- #106
zoobyshoe
- 6,510
- 1,291
vanesch said:This is absolutely not perpetual motion, not any more than the little car between a static and a turning wheel is (see my previous post).
What you have is that there is a mechanical binding between the cart and the turntable on one hand (given by the wheel on the turntable), and there's another "binding" between the propeller and the air mass, and there is a mechanical link between both. For a certain RPM of the wheel on the table, a certain RPM of the propeller is set, and this, in turn, gives a certain force on the cart. There will be a balance between the power taken or given by the wheel on the table, and the power taken or given by the propeller. The cart will settle in that motion when both are in equilibrium, and that equilibrium is given by the equivalent of a gearing ratio (including, in this case, the efficiency of the propeller).
Here is my problem with this DDW notion: power available from the wind is proportional to V^3
If a 20 mph wind presses on your sail or propeller and accelerates you directly downwind to 10mph, it has reduced its own speed relative to you by half and you now experience it as a 10 mph wind, which is only 1/8 as strong as a 20 mph wind. The more it manages to accelerate you the weaker it becomes relative to you. If it accelerates you to 15 mph you now experience it as a 5 mph wind which is only 1/64 as strong as a 20 mph wind. At some point before you ever reach wind speed its power to accelerate you will be held in check by your friction over the ground.
