- #106
- 24,488
- 15,021
Photons are indistinguishable bosons. That's a very well defined mathematical property and has nothing to do with any interpretational issues.DrChinese said:I guess your definition of indistinguishable is different than mine. Experimentally, we can have entangled photons that have never interacted in the past, as they are from different sources. They are clearly identifiable, and can have markers (such as their wavelength) that identify them uniquely. They can be passed through filters to confirm that uniqueness.
If QFT is local and realistic, as has been said a hundred times, it's wrong. So tell me exactly where you consider it non-realistic? Non-realistic meaning there is observer dependent reality.
I don't know, what "realistic" means. It's an undefined philosophical expression. QFT is by construction a local relativistic QFT. Local means that
(a) the Heisenberg-picture field operators transform under proper orthochronous Poincare transformations as their classical analogues. The transformation property is determined by the unitary representation of this group the corresponding field operators refer to.
(b) the Hamilton density commutes with any operator representing a local observable if the arguments of these are space-like separated
Further one assumes
(c) the Hamilton is bounded from below. By convention the ground-state energy (vacuum energy) is choosen to be 0.
From this the spin-statistics theorem follows, i.e., you have to quantize the field theory either as bosons (if the spin of the field is integer) or fermions (if the spin of the field is half-integer). This implies indistinguishability of the quanta represented by these fields.
There is no observer-dependent reality. States of quantum systems are well-defined, and I don't know, what entanglement swapping, which you seem to refer to once more, has to do with all this. There's no problem to describe entanglement swapping within standard local relativistic QFT.
Once more the claim that the outcome of local measurements of B's photon would instantaneously be changed by the outcome of local measuremnts by A on a photon pair prepared in a Bell state, cannot be made within local relativistic QFTs. What B measures are unpolarized photons. What A measures are unpolarized photons. There's no dependence of this result on the A's or B's choice which observable they measure (e.g., they can measure the polarization of the photons in arbitrary directions). Only if they compare measurement protocols one finds the correlations between A's and B's outcome of measurements as predicted by QFT for the photons prepared in this entangled state. This implies the violation of Bell's inequality and related properties of this kind. There's not tension between Einstein causality and locality in the sense of relativistic local QFTs whatsoever. Inseparability is implied by any kind of quantum theory, including local relativistic QFTs and no contradiction with locality either.
I call this "realistic", because it's in accordance with all known very accurate experiments on this issue. For me there's no other notion of "reality" which makes sense as a scientific rather than a philosophical notion.
