equivalent to specification of behavior in a given context. What I would like to add to that is the fact that "behavior" of that identified (and/or labeled) entity is also equivalent to to specification of acceptable context. :rolleyes: Behavior is a statement of the expected path of that space-time-line given the space-time-paths of other relevant entities. The entire collection of information about the circumstance is embodied in the collection of space-time-points presumed relevant. :cool:
So let's stand back and look at the perspective I have just laid out. Our knowledge of the universe can be represented by a set of points in a four dimensional coordinate system. That representation represents both the existence of entities and the behavior of those entities. In addition to that, every bit of that "knowledge" available to us was gained in the past and we can't go back and change one iota of it. So, "what is" is "what is" and there doesn't seem to be any rules embedded in the perspective at all.
This brings me to the issue of rules. Exactly what do we mean when we think about "rules"? It seems to me that what we mean is that all possible distributions of "space-time-points" are not possible! That is, nameta9's "infinite-infinite" universe (also apparently known as the "Cosmic Universe of Complete Oblivion" :smile:) is not an acceptable solution to the problem: "What is reality all about anyway?" :wink:
Thus it is that I come to the conclusion that "the rules of the universe" consist of a mechanism which will answer the question (regarding any specific distribution of space-time-points), "Is that particular distribution possible?" Or better yet, given what I "know" about reality, what is the probability that the specific distribution of space-time-points is a possible distribution? (I really can't presume the answer has to be either yes or no, since I have to include the possibility that I could be wrong :biggrin: )
Since the information (a specific distribution of space-time-points) is a set of numbers and the answer to the question is a probability (another number), it should be clear that it makes no difference what the rules are, they can be expressed by a mathematical function: i.e., you plug in the numbers which specify the distribution and the function yields the probability the distribution is a possibility. Note that I haven't made the claim that the function is easily represented by standard mathematics (it could be no more than a table of correct answers; that is, I could be God and simply "all-knowing" :smile:).
What I have presented here is a very abstract representation of the problem. It clearly is not a very usable representation of reality but it is certainly rather universal; at least from a physicalist perspective: i.e., if what we know of reality can indeed be represented by that massive accumulation of numbers (the relevant space-time-points). Remember, I am trying to come up with an abstract representation of "the best that I can do" (knowing what I know) and am not making any claim that "the best that I can do" is ever the correct answer. However, tomorrow I may know something I don't know today but, even tomorrow, "the best I can do with what I know" will still be "the best I can do with what I know" so that at least will not change! o:)
Think a little about what I have said here and let me know if any part of it seems unreasonable. At this point, I admit it seems rather physicalist in outlook but, if you admit that their perspective covers a lot of valuable ground, I will show you how to expand it beyond the physicalist view.
Have fun -- Dick
  • #719
HOW PARAFUSES IN SCIENTIFIC PROPOSITIONS AFFECT REDUCTIONISM (PART I)
The rate at which PARAFUSES (vagueness, confusions, misunderstandings) are plaguing scientific propositions is causing grave concerns, especially in mathematical and experimental physics. By this, I mean any scientific statements that appear on the surface as wholly true and conclusive but which in actual fact are vague or confused or grossly misunderstood. The devil (usually) is in the detail! There are many of them, but here are just two good examples:
1) A instantaneously reacts or responds to B, regardless of the space distance between them.
2) I experimentally create A and B from ‘Nothing’ (or ‘Nothingness’, if you like)
In Philosophy these two scientific statements would be held not only with utmost suspicion but also it would be confronted with utmost intellectual and analytical ruthlessness. The philosophers in the disciplines of Metaphysics, Epistemology and Philosophy of Science would have not only a great deal to say about these two claims but also a great deal of very hard fundamental questions to ask about them. Now, to have a glimpse of what I am talking about here, let alone appreciate it, let us look at each of these two claims in turn.
Quantitatively, there is the fundamental need to state at the very elementary level the Time Interval (TI) or Elapsed Time (ET) between A’s Action and B’s Response or Reaction. For example:
Let ‘AT’ stand for Action Time
Let ‘RT ‘stand for Response/Reaction Time
Let ‘TI/ET’ stand for Time Interval/Elapsed Time
Therefore the calculation would be;
TI/ET = RT – AT
Now, the quantitative implication of this carefully deduced formula is that the resulting TI/ET from the calculation could range between an absolute zero and an infinitely large numerical value. This is a very basic and well-understood formula and, as far as a two-way communication is concerned, it could be escalated to any level of complexity and sophistication by adding relevant parameters (for example, nonchronous (a type of communication that the signal is received but with no response), synchronous and asynchronous types of communication). Here we are not concerned with that. Infact, that level of complexity is better left to communication and computer engineers who design and implement communication protocols for Computer Network Systems and Telecommunication Equipments. Rather we are only interested in the metaphysical, epistemological and logical implications of the action-reaction scenario of which this basics formula is more than sufficient to drive the message home. Therefore, fundamentally, there are two things that metaphysicians, epistemologists and philosophy of science philosophers would like to know, as consequences flowing from this basic formula:
The first one is this:
Does ‘A instantaneously reacts to B’ imply TI/ET = 0? In other words, what are the metaphysical, epistemological and scientific or empirical consequences of TI/ET being equal to zero?
