COVID-19 Coronavirus Containment Efforts
In summary, the Centers for Disease Control and Prevention (CDC) is closely monitoring an outbreak of respiratory illness caused by a novel (new) Coronavirus named 2019-nCoV. Cases have been identified in a growing number of other locations, including the United States. CDC will update the following U.S. map daily. Information regarding the number of people under investigation will be updated regularly on Mondays, Wednesdays, and Fridays.
  • #1,961
atyy said:
Indonesia is doing rapid tests, which are antibody tests. I am not sure, but I believe the accuracy of these tests is low (relatively speaking), so they are used to rapidly identify people who need to take a confirmatory test.
https://www.thejakartapost.com/news...se-tb-test-kits-for-covid-19-doctor-says.html
https://www.channelnewsasia.com/new...avirus-cases-deaths-jakarta-measures-12585684
So anyone who tested positive by antibody-based test should be tested with an RT-PCR to confirm the positive test. Maybe it's just me, but it seems redundant.
Biology news on Phys.org
  • #1,962
That might help distinguish between someone who is active vs recovered.
  • #1,963
The antibodies remove the virus from the body somewhat quickly. You can't confirm an antibody test with a test that looks for the virus particles. They are different things, for different times, with different purposes.
  • #1,964
mfb said:
It can be used to see if you had contact to the virus at least two weeks ago or so. It can't help finding people who got infected recently.
In addition to the antibody tests (post 1936) Germany aims at 200,000 virus tests per day by the end of April. German source.
Ideally this will be enough to test contacts of infected people again.
We'll get so many publications in the future analyzing the strategies of different countries. Will be very interesting to see once this pandemic is over and people have more time to study everything in detail.
I've seen reports of a test that can detect antibodies as early as 3 days after someone shows symptoms:
Introduction: SARS-Cov-2 (severe acute respiratory disease Coronavirus 2), which causes Coronavirus Disease 2019 (COVID19) was first detected in China in late 2019 and has since then caused a global pandemic. While molecular assays to directly detect the viral genetic material are available for the diagnosis of acute infection, we currently lack serological assays suitable to specifically detect SARS-CoV-2 antibodies.
Methods: Here we describe serological enzyme-linked immunosorbent assays (ELISA) that we developed using recombinant antigens derived from the spike protein of SARS-CoV-2. These assays were developed with negative control samples representing pre-COVID 19 background immunity in the general population and samples from COVID19 patients.
Results: The assays are sensitive and specific, allowing for screening and identification of COVID19 seroconverters using human plasma/serum as early as 3 days post symptom onset. Importantly, these assays do not require handling of infectious virus, can be adjusted to detect different antibody types and are amendable to scaling.
Conclusion: Serological assays are of critical importance to determine seroprevalence in a given population, define previous exposure and identify highly reactive human donors for the generation of convalescent serum as therapeutic. Sensitive and specific identification of Coronavirus SARS-Cov-2 antibody titers will also support screening of health care workers to identify those who are already immune and can be deployed to care for infected patients minimizing the risk of viral spread to colleagues and other patients.
https://www.medrxiv.org/content/10.1101/2020.03.17.20037713v1
As others have mentioned, the standard nucleic acid tests (RT-qPCR or the faster isothermal amplification test from Abbott) are probably the best for diagnosing new infections. Serological tests will have complementary functions in identifying those who were infected in the past (esp asymptomatic or mild cases that did not require hospitalization and were not tested) and are now immune (as well as monitoring whether immunity persists over time).
Likes mfb, BillTre and Astronuc
  • #1,965
I did two tables today concerning the current case fatality rates (CFR)* of Covid-19.
Wikipedia article on Case fatality rate said:
In epidemiology, a case fatality rate (CFR) — sometimes called case fatality risk — is the proportion of deaths from a certain disease compared to the total number of people diagnosed with the disease for a certain period of time. A CFR is conventionally expressed as a percentage and represents a measure of disease severity.
The left table contains the CFRs of the 25 countries with the largest numbers of confirmed cases.
The right table contains the CFRs of the 25 countries with the largest CFRs.
The total CFR for the world is currently 4,9 % (this is the total of all countries, not just the countries present in the tables).
Source: Covid-19 CSSE dashboard.
Date: 31 March 2020.
