- #246
- 5,769
- 3,001
One correction: It doesn't require an ideal emissivity to reach thermal equilibrium. When the object reaches temperature ## T_{ambient} ## it is at equilibrium. The reason is at ## T_{ambient} ## in an enclosed cavity, ## E_s(\lambda)=M_{bb} (\lambda, T_{ambient}) ##. Now, writing the power as a spectral density function, ## P_{absorbed} (\lambda)=A \, \epsilon (\lambda) \, E_s(\lambda)=A \, \epsilon (\lambda) \, M_{bb} (\lambda,T_{ambient}) ##, and ## P_{reflected} (\lambda)=A \, (1-\epsilon (\lambda) ) M_{bb} (\lambda, T_{ambient}) ##. The power radiated ## P_{radiated} (\lambda)= A \, \epsilon (\lambda) \, M(\lambda, T_{ambient}) ##, so that the power emerging from the wall is ## P_{emerging} (\lambda)=P_{reflected} (\lambda) +P_{radiated} (\lambda)=A \, M_{bb} (\lambda, T_{ambient} ) ##, completely independent of any emissivities. Notice also that ## P_{absorbed} (\lambda)=P_{radiated} (\lambda) ##. ## \\ ## Regardless of the emissivity of a portion of the wall, in an enclosure at thermal equilibrium, the surface looks like a blackbody even if its emissivity is very low. This is only the case at equilibrium, but it is a very common scenario, and this concept is used in deriving the Planck function, as we previously discussed. See post #206.
