- #246
rcgldr
- 8,888
- 649
As you just mentioned, and I explained in an earlier post, advance ratio for propellers is ratio of (prop speed in the direction of wind) / (tip speed perpendicular to the wind), and it's also generally less than 1.zoobyshoe said:This needs clarification in my mind. The "We've been calling..." means you have adapted this term from aeronautics to apply to the DDW vehicles?
However slip ratio isn't correct either. Another ratio is prop pitch / prop diameter, but that's also not a good analogy.Jeff Reid said:correction - What I was calling "advance ratio" is called "slip" in the case of propellers. For propellers, "advance ratio" is the apparent head wind speed / (prop diameter x rate of rotation) = (apparent wind speed / (2 x prop tip speed)) acheived in steady (non-accelerating) flight. Propeller "slip" is (effective pitch) / (geometric pitch).
The people that posted in the earlier threads here and at the wiki web site. Spork was the one that defined the term advance ratio so it was less than 1 for a DDWFTTW cart, and the particpants in those threads at the time agreed so there was a "community standard" for the term "advance ratio" The term "advance ratio" seems generic enough to apply to objects that move at different speed, which is why Spork and others started using it for DDWFTTW carts, even though it's meaning is different in the case for propellers.Who does "we" refer to
Another term used for propellers and tires is slip ratio, actual speed / gemotric speed, but this is a slippage factor, not an effective gearing factor that Spork and others wanted to convey with the term advance ratio.
I didn't start the precedent of using "advance ratio" in reference to DDWFTTW carts, but I did re-introduce it in this thread so if members here read the older threads here or at wiki (and a few other places), the usage of the term "advance ratio" will be consistent, and it's a relatively easy concept to understand.
I attempted to explain "advance ratio" in post #237.