Notes: Please note that the numbers of cases are confirmed cases only which may also depend on the number of tests done in each country. Please also note that these numbers are a snapshot of the current situation, i.e. the numbers and thus the case fatality rates may change in the near future.
The tables:
  • Sad
Likes PeroK
  • #1,966
Poor Italy. It's not exactly La Dolce Vita there at the moment.
  • Sad
Likes bhobba
  • #1,967
I just saw an interview with a particle physicist who is using a synchrotron to get a more detailed look at the coronavirus. I know we have particle physicists here and am curios if they have been called upon to do that type of work.
Thanks
Bill
  • #1,968
bhobba said:
{snip...}my physio keeps his distance and just guides me through the exercises, but there are some moments he gets close, such as when he attaches weights {snip...}
I always learn from reading posts from other countries and cultures. If 'physio' is similar to our 'physical therapy', then I schedule a grueling three visits a week prescribed by my primary care (PCP) and pain management doctors and approved by veteran's administration (VA) cardiologists.
While we have strap on weights at the physical therapy clinic, staff prefers we use calibrated stainless steel hand weights and appropriate weight machines that are easy to sanitize after each use. Healthy athletic people might scoff at 2 pound (less than 1 kilogram) hand weights and 15 pound leg lifts, but they give remarkable results for increased strength and mobility for people with physical disabilities.
We all differ but last year swimming 6 days a week plus 'physio therapy' twice a week kept me able to walk reasonably well. With pools and gyms closed, I am attempting Monday Wednesday Friday (MWF) physical therapy plus home exercise; but I workout much better with supervision even if the trainers remain distant. You mentioned safety equipment:
While swimming I wear long sleeved light synthetic shirt to protect from chill and sun and shaded face mask with snorkel to protect eyes and face. I also need foot fins plus plastic mesh leg braces, optional for most swimmers :cool:. The snorkel plus fins allows prone position with head level with spine, lots of air, no twisting, and regular slow movement. Let the water support you.
While exercising out of the water I always wear long gym pants over or under my leg braces to protect my legs, long socks (UK stockings?), and light walking (cross-trainer) shoes. I wear a thin cotton long-sleeved shirt covered by a larger synthetic T-shirt, with a sweater when cold. This helps protect core, spine and arms. I always wear heavy synthetic gloves with padding, that cover fingers, sealed at the wrist over the long sleeve shirt to protect hands from damage and contamination.
I also wear prescription acrylic glasses* secured by a rolled bandanna (cotton scarf). I have used a second folded bandanna as an improvised face mask and also carry N95 masks in my gym bag and vehicle. I wipe surfaces before and after exercises. I also carry my own towels and yoga bands (canvas and rubber straps). Everything gets laundered and cleaned after each visit except shoes.
While I love exercise, I am not naturally a 'gym rat'. While the pain can be intense and fatigue difficult to master, the short and long term results of mild regular exercise are beneficial. Thanks
*also wear safety lenses over glasses or contact lenses or bare eyeballs for any activity that 'raises dust' or fragments or excessive light.
  • #1,969
@PeroK and others who get sad and/or anxious by the numbers:
I get sad and anxious too. I actually had to take a pause from working with the statistics. After I did the first two charts I posted previously in the thread, I did not feel good. I can't remember I've ever felt this before when doing statistics or analyzing numbers. Technology and science most often concerns numbers that are far away from the life and death of humans. This is very, very different, and it clearly affects me. So will take a pause from these statistics again.
On a more positive note:
Why I did the comparison was simply that I was interested in comparing countries to see which countries were doing well and what can possibly be learned from the countries that have been/are doing well.
This is the spirit I am hoping for:
"We shall defend our lives, whatever the cost may be, we shall fight the virus in the hospitals, we shall fight in the homes, we shall fight in the fields and in the streets, we shall fight in the hills; we shall never surrender."
...heavily influenced by Winston Churchill. :smile:
Likes atyy and Klystron
  • #1,970
First 21 states to declare stay-at-home prior to March 25
https://www.physicsforums.com/threads/covid-19-coronavirus-containment-efforts.983707/post-6316586
Thirteen states declaring stay-at-home throughout state after March 25
Alaska, Stay at home, March 28 at 5 p.m.