For a start, with regards to this, metaphysicians and epistemologists would be outraged by your claim because you have single-handedly created a completely new metaphysical and epistemological categories that need a new breed of human beings to look at them, recognise them and understand them obviously in a completely new light. Metaphysically, you have created a Timeless/Spaceless Category in the psychology of the perceiver with regards to time, space and action. Epistemologically you have undermined our previous understanding (at the fundamental level) of the notions of time, space and motion and their causal relations. While in one hand Metaphysicians and Epistemologists are jointly pondering over this, the philosophy of science philosophers and Epistemologists in the other hand would be jointly outraged and pondering over the step-by-step procedures and methodologies by which you derived at such a claim. What methods or procedures did you use to derive at such a claim? So, as you can see these three groups of philosophers all have a stake in the magic that you are performing.
The key issues they are interested are these: (1) the possibility of this new Timeless Metaphysical category, (2) if so, how is this new category to be perceived and understood, and (3) if so, what scientific method or methods are there for bringing about or creating such a category? They would all together argue that by creating this new metaphysical and epistemological category, by whatever scientific method or methods that may be available, you are categorically implying that it is possible (1) not only for a single moving object of a given size to instantaneously act and react to itself at TI/ET = 0 but also (2) for multiple or infinite number of moving entities to instantaneously act and react or respond to each other at TI/ET = 0, regardless of the space distance involved. This is the gravest and far-reaching connotational implication of this sort of scientific claim or statement.
Any scientist that does not understand this and henceforth take utmost caution when he or she is making this sort of claim should immediately return his or her PhD back to the university that issued it. For no university that sincerely aims at bringing the production of scientific knowledge to the next level should tolerate this kind parafuse in scientific thinking and reports.
The second thing that they would also like to know is this:
Does ‘A instantaneously reacts to B’ imply TI/ET > 0? In other words, what are the metaphysical, epistemological and scientific or empirical consequences of TI/ET being greater than zero? That is, something like:
0.01
0.00142
0.000001
0.000000000000000000000000000134
and so on.
With regards to this they will argue that absolute zero is a plain zero with no fractional parts, therefore any zero that takes on any fractional parts (regardless of if such fractional parts run into infinities) is metaphysically and epistemologically inconclusive. For example, if you scientifically reported that ‘A reacts to B at TI/ET = 0.000000000000000000000000000134 unit of time‘, surely you wouldn’t want anyone who reads your report to think and understand this as being identical or equivalent in meaning to ‘A reacts/responds to B at TI/ET=0 unit of time’? Would you? Well, if you said yes to this question, epistemologists and their colleagues in the related disciplines would argue that the latter is instantaneous and not the former in the strictest sense of the word. Ok, for argument sake, you might say “but in mathematics, I have always been taught from childhood to round up numbers with fractional parts to the nearest whole numbers!” Good for you, but what your teacher failed to remind you of is the fact that when you do so you are chopping off a significant part of a numerical value that has meaning and relevance in reality. Metaphysically and epistemologically, you have not escaped the fact that you were taught how to make approximations with numbers that do not directly amount to absolute numerical values. Approximations may be representative and simulative of certain facts but they are not absolute facts. For absolute facts is everything over and above approximations!
Ok, let’s say that you went ahead and started to chop things off from your resulting scientific calculations and experiments. In that case, Epistemologists and their colleagues in the philosophy of science discipline would ask you:
“Ok, you have been taught and permitted in your scientific reports to round things up to the nearest whole numbers, and you are now doing exactly that here, what actual or potential effects could or does this have on the truth or epistemological status of the objects or events under observation?”
In this very case, the question would be referring to the actual or potential effects on rounding TI/ET of 0.000000000000000000000000000134 unit of time to TI/ET of 0 unit of time. Well, for a start they would argue that you are doing magic and cheating by trying to turn a numerical value of physical importance and relevance to an absolute zero. In Metaphysics, Epistemology and Philosophy of science, this would be a non-starter. They will argue that you do not understand the physical consequences of what you are doing scientifically.
NOTE: No one would appreciate the implication of this argument until you cast your mind back to those days when many machines were embed with crude bivalent logic circuitries and could not handle physical mathematical values that range over, or even if they did, were rounding things up to whole numbers that ignored important and relevant fractional parts. Do you remember those days that people used to kick and vandalised telephone boots and food and drinks vending machines because they could not give change back from the costs prices of those goods and services? Well, this is precisely what this argument is all about, and I guess those of you who lived in those countries with this problem should realize that during the period that these machines were in operation people must have been short-changed and cheated out of millions of their hard-earned currencies. This is just a simple real example of the consequences of parafuses in scientific thinking, methodologies and reports, yet holistic examination of this shows that the problem is widespread across science disciplines.
  • #720
HOW PARAFUSES IN SCIENTIFIC PROPOSITIONS AFFECT REDUCTIONISM (PART II)
This claim is by far the most metaphysically, epistemologically and empirically or scientifically problematic. Reducing ‘Nothing’ to something and ‘Something’ back to ‘Nothing’ is metaphysically, epistemologically and scientifically impossible. But not withstanding, a huge population of scholars still believe that this is possible. On this PF alone, there are many threads running in parallel trying to prove both mathematically and otherwise that this is a scientific possibility. Well, not quite. Instead it is more a parafuse in the scientific thinking and calculations than a scientific possibility. The scientific claim that microphysical particles of matter can magically and non-procedurally pop up from nothing or nothingness is frankly not only an abuse of logic but also an abuse of mathematics as well. Now, let us look at this claim more closely (or should I say give it philosophical treatment).
