Confused by nonlocal models and relativity
In summary: Nonlocality is an important feature of BM.3. Finally, does the conclusions in those papers prevent any attempts to make BM relativistic?No, the conclusions in those papers do not prevent any attempts to make BM relativistic.
  • #246
vanhees71 said:
Sure, but it's important to treat the photons as bosons (or electrons as fermions) particularly when it comes to entanglement.
Ok, I agree it is important to always be precise in math descriptions, but in this particular experiment, does the Fock space instead of the tensor product description of the system add anything to the conceptual issue of swapping and entanglement we've been discussing with DrChinese? I just want to make sure I'm not missing something important.
  • #247
In this case it doesn't make much of a difference.
  • #249
PeterDonis said:
...he is taking an ensemble interpretation viewpoint, in which QM does not describe individual photons or individual experimental runs, but only ensembles of them.
PeterDonis said:
...I'll also repeat once more my suggestion to not use vague ordinary language but instead look at the math. The math is unambiguous, but there are many different ways of describing in ordinary language what the math is telling us...
Regarding the "Ensemble Interpretation", one can clearly speak out how "murky" this interpretation is. See comment https://www.physicsforums.com/threads/confused-by-nonlocal-models-and-relativity.973876/post-6202479 or listen to Maximilian Schlosshauer in “Decoherence, the measurement problem, and interpretations of quantum Mechanics”, Section B. 1. Superpositions and ensembles (https://arxiv.org/abs/quant-ph/0312059):
“Put differently, if an ensemble interpretation could be attached to a superposition, the latter would simply represent an ensemble of more fundamentally determined states, and based on the additional knowledge brought about by the results of measurements, we could simply choose a subensemble consisting of the definite pointer state obtained in the measurement. But then, since the time evolution has been strictly deterministic according to the Schrödinger equation, we could backtrack this subensemble in time and thus also specify the initial state more completely (“postselection”), and therefore this state necessarily could not be physically identical to the initially prepared state on the left-hand side of Eq. (2.1).“
  • #250
I don't understand this criticism of the ensemble interpretation. Of course QED is T symmetric and thus all interactions of photons with charged matter are in principle reversible, but what has this to do with any specific interpretation?
  • #251
vanhees71 said:
There's no wave function for photons!
Ok, then substitute "quantum state", which is more general and allows for the somewhat different mathematical objects that model photons in QFT.
If your criticism is that, strictly speaking, QFT has no invariant concept of "the quantum state of an extended system at an instant of time", that is true, but you can still pick a particular frame, such as the overall rest frame of the system + measurement apparatus in the experiment under discussion, and construct the quantum state of an extended system such as the multi-photon system in the experiment at an instant of time in that frame. That is implicitly what is being done when we talk about the "wave function" of the multi-photon system.
Also, as has been pointed out, you could do a similar experiment with electrons moving at non-relativistic speeds. Such an experiment could be modeled using only non-relativistic QM, in which the description in terms of wave functions is unproblematic and the issues you appear to be raising with photons not having wave functions do not arise.
  • #252
The point is that photons have no position observable to begin with. All you can measure are probabilities to register a photon (with given properties depending on the measurement you do).
Surely you can do such experiments in principle also with electrons though I guess for technical reasons neutrons are better candidates. The formalism is nearly the same (up to electrons/neutrons being fermions rather than bosons).
  • #254
Nor is one needed for the experiments under discussion. The states you wrote down earlier, where photons are distinguished by having momentum in different directions, with no position observable anywhere in sight, are quite sufficient to analyze the experiments.
  • #255
Sure, that's what I'm saying!
  • #256
SteveF said:
And what could be the alternatives?
The straightforward alternative is simply a return to the Lorentz ether. Which is the original interpretation of special relativity, before Minkowski proposed his spacetime interpretation. Also known as the preferred frame hypothesis.
A straightforward candidate for that preferred system of coordinates exists - the CMBR frame.
Once you have a preferred frame, you can do standard QM as well as BM without any problems, and they will be equivalent in their physical predictions.
In the relativistic context, at least for bosons the field ontology is the most natural choice, see Bohm.D., Hiley, B.J., Kaloyerou, P.N. (1987). An ontological basis for the quantum theory, Phys. Reports 144(6), 321-375.
  • Skeptical
Likes weirdoguy
  • #257
Discussion of LET is off limits here.
As far as I can tell, this paper says nothing about any "preferred frame", and certainly does not hypothesize that the CMBR rest frame is such a thing.