Arizona, Stay at home, March 31 at 5 p.m.
District of Columbia, Stay at home, April 1 at 12:01 a.m.
Kansas, Stay at home, March 30 at 12:01 a.m.
Kentucky, Healthy at home, March 26 at 8 p.m.
Maryland, Stay at home, March 30 at 8 p.m.
Minnesota, Stay at home, March 27 at 11:59 p.m.
Montana, Stay at home, March 28 at 12:01 a.m.
New Hampshire, Stay at home, March 27 at 11:59 p.m.
North Carolina, Stay at home, March 30 at 5 p.m.
Rhode Island, effective March 28
Tennessee, Stay at home, March 31 at 11:59 p.m.
Virginia, Stay at home, March 30
Eleven states leaving stay-at-home declarations to cities and/or counties, some of which acted before March 25
Alabama - City of Birmingham Shelter in place, March 24 at 12 p.m.
Florida - limited parts of SE Florida
Georgia - Atlanta, Blakely, Carrolton, Savannah, Athens-Clarke County, Dougherty County issued stay-at-home or shelter-in-place
Maine - Portland, Stay at home, March 25 at 5 p.m.
Mississippi - Oxford, Stay at home, March 22
Oklahoma - Norman, March 25, Oklahoma City, Tulsa, March 28
Pennsylvania - stay-at-home orders for more than 20 counties in the state, varies by county
South Carolina - Charleston, March 26 at 12:01 a.m.; Columbia, March 29 at 12:01 a.m.
Texas - left to cities and counties; counties involving Houston, Dallas-Forth Worth and San Antonio issued stay-at-home declarations
Utah - Salt Lake County, Stay at home, March 30 and Summit County, March 27 at 12:01 a.m.
Wyoming - Jackson, Stay at home, March 28
No stay-at-home: Nevada, Nebraska, North and South Dakota, Iowa and Arkansas
Ref: https://www.nytimes.com/interactive/2020/us/coronavirus-stay-at-home-order.html
Likes atyy
  • #1,971
Washington State Department of Health has delayed reporting data for positive and negative cases since March 28. They issued the following statement:
https://www.doh.wa.gov/Portals/1/Documents/1600/coronavirus/DelayDataPosting.pdf
The Department of Health is committed to continued data transparency. We are working to ensure daily numbers are posted on time. Here’s some context about recent challenges:
  • The Washington Disease Reporting System (WDRS) is used to report notifiable conditions.
  • Outside a pandemic, only positive results would be reported.
  • WDRS is now tracking negative results for COVID-19. This volume is overwhelming the tool.
  • We have worked with the vendor supporting WDRS to increase capacity.
  • We are also investigating additional solutions, which may include:
    • A separate reporting tool for negative results (roughly 93% of the data at this time).
    • Automating deduplication work performed manually each day. One day last week, more than 2,000 duplicate results were removed to ensure accurate, reliable numbers.
DOH will share additional updates if this problem persists. We cannot provide an estimate for the next release of numbers, but are working diligently toward that goal.
Washington DOH had revised their website on March 28 and changed how they report data, and they have not updated the numbers since. So positive and deaths are currently under-reported.
https://www.doh.wa.gov/Emergencies/Coronavirus
The number of cases by date were also changed/revised for the month of March.
Washington state Gov. Jay Inslee on Monday raised questions about some alarming new COVID-19 test results coming out of a handful of rural counties.
https://komonews.com/news/local/experts-try-to-understand-rural-spike-in-positive-covid-19-tests
Um, people travel! And testing rates are lower than in high population (metropolitan) areas.
More on the Skagit Valley Chorale choir. 28 of 45 people who fell ill have tested positive for COVID-19, so 17 others are presumptive cases.
https://komonews.com/news/coronavir...-choir-killing-2-members-and-infecting-others
Likes mfb
  • #1,972
The synchrotron machines are not directly connected to particle physics. They are normally closed, but they keep the ability to restart quickly if the medical field is interested in a study.
http://www.esrf.eu/home/news/general/content-news/general/covid-19-update.html
Situation at DESY - they had a request already
Italy's last daily update matched the day before, i.e. notably lower than the 10 days before that.