If you were a scientist observing a given object with your visual organs or in combination with their extensions (scientific instruments) and then suddenly say “ I have just experimentally created particles A and B from Nothing’, metaphysicians and epistemologist would be outraged by this sort of claim because (1) you have not only single-handedly created a new Metaphysical category in the realm of the human reality that requires a new epistemological maintenance in the perceiver’s head but also (2) you have mysteriously or perhaps scientifically instantiated and enforced a brand new CAUSAL RELATION between two fundamentally alien metaphysical categories. Epistemologists and their colleagues in the philosophy of science discipline would argue that you have created a brand new world or universe with a completely new set of laws of physics. They will then say to you “please table the methods and procedures by which you step-by-step but systematically created such a world so that we can look at and examine them ourselves to the finest grains of details”.
On the quantitative side of things, they will ask you:
“How much of the world do you see when you observe things and events, either with your naked visual organs or in combinations with their extensions (scientific instruments)?”
In response to this question, they would expect you to say something like:
“The nature of my visual organs and their complementary extensions is such that I can see n% of the world whenever I am observing”
They will then insist:
“How much in hard number is n%? Or simply, what percentage of the world do you always see with your visual organs and their extensions when you are scientifically observing?”
Of course, at this point you would know right away that they want you to epistemologically commit yourself to giving the exact percentage value of how much of the world you always see under scientific observation. This is your only ticket to convincing them that your original claim of creating something from nothing has any credence or substance in it, let alone being wholly proven to be true. Would you then answer, for example, that?:
‘n%’ = 0
‘n%’ = 0.01
‘n%’ = 0.0023
‘n%’ = 0.0000000000000000023
‘n%’ = 10
‘n%’ = 50
‘n%’ = 99.99
‘n%’ = 100
Surely, you would not expect these guys to expect n% < 100 in your answer. Of course, they will expect you to epistemologically commit yourself and confidently assert that each time you scientifically sniff around the world you always see 100% of all there is to be seen. Well, I can’t speak for any other discipline, but in philosophy, metaphysicians, epistemologists and their colleagues in the philosophy of science discipline would not accept anything less than 100% in your scientific report. Then if you dare to commit yourself to this 100% limit, they would want you to submit the method or methods by which you came by this value for further philosophical scrutiny or inspection.
A further question of epistemological and metaphysical significance would be that concerning the issue of rounding things up. Supposing you decided as we did in the action-response problem above to round 99.99% up to 100% in other to appear to the reader of your science report or thesis as if you are implying or asserting that you always see 100% of what you are observing? But they would ask you what happens to the missing 0.01% from your calculus? Where did you put this missing percentage value that you treat as scientifically and epistemologically insignificant? Or were you trying to cheat and mislead your reader in the process?
NOTE: Infact, it is not only philosophers that would be puzzled and triggered to scrutinise to the finest detail this sort claim and chopping off of significant numerical values. Ordinary lay people in the real world would be as much startled and likewise triggered to do the same. They would do this because they know that if you take £0.01 from
£1,000,000 what remains is £999,999.99 and therefore you are no longer a millionaire. You would be metaphysically and epistemologically recategorised or reclassified as a thousanaire. The same is true of you trying to buy something from a shop priced at £10 and you have only £9.99 in your pocket, the fact remains that you may encounter a very strict and awkward shopkeeper that would not sell you that thing until you produce the remaining £0.01. Well, don’t take this as strange because it does happen.
The final most important question they will ask is this.
“Does the remainder (0.01% missing realm of the world that you cannot see during your routine scientific observation) epistemologically translate to ‘Nothing’ or ‘Nothingness’?
Epistemologists particularly would ask you:
“How do you know that what you cannot see is Nothing?”
This sort of question is not the sort that you would respond with such asnwer as:
"I may not see 0.01% of the world, but I am convinced and do know that whenever I create something from this very source it comes from nothing" or simply that "I know that 0.01% of invisible part of the world is nothing
Well, I leave this two-part piece of my personal observation with no conclusion. Search your consciencne and make your own conclusion!
Many thanks.
Think Nature...Stay Green! Above all, think of how your action may affect the rest of nature! May the 'Book of Nature' serve you well and bring you all that is Good!
  • #721
Behaviour
What will be seen as acceptable context, how we choose a subset (how important are e.g. the different coordinates [x,y,z,ict]?), is assumptive.
Rules
Okay.
Okay, so its "pattern matching" regarding all kinds of simular sets.
Doesn't that assume that:
  1. existence really is an on/off matter (existence is a boolean value that can be assigned to a 4D coordinate system)
  2. there exists no randomness in the sets (what would have as consequence that each pattern does have the same probability :cry:).
  3. every used resolution of the coordinate system does show the same patterns (no way to say when it is the real causal system)
Non-physicalist view
I hope you can clearify these things, or expand you model a bit. :smile: I'm looking forward to your explanation of how this all doesn't entail a physicalist view.
  • #722
Of course it is assumptive; but it reflects an assumption made in the analyzer's mind, not an assumption in my picture of the phenomena. You should be able to understand that "what is relevant" exists in the act of identity labeling itself, not in my representation of it.
