mfb
Mentor
- 37,386
- 14,215
It is not, but it gives a good lower estimate if you take the change in center of mass after leaving ground, and a good upper estimate if you take the total shift in center of mass.marcus said:Is it as simple as saying that you could jump 35 times as high?
The acceleration distance will be the same, but you don't have to fight against so much gravity so your final velocity is larger, giving you more than 35 times the height after leaving the ground.
The acceleration time will be lower for the same reason, which means you can at most put the same energy into the jump, giving you at most 35 times the total height difference in your center of mass.
With ~50cm and 1m for those two values on Earth (note: don't include pulling your legs up, that does not change the center of mass and will have a negligible effect on the height on Ceres), you could jump somewhere between 20-35 meters high.
Related discussion
