Classification of mathematical objects
I'm sorry, I do not understand what you mean. Could you please clarify? The first and second theorems are basic properties of integers that are easily proven and do not require any additional assumptions. The third theorem is a basic property of finite groups that can be proven using the structure theorem for finite abelian groups, without any additional assumptions.
  • #36
Ok, we have for 4n=1, where n is a natural number. 4x1=1 is wrong, 4x2=1 is wrong, so supposing that 4n=1 is also wrong, we will prove that 4(n+1)=1 is also wrong. 4(n+1)=1=>4n+4=1=>4n=-3 which is wrong because n is a natural number.
Mathematics news on Phys.org
  • #37
How are you proposing to prove that 4(n+1)=1 is also wrong? At some point you are going to need to refer to the axioms.
It can be proven. But not the way you are going about it.
  • #38
@pbuk: my apologies for a rash post. I have deleted (hopefully) the offending parts.
  • #39
Lordy, this is going downhill fast.
If you want a proof, you need a plan. That's the very second thing you need. (The first is the set of axioms and definitions you are using.) An example of a plan would be:
I will prove this for natural numbers, and then extend the proof to all integers. I will prove it for natural numbers by induction, showing that if it is true for the set {1,2...n} it is true for the set {1,2...n+1}. I will extend the proof to natural numbers by showing that if a is even, so is -a, and if a is odd, so is -a. I will complete the proof by showing 0 is even.
Now you have a plan you can execute. It is not necessarily a good plan (in fact, there is a logical hole in it - can you find it?) but it is a plan. From the plan, you can then attempt a proof.
Likes berkeman
  • #40
I think i found a proof that shows that n where n is natural number can be only odd or even. So, ##n=2k##, k is a natural number or ##n=2k-1## are the only options we want for n.
Let us suppose that a number n that is in the set of natural numbers is neither odd nor even, then these hold: ##n\neq2k## and ##n\neq2k-1## ##\Rightarrow## (##n>2k##, ##n>2k-1##) (1) or (##n<2k## (i),##n>2k-1##(ii))(2) hold there are two other cases also which have similar proofs.
Let us take (1), if we subtract on both sides those inequalities, we get ##0>1## which is a contradiction, in (2), we multiply the second inequality both sides by ##-1## so we get ##-n>-2k+1##(3) adding (i) and (3) we get ##0<-1## which is a contradiction.
There is left no other choice for a natural number than to be even or odd.
  • #41
For your case 1, if n > 2k, necessarily n > 2k - 1.
For case 2, if n < 2k, does it necessarily follow that n > 2k - 1? For example, if k = 4, you have n < 8 and n > 7. Is that possible for natural numbers n?
  • #42
I made this mistake, sorry for that. So is what i wrote correct without that case?
  • #43
It's good to see you regain interest after four months. But you seem to have missed an important point: If you want a proof, first you need a plan. Don't just start writing statements down.
  • #44
I would suggest trying to do a proof by induction. Suppose n is the smallest number that cannot be written as 2k or 2k+1. What can you do with it?
  • #45
Inequality 1: n > 2k and n > 2k - 1
Let us take (1), if we subtract on both sides those inequalities, we get 0>1 which is a contradiction
If we subtract what from both sides of the inequalities? Without details, it is "arm waving" to conclude that 0 > 1.
As already noted, your inequality 2 is flawed, since there are no natural number n for which n < 2k and n > 2k - 1.
Likes Vanadium 50
  • #46
We could say that l is the minimum of a set ##L=\{m: m\neq2k, m\neq2k-1, m\in N\}##, so we want to prove that ##L=\emptyset##. We want to reach a contradiction? Is the proof you want like this? i have not finished this proof yet.
  • #47
I think the way i am trying to prove it is a wrong one.
  • #48
Start with a plan. Office Shredder mentioned induction. Can you form a plan around that? You mentioned contradiction. Can you form a plan around that?
  • #49
Well, he seems to have lost interest and wandered off again. But he seems to have subtracted one inequality from another. Why he thinks this is valid is unclear. 10 > 9 and 6 > 3, but when you subtract them you get 4 > 6, which should have given him pause.
  • #50
What should my plan be?How should i start? Apart from knowing the Peano axioms what else should i know and use?
  • #51
If I tell you that, it's not your proof, is it? It's mine.
What plans have you made and why did you discard them? And if you really don't have a clue on where to start, maybe we need to step back and try a simpler proof.
  • #52
1. Let us suppose there is a natural number that is neither an odd nor an even number. 2. Try the cases of ##k=1## for ##n=2k## for evens and then ##n=2k-1## for odds and then supposing it works for ##k=n## we prove for ##k=n+1## 3. Try by using successors but i do not know how to do it. These are my plans.