The real problem here is that actual realization of what is relevant is quite vague under normal circumstances (people presume a lot). Educating a student is a process of delineating, through examples, exactly what phenomena are relevant. Think about explaining exactly what an electron is to a new student. The subtleties of this process go on all the way to graduate school. Learning anything is a process of refining the relevant information.
Yes it does. :smile: However, your mistake is assigning that assumption to my analysis of the problem instead of assigning it to its rightful place: the decision process of the scientist deciding on the validity or invalidity of a rule. Though there may be some steps in his thought process which admit of alternate possibilities, in the final analysis, the foundation of the decision can usually be traced down to specific examples of distributions of space-time-points he holds as valid representations of reality (the physicalist's description of the facts behind his case). That is why I started with the physicalist viewpoint; essentially, the physicalist believes that nothing exists beyond what can be represented by these collections of four dimensional space-time-points and there exists a large volume of relevant discussion on the applicability of their perspective. :smile:
The past (the information the scientist bases his theories on) is fixed (at least as far as it is understood by most rational scientists). Randomness is an oxymoron if one specifies the past in terms of a collection four dimensional space-time-points. "What was" is "what was"; the rest is no more than how you see it. Randomness arises only when one begins to label the specific examples of the phenomena one wants to discuss. The specification of relevance establishes the nature of that associated randomness. Without identity labeling, all specific events in the history of the universe are different events and occur but once.
You will have to make yourself a little clearer here as I do not understand what you are trying to say.
On the non-physicalist view, it's coming down the pike but there are still a few issues I have to get across before we can seriously discuss that issue. For the moment, the physicalist perspective makes it much easier to get the central nature of those subtle issues across.
I am not really sure you understood what I was saying about the relationship between the rules and what exists. Now, my statement that the two concepts are orthogonal is a different matter. That I will defend in detail further down the road. But meanwhile I want to make the relationships between the two as clear as I can. It isn't really a deep issue at all though I think it is a very very important one.
A simple example is the invention of the neutrino. The existence of the neutrino was originally based on the failure of observed reactions to conserve energy. So it is thus the rule that energy must be conserved which gave rise to the idea that the "neutrino" had to exist. Now, after its existence was proposed, other consequences of that existence were carefully thought out (under the assumption that the rules of physics were correct). And, by this means, its existence was further verified: that is to say, if the rules were valid, then the existence of neutrinos was verified. :devil:
Now, the issue I am bringing up here is not the logical decision that "neutrinos existed" but rather the fact that the conclusion was a consequence of acceptance of the rule that energy must be conserved (and then later by the acceptance of the general rules of physics as understood at the time). The issue here is the validity of the process itself, not the relationships put forth. If one is to maintain their objectivity, these relationships must be kept in mind. Fundamentally, the scientific community invents entities with the properties needed to explain the results of their experiments. If, by the rules they believe to be valid, the results of all experiments are consistent with the existence of those entities, then the entities are deemed to exist. On occasion, they will also alter the rules in some way if that process yields better agreement, but this act is usually rarer than invention of entities. (I think new rules are harder for them to think up than new entities. You have to understand and believe the rules, but you only have to believe in the entities and their actual definition and/or behavior is easier to keep vague! :smile: )
Thus it is that the central issue of explaining reality is the inventing of entities which obey the rules presumed to be valid. In fact, it should be clear to everyone that, if the outcome of every experiment which can be performed is consistent with the deduced consequences of existence of an entity, then that fact is taken as prima facia evidence that the entity exists. My problem is that there is a fundamental presumption embedded in that statement: it is the assumption that there exists no alternate explanation which will satisfy that same constraint. If we are to be rational, we must keep that fact in mind. If we don't, we are once again pretending to know something which we cannot "know". :wink:
In the interest of maintaining recognition of that fact, please allow me to divide the body of "things that exist" into two quite different categories: things that "really" exist and things that don't "really" exist but are actually just figments of our imagination which happen to be wholly in alignment with the rules we believe are true. Now, let me make this perfectly clear, the difference between these two categories allows no mechanism to perform a separation one from the other and there can exist no way to know which is which, but that was not the purpose for which I made the division. I made the division in order to simplify my thinking as the two categories need to be thought about quite differently. :rolleyes:
Things that "really" exist are not dreamed up, they are reality itself and cannot be altered by our explanations. On the other hand, things that are figments of our imagination can be altered any way we choose so long as their existence is totally consistent with the rules being promulgated and all deduced consequences of those rules. It is thus possible, under this perspective, to see the universe as existing exactly as proposed by the current scientific community (nothing they have discovered is a figment of our imagination) or, equally easily as totally solipsistic (nothing "really" exists). The issue as to which of these perspectives is correct has, in the perspective I have just laid out, been made totally beside the point and need have no bearing on our analysis. What I am pointing out is that not knowing the answer to the question "what is really real" is no problem so long as we have a mental mechanism to allow exact analysis independent of the answer. And the division I propose gives us exactly that mechanism. It is subtly quite different from ignoring our ignorance, which is the standard attack on this difficulty, but has almost the same consequences (but not quite).