  • #258
That this has not been mentioned explicitly is not difficult to explain - the authors would clearly prefer to have a theory which is completely Lorentz-covariant but they are unable to present one. To present a version which requires a preferred frame is nothing scientists are proud of so that they would like to mention it, and they would even less like to refer to it using the e-word.
On the other hand, there is no necessity to mention this. The Bohmian field theory has been developed there for a relativistic scalar field theory. This has been done in a particular frame, without claiming or presenting anything which suggests that the construction could be made Lorentz-covariant. Look at the variables the wave functional [itex]\psi[/itex] depends on, say, in the formula after (6) in part II:
[tex]\psi = R(\ldots \phi(x,t),\ldots,t)\exp[iS(\ldots \phi(x,t),\ldots,t)][/tex]
It explicitly contains a reference to time t, which is the time parameter of the Schroedinger theory, without any relation to any spacetime. So, Bohmian field theory as developed in the paper is a theory based on a field [itex]\phi(x)[/itex], which defines the configuration, changing in an absolute time t.
Lorentz symmetry exists only for the Lagrange density and the resulting classical field equation.
Once there exist no Lorentz transformation rule even for the basic objects, in particular, for the wave functional, the theory can not even pretend to be more than a theory with a preferred frame, moreover, presented only in this particular preferred frame, without even caring about other frames.
The important point for this thread is that for relativistic bosonic field theories a Bohmian version exists, with the details worked out in the mentioned paper. This version is not fundamentally Lorentz covariant but uses a preferred frame.
There are those which consider this to be a decisive objection against it, and there are others who think there is no base to care, as long as all the observable effects are the same as predicted in standard QFT. It would be, indeed, off-topic to discuss here who is right.
But it is important to mention that relativistic field theory is something which not only potentially can be, but actually has been handled by a Bohmian version of field theory, even if it can be criticized for depending on a preferred frame.
  • Skeptical
Likes weirdoguy
  • #259
How is it relativistic if it's not Lorentz covariant?
  • #260
It is relativistic once the predictions for all observable effects are Lorentz covariant. The theory itself, on the fundamental level, does not have to be Lorentz covariant for this. Only observable effects matter, not?
Given that the question is not discussed in the paper, let's consider the straightforward way how to prove this, namely, by proving the equivalence with standard QFT. One uses a lattice regularization on a large cube with periodic boundary conditions in space (not time) to get rid of UV as well as IR infinities. The resulting theory is, then, finite-dimensional. The Lagrangian has then the standard form required for Bohmian theory (quadratic dependence on the momentum variables) as presented in the paper. Then one can use standard Bohmian theory to show the equivalence for anything observable of the Bohmian theory to the Schrödinger picture of QM and its equivalence to the Heisenberg picture too. So, we have equivalence with the Heisenberg picture of QM for a particular regularization. What remains to be proven (namely that the resulting theory is Lorentz covariant if we consider the continuous limit) is already part of standard QFT.
  • #261
But are they? If the equations aren't Lorentz covariant, and the equations generate the predictions, how can the predictions be Lorentz covariant?
Has such a proof been given in any reference?
  • #262
I'm not aware of such a proof being published, and I see no necessity, given that the part relevant to dBB theory is a trivial reference to the standard dBB equivalence results. What would be the non-trivial part of the proof? That a lattice regularization on a cube with periodic boundary conditions is finite-dimensional so that the standard theorems can be applied?
The third part, from the lattice regularization to the QFT itself, would be non-trivial, but this is already pure standard QFT.
The important non-covariant part, the trajectories, are not observable. If one removes important parts of reality from consideration, the symmetry will change.
  • #263
There are plenty of examples for formulations of relativistic theories that are not manifestly Lorentz (or rather Poincare) covariant, while the results on observables perfectly are. An example are relativistic gauge theories (like QED or the Standard Model) in "non-covariant gauges" like the Coulomb gauge: The Feynman rules and the proper vertex functions are not manifestly covariant, the S-matrix elements referring to physical cross sections are. Sometimes non-covariant formulations have their merits!
Likes bhobba
  • #264
SR requires no interpretation. Its simply what the symmetries of nature require. That derivation just leaves the value of one constant to be determined - many many experiments show its the speed of light.
Thanks
Bill
  • #265
SR does not contradict an aether. Its simply superfluous. I have no issue with a preferred frame and its a perfectly legitimate conjecture. I am a little perplexed why anyone would worry about a theory that required such. Theoretically one would break the isotropy of an inertial frame but the CBMR already does - however it can be screened out. Any other preferred frame hopefully would be similar or basically undetectable - if not then we really do have a revolution on our hands similar to the discovery of broken parity symmetry. Maybe that's why some would dislike it.