  • #53
That's not a plan. A plan explains how the process will work. It has a beginning, a middle and an end. Your plan is similar to (but not as good as) a plan to drive from Rome to Paris: "Drive out of Rome. Drive on various streets until I bump into Paris." The driving plan is better because it at least states that it's random luck that this plan is counting on.
An example of a plan - and I wouldn't use this plan - would be:
  1. Start with the set of natural numbers
  2. Remove all the even numbers
  3. Remove all the odd numbers
  4. Show that the resultant set is empty. QED.
See how it has a beginning, a middle and (most importantly) an end? That's a plan that one might execute. (Although I would not use this plan for this problem)
  • #54
1. ##N=\{1,2,3,...\}##
2.mathematical induction for the even numbers which means ##2## is even, and supposing that ##2k## is even we show that ##2(k+1)## is even
3. mathematical induction for the odd numbers but now we have ##2k-1##
4. suppose that an element exists that belongs to the##N## and is neither an even nor an odd and showing that this leads to contradiction, which means it is empty.
I get stuck at the step number 4.What should i do?
  • #55
I think the proof by contradiction is a fine approach. Let S be the set of natural numbers that are not of the form 2k or 2k+1. Let m be the smallest element of S. There are two possibilities:
1.) m-1 is a natural number. If it is what can you say about it?
2.) m-1 is not a natural number. If it's not, what can you say about m?
Likes Vanadium 50 and jbriggs444
  • #56
1. Extra close brace or missing open brace
You might want to fix this.
This is a very, very common approach. Learn it. Love it.
Probably ask us to do the rest for you. Why should this be any different? :frown:
You are still confusing a plan for a proof with a proof itself. Until you stop doing this, you will be unable to prove anything that requires anything beyond what you can immediately see. That means you be unable to prove anything that is non-obvious.
@Office_Shredder has written down a plan. His plan is:
  • We're going to do this by contradiction
  • If the set of numbers that is neither even nor odd is non-empty, it has a smallest member.
  • Look at properties of this smallest member and show that they lead to a contradiction.
That is a good plan. It is also not a proof. It is a plan for a proof.
  • #57
Should i use infimums and supremums and lower bounds or upper bounds?
  • #58
I don't understand why you are ignoring the advice that @Office_Shredder gave you.
  • #59
1) ##m-1\geq1 \Rightarrow m\geq2 \Rightarrow m\in S## contradiction because ##m-1\leq m ## and m is the smallest element of S.
2) (i)##m## is of the form ##2k## ##\Rightarrow## ##m-1## is an odd,
or (ii) ##m## is of the form ##2k-1## ##\Rightarrow## ##m-1## is an even, but we said that m-1 is not a natural number , contradiction.
Both cases show that there is no such ##m\in S##
  • #60
I want to say that i knew about the method of telling ##S## has its smallest element, I had read in other proofs of other theorems but i did not know about continuing with ##m-1## and reaching a contradiction.
Thank you.
  • #61
I don't get this at all. ##m-1\notin S## means that ##m-## can be written as ##2k## or ##2k+1##. You need to use that.
Likes Vanadium 50
  • #62
<sigh>
Writing random statements hoping you will accidentally prove this is not a good strategy.
<double sigh>
If m is the smallest number that is neither even nor odd, is m-2 even? Is it odd? Is it neither?
  • #63
I don't get this at all. ##m-1\notin S## means that ##m-## can be written as ##2k## or ##2k+1#. You need to use that.
I am sorry for the mistakes before.
a) ##m-1\notin S##
(i) if ##m-1=2k## ##\Rightarrow## ##m=2k+1## ##m## is odd contradiction because we said that ##m\in S##
(ii) if ##m-1=2k-1## ##\Rightarrow## ##m=2k-2## ##\Rightarrow## ##m## is even, contradiction because we said that ##m\in S##
(b) if it is neither of these two forms then it is a contradiction because then ##m-1\leq m## but we know that ##m## is the smallest element of ##S##.
  • #64
Is this effort correct?
  • #65
So, i had to suppose that there is a set ##S## that contains the rest of the natural numbers and prove that it is empty.
Thank you for your help and time.
  • #66
If m-1=2k-1 then m=2k, not 2k-2. But now what you have looks a lot more like a correct proof.
I think you are still not handling the m-1 not a natural number case. That just means m is 1 or 0 depending on your definition of natural numbers. You need to confirm that is either even or odd also.
Likes Vanadium 50
  • #67
This proof requires careful examination of the edge cases. Also, as originally posed (by you) it was a statement about integers, not natural numbers, and that will make zero an edge case as well.
  • #68
Is the proof for integers analogous to the one i made? Is there anything else needed?
  • #69
You tell me. You won't get very far asking other people to prove things. You want to get better, you need to work yourself.