Another way to put it is to say that what really exists is what we need to explain. Whatever else we decide must exist must be part of the explanation. The single most important issue here is that, no matter what the rules are, both components must obey exactly the same rules. Think about it and let me know what part of what I have laid out you find unreasonable. :-p
Have fun -- Dick
  • #723
Assumptions
Yes, I know. Actually, that time I was searching for a word without an additional flavour. I thought 'assumption' was a better word than 'presumption'. I speak English as a second language. We have to assume some things, or we can't identify. I agree with that. :smile:
Sorry for that. :blushing:
Yes, that was what I wanted to say. In that way only different objects exist. And no law does exist that works at a global scale.
I was just listing some things that such a - physicalist - coordinate system presumes. And besides the two things of above, it assumes IMHO that [x,y,z,ict] is continuous or discrete.
If it is continuous no worldline is identical (with arising circularity in identifying - like you said), if it is discrete some kind of stepsize has to be taken (and after that we can observe patterns that maybe would alter if we had token - or had access to - a smaller stepsize). Continuity or a certain stepsize has to be assumed. It's our horizon.
If there is "causality" through time or space we can observe it, except if it falls out of our horizon (e.g. Brownian motion).
Hypothetical rules and particles
Yes I agree. I heard more often about a 'hypothetical particle' (tachyon, magnetic monopole, gluon, graviton) than a 'hypothetical law'. I also would say with Epictetus: "This also is a hypothetical law that we must accept what follows from the hypothesis."
I think that sometimes physicists propose a 'theoretical particle' in stead of a 'hypothetical particle' (e.g. a 'hole' as opposed to an 'electron'). Do you think that scientists often fail to notice this difference?
Do you have ideas about when we should call something 'real' and when 'theoretical' (like 'hole' vs 'electron' mentioned above)?
You lost me
I'm not sure to which mechanism you're referring here. Sorry, I can't follow your reasoning in the last two paragraphs.
  • #724
Hi Savior,
Sorry about being slow in my response. I wanted to think about your comments and answer them in a manner which would make my thoughts as clear as possible.
At least you have a second language; as far as I can tell, you are doing a fine job. To get my Ph.D. I had to pass a "proficiency" exam in German and Russian. All I had to do was translate some scientific articles which talked about things I already knew; personally, I wouldn't exactly label my ability as "proficient". They even let me use German/Russian to English dictionaries while I performed the translation. I am afraid I don't speak anything but "American English" and I am not very proud of that.
I think you understand the lack of assumptions (other than that physicalist thing) in my approach. :smile:
Sorry about that, but I have one for you (down the road when you can better understand the relationship between "what exists" and "what the rules are").
I won't argue with you on those issues (what the physicalist assumes); however, I do not make exactly those assumptions. In particular, I agree with Zeno's argument against continuity. I would however argue with you on the statement that one must either accept continuity or a certain step size. I have a third option for you.
I think you have to admit that "causality" can not be observed if every space-time-point is thought of as a unique occurrence."
I could be wrong, but you appear to skip over my comment:
I am not sure you understood what I meant. :confused:
In my head, there is no difference between a "hypothetical particle" and a "theoretical particle". People don't always put the same connotations on a word and assuming others comprehend what one means when one uses a word is a very dangerous step. In my opinion, the only way to support the contention that one understands something or is being understood by another is when the exchange of communication symbols become consistent with one's expectations (not a lot of surprises). When you understand someone, their reaction to your comments should be expected. Likewise, when you understand the universe, its reaction to your behavior should be expected.
Lack of surprise is the central sign of understanding and understanding is achieved through exchange of information. In that sense, understanding reality is completely equivalent to establishing coherent communications; that is why I responded to the issue of communications earlier in this thread.
No, and I wouldn't try. You seem to have missed the central issue of my complaint expressed immediately above. I suspect that is probably where I lost you.
There was a Roman philosopher, sometime shortly after the time of Christ, (an official pagan, and not Christian) who said, "belief in the gods does not require that the gods exist". What he was talking about was, in a certain sense, exactly what I am talking about here. (He went on to clarify his position by pointing out that the central purpose of "belief" is to provide proper and successful rules of behavior.) I tried to find the quote I had seen but couldn't; it's somewhere in Thomas Hodgkin's "The Barbarian Invasions of the Roman Empire" (a little long to peruse in a few moments). Religion seems to have played a significant role in the collapse of the Roman Empire; at least all the historians I have read credit religious arguments as being the major force behind a lot of important events.
The point here is that we want to understand reality and, while actually proving something is real is quite impossible (see any defense of Solipsism), no one actually believes all of reality is just a figment of their imagination. What is very important here is that belief in your answers does not require that they be true. What belief requires (to be an acceptable belief) is that it provides proper and successful rules of behavior for the universe you believe in. Gets rid of those surprises that screw up our plans. :smile: :smile:
Now I know that statement sounds awfully circular (I could have omitted "you believe in" and perhaps slipped the issue past you); however, embedded in that circle are two very different components. Any rational person knows full well that there are things he believes in which will probably turn out to be fictitious; on the other hand, the idea that "everything is fictitious" simply removes the usefulness of the concept "real" and we have nothing to "understand". Contrast this with advances in our understanding of reality over the last hundred thousand years. Apparently, to paraphrase the Roman philosopher mentioned above, understanding reality does not require knowing what is real. Now, don't quote me on that! :smile: At least not until you have heard me out.