Thanks
Bill
  • #266
Symmetries it itself require nothing. And without interpretation, it is not even clear what is symmetric. SR certainly requires interpretation. Say, something non-symmetric may be in one interpretation only an irrelevant mathematical object, in another interpretation something really existing. Even if to mention other interpretations is forbidden here, the one interpretation which is allowed is nonetheless a nontrivial interpretation.
But to mention the aether contradicts the rules of this forum, I have been told. So, there is something some people worry a lot. We are free to speculate about the reasons for ourselves, but cannot discuss it here.
Likes akvadrako
  • #267
I don't know what's going on here. There is no rule about mentioning an aether. There is a rule about LET:
Generally, in the forums we do not allow the following:
Attempts to promote or resuscitate theories that have been discredited or superseded (e.g. Lorentz ether theory); this does not exclude discussion of those theories in a purely historical context
This is because modern SR has superseded LET and discussion about it will not lead anywhere except to why it was superseded, which is allowable in a historical context if that is what you are interested in. But it needs to remain in that context.
The aether is sometimes discussed when talking about the DBB interpretation because some think it implies an aether, and that is OK. But in order to avoid any confusion I personally call it preferred frame. In LET the aether, according to the theory, has physical effects, but could never actually be detected by experiment. That goes beyond preferred frame so what is meant could be a bit ambiguous.
Thanks
Bill.
  • #268
An inertial frame is, by definition, homogeneous in space and time and isotropic. That is a definition and in and of itself contains no physics. The physics lies in the many experiments that show, to a high degree of accuracy, such frames exist. The principle of relativity ie the laws of nature are the same in all inertial frames, or frames moving at constant velocity wrt to an inertial frame, are the same is also able to be experimentally checked and has been found correct.
That is all that goes into the derivation of SR. The value of the constant that appears in that derivation can be found in many ways, and that it is the speed of light is not the most obvious. But this is getting way beyond the scope of this thread. If you want to delve into the foundations of SR please start a thread in the relativity section.
Thanks
Bill
Likes weirdoguy and vanhees71
  • #269
Except that if gravity is considered, we have no such things as inertial frames and they survive only as local approximations. So, given the empirical evidence for GR, SR has already been found incorrect.
To start a thread about the foundations of SR would be suicidal in a forum where even to mention one of the two established interpretations of SR is simply forbidden. One can hope for some possibility of discussing the foundations of quantum theory, but given that the most interesting (namely all realistic and causal) interpretations depend on the forbidden interpretation of relativity, this is nothing but a quite naive hope.
  • #270
LET is an established modern interpretation? It has been well and truly superseded. It is on topic to discuss the history of why that is but these days to put it mildly it is very backwater. However, the reason, history wise, should be obvious - we have a justification in SR that requires no interpretation - it's simply a consequence of very well verified symmetries. These symmetries determine the geometry of space-time. I seem to recall the Enlargen Program was concerned about showing the strong connection between symmetries and geometry - the symmetries of SR implies Minkowski geometry. Its like asking what is the interpretation of Euclidean Geometry - there is no interpretation. Its just a consequence of Euclid's axioms that may be true or false. I am not talking about Hilbert's axioms, but the basic geometry you learned at school.
Thanks
Bill
Likes weirdoguy and martinbn
  • #271
That's wrong. There are all sorts of interpretations about eg Primary State Diffusion:
https://arxiv.org/pdf/quant-ph/9508021.pdf
To be fair though that one may have been experimentally disproved.
BTW I know of no interpretation that requires LET. I do know some people think DBB may require a preferred frame - but LET is more than that.
Thanks
Bill
  • #272
Whats your point? Notice I said 'The physics lies in the many experiments that show, to a high degree of accuracy, such frames exist.' They exist to very good approximation when gravity is weak. That would be on the Earth where it takes very sensitive equipment to show its not inertial. I saw an experiment where a clock was lifted a foot and it showed a difference when returned - but that was not a normal clock. For most purposes the Earth is inertial as has been demonstrated many times.
Thanks
Bill
  • #273
bhobba said:
Whats your point?
Showing the inaccuracies in your text. Conceptually, given that the theory that inertial frames exist is already falsified, it does not make much sense to use this existence as a base for derivations.
Whatever, once I use "realistic" in the way of EPR and "causal" as containing Reichenbach's principle of common cause and no causal loops it is proven that interpretations which are realistic or causal but have no preferred frame cannot recover QM predictions.
The "more than that" part is uninteresting. But, ok, that means that I'm free to discuss theories with preferred frames, and following some other post to say "aether" is not forbidden too, but saying "LET" is forbidden? Why such hatred against one of the greatest scientists?
Given your criteria of modernity, which names aspects of the Erlangen program of 1872 modern, certainly.
Why do you provoke discussions which would be illegal here making false claims which cannot be questioned? If it is only allowed to discuss LET (or the preferred frame, which is that really matters) historically, this would exclude the consequences of Bell's theorem, as well as published generalizations of the anathema to gravity and the SM.
No, the historical reason is much more trivial, namely that nobody has extended to Lorentz ether to gravity at that time. A legitimate reason, except that it vanishes into thin air once such a generalization appears.
That these symmetries are also the symmetries of that construction named "space-time" is fine, but nothing follows from this without interpretation. The symmetry is also simply the symmetry of the wave equation. You can use it to construct new, Doppler-shifted solutions out of a given solution of the wave equation. This works for sound waves too, using the speed of sound instead of c. Thus, the same symmetry group plays some (however minor) role in completely different physical situations too. To claim that something follows from the symmetry group alone makes no sense.
Euclidean symmetry requires interpretation too. The GR interpretation - that it is simply an approximate symmetry applicable locally, for small speeds, and if the rulers are not too much distorted by gravity - certainly differs from Kant's interpretation as a necessity of thought.
  • #274
Huh? Bell's theorem says nothing about a preferred frame.
  • #275
The choice left by Bell's theorem is between giving up realism (EPR criterion of reality) as well as causality (Reichenbach's principle of common cause), or accepting a preferred frame.
  • #276
Again, huh? Bell's theorem says nothing about a preferred frame. I have no idea where you are getting this from.
Likes Heikki Tuuri
  • #277
To say that Bell's theorem plus quantum mechanics implies a choice between realism, causality and a preferred frame is taking an additional step, which is reasonable but not strictly justified. In the final part of this discussion by Bell, it seems that violation of a Bell inequality does not exclude a Lorentz covariant theory (no preferred frame) that is nonlocal (due to violation of the Bell inequalities): https://m.tau.ac.il/~quantum/Vaidman/IQM/BellAM.pdf
An example of an attempt to construct a nonlocal Lorentz covariant hidden variable theory is https://arxiv.org/abs/1111.1425
Of course, as Bell himself proposed (building on earlier work), it may be possible to construct hidden variables consistent with standard relativistic quantum field theory, in which the hidden variable theory does have a preferred frame: https://www.informationphilosopher.com/solutions/scientists/bell/Beables_for_QFT.pdf
Furthermore, whether orthodox relativistic quantum field theory with collapse has a preferred frame or not is a matter of definition: https://arxiv.org/abs/0706.1232"1. Collapse cannot be described covariantly in a relativistic theory at the level of the state-description, only at the level of probabilities. This thereby precludes progress on questions such as “Why God plays dice.”
2. As first pointed out by Bell [48, 47, 9], Lorentz-covariance in the state-description can be preserved in a theory like TSQM [32] (§2.4). In addition, we believe it to be the most fruitful approach to probe deeper quantum realities beyond probabilities, thereby providing insight toquestions like “Why God plays dice.”"
Likes bhobba
  • #278
The other choice is to simply accept standard relativistic QFT, which is Poincare invariant and causal though, as any QT, indeterministic. There's by construction no need for any preferred frame. Preferred frames come into the game only when having many-body systems, e.g., in thermal equilibrium, but even this case can be formulated in Poincare-invariant form. The only thing that appears are frames preferred by the physical situation, the local rest frame of the "heat bath".
Likes weirdoguy and bhobba
  • #279
QFT is microcausal and Poincaré covariant, but it doesn't obey EPR realism and Decorrelating explanations (a part of Reichenbach's common cause principle).
The first is nothing more than what is implied by the Kochen-Specker theorem (i.e. no values pre-exist the measurement/the measurement creates values) and the latter is just the multiple sample spaces point we've spoken of before.
  • #280
If you have between two events A and B there is a violation of the Bell inequalities, but assume EPR realism or Reichenbach's common cause, then there are only two explanations for such a correlation: Either ##A\to B## (the decision what to measure at A has causally influenced the outcome at B), or, reverse, ##B \to A##.
QT predicts the possibility of violations of Bell inequalities for every pair of events. If we assume causality without causal loops, then there cannot be both ##A\to B## and ##B \to A##, but one has to be. But this allows to define a preferred contemporaneity. The event contemporary to A is the event on the worldline B(t) where ##B(t) \to A## switches to ##A\to B(t)##.
It is, of course, hidden, because we don't know if ##A\to B## or ##B \to A## is true.