Likes bhobba and atyy
  • #1,973
About 35 companies and academic institutions are racing to create such a vaccine, at least four of which already have candidates they have been testing in animals. The first of these – produced by Boston-based biotech firm Moderna – will enter human trials imminently.
  • #1,974
*The left table contains the CFRs of the 25 countries with the largest numbers of confirmed cases.
The tables:
Thanks for the nice tables on top 25 Countries: Current Confirmed Cases (CCC) vs Current Case Fatality Rate (CFR).
I would like to add the following factors on your notes for everyone's consideration and deliberation.
1. Age structure of the population: Italy has the second oldest population in the world, after #Japan, which may partly explain the high mortality observed.
2. Health care availability (number of hospitals, intensive care beds) and accessibility (free vs. paid): Low death rates in Germany and SouthKorea are partially due to the relatively high number of hospital beds per capita. Differences in death rates within the same country, for example Hubei province (location of Wuhan, where the outbreak emerged) and other parts of China are mainly because of the rapid increase in cases in Hubei (strain on health care resources).
3. How long the virus has been circulating: COVID19 has had longer to affect Italy and spread within the population compared to other countries.
4. Country’s systems of death registration / coding. Are deaths reported as COVID-19 / as the underlying medical condition with COVID-19 as secondary cause? Countries (even provinces / states) may vary in this respect too.
5. Country’s testing policy. Testing more patients increases the denominator (people who have a positive SARSCoV2 test); reduces the death rate.
Likes DennisN
  • #1,975
mfb said:
Do we have some data what happens to asymptomatic cases over time? People who get sick seem to be infectious as long as they have symptoms and then a little bit beyond that. But that approach is meaningless for people who never develop symptoms.
Not an answer to your question, but it may be possible this will result in some data.
China starts to report asymptomatic COVID-19 cases
https://www.channelnewsasia.com/news/asia/coronavirus-covid-19-china-asymptomatic-cases-12597704#cxrecs_s
I suppose from the context, some of these could be pre-symptomatic.
Also, the word "asymptomatic" has been used in some reports to mean no symptoms as noticed by the patient (which is a practically important definition). However, they did have symptoms when examined by a CT scan. For example, patient 5 in this report was aymptomatic but did have abnormalities in the CT.
"For the two asymptomatic children (patients 5 and 6), patient 5 had ground-glass lung opacities identified by CT scan. Unlike patient 5, who was aged 10 years and non-compliant to parental guidance, patient 6, who was aged 7 years and reported by her mother to wear a surgical mask for most of the time during the period in Wuhan, was not found to be infected by virological or radiological investigations."
https://www.thelancet.com/journals/lancet/article/PIIS0140-6736(20)30154-9/fulltext
  • #1,976
Bandersnatch said:
Case Fatality Rate - the likelihood a person diagnosed with the viral infection will die
Infection Fatality Rate - the likelihood a person will die after contracting the virus (whether diagnosed or not)
Since most infections are mild and go unreported, the former is higher than the latter.
It looks like the table reports CFR for the novel coronavirus, and IFR for the influenza.
Possibly a dumb question, but how do we know the IFR?
If someone is never diagnosed, how do they even show up in the statistics? Thanks.
  • #1,977
You can infer it by measuring the infection rate in a reduced sample and measuring the fatality rate over the population.
[Not my field, but that's how I'd do it]
  • #1,978
@jbriggs444 Yep that is a reasonable way to do it. You have to wait for deaths, and with an example 2% death rate in a small population this can take time.
  • #1,979
https://www.usatoday.com/story/news/world/2020/04/01/coronavirus-covid-19-china-radical-measures-lockdowns-mass-quarantines/2938374001/ said:
This is what China did to beat coronavirus. Experts say America couldn't handle it
In late February, as Coronavirus infections mounted in Wuhan, China, local authorities went door-to-door for health checks – forcibly isolating every resident in makeshift hospitals and temporary quarantine shelters, even separating parents from young children who displayed symptoms of COVID-19, no matter how seemingly mild.
Caretakers at the city's ubiquitous large apartment buildings were pressed into service as ad hoc security guards, monitoring the temperatures of all residents, deciding who could come in, and implementing inspections of delivered food and medicines.
Outside, drones hovered above streets, yelling at people to get inside and scolding them for not wearing face masks, while elsewhere in China facial-recognition software, linked to a mandatory phone app that color-coded people based on their contagion risk, decided who could enter shopping malls, subways, cafes and other public spaces.
"We couldn't go outside under any circumstances. Not even if you have a pet,"
More draconian steps are needed in the U.S., these officials say, although they also cast doubt on whether Americans could do what the Chinese did, for a mixture of reasons: political will and deep-rooted cultural inclinations, among them.
"Lockdowns, bans on gatherings, basic quarantines, testing, hand-washing, this is not enough, You need to isolate people on an enormous scale, in stadiums, big exhibition halls, wherever you can. It seems extreme. It works,"
I expect what the article says about the USA culture also applies in Europe, South America, and many other places.
Likes russ_watters
  • #1,980
This is where a serologic test becomes useful. A serologic test will detect if someone has antibodies against the virus, which is a sign that they were infected in the past. As others have mentioned, you can use the test to sample a population after the outbreak to estimate the real infection rate (which also tells you the fraction of undiagnosed mild/asymptotic cases).
  • #1,982
Is it possible to use an antibody test as a step in testing the effectiveness of a vaccine? For example, before testing whether the vaccine reduces infections, would it make sense to first check that the vaccine is able to elicit antibody production?
  • #1,983
I was told that:
1. The COVID-19 RDT can only be used in people who had onset of symptoms for at least 5 days (i.e. for IgM) and 21 days (i.e. for IgG). Most kits include both IgM and IgG, so they can be used by day 5.
2. Anyone who tests positive for IgM should be tested with an RT-PCR to confirm the positive test.
3. A negative IgM test DOES NOT rule out COVID-19 and the symptomatic patient should REMAIN ISOLATED, and swabbed using RT-PCR for confirmation.
4. IgG-only positive individuals without RT-PCR should be labeled as presumptive past COVID-19 and not be officially counted as confirmed unless there is a further validation test in the future, or if validated with a PRNT (Plaque reduction neutralization test) or viral culture by a third party. If a patient is symptomatic, an RT-PCR should be done, and the patient should be quarantined. If a patient is asymptomatic, there is no need to test using an RT-PCR.
5. The IgG antibody can be used as an adjunct test to clear quarantined patients who remain asymptomatic at 14 days post discharge. The presence of antibodies typically indicates viral clearance. If IgG is positive, the patient can be released from self-quarantine. If IgG is negative, a repeat RT-PCR should be performed
  • #1,984
peanut said:
I was told that:
Where did you read this? I'm asking because the protocol might be different in different countries.,
Likes peanut
  • #1,985
I've learned that in our group chat from an infectious diseases physician. Yes protocol vary from country to country.
  • #1,986
Do you know which country he was referring to? I'm patricularly interested because of point 2 (Anyone who tests positive for IgM should be tested with an RT-PCR to confirm the positive test) - I think practice here varies the most. My guess from news articles is that Indonesia does something like this, but as @chemisttree and @mfb indicated in posts #1962 and #1963, the purpose of the PCR test may not be to confirm the result of the antibody test.
  • #1,987
In this spirit, I continued with the statistics from 31 March 20201.
This is a selection of 25 countries2 (with number of cases larger than 7163) that have reported comparatively low case fatality rates (CFR), sorted from low to higher CFRs :
Source: Covid-19 CSSE dashboard (31 March 2020).
Notes:
  1. The numbers may have changed since yesterday.
  2. There are other countries with low CFRs (countries with numbers of cases smaller than 7163).
  3. This is just an arbitrary selection criteria due to the fact that I restricted the list to 25 countries.
Likes morrobay and atyy
  • #1,988
@bhobba , @davenn :
Australia seems to have a comparatively low case fatality rate (ca 0,4%) judging from the statistics I posted above. Does anyone of you have any thoughts about why this could be the case?
Tell us your secrets... :smile:
EDIT:
Coincidentally, Sweden (where I am from) and Australia are currently just next to each other in the list with respect to numbers of confirmed cases (1 April 2020):
Sweden:
Cases: 4947
Deaths: 239
Case Fatality Rate (CFR) = 239/4947 = 0,048 = 4,8% (ca)
Australia:
Cases: 4862
Deaths: 20
Case Fatality Rate (CFR) = 20/4862 = 0,004 = 0,4% (ca)
So currently Australia has got a 10 times (ca) lower case fatality rate than Sweden.
Likes davenn
  • #1,989
Yes, for example, this is one thing that Moderna will be monitoring during their phase I clinical trials of their mRNA vaccine:
This is a phase I, open-label, dose ranging clinical trial in males and non-pregnant females, 18 to 55 years of age, inclusive, who are in good health and meet all eligibility criteria. This clinical trial is designed to assess the safety, reactogenicity and immunogenicity of mRNA-1273 manufactured by ModernaTX, Inc. mRNA-1273 is a novel lipid nanoparticle (LNP)-encapsulated mRNA-based vaccine that encodes for a full-length, prefusion stabilized spike (S) protein of SARS-CoV-2. Enrollment will occur at one domestic site. Forty-five subjects will be enrolled into one of three cohorts (25 microgram [mcg], 100 mcg, 250 mcg). Subjects will receive an intramuscular (IM) injection (0.5 milliliter [mL]) of mRNA-1273 on Days 1 and 29 in the deltoid muscle and will be followed through 12 months post second vaccination (Day 394). Follow-up visits will occur 1, 2 and 4 weeks post each vaccination (Days 8, 15, 29, 36, 43, and 57), as well as 3, 6 and 12 months post second vaccination (Days 119, 209 and 394). The primary objective is to evaluate the safety and reactogenicity of a 2-dose vaccination schedule of mRNA-1273, given 28 days apart, across 3 dosages in healthy adults. The secondary objective is to evaluate the immunogenicity as measured by Immunoglobulin G (IgG) enzyme-linked immunosorbent assay ELISA to the SARS-CoV-2 S (spike) protein following a 2-dose vaccination schedule of mRNA-1273 at Day 57.
https://clinicaltrials.gov/ct2/show/NCT04283461
However, detecting antibodies against the virus doesn't necessarily guarantee that the vaccine will be effective. If the vaccine is not designed correctly, the antibodies could recognize the antigen from the vaccine very effectively but not the antigen in the actual virus. In some cases, antibodies can bind to the antigen, but instead of neutralizing the virus, they actually help the virus get into cells (a phenomenon known as antibody dependent enhancement). These are some of the reasons why a lot of clinical trials are necessary before vaccines can be made available to the general public.
  • #1,990
DennisN said:
@bhobba , @davenn :
Australia seems to have comparatively a low case fatality rate (ca 0,4%) judging from the statistics I posted above. Does anyone of you have any thoughts about why this could be the case?
It's a sports mad country, they spend all their time running and swimming at the beach so they are fit. :oldtongue:
  • Haha
Likes bhobba, davenn and DennisN
  • #1,991
...and it's a big country with a lot of boomerangs they run around trying to take cover from. :smile:
  • Haha
Likes Klystron, bhobba, davenn and 1 other person
  • #1,992
Nothing to say that viruses that diluted over space can still cause an infection. Plus the absence of gravity allows them to be suspended in air (easier transmission? Especially in a closed environment - space shuttle etc)
  • #1,993
Sweden stopped most tests, so cases are limited to some hospitalized patients. Forget their confirmed case count, it doesn't reflect reality at all.
Looks like Australia follows the path of Germany so far.
Daily new cases in the US now exceed 24,000, which means 1000 per hour or one every 3.6 seconds.
Likes bhobba and DennisN
  • #1,994
Yes, I was aware of that. I wasn't aware of why, but according to this article which the wiki page referred to (Swedish only, sorry) the government epidemiologist Anders Tegnell said that they think there is community spread and they will focus to look more on severe than general cases:
Epidemiologist Anders Tegnell said:
We won't discuss anymore if we have 458 or 562 cases. Instead we'll look at how many regions are affected and how severely affected they are, says Tegnell.
(my translation to English from Swedish)
I guess time will tell if that was a wise decision or not... :confused:
Likes atyy
  • #1,995
In the coming years, I'm sure that we'll hear a lot more about such decisions.
Should each continent/country/state/county/town/city/neighborhood/family/person be able to choose their own strategy independent of others? If yes, we have no containment. If no, we have a single world government with total authority. Freedom versus survival is not a nice choice to make. See #2979 about China.
Likes russ_watters
32K