First, the fact that a particular entity is a fictitious creation of our minds is revealed only when experiments demonstrate that its existence is inconsistent with reality. Until that specific and very real event occurs, we are working with a collection of entities (some real and some fictitious) which are perfectly consistent with everything we know about the universe. One can cavil that what I just said presumes that consistency has been correctly thought out. That cavil turns out to be wrong and brings up some very interesting consequences which we can discuss only after you understand what I am presenting. So, for the time being, lay that cavil off with the physicalist perspective: i.e., something I will get back to later. (Is this fun or not? :biggrin: )
So, what we know about the universe consists of two very different things: that which is "really real" and that which we "only think is real". The only thing which changes as advances in our understanding occur is the things we "only think are real". Those things which are "really real" can never change! It should be clear to you that, no matter what intellectual advance is made, before it can explain the future it must first explain the past. It must explain the historical record; that means that something didn't change. If we want to be exact in our examination of reality, we must maintain the fact of that important duality in what we think we know.
It follows from the above that our understanding of reality is based on information which consists of data of two very different natures, Personally, I like to label these two different kinds of information and I have two labels I find intellectually convenient: "knowable" and unknowable. That which is really real is knowable in the sense that, if it is not "knowable" (in the common sense), how can we possibly "know" about it? If we can't "know" about it, what possible difference can it make? And secondly, every explanation which can ever be promulgated as valid must be consistent with the existence of this information as the explainer cannot claim that it "cannot be known", not if it is "really real" as it defines reality itself. And that part which we only think is real is "unknowable" in the sense that it is possible that it might be proved to be inconsistent with reality: i.e., we only think we know it and there cannot exist any proof that it is "really real"; you can't really know it is true.
Philosophers can't resist going off on silly "if you can't tell me how perform the classification, the classes are meaningless" cavil. The difference between these two kinds of information clearly is not anything which can be used to label any specific piece of information; however, as I said earlier, "understanding reality does not require knowing what is real". Understanding reality has to do with being able to explain what we know. What is important about the division I made is that what must be explained is the "knowable" data; the "unknowable" data is part of the explanation. When we think about the problem we are trying to solve, I will show that this division becomes a critical factor in establishing the range of possibilities for behavior. As I said, "It is subtly quite different from ignoring our ignorance, which is the standard attack on this difficulty, but has almost the same consequences (but not quite). "
So the mechanism I am referring to here is the process of arriving at the "best" explanation of reality. If we are going to look for the "best" possible explanation, it behooves us to make sure we leave out no possibilities. It is the development of that analysis which makes use of the knowable/unknowable aspects of the supposed information available to the assembly of possible explanations.
But, before I show you how to assemble a representation of the collection of all possible explanations, I need to tell you exactly what I mean by "an explanation". I will begin by pointing out that all "explanations" require something which is to be explained. Whatever it is that is to be explained, it can be thought of as information. It follows from that perspective that "an explanation" is something which is done to (or for) information. If we are to lay down an abstract representation of "an explanation" in general, we must first establish exactly what it is that an explanation does to (or for) information.
Let us presume we have some body of information we are interested in explaining. It seems quite clear to me that, if all of that information is known, any question about that information can be answered. That circumstance could, in fact, be regarded as defining what is meant by knowing. On the other hand, if the information is understood, then questions about the information can be answered given only limited or incomplete knowledge of the actual underlying information: i.e., one only needs to know limited subsets of the information. What I am saying is that understanding implies it is possible to predict expectations for information not known; the explanation of the information (that which yields the understanding) constitutes a method which provides one with those rational expectations for unknown information consistent with what is known.
Thus I define "an explanation", from the abstract perspective, to be a method of obtaining expectations from given known information. :smile: Just as an aside, notice that there is nothing in that definition which says anything about the qualities of the explanation. It defines what I mean by "an explanation" and it can be wrong, incorrect, useless or perhaps even true. It even includes nameta9's infinite-infinite universe. :smile: :smile: (And even qualia!) :biggrin:
Did I completely lose you there or do my machinations make a little sense to you? If it makes sense, I will shift out of the physicalist viewpoint in my next post; but I want to be as sure as possible that you are not confused by what I have said so far.
Have fun -- Dick
  • #725
Well, all I can say is, if everything can be reduced to pure physics alone, I'd sure want to know physics. :)
However, I don't presently see how physics can explain why my lucid dreams (non-random) can appear more real than reality - and how I make valid scientific observations within dreams as though they are reality, only to awaken and find that they were not "valid."
  • #726
The problem is very simple. You are presuming I am saying something I am not saying. :smile: You need to define exactly what you mean by "an explanation". Without a definition of what you are talking about, discussion of the subject is little more than emotional ramblings signifying nothing.
I have taken the trouble to define what I mean by "an explanation" o:)
Given that definition, I can show that all "explanations" can be examined in an exact manner. Thus it is that I can "prove" that exact analysis can explain anything which can be explained. Follow what I post here and you will understand that proof. :cool:
There are only three possibilities here. First, you might not like my definition. In that case, you should show me an explanation which does not conform to that definition or show me something which conforms to that definition which can not be thought of as an explanation. Second, you might find an error in my proof. In that case, you should take the trouble to point out the error. Or third, you will come understand why anything which can be explained can be explained in an exact manner fully compatible with the accepted constraints set forth as delimiting the field of physics. :biggrin:
Of course the above presumes you are intellectually capable of thinking things out in an exact manner. :devil:
Have fun -- Dick
  • #727
Wow, Dick. Thank you for exposing my intellectual sloth!
From my experience, and my known information, lucid dreams can summarily be explained as "experience driven by expectation." But what is expectation within the context of a dream, where one's memory potentially has been altered to accept the dream memory as primary and waking memory as periphery? When known information is altered, expectations are altered, and, thus, the experience is altered. It is quite a curious event, begging the question, "where does this 'new' information come from?"
In dreams there is probably no effective separation with the perceived phenomena and one's self, since the experience appears to be purely subjective and occurring entirely within one's imagination. But how do we explain phenomena within a lucid dreams that have no meaningful reference to waking phenomena? Stephen LaBerge forwarded the concept of schema, but we do not know how many schema's exist nor is it apparent that schemas have any necessary specificity. For example, LaBerge believes there is a "story schema" within the psyche that comes into play, making a dream appear as though it follows a narrative. However, one does not know how incredibly imprecise the notion of a story schema is until putting it into practice within a lucid dream. I have the feeling LaBerge held back on saying what he truly felt so as to not be completely ridiculed by the scientific community.
Yes, Dick, I am capable of thinking of things in an exact manner, which is precisely why I made the post that I did. Dreams tend to circumvent exact explanation.
Expectation regarding dreams is not exactly subject or object, but much closer to predicate. And there are new categories of phenomena that can be experienced after such a realization (e.g., the feeling of flying without the aid of device, the feeling of speaking without language, etc.)
I'd like to bring lucid dreams out of the status of protoscience. They truly are wonderful and useful experiences and we can know more about them if we apply the scientific method. However, I am incredulous about our ability to frame dreams into a model of causal exactitude. The causal reality of it is much simpler (nonlocal, if you will), where our explanations tend to define the experience instead the experience defining our explanation. (e.g., mystical or religious dreams tend to support the dreamer's individual religion).
Sorry if I offended you! If you want to experience what I'm talking about for yourself, please don't be afraid to apply the scientific method and write a diligent dream journal for about 2 weeks. You will undoubtedly lose some sleep, but if you can't handle it, I understand.
  • #728
Hi Telos,
I think you take my comments a little too personally. :biggrin: Just think of me as a cranky old man who says what he thinks and is pretty harmless otherwise. I have my own opinions on dreams but they wouldn't be understood without first understanding my perspective on reality so it's really a waste of time for me to talk about the subject. Personally, I love dreams and always have. Even as a child I enjoyed them all, even what one could call nightmares because it was so wonderful to discover the experience wasn't real. :wink: But that was when I was a child and didn't understand reality. :devil:
Then you don't believe it could come from "reality"! :smile: I think one has to understand reality before that decision should be made. :cool:
I can believe that!
I am afraid nothing can circumvent exact explanation. As far as I know, no one save myself has ever even considered examining the nature of "exact explanation". Not an "exact examination" anyway. :smile: :smile:
Don't worry about it. I am quite difficult to offend. :smile: And I see no need of keeping a dream journal as I have made a major effort to remember my dreams since I was very young and remember almost as much of them as I do of my "real" life. :-p
Have fun -- Dick
  • #729
Then you don't believe it could come from "reality"! I think one has to understand reality before that decision should be made.
Whoa, Doc. I never said that. It's an open ended question.
Wherever it comes from, I am skeptical that we will be able to explain its origin - whether you define it as "reality" or something else. (in my mind, there is no such thing as non-reality, only reality that hasn't been observed or created yet, so please don't drag me into those meandering qualia discussions lol).
I am quite literally talking about the origin of creation (driving personal creative ability) and you are certainly an exuberant old man to attempt to explain something such as that. Good luck. Hopefully you will have a better track record than theologians, philosophers, and shamans. And myself. ;) Just because I'm skeptical doesn't mean I've closed my mind to it. I am trying to learn the math of modern physics, after all.
Ah! You are not uncommon. Everyone thinks they already know about their dreams - just because they can "remember" them.
Do you take an active role in them? Have you consciously mastered them to serve you? No - of course you haven't. Otherwise you'd be able to explain them.
Your memory and perception of the experience changes when you put it on paper. The information literally travels from one side of your brain to the other. The language and reasoning centers of the brain are rarely ever active while the dream is occurring, so your memory of them is clouded by lack of explicitness. When you add language to them, you begin a process of association that widens your perspective. It gives you greater field of vision and influence. Each word is like brick over a path, giving you a platform to probe deeper.
Don't mistake the forrest for the trees, Doc!
Personally, I think you're just either scared or lazy. :wink:
  • #730
I don't believe how there are 5 people that voted that religion can explain everything, if religion can't even explain religious topics... not even the people that live for religion believe that religion explains everything.
I voted multi-disciplinary, physics would be the biggest supporter, but there is biology, filosiphy...
  • #731
Oh is it now? It seems to me that you are very much presuming some answers without considering the lack of support for those answers. :frown:
I don't know about that. Again, you seem to be confidently asserting something without any supporting argument beyond your own belief. :devil:
I have a very strong opinion as to what they are; however, as I said earlier, comprehending my opinion will be beyond you so long as my perspective on reality is beyond you. :zzz:
I don't believe you even begin to comprehend the volume of presumptions behind that statement alone. As I say, you are asserting answers without understanding the question.
I don't think you have managed to get past the bark. You should read my essay on thought here. And consider the vocabulary suggested in this thread. :cool: You are speaking of the power of "squat"! Or should that be "sqought"? :smile: Honestrosewater has never answered me on that issue. :smile:
Have fun -- Dick
  • #732
This is ridiculous. I have presented only skepticism, not answers.
The question is "can everything be reduced to pure physics" and I have not settled on a yes or no. But I doubt that it can. My goodness, what's so difficult to understand?
Maybe I haven't done a very good job of presenting it. Feel free to quote the previous sentence and supply a pithy retort and a smilie.
And statements like "The information literally travels from one side of your brain to the other," are not intended to be definitive but simplifications for a very real phenomena. I have psychological literature with which to back up that statement, but I am not interested in writing a thesis for you.
Your ignorance of my skepticism about the origin of creativity notwithstanding, where/what do you think creativity comes from? It is becoming apparent to me that you do not have much experience with creative thought, and therefore the question is beyond your ken. I have challenged you to perform your own experiments and experience creativity more intimately, but you have categorically dismissed it as "squat." Fittingly, it is an unoriginal way to remain to ignorant.
I am not content with saying "creativity comes from dreams." If that's the way you read it, I apologize. I know even less about where dreams themselves come from. However, I am content with considering that dreams and creativity are related psychological phenomena, and I have my life experience to back it up. If you are interested, I wrote about it in the thread concerning the origin of creativity.
What's wrong with skepticism? How can you say I'm not thinking critically if I am thinking within the framework of skepticism?
Small words from a mind of small curiosity and small vision, but from a big mouth.
I repeatedly suggested that you apply diligent critical thought to your dreams and you have ignorantly suggested that you don't need to. You do not seem interested in anything other than horseplay.
I can't say I blame you. If I was a retired theoretical physicist, finishing a long life of "thinking," that might be all I'd be interested in too. I have spoken at length with another retired theoretical physicist online, and he is much like you. But he has settled into a highly spiritual interpretation of quantum mechanics and has claimed his conclusions are "hard-nosed." I disagree with him mightily, not on his conclusions of spiritualism, but that they are "hard-nosed." Similarly, you are not hard-nosed either. Maybe it has something to do with an increasingly desperate desire for certainty as one, who has dedicated his life to searching for answers, careens downwards to an unknowable but necessarily answerable death! The telos of life isn't to be blissfully ignorant, is it?
Doc, I am so deep in the woods, there's no turning back for me.
  • #733
...My problem is that there is a fundamental presumption embedded in that statement: it is the assumption that there exists no alternate explanation which will satisfy that same constraint.
I was merely stating that there are at least two different ways to think (as a physician); I called one 'hypothetical' and I called one 'theoretical'. My connotation with these terms is as follows: a 'hypothesis' has to do with testing - as if it is possible to know reality*; and a 'theory' with embedding in a knowledge system**.
I'll quote you. :smile: Understanding has to do with seeing (the different) possibilities, isn't it?
:smile: You said it yourself.
The 'really real' is 'knowable' (if we can't know something, why should we call it real?) and that what we 'only think is real' is 'unknowable' (no proof, no solution, not decidable). Summarized: There are things that:
  • are knowable and real
  • are unknowable and real [real becomes useless here: the unknowable can not be called real]
  • are knowable and thought of as real [likewise]
  • are unknowable and thought of as real
And so we derive these propositions: There are things that:
Okay. Go on.
* not believing that "all of reality is just a figment of their imagination"
** "working with a collection of entities (some real and some fictitious) which are perfectly consistent with everything we know about the universe"
  • #734
That is what you think; however, you are making a serious error. You are, in fact, making some very serious undefended assumptions. From your response, I can only conclude that you did not even bother to read my reference from my previous post. :wink:
No problem understanding that, it's a pretty common perception. The problem is your complete failure to even consider the idea that you might be wrong. :smile:
Creative thought is great, but, in the absence of logical thought it is little more than entertainment. If you have no competence in analytical thought, creativity is perhaps a decent ego substitute for understanding but it is insufficient to unravel the mysteries of life. The probability of being wrong is far greater than is generally assumed. Very few people manage to "guess" correct solutions to complex problems.
Telos said:
...but you have categorically dismissed it as "squat." Fittingly, it is an unoriginal way to remain to ignorant.
I gave you the source of my usage of that word but you apparently prefer the common interpretation. That's why I used it: it has connotations which upset people who don't listen, making them easy to identify. You've just missed the ball by a mile. I'll just call it "strike one". :wink:
Another swing and a miss! Nothing I have said has penetrated has it? What I have been looking for is someone with enough brains to understand what I am talking about and a long enough attention span to get to the meat of the issue.
I guess you got that one right :smile:
Have fun -- Dick
  • #735
Dick, have you been forgetting your medication?
But, seriously, how does it feel to be on my ignore list?
Those gears must be turning in your head! That's right, you can't tell me. Don't worry about it, though. I've already determined your answer's approximate uselessness with the help of inductive and deductive theoretical reasoning! Yes, I included your pleonastic reference, which I read long before you mentioned it.
Thanks for nothing. But thank you for, ironically, being an anachronism. You are exactly what you hate most. And that is somewhat amusing, albeit kind of disgusting.
Ta-Ta! :smile:
