Exploring Photon Trajectories in Double Slit Experiments
  • #151
Ken G said:
If you think that obvious point is in any way relevant to what I said, it is hopeless that you will understand what I did say (which is that many quantum phenomena can be better understood by noticing their classical analogs). Indeed, I've mentioned several classical analogs in this thread, I explained how they could have been arrived at even without knowing that we are dealing with quanta (like two-slit diffraction patterns), and still you cling to the empty claim that this somehow doesn't make sense.
What’s empty and what doesn’t make any sense is, as far as I can see, still under debate in this thread.
Ken G said:
Maybe you can answer this: just what do you think is inherently "quantum" in a two-slit diffraction pattern? I'm all ears.
I’ll do that in this post, no worries mate. In the meantime, I’ll provide a little dish of https://www.physicsforums.com/showpost.php?p=3366381&postcount=110" to chew on:
"So we can say that we cannot classically explain why the pattern is built up from dots (that's the *inherently 'quantum'* part)"
(emphasis mine)
Ken G said:
Meanwhile, I'll just have to hope that someone else was lurking in this thread, someone who actually did wish to understand the correspondence principle, and who might glean the importance of these words: every quantum theory spawns a classical theory that has to work in the classical limit. That's what "classical analog" means, for those watching at home.
And this is why I’m still pursuing this thread, because this latest confusing "classical twist" will undoubtedly misguide any "layman at home".
For a start – you’re contradicting yourself:
(emphasis mine)
Ken G said:
*every* quantum theory spawns a classical theory that has to work in the classical limit. That's what "classical analog" means, for those watching at home.
Ken G said:
Note I never said "there is no such thing as a quantum effect that has no classical analog." What I did say is "*many* quantum effects do have classical analogs that we take advantage of all the time, especially when testing quantum mechanics, yet many people seem to be unaware of this fact."
I do hope you understand difference between "every" and "many"??
(And please don’t tell me that there are "quantum effects" that "we take advantage of", without a corresponding "quantum theory".)
This kind of confusing gabble will undoubtedly misguide any "layman at home".
I don’t know why you use this vague language of double negation; "I never said “there is no such thing as a quantum effect that has no classical analog.”"...??
I have no idea why you 'beat around the bush' like this, but I’ll help you spelling it out in simple understandable English: You are saying that – YES *there are* quantum effects that have *no* classical analog.
Good, now when we come this far, could you just mention ONE quantum effect that have no classical analog (to cancel out the 'beating around the bushes' accusation), pleeeeeeeease??
To be fair to the "layman at home", don’t you think it would be suitable to explain more in detail what the Correspondence principle really is? That it’s not a law of nature? That it’s not without controversies among physicist, including the founding fathers of QM like Sommerfeld, Pauli, and Heisenberg? That it was formulated by Niels Bohr in 1920, at the time of the old quantum theory, and that it originates from as early as 1913, when Bohr was developing his model of the atom (which we now know is incomplete).
Yes, the Correspondence principle was a cornerstone in Bohr's philosophical interpretation of quantum mechanics - the Copenhagen interpretation, yet there are three (3) different interpretations of the Correspondence principle - the frequency interpretation, the intensity interpretation and the selection rule interpretation.
And as I said, the Correspondence principle was mistrusted by Arnold Sommerfeld, Wolfgang Pauli and Werner Heisenberg:
Bohr has discovered in his principle of correspondence a magic wand (which he himself calls a formal principle), which allows us immediately to make use of the results of the classical wave theory in the quantum theory. (Sommereld [1919] 1923, p. 275)
The magic of the correspondence principle has proved itself generally through the selection rules of the quantum numbers, in the series and band spectra… Nonetheless I cannot view it as ultimately satisfying on account of its mixing of quantum-theoretical and classical viewpoints. (Sommerfeld 1924, p. 1048; quoted also in Seth 2008, p. 345).
I personally do not believe, however, that the correspondence principle will lead to a foundation of the rule… For weak men, who need the crutch of the idea of unambiguously defined electron orbits and mechanical models, the rule can be grounded as follows: ‘If more than one electron have the same quantum numbers in strong fields, they would have the same orbits and would therefore collide… The justification of the exclusion of the above-mentioned cases in the H-atom by pointing to the collision with the nucleus has never pleased me much. It would be much more satisfying if we could understand directly on the grounds of a more general quantum mechanics (one that deviates from classical mechanics). (Pauli to Bohr December 31st, 1924; quoted in Heilbron 1983, p. 306 and Serwer 1977, p. 236)
It is true that an ingenious combination of arguments based on the correspondence principle can make the quantum theory of matter together with a classical theory of radiation furnish quantitative values for the transition probabilities… Such a formulation of the radiation problem is far from satisfactory, however, and easily leads to false conclusions. (Heisenberg 1930, p. 82)
One should also add that in 1920, no one knew about Bell's inequality and EPR-Bell test experiments, which is completely impossible to find any classical analogy for, unless some crackpot is claiming that non-locality and/or non-realism is indeed "Classical Properties" (and now we are talking LARGE quantum numbers!).
Everyone knows that in EPR-Bell 1 + 1 = 3 and that this is not a classical number.
SpectraCat said:
I really don't know what you are talking about, to clarify the situation, please write down the classical formulation of wave mechanics that predicts the diffraction of "large ensembles of electrons".
(emphasis mine)
Ken G said:
First you need a classical measurable. Electron energy flux density will suffice (we could use electron number flux, but my point is that we never need to think of these things as particles at all to "understand" diffraction). Now you need a wave theory. Huygen's principle works fine. Let's simplify life and just get a theory that works for electrons of a given energy (which here means a given ratio of energy flux to mass flux). The wave equation with the v of that population of electrons will work fine, where v is found from timing experiments. Now we need a concept of frequency because it's a wave theory, and here we can leave the frequency as a free parameter that the interference experiment will determine. The wave equation describes the speed of signal propagation, Huygen's principle tells us how to handle the sources and the slits, and the frequency parameter gives us the interference we need. Every one of these is a 100% classical concept, remember that we are pretending we don't even know we have particles here. Now we put them together to calculate the energy fluxes everywhere subject to the free frequency parameter, compare to experiments, and poof, both the frequency parameter drops out, and the fact that we have what we would call a correct theory for electron diffraction, and all classical.
I have to agree with SpectraCat, I don't know what you are talking about?? How could we pretend there are no particles and at same time claim "poof" we have "electron diffraction, and all classical"?? :bugeye: I’m sorry Ken G, this is nuts, totally nuts.
But okay, I’ll be a nice guy and pretend that you are also just a nice guy who wants to help laymen to understand that QM is not weird or mystical at all, and most of the time we do find analogies in our classical world that works perfectly well – nothing to 'worry' about. Okay?
Let’s look at the Double Slit Experiment in way that I know you’ll like:
http://www.youtube.com/watch?v=ZXyxnxnWAAQ&hd=1
https://www.youtube.com/watch?v=ZXyxnxnWAAQ
A hardcore 'QM-Weirdo-Mystifier' would now say: – OMG! OMG! Look at that totally weird QM laser stuff! Totally AWESOME man! Out of this world man! NO ONE could never ever explain this in classical terms!
And then Ken G, you come in the picture and calm things down by showing this video:
https://www.youtube.com/watch?v=-8a61G8Hvi0
And then you say: – See? There’s absolutely nothing strange about this... It’s just ordinary wave mechanics, completely explainable in everyday classical physics!
This is perfectly cool by me, and probably a good thing to teach the public the wave part of QM.
The problem begins when you use all kind of weird arguments to avoid the other crucial particle part of QM, and it all becomes very strange since you are using Niels Bohr in this odd campaign – the same man who is very well known for his basic QM principle of http://en.wikipedia.org/wiki/Complementarity_(physics)" , i.e. the wave–particle duality...??
I think it’s sad, because my first impression was you did have a lot of usable knowledge, which for sure could be used in a better way than this.
Finally, back to you initial question – What’s inherently "quantum" in a two-slit diffraction pattern?
Well, besides having you answering the question yourself, I would add the obvious – it’s of course the quantum itself! Call it what you like; energy package, particle, electron or whatever – but we all know what it is, it’s not the wave(function), it’s that other "stuff" that makes all the difference in the world! If there were no quanta in Quantum Mechanics, it would of course have been called "Wave Mechanics" instead...
And now, if you still want to demystify the Double Slit experiment with only waves, you have to put in a high pressure washer instead, and hope the water would magically split before the slits, and then magically start interfere with itself after the slits, to finally reenter into a concentrated beam just before hitting the detector to make ONE concentrated mark, not a splash all over the place.
That’s what I call real water-wave-magic! Totally AWESOME man!
If Niels Bohr in 1920 would have had access to Dr. Tonomura’s video of single electrons in the Double Slit experiment (that I showed in https://www.physicsforums.com/showpost.php?p=3366035&postcount=107"), I’m sure he would had reformulated the Correspondence principle – but he hadn’t.
There is no way to make these facts go away – every single electron-detection is visible – even if there are millions of electrons in the experiment.
Inherently quantum two-slit diffraction pattern
Before ending this long post; I have a question for you – Do you believe that Local Realism is still feasible? Yes or no please, there is no way to be a bit pregnant.
  • #152
SpectraCat said:
Man, you really pick and choose the points in my posts that you want to respond to, don't you? /quote]Actually, I find that in situations where you feel essentially everything I'm saying is wrong, and I feel essentially everything I'm saying is right, it serves to find one clear case where you are saying I'm wrong and I can demonstrate that I'm right. The neutron diffraction experiment is exactly that, so let's see how that plays out, and the rest should follow.
Of course (assuming they width of the energy distribution is sufficiently narrow that they can be described as monoenergetic) ...
OK, this is good, we've established:
I) A neutron diffraction experiment gets the same diffraction pattern if it's done with one neutron at a time, or a vast ensemble of neutrons, so long as we stay in the collisionless limit where neutrons are not bouncing off each other.
That's actually all I'm going to need.
There is no classical limit or correspondence principle at work there .. you just have more quantum particles going through the slits, so you build up the interference pattern faster than you would have when there were fewer particles.
Actually, you do have a classical limit here, you do have a correspondence principle here, and this is the entire point I'm making. First you need a classical observable. Energy flux will do nicely. So hold up your classical detector into this vast ensemble of neutrons and measure the energy flux at various places. You get the diffraction pattern we both agree on.
Now pretend you are a student, given that detecting apparatus, but you have no idea what is being sent from the emitter, it could be particles or sound waves or phlogiston, you have no idea. Your job is to be a scientist, and develop a theory that can predict what will happan if you modify the geometry of the slits. I'm serious, this would be a wonderful exercise in how science works. So you notice you have a pattern that looks like interference, so you say "aha, I think a wave theory might work here." I'm serious, this is exactly how it was done in many situations. You play with the equations, and sure enough, you develop a wave theory that beautifully predicts what will happen when you modify the slit geometry. You say, "I understand the physics here, we have a wave coming out of the emitter, I'll call it a nound wave. It has a characteristic wavelength I can set as a free parameter to make the pattern work, and that parameter stays the same when I alter the slits, and my predictions work too. Then I swapped my classical energy detector for a classical momentum detector, and sure enough, I found a fixed ratio between energy and momentum fluxes, which I'm going to call (half) the speed of the wave. This also stays constant when I alter the geometry of the slits. I'm doing great, I have a wave with known speed and wavelength, so also known frequency, and my theory predicts the energy and momentum fluxes for any slit geometry. I have a classical wave theory, please give me my coveted scientific award.
Now please note several things:
1) the student did all this without knowing that there were any particles involved here at all, let alone neutrons, and
2) the classical wave theory the student arrived at is exactly what you get if you take the Schroedinger equation in the limit of large occupation numbers (yes for monoenergetic neutrons, and as I say long ago, that particle energy could also be a controlled variable and the classical wave theory would work just great, would find a different wave speed for each mono-energy, just as I said-- the classical theory generated by the quantum mechanics of a particle with mass has a dispersion relation built into it).
3) Facts 1 and 2 are called "the correspondence principle".
4) Sometimes by accident of history, the quantum theory comes first, sometimes the classical theory comes first, it just depends on the particle. But whichever theory comes first, they are connected by the correspondence principle.
The appearance of interference fringes still depends on the quantum delocalization of the particles due to the HUP, as I have said from the beginning. As such, it cannot be described as classical.
I just told you how it would be completely described as classical. If this still hasn't clicked, ask yourself this: what if my hypothetical student experiment had actually been carried out in the year 1900? Bingo, we would have exactly an interference pattern that would be explained as classical. Whether some predicted experimental outcome can be called classical or not is not an ontological stance, it is purely answered by what type of theory predicted it, and many results, like interference fringes, can be predicted by either classical or quantum theories. As I just showed.
That sums up what I've been saying. There's really no need to go through every objection you've raised, what I've just shown makes it all crystal clear. Most of the time you were using a different type of correspondence principle anyway, not the classical limit that turns a quantum into a wave, but the classical limit that turns a quantum into a bowling ball. So all that can be ignored as a category error, and it's better to just focus on the above, because the whole nature of the disagreement is spelled out right there.
Now I have a question for you ... let's switch back to electrons, so we are talking about a physically real case again
(ahem, neutrons are physically real)
... by passing large numbers of particles through, you claim we are somehow studying the system in the limit of large quantum numbers.
Correction, large occupation numbers, as I said. "Large quantum numbers" is a rather ambiguous phrase, you are misinterpreting its meaning here.
Please explain, in as much detail as possible, which quantum numbers are different (i.e. "in the large limit") between the one-by-one case we agree is clearly quantum, and the "large numbers of electrons" that you claim somehow bring us to the limit of the correspondence principle?
The occupation numbers of the modes. This is exactly why you are not understanding.
Until you can answer that question, we can't make any progress here.
I've answered it half a dozen times already, just scan for the phrases "occupation number" and "classical wave."
With all due respect, that last bit is utter nonsense. As I have explained repeatedly, and you have never addressed even once (except to contradict it without explanation), there is no classical limit in which massive particles behave like waves.
With all due respect, that's complete nonsense, and let's hope our common ground point (I), and the experiment I just described in great detail, makes that crystal clear.
That you would think there is, or even could be, indicates that you have a deep-seated misunderstanding of the quantum mechanical principles that you suppose yourself to be educating others about.
Now we have exposed just how ridiculous that claim is!
  • #153
(emphasis mine)
Emphasize it all you want, it's completely correct, and contradicts nothing I've said. The things I am saying are fully self-consistent, I can't even yet tell why you think they're not.
Sorry, no help there-- citing those two perfectly correct and perfectly non-contradicting statements does not help me see what misconception is leading you to think they contradict each other.
Sorry, still no help, because I do know the difference between those two words, and I still have no idea what contradiction you are imagining. Seriously, I don't--- those statements are both correct, neither contradicts the other, and the words "every" and "many" were used in completely correct ways. I suppose if you lift the words out of their sentences, they do seem like contradictory words, but I'm afraid lifting them out of their very different sentences doesn't help me find the contradiction you imagine here.
Excellent, then you did understand me, despite the double negative. I knew you could handle it. In fact, I spelled out a quantum effect that has no classical analog-- the way spots accumulate on a detector when we turn the flux down. Oh yes, you quoted that point just above, how helpful. Now what is your problem with these true facts? I'm stilil missing the contradiction you imagine, I think you must be making a logical error.
Welll I'm not sure what your personal definition of what a law of nature is, but it is perfectly irrelevant. I explained at great detail what the correspondence principle is, it is the statement that all quantum theories must be consistent with a classical theory in the classical limit, and the classical theory can be derived from the quantum theory if you don't already have the classical theory, and if you do already have the classical theory but not the quantum theory, it imposes constraints on what the quantum theory can do. Whether or not you personally call that a law of nature is of no concern to me, it is what it is. Are you offering a counterexample to it, or do you just think the "layman" at home should be kept ignorant of this principle?
Apparently your argument here is once again that because you can find quantum phenomena with no classical analog (which I already gave an example of myself), it refutes my claim that many quantum phenomena do have classical analogs and it can be quite informative to understand them. I just can't follow that reasoning, it sounds like wrong logic to me.
Then read my last post to SpectraCat, I think it should be pretty clearly laid out. Are you as confused as he is about the difference between a "large quantum number" like a huge energy for a single particle, and a "large quantum number" like a huge occupation number for the number of particles in a given domain of phase space? Let me clarify. A classical wave theory is linear, so we have the concept of modes. We also have a concept of energy in the modes. Via the h parameter, this converts to a quantum-number concept of the number of quantums of excitation of the mode. In the classical theory, you don't know these are particles, so you just call them energy in the mode. But if the number of quanta in the mode is large, then you have a classical limit, and if it is small, then you are in the quantum domain. The correspondence principle constrains the behavior of the two theories in these two limits.
In particular, it says that everything that happens in the classical limit must happen in the aggregated limit of many repetitions in the quantum domain, but you can have things that happen in the quantum domain that "average out" and do not appear in the classical domain. All the same, much of the quantum behavior does survive to the classical domain, and when it does, we have ready access to classical intuitions. This is a Good Thing. So now you understand what I have been saying over and over.
Excellent, so what are you going on about? Those two statements more or less summarize everything I've been trying to accomplish, that you have been fighting, with faulty logic and vast misconstruals of what I said. When you actually quoted what I did say above, there was no contradiction at all, yet you still claimed there was because of two different-sounding words you could lift out of the sentence. That is just not even close to a logical argument.
Complementarity, as I pointed out above several times, is an absolutely wonderful example of exactly what I'm talking about-- the value of understanding classical analogs. I'm going to guess you've heard of Fourier transforms and their use in analyzing classical wave systems? Very instructive, very useful intuition, all extremely classical, and all very useful for understanding complementarity. Everyone knows this, actually, and the similar concepts that appear almost daily to sound engineers and radio astronomers are not quantum mechanics. A typical sound engineer probably never even learns quantum mechanics, they don't need to know a "phonon" from a hole in the wall, expressly because they work in the classical limit (of occupation number, once again-- I'm not sure you're getting that). Yet they could much more easily understand complementarity than someone without that classical experience. Do you reject that simple claim? Remember, it is the crux of what I have been saying, as is a matter of black-and-white record above, so to reject my point above, you must reject this claim now. Do you, or don't you?
The irony here is that the quantum weirdness associated with the complementarity principle is not the mundane constraint connecting the localizabilty and bandwidth of a wave packet, it is the weirdness that particles experience this same constraint. So this constraint is not a purely quantum phenomenon, but it only seems weird when it is a quantum phenomenon! Which is my entire point here, actually, so thank you for bringing up such a perfect confirming example of my thesis, though you strangely see it as a refutation.
Well here's the thing: anything can seem wrong when you don't understand it. The danger is in concluding it's actually wrong, when in fact you just don't understand it.
Well this only exposes what I already know, you still have no idea what I've been saying. Let me clarify with these questions: do we see two-slit patterns in contexts other than quantum mechanics? Is there value in understanding that? Is that an example of a classical analog helping us understand a quantum phenomenon? Is this a perfect example of the correspondence principle (with respect to occupation numbers)? When you understand that the answer to every one of those questions is a definitive "yes", then you will finally, finally, understand what I am really saying, and not what you have been telling yourself this whole time what I was saying.
This is the kind of perfectly obvious statement that just leaves me scratching my head about why you think it is the least bit relevant to the actual argument I've presented. At no time have you had the slightest idea what that argument was, so all your objections are just completely irrelevant, even the ones with correct logic like this last remark.
Nope, still not the least bit of relevance to my actual argument. I might blame myself, except I think I've been perfectly clear. I think the actual blame falls mostly on the fact that you still don't get that I have been talking about the classical analogs you get when you go to high occupation numbers of the quanta in each relevant patch of phase space. Maybe if you get that, you can go back through what I've said, and start to see what I actually said instead of this absurd distortion you keep reflecting.
If Niels Bohr in 1920 would have had access to Dr. Tonomura’s video of single electrons in the Double Slit experiment (that I showed in https://www.physicsforums.com/showpost.php?p=3366035&postcount=107"), I’m sure he would had reformulated the Correspondence principle – but he hadn’t. (my bold)
Now that is just patently absurd! You don't think Nils Bohr knew everything in that video? Did he ever recant the correspondence principle? Let's look at a simple syllogism here:
1) Niels Bohr was not an idiot.
2) Niels Bohr died in 1962.
3) Niels Bohr formulated the correspondence princple, and adhered strictly to some version of it his whole life
4) Electron diffraction earned Thomson and Davisson the Nobel Prize for Physics in 1937
5) Niels Bohr knew that one electron at a time would make individual spots
6) Niels Bohr knew that the correspondence principle predicted repetition of the spots would reveal the pattern that Thomson and Davisson got the Nobel Prize for, indeed that is exactly the purpose of the correspondence principle to be able to predict that (do you understand that yet?)
6) Your claim just made Niels Bohr roll over in his grave. Fortunately, I'm here to point that out, with this little syllogism, so maybe he can get some rest.
Ah, the entanglement issue. I can only imagine you brought it up because you are still folllowing the faulty logic that if someone says quantum phenomena always spawn classical theories that mimic enough of the behavior to be useful to know about, then any example of quantum phenomena that don't have classical analogs somehow refutes that. No, that is just plain bad logic.
  • #154
Ken G said:
The more important concern is that the correspondence principle should generate the "same physics" from the classical and quantum theories, which does not require the same trajectory when the trajectory itself has no real physical meaning (the "butterfly effect"). Instead, the "same physics" should simply mean the same statistical tendencies, the same probability distribution of outcomes for any realistic uncertainty in the initial conditions.
The problem with this line of reasoning is that for any real system the probability distributions as predicted by quantum mechanics and the distributions expected from classical arguments differ. There is no real system where these two can be STRICTLY identical up to all orders, not even for a laser beam.
  • #155
DevilsAvocado said:
... Before ending this long post; I have a question for you – Do you believe that Local Realism is still feasible? Yes or no please, there is no way to be a bit pregnant.
Ken G said:
Ah, the entanglement issue. I can only imagine you brought it up because you are still folllowing the faulty logic ...
I can see that you are very good in imagining things, but sorry – you’re wrong again. I brought it up to finally find out if you’re a real crackpot, or if all this is just a giant misunderstanding that makes it look like this.
But I have to tell you, the way you’re avoiding this simple question does not look promising. How hard can it be?
Therefore: Yes or no please?
  • #156
The problem is that the points you ignore are the ones that show why you are wrong. For example, you have yet to provide an equation for your supposed classical theory of electron diffraction. You also have not explained how you can obtain a classical wave equation by taking the classical limit of the Schrodinger equation. Finally, you have not explained how a classical theory can preserve or predict the spatial delocalization that gives rise to the experimentally observed diffraction of massive bodies .. of course that is because it cannot, since spatial delocalization of massive bodies is a feature that is exclusive to (if not definitive of) quantum theories.
The neutron diffraction experiment is exactly that, so let's see how that plays out, and the rest should follow.OK, this is good, we've established:
*Sigh* .. the problem is that you some idea what you are talking about, but you have, as I already pointed out, deep-seated misunderstandings about quantum mechanics. In addition, your posts strongly suggest that you are not an expert in science, although you may be an expert in another field, like philosophy or history of science. The fact that you would continually confuse photons, and electrons is evidence of that, as is the fact that you are apparently incapable of writing down an equation or providing a mathematical derivation to back up your reasoning. Finally, a scientist would realize that the fastest way to end an argument like this is to provide a literature reference for their claims. I can do that, because every single text on quantum mechanics will back up what I am saying. I have asked you to do the same for your claim that one can formulate a classical theory of electron diffraction, and it seems you cannot. That would mean that all of your musings in that regard constitute a personal theory, and such theories are not allowed to be discussed on these forums. To clear that up, please provide the reference I have asked for.
I have done this before to no effect, and I will try one more time ... here are the detailed refutations of your latest arguments.
This is the first time that neutrons have been raised on this thread. Where did you get the idea that we are talking about neutrons? The hypothetical particles that we agreed to discuss are uncharged particles with the same mass as an electron, and therefore are not neutrons. It is the repeated confusion of significant details like this which suggest that you are not a scientist. Neutrons also diffract, but they do so differently than electrons, due to their larger mass and different interactions with matter.
No, you only think you showed it. There are several significant problems with the analysis above, and I deal with several of them in more detail below. First off, the process you describe does not lead to a classical theory at all, it leads to a phenomenological model, which is could be either quantum nor classical. The "quantum" or "classical" nature would depend on the assumptions made during the development of the model. If such a model involved assumptions based on classical mechanics, then it would be later discovered to be "wrong", because it would fail to predict other physical phenomena (most notably the discrete nature of the "mass flux" of the "nound" wave). An analogous example would be the Bohr model of the atom, which was "wrong" because it assumed classical orbits for the electrons. So, the phenomenological theory developed in way you describe would either be discarded as incorrect (or perhaps incomplete), or scientists would continue to investigate until the eventual discovery of de Broglie hypothesis (to explain the wave nature of the "mass flux" .. to use your term), and thus to the development quantum mechanics (assuming it had not yet been discovered). This is because there is no classical basis for massive bodies to have wave-character, after all, that is the seminal difference between quantum and classical theories, and as I have said all along, it is grounded in the HUP.
We do agree on one thing, and that is that any scientist (student or otherwise) conducting such experiments in the early 1900's would be worthy of a Prize!
That's just wrong ... I have been using precisely the same definition of the correspondence principle as you have, the difference is that I have been applying it correctly and drawing physically correct conclusions, while you have not.
Ahem, we weren't talking about neutrons.
No, that is not correct, and this may be the crux of your misunderstanding. The correspondence principle doesn't say anything about "occupation numbers" .. it talks about quantum numbers .. let's not confuse the issue with different terms. The quantum numbers for the states of the quantum photon field are sometimes called occupation numbers. However, there is no analogous quantity for the quantum states of a massive system ... you cannot build up a classical "field" from the quantum descriptions of electrons (or neutrons) in the same way. For one thing, photons are bosons, so there is no limit on the number of photons that can be added to a single quantum state. Electrons (and neutrons) are fermions, and such there can be no more than one particle per quantum state, so the idea of "occupation numbers", as applied to photons, doesn't make any sense. Furthermore, as I pointed out previously, in order for massive particles to diffract, the quantum numbers for their momentum states must not be in the "limit of large numbers". If they were, then the de Broglie wavelength would be small with respect to the size of the slit, and there would be no diffraction. With regard to your model for developing a phenomenological theory of electron diffraction, it is this feature of the experiments, the fact that the diffraction pattern depended on the momentum of the "mass flux", that would lead to the discovery of the de Broglie hypothesis, and therefore to quantum mechanics.
That's not an acceptable answer, because it is not at all clear which "modes" are you talking about? Please provide a complete description in terms of quantum mechanics. As I described above, the idea of multiple particles building up in the same "mode", as occurs with photons, is fundamentally impossible due to the Pauli exclusion principle.
Yes, and each time you have been wrong. Repeating yourself doesn't make it any less wrong. Furthermore, you have never provided the requested quantum mechanical explanation for your answer, for the case of massive particles that we have been discussing.
Well, calling it nonsense doesn't make it nonsense, and my statement is completely within the mainstream of physics. So, what it made crystal clear is that you have, as I said, a deep-seated misunderstanding of quantum mechanics.
No, quite the contrary .. your post showed how well-justified that claim is. What is ridiculous is that you would claim that classical theories could explain the very features of the physical world that led to the discovery of quantum mechanics! I really have to insist that you provide some sort of literature reference to back up your preposterous claim.
  • #157
That is indeed a problem-- if the probability distributions are different. I wonder why chaos does that? What breaks the connection between the commutators and the Poisson bracket?
  • #158
DevilsAvocado said:
I
You want my opinion on local realism? I'm mor of an expert than Bell you think? I have no opinion different from the standard expectation that entanglement cannot be described by local realism.
My turn. Do you understand the difference between a classical limit that turns a particle into a bowling ball (say an ultra-high energy cosmic ray), and the one that turns a photon into a laser beam? I claim this is still your fundamental mistake in interpreting everything I've said.
  • #159
Take the Schroedinger equation, and take h->0 while interpreting every h/m as a constant equal to 2*v*lambda, where I explained how to get v and lambda in the experiment I described (that you still have not commented on, oddly).
I thought it was clear from the description I gave, but now it should be clearer still. The only wrinkle is having d/dt instead of d^2/dt^2, an interesting issue that might be worth discussion when you finally understand what I'm saying.
I never made the slightest claim that this was possible. Are you another one of these people who can't tell the difference between the logic of "classical analogs are often easy to find and useful when you can" and "there always has to be a classical analog of everything or what I'm saying is wrong." Read those two phrases as many times as it takes.
Incorrect, I simply don't see the fundamental difference there that you do. They both diffract, after all, and diffraction is what we are talking about.
I'm still waiting to find out if you have the slightest idea what I'm saying about occupation numbers rather than energy per particle. You have not made one single remark that indicates you appreciate that difference.
You still haven't even understood what I'm saying, as I keep pointing out. Why have you not commented on the student experiment I described? Do you think a reference you can find will contradict what I said there?
Wrong again.
Are you serious? We were talking about chargeless electrons. You need a road map?
So now you think the mass of electron being what it is is decisive to your argument? I'm afraid that's ridiculous.
No, it shows I know the difference from when the numerical value of the mass matters, and when it cannot. This is your "refutation" of my argument?
You think they diffract differently in a way that is not contained in the v and lambda parameters that I carefully described? Please elaborate.
That's just silly. I explained a classical approach to getting a wave theory, it makes no difference if classical mechanics is in the background somewhere (as for sound waves) or if it isn't (as for neutron diffraction).
You still see no significance in the difference between one particle with lots of energy, and a huge ensemble of particles with low energy? Not one of your remarks is germane to that distinction,
I gave a prescription for finding the classical theory, both experimentally and theoretically. And by Bohr's logic, it must agree with the quantum theory. I'd call that a pretty obvious example of the correspondence principle, and I've been quite clear that is what I have been talking about all along.
And I pointed out I'm well aware of that. That was the whole "particle turning into a bowling ball" business. You just read past that?
Modes are sectors in phase space. All we need is enough occupation in each to generate a classical theory, via coarse-graining. Like all classical wave theories.
Let me conclude. You still think Bohr would change the correspondence principle if he knew about neutron diffraction? What aspect of it do you think he didn't know about?
  • #160
Oh, sorry for the misunderstanding. I was not referring zo chaos. In fact I do not know enough about chaos to make claims about it. The probability distributions already differ for simple systems like a common laser beam. Maybe this is easier to visualize in an extended explanation. In laser beams the fact that the measurement of a photon destroys it, is countered by the intrinsic noise properties of the laser beam such that the detection of a photon does not alter the statistical tendency to detect another one which is the classical limit that a measurement does not change the measured state. Mathematically speaking this means that for a light field of mean photon number \langle n \rangle and momentary fluctuations \Delta n you want the expectation value
\frac{\langle n (n-1) \rangle}{\langle n \rangle^2}=\frac{\langle (\langle n \rangle +\Delta n) (\langle n \rangle + \Delta n -1) \rangle}{\langle n \rangle^2} to be equal to one.
It turns out that the above reduces to
1-\frac{1}{\langle n \rangle} +\frac{\langle \Delta n\rangle^2}{\langle n \rangle^2}
which is one if \langle \Delta n\rangle^2 =\langle n\rangle
or in other words it is true if the probability distribution shows the same variance as a Poissonian distribution.
Now you can repeat that game and check what is the requirement for the quantum and classical distributions to coincide if you detect three instead of two photons. You will now find that it is necessary that the skewness of the quantum distribution is the same as that of a Poissonian distribution. For four photons the kurtosis must match and so on and so on. If you want to detect some arbitrary number of photons the distribution must be equal to a Poissonian one up the order that corresponds to the number of photons. To get full correspondence between the distributions this must hold up to arbitrary order. However any real system will have some limited (but probably extremely large) number of emitters and can therefore not fulfill this condition in some order. At this point the quantum and classical distributions and predictions start to differ. Usually this order will be on the same order as the mean photon number in a beam.
Of course one could call that nitpicking, but for example in optics any formulation of the correspondence principle will only hold for large photon numbers and also only for orders of the probability distribution that are small compared to that mean photon number. Of course not many people are interested in the, say 67th order of a distribution, but one should keep in mind that there are differences somewhere.
  • #161
First of all, I want to thank you for bringing your expertise to bear on this issue. But I'm not sure we are talking about exactly the same thing here, and I wish to learn more. I would have said that to have a correspondence principle, we do not need that expression to be exactly one, that would imply the two theories are identically the same in regard to expectation values at all orders. We only need the difference between that expression, and 1, to vanish uniformly as n gets large, for some given question we are asking (perhaps a given order of the probability distribution). That's what I would mean by "in the classical limit" for the purposes of that specific question. You are saying that no classical theory can be identical to a quantum theory to all orders, which I would expect to be true but isn't what should be considered a refutation of the correspondence principle. Granted, just exactly how we should frame the correspondence principle is very much at issue, and the discussion will likely lead to expansion of this idea.
Ah, that's the interesting point, you are saying that what is meant by the "classical limit" depends on what aspect of the probability distribution you are interested in. Point taken, but to me, that's just a clarification of the meaning of the classical limit, not a refutation of the correspondence principle. Generally speaking, a classical limit is not interested in arbitrarily high orders of the probability distribution, but you're right that it very much depends on what question we are asking.
Yes, I am perfectly willing to assert that no classical theory can be exactly the same as a quantum theory. Indeed, it is likely that such high orders of the probability distribution are exactly the kinds of considerations you'd need to get "spots" appear on the detector. Above I said that the appearance of spots is a fundamentally quantum phenomenon. This is natural, because that is what motivates the characterization as a "quantum" in the first place. So my prevailing point here is that we should give unto Caeser what is Caeser's (the fundamentally quantum phenomena like spots), but we should not give unto Caeser what is not rightfully his (the diffraction pattern). Certainly we view the quantum theory as the more fundamental, that also does not refute the CP-- the CP only says that a classical theory can answer the classical questions, and I've added to that that this is actually a useful thing to do to help us understand the more fundamental quantum theory. That sums up exactly what I'm saying here.
Let me summarize even more clearly, for it has been a long exchange and much of the disagreements have stemmed from the simple fact that I was not understood, which as we all know can waste a lot of bandwidth! I'm identifying what we might call a "classical theory", which uses classical notions like real-valued functions in space and time and classically aggregated measurements like energy and momentum fluxes, to predict the outcomes of experiments involving large ensembles of occupation numbers, which I stressed includes a concept of large enough phase-space density to be addressed by classical notions (though others on the thread have interpreted stictly as "large quantum numbers", but I'm saying that can also be viewed as a large occupation number of elementary excitations of some kind of internal quantized mode, though that is not the kind of limit I have been describing above). An important point about the classical theory is that is must never invoke a quantum of any kind, because that is the distinguishing element from a quantum theory, and the quantum theory uses different measurements like spots and coincidence counts (and internal degrees of freedom like spin, but we don't need to get into spin here, it's just another example of a realm of quantum topics that sometimes have useful classical analogs and sometimes don't).
OK, given this, what I'm fundamentally saying is that the correspondence principle asserts a logical consistency between quantum and classical theories, such that the projection of the quantum theory onto the classical measurables must generate a classical theory that could have itself described those measurables in the classical limit. Also, if we already have a working classical theory on those measurables, then any more fundamental quantum theory must have a structure that, when taken to the classical limit, is consistent with the classical theory. That is just precisely how I characterized "the correspondence principle" above, and I think pretty well encapsulates the logical content of what Bohr had in mind. So in this light, we see that if the quantum theory ever disagreed with the classical theory in the classical limit, we could not say "that's quantum for you", we'd be forced to say "one or the other of these theories must be replaced."
Then I made a few claims about this logical connection. I said that it is just an accident of history in each particular context whether the quantum theory or the classical theory was discovered first. We all know that classical theories are not thrown out, because they still work fine in the classical domain. In particular, photon diffraction was first studied as a classical phenomenon, and electron and neutron diffraction were first studied as a quantum phenomenon. Others on this thread seemed to think this has fundamentally something to do with their masses, but my point is that there is no reason we can't imagine the classical work first being done on electron and neutron diffraction, and the quantum work first being done on photons-- it actually has nothing at all to do with their masses, it's just how history went. Given all this, the real over-arching point is, classical analogs are very useful to keep track of, even in quantum theories, and many people seem to over-stress the "weirdness" of topics that are actually not considered weird in the classical theory-- so the true "quantum weirdness" is not that the phenomena show up in a theory, it's simply that we did not expect them to show up in a quantum theory, owing to certain prejudices we have about how quanta "should" behave based on our experiences with bowling balls.
Now that I've summarized what I have been saying above, I'm quite interested in your take. I think it is fair to say that none of the above detractors of this idea ever understood that this is what I was saying, so essentially none of their objections were relevant, though some interesting points did come up and I expect some more will too.
  • #162
Again, that's not a proof, a demonstration, or an equation .. it's just a mathematically vague recipe. Furthermore, to me it sure looks like if I follow your recipe, I will end up in the limit of lambda=0, which I agree is the correct classical limit, but of course there would be no diffraction in that limit. If you mean something else, then please write down the mathematical derivation you describe, along with the result that you claim can describe electron (or neutron) diffraction in the classical limit. Or provide a reference that supports your claims.
I haven't commented much on the experiment you describe, because it isn't very helpful to the discussion as you have described it. You have given vague ideas which assume the existence of measurement techniques where it is not at all clear that such techniques exist. For example, you just assume that the speed of the "waves" will be clear to the experimenter ... really? How will they get that information? In order to measure the speed of the waves, you need to be able to resolve the peaks and valleys of the waveform. How is that done in your experiment? How do you propose to measure the momentum of the "classical waves"? You also talk about measuring the energy flux .. how will that be done? The lack of those details makes the description you have provided basically useless .. you just assume that all of the quantities you need can be clearly defined and measured "in the classical limit", when it is not at all clear how that can be done without using devices that are based on understanding the underlying quantum mechanical principles in play. The only facet of this experiment that is at all clear is that an interference pattern *could* be observed under the right source conditions (i.e. monoenergetic beam, with the energy selected such that the wavelength of the particles is of the same order as the slit width), but that relies on a quantum mechanical description of the diffraction phenomena (i.e. that the massive particles have a wavelength).
Good lord .. you think that's a *wrinkle*? That's like saying that the distinction between velocity and acceleration is a *wrinkle*. The significance of the different orders of the time derivative is fundamental .. it means that quantum probability distributions have time-evolutions that are analogous to diffusion, rather than wave-propagation. This is not a *wrinkle* that can somehow be finessed away.
You certainly did claim that it was possible ... your claim that you can explain electron diffraction "in the classical limit" is identical to my statement. That is the fundamental misunderstanding that persist in proffering on this thread, and it is getting very tiresome. You are not making claims that are supported by mainstream physics .. I doubt anyone is following this right now, but this thread will be maintained as a permanent record for as long as PF exists, and it is important that your incorrect statements about the correspondence principle and quantum mechanics are not allowed to stand.
Right .. *you don't see the difference*, even though it does exist, and it is important. That is the source of your misunderstanding, as I identified umpteen posts ago.
[I put the section below in bold, because you appear to have missed it in my previous comments]
I already explained why "occupation numbers" don't make any sense for massive particles in the sense you are using them. There are no "occupation numbers" that pertain to particle number for massive particles, except in the case of exotic matter like BEC's which are not under discussion here. The only "occupation numbers" for massive particles are quantum numbers, which index the amount of energy (or momentum [EDIT] or other properties like angular momentum that are not directly relevant to this dicussion) carried by the particles, in the sense that they tell you [EDIT][STRIKE]how many[/STRIKE] which (and how many) quantum states are populated. That is why there is no other "version" of the correspondence principle that works in the manner you have described for massive particles.
In addition, I also gave another fundamental reason why occupation numbers are nonsensical for the particles we have been talking about (electrons and neutrons), since those particles are fermions, and thus are prohibited from occupying the same quantum states. Are you unfamiliar with the Pauli exclusion principle? Assuming you are not, please define "occupation numbers" for electrons (or neutrons) in a manner that is consistent with the PEP.
Well, you haven't said anything well-defined yet about that experiment, so it's hard to refute or support your claims.
Yes, they certainly do .. neutrons do not interact with matter in the same way as electrons do, and this has nothing to do with their wavelength of speed. Neutrons pass through matter much more readily than electrons do, thus you could not design a double slit for neutrons in the same way as for electrons. But that was not my main point, my main point is that you are injecting unnecessary confusion into the discussion by continually switching around the definitions of that particles we have been discussing. I can keep up with it (although it is irritating to have to do so), but a less experienced reader might get lost. That is why I have had to take the time to point out and correct every time you change the definitions of particles in your descriptions. The distinctions *are* important, even though you have not realized that yet.
Yes, it does ... the theory is only classical if obeys the assumptions of classical physics. As I pointed out before, the process you describe does NOT result in a classical theory .. it only results in a phenomenological model. For it to evolve into a classical theory, it would need to be consistent with the rest of classical physics, and also have predictive power about experiments carried out with "neutron fluxes" (or whatever you want to call them) under different experimental conditions. As I have also pointed out, investigation of the diffraction phenomenon we have been discussing would necessarily lead to the discovery of quantum mechanics, thus the phenomenological model you have proposed (assuming it would even be possible in the manner you describe), would ultimately result in a quantum theory. In fact, this is not so different from how quantum mechanics was developed in the first place, except for the (not insignificant) fact that the theory preceded the experiments in several important cases.
I see EVERY significance in that distinction .. it is YOU who appear to be saying that an equivalence can be drawn between the two cases via your *misapplication* of the correspondence principle. Think about what you just wrote ... then think about the photoelectric effect ... do you see why I am bringing this up?
That's nonsensical post-rationalization. You yourself have said that there are quantum phenomena and theories that have no classical analogs. What you have yet to realize is that diffraction phenomena for massive particles is an important example of that case.
I don't know what to say .. you say you are aware of it, but then you demonstrate that you don't understand it's significance. That's why I keep bringing it up .. to try to get you to realize that it is the fundamental distinction you have been missing, and the reason why you cannot draw parallels between photon diffraction and electron diffraction in the manner you have been attempting to do.
Ok, I'll try this in your jargon ... what does it mean to increase the "occupation" for "sectors in phase space" for massive bodies? It does NOT have the same physical significance as increasing occupation for quantum field modes in the case of photons. There is no quantum number for massive particles corresponding to "occupation of sectors in phase space", so increasing the "occupation numbers" of such "modes" does not bring you into the limit where the correspondence principle applies.
Where did that question come from? Of course he wouldn't .. as I have said, there is no issue with the correspondence principle .. it just can't be applied to get a classical theory of neutron diffraction. Bohr would never have claimed that it could. Actually, perhaps I now see where another facet of your misunderstanding stems from. What the correspondence principle actually says, is that classical physical theories emerge naturally from quantum theories in the limit of large quantum numbers. It does not say the reverse, which is the way you have been phrasing it. You have repeatedly said that the correspondence principle maintains that "every quantum theory spawns a classical theory that has to work in the classical limit", which is simply incorrect. There is a quantum theory of electron spin, what is the equivalent classical theory? There is a quantum theory for the photoelectric effect, what is the equivalent classical theory? There is a quantum theory for electron tunneling, what is the equivalent classical theory? There are no equivalent classical theories for those phenomena, because they are purely quantum phenomena. The same is true for electron diffraction, or diffraction of any other massive particles.
Anyway, I have wasted far too much time on this discussion, and I have allowed you to distract me from my far more interesting discussion with other PF members about the title issue of this thread. This will be my last post on the matter until you start providing better justifications for your claims, either in the form of detailed mathematical derivations, or literature references to support your statements. I would also again caution you about the PF rules against using these forums to put forth your personal theories about physics.
  • #163
This seems to be the crux of the issue-- whether or not someone with no knowledge of quantum mechanics and no invoking of any quantum particle could have explained electron (or neutron to avoid the charge issue) diffraction with a purely classical wave theory. You claim that would not have been possible, I claim that it would have been possible. Your argument requires that the mass of the particle be the thing that would make it impossible, because we certainly know it was possible with photons. Can we agree this is the crux of the disagreement? The rest is getting too long to wade through (I should comment, it was DevilsAvocado who made the claim about Bohr, not you, I mistakenly crossed those arguments but apparently I am not facing such a "unified front" of counterargument since you three don't always agree with each other about the correspondence principle).
I'm awaiting Cthugha's take on whether or not the mass of a particle makes it impossible to create a working classical theory of its diffraction, which is the crux of our disagrement. I find your argument there totally unconvincing.
I did miss this statement in your earlier remarks, and yes, this is the crux of the issue-- is there a "classical limit" that refers to occupation number, which in the classical limit is a concept of "phase space density." So we must ask ourselves, does the correspondence principle apply to a concept of a classical limit in phase-space density? You say emphatically no, I say yes, this is one of the most important places we find the correspondence principle. As I am well aware of the Pauli exclusion principle, the occupation number I refer to (as I mentioned) is a classical limit in the occupation in physically resolvable (coarse-grained) cells in phase space. So is there, or is there not, a "classical limit" in phase-space density, and is this relevant to the correspondence principle?
I point out that if the answer to that is "yes there is such a classical limit", then essentially every single thing you have said in this entire thread is irrelevant to anything I am talking about, which is just exactly my contention here.
  • #164
Ok .. that was actually very useful for narrowing down the source of our disagreement, so I will make one more post in response to this point. With regard to your latest question, of course there is no classical limit on the phase space density. Think about what you are asking for ... you are asking for phase space to be *quantized*? How can that arise in a classical context? In phase space, each configuration of the system corresponds to a point in phase space, which is continuous in every dimension, hence since there are an infinite number of points in any finite region of phase space, the classical phase space density can increase to infinity.
To come at it from another angle ... what do you think the HUP *is*? It is the *quantum* limit on the phase space density, which classical theories tell us is infinitely divisible. That is why Planck's constant is sometimes said (generally in pop physics books) to specify "the fundamental graininess of space-time". This is what I have been saying all along. If you try to develop a theory along classical lines that involves phenomena occurring where this limit on the phase space density matters, then you will UNAVOIDABLY end up developing a quantum mechanical theory ... or else an incorrect theory, I suppose.
If you won't believe me, perhaps you will believe another PF Science Advisor, Bill_K, who says precisely the same thing on https://www.physicsforums.com/showthread.php?t=489484" (it is the 3rd link that comes up if you google "phase space density quantum mechanics").
Here is another result from google searching: http://www.ysfine.com/home/book91.html
Finally, here is a wikipedia link that also supports what I am saying: http://en.wikipedia.org/wiki/Wigner_quasi-probability_distribution#Relation_to_classical_mechanics.
  • #165
Not quite, I'm asking it to be coarse-grained. That's a perfectly routine concept in hydrodynamics. Even plasma physics has a concept of "occupation number", in some sense-- the number of particles in the DeBye sphere. It is natural for a distribution of particles to have some natural scale, such that when you get many particles in that scale, you have a kind of thermodynamic limit. Part of the problem is terms like "classical"-- what does that really mean, that the Greeks did it, that Newton did it, that it isn't quantum mechanics? All I mean by the term is that you start to see physics where you do not need to know there are any particles there. Much like the equations of MHD plasma physics or thermodynamics or hydrodynamics, all things I would call "classical theories" simply because none of the equations of the theory invoke particles. Deriving certain terms in the equations can invoke microphysics, but these can also be set experimentally, as I described in the "student experiment" I was talking about.
I hope I've made it clear that a "fluid average" in the reduced phase space used in both fluid and wave mechanics (where you are essentially manipulating moments rather than particles) is actually quite routine, not a problem.
It is the quantum origin of the reason that classical wave mechanics works. That's your answer in "correspondence principle language."
And that has nothing to do with what I'm talking about, as I've said, because I am talking about the classical limit of that same quantum mechanical theory.
What you are not getting is that the issue here is not that I don't believe you, indeed I already know almost everything you say. It is that it is not relevant to what I'm saying. How do turn "what you're saying is not understanding what I'm saying" into "I don't believe you"?
None of the links you gave adjudicate our discussion in any way, they only adjudicate wrong things that you think I am saying, that I have repeated over and over I am not saying. For one thing, I understand the HUP just fine. Wigner distributions I don't know much about, but from what I can see, they completely support what I am saying-- that there is value in considering classical analogs to quantum mechanics, not because it's the same thing, but because it can be instructive to do so, and can help dissipate some of the "quantum weirdness" by understanding things in a more classical way.
  • #166
Here are some more papers about applying the correspondence principle in phase space:
http://iopscience.iop.org/1367-2630/11/1/013014/fulltext#nj293180s2
On the correspondence principle: implications from a study of the nonlinear dynamics of a macroscopic quantum device
abstract:
The recovery of classical nonlinear and chaotic dynamics from quantum systems has long been a subject of interest. Furthermore, recent work indicates that quantum chaos may well be significant in quantum information processing. In this paper, we discuss the quantum to classical crossover of a superconducting quantum interference device (SQUID) ring. Such devices comprise a thick superconducting loop enclosing a Josephson weak link and are currently strong candidates for many applications in quantum technologies. The weak link brings with it a nonlinearity such that semiclassical models of this system can exhibit nonlinear and chaotic dynamics. For many similar systems an application of the correspondence principle together with the inclusion of environmental degrees of freedom through a quantum trajectories approach can be used to effectively recover classical dynamics. Here we show (i) that the standard expression of the correspondence principle is incompatible with the ring Hamiltonian and we present a more pragmatic and general expression which finds application here and (ii) that practical limitations to circuit parameters of the SQUID ring prevent arbitrarily accurate recovery of classical nonlinear dynamics.
and
http://onlinelibrary.wiley.com/doi/10.1002/9783527610853.ch27/summary
The Bohr-Heisenberg Correspondence Principle Viewed from Phase Space
abstract:
Phase-space representations play an increasingly important role in several branches of physics. Here, we review the author's studies of the Bohr-Heisenberg correspondence principle within the Weyl-Wigner phase-space representation. The analysis leads to refined correspondence rules that can be successfully used far away from the classical limit considered by Bohr and Heisenberg.
These underscore the value of classical analogs, though again we find that there are some problems in getting quantum chaos to agree with classical chaos. I interpret that as being because generally the classical limit is successful at recovering lower-order structures (like diffraction patterns) rather than high-order structures (like spots), and this fact is confounded by the sensitivity to initial conditions found in chaotic systems. The main objection we saw above seemed to center on the idea that diffraction patterns had to be inherently quantum effects when seen in particles with mass, but not in particles with no mass, and to be quite honest, I still haven't the slightest idea why those detractors believed that, so I can't really comment on it further.
  • #167
GREAT – an expert – wow!
I was real worried there for awhile... on the other hand, the rest of your posts doesn’t directly save your a*s when it comes to crackpotery.
One of your major preposterous claims: "Every quantum theory spawns a classical theory that has to work in the classical limit"
Now, I do hope you realize that Local Realism is a significant feature of classical mechanics? And that you’ve just admitted that quantum mechanics rejects this principle due to the theory of distant quantum entanglements...
Get the picture?
I guess you know who Erwin Schrödinger is, and what the Schrödinger equation mean to QM??
Erwin Schrödinger coin the word Verschränkung (translated by himself as Entanglement): "to describe the correlations between two particles that interact and then separate, as in the EPR experiment", and in the paper defining and discussing the notion of "entanglement" he recognized the importance of the concept, and stated:
"I would not call [entanglement] one but rather the characteristic trait of quantum mechanics, the one that enforces its entire departure from classical lines of thought."
There’s not much to add after this, is it...? :-p
*The* characteristic trait of quantum mechanics, the one that enforces its *entire departure* from classical lines of thought.
I hope you realize that you have to run over both Erwin Schrödinger, and the most fundamental concept in the theory of QM, to still make any claim of this cranky delusion of yours: "Every quantum theory spawns a classical theory that has to work in the classical limit"
The theory of quantum entanglement does not work at all in any "classical limit", and it proves that Local Realism, a significant feature of classical mechanics, does not work in QM theory, interpretations or any performed experiment this far. The theory of QM + Bell's inequality + thousands of Bell test experiments has once and for all proven that the concept of Local Realism cannot be applied to QM, period.
Unless you widely expand your cranky thoughts and make "enough-to-get-permanently-banned" statements that – YOU are right and QM is wrong – you lose buddy!
I would absolutely recommend any layman to generally completely ignore all of your homemade nonsense regarding the "law of nature", and particularly your distorted an twisted lies about Niels Bohr and the Correspondence principle, because your 'homemade version' is all false from the beginning, period.
You are the worst kind when it comes to crackpotery. Clever enough to fool any layman, and even some professionals (to begin with), and dishonest enough to not clearly spell it out what you’re really aiming for, and then accusing people who "don’t understand" for being dumb and not clever enough to see this "beautiful theory of yours" – when the whole point is to type as much nonsense as possible to create complete confusion – of course delicately mixed with your personal crackpot "theory". As long as you’re able to dump these cranky ideas of yours – is everything is fine.
You start with this very 'friendly attitude' of being on a 'voluntary quest' of 'helping' poor laymen to more easily understand the "wonders of QM" by making classical analogies. And in the spirit of this wonderful quest you state – "many quantum effects do have classical analogs" – which sounds pretty harmless. And of course, you do not explain for the poor and dumb layman that "analogies" and scientific proofs are two completely different things.
Then you move one step further and state – "every quantum theory spawns a classical theory" – which start to sound like a proof of something, but you (deliberately) 'fail' to explain exactly what this mean, and how it works, and last but not least – you are just mumbling a lot of words without any references and equations to backup this 'revolutionary' thesis of yours.
The next step is to conclude the "obvious" – (your version of) the correspondence principle is a law of nature!
Wow! This is crackpotery in the higher dimension! Watch and learn folks, Ken G might soon be permanently banned...
Now, when users like SpectraCat tries to debate these claims of yours, you jump swift and easy between these different "levels of complete nonsense" to create even more confusion. Sometime you’re just trying "to help laymen understand", next you have something fundamental to say about quantum theory, and shortly after that you have a philosophical "law of nature", without any math whatsoever. The nearest any of kind of "proof" we ever get, is your brilliant circus trick to pretend and then – "poof" – everything works!
This is 'hilarious'.
No wonder SpectraCat gives up. This can’t be discussed in ordinary terms – because there is nothing to discuss, and you utilize every smokescreens available to hide this fact.
You’re crackpot, educated, but still a crackpot.
Things get real nasty when you, without hesitating, enter the next level in "crackpot heaven", and provide clear signs of developing a 'theory' of your own??
"How we should frame the correspondence principle"? "lead to expansion of this idea"?
And after this PF Guidelines violation, comes GRAND FINALE:
WTF is this?
You must seriously overestimate your 'fiddling artistry'... We all know that you have been deep fishing for some totally crazy version of "Classical QM", and now you spell it right out in the open??!?
READ https://www.physicsforums.com/showthread.php?t=414380" FOR GOD’S SAKE!
Well, patently absurd is not a bad summarization of the BS you produced in this thread lately, no bad at all. We all know very well that Niels Bohr wasn’t an idiot, he was a genius. Sadly, this characterization is more uncertain when it comes to others in this discussion.
Niels Bohr and Albert Einstein were the two monumental giants of their time, both very bright and genius. But they were not "Gods" – they were humans and both made mistakes (as all humans do). They will always be remembered in the history of science.
I have given you pretty harsh critics in this post, and that partly because I now know that you are deliberately exploiting and twisting the great work of Niels Bohr – for your own purpose.
Shame on you
There’s no secret that the 'experimental environment' was limited at the time; mainly scattering experiments like the Compton-Simon and Stern-Gerlach experiments in which the measurement result was established by ascertaining the direction in which a particle or a photon had been scattered. Furthermore, there where important transitions from the Old quantum theory to Quantum mechanics, and last but not least; Einstein challenged Bohr constantly since he was 'unsatisfied' with the path on which QM had taken after 1925. The famous Bohr–Einstein debates lasted for several decades and culminated in 1935 with the EPR paradox, which forced Bohr to reformulate his Correspondence principle. The philosophical (or epistemological) debate between Bohr & Einstein was never settled. In 1955 the world lost one of the greatest geniuses of all time, Albert Einstein, and in 1962 the other scientific giant Niels Bohr died. None of them ever knew that the EPR paradox could be solved mathematically and proved experimentally, since Bell's inequality was published first in 1964 by John Stewart Bell.
Niels Bohr & Albert Einstein in 1925
In point 3 you show that you know there has been more than one version of the Correspondence principle. The truth is there have been three (3!) versions:
  • Correspondence in the Old quantum theory
  • Weak form of the correspondence principle
  • Strong form of the correspondence principle
Correspondence in the Old quantum theory was applied during the developing stages of quantum physics preceding the conception of quantum mechanics (i.e. before 1925); it implies that in dealing with quantized systems classical relations are preserved as much as possible. Note that the correspondence approach in the Old quantum theory has given rise to the http://en.wikipedia.org/wiki/BKS_theory" which turned out to be in disagreement with experiment, and therefore was a blind alley in the development of quantum physics. Also note that BKS sticks to a classical wave description of the electromagnetic field, which failed.
Weak form of the correspondence principle implies the expectation that if quantum mechanics is applied to larger and larger objects the quantum mechanical description finally will coincide with that of classical mechanics, it coincides with the belief that classical mechanics is the 'classical limit' of quantum mechanics (h → 0). I.e. this is the version that YOU for some nutty reason refer to as the last and valid version...? WHY?? :eek:
Strong form of the correspondence principle is switching from the 'relation with classical mechanics' to the 'relation with the measurement arrangement'. Compared to earlier versions the notion of 'correspondence' changed in several ways:
  1. Does not rely on the 'classical limit of quantum mechanics'.
  2. Is stressing the 'importance of the experimental arrangement' in establishing the physical meaning of a 'quantum mechanical observable'.
  3. Is pointing to the difference between quantum mechanics and classical mechanics rather than to their similarity, the difference being established by the notion of 'incompatibility of quantum mechanical observables'.
The final conclusion of all this cranky excess is that the one who will make Niels Bohr, not only roll over in his grave, but also throw up at the same time is YOU, Ken G.
To sum it up for any layman still lurking in this thread:
  • #168
(Now I know who will get my vote on next PF Best Humor Award. You are worthy of that Prize!)
... if this continue there’s definitely need for action ...
  • #169
This comment is a waste of bandwidth, as it is pure rhetoric with zero logical content.
I'm afraid this is very poor logic on your part, because the correspondence principle certainly allows local realism to appear in the classical limit, and you have not argued that it doesn't, which is an obvious logical requirement of your argument. I trust you can see that, it's quite simple really. Or can you now tell us a quantum theory that does not obey local realism in the classical limit? I think you might get a Nobel prize if you can show that a classical limit of a quantum theory can disobey local realism, because then we can all stop wasting our time with difficult quantum experiments and coincidence counting, because from now on we can get violations of local realism in classical experiments. But I predict you will fail in this most simplest of requirements to support your claim.
Get the picture?
All too well-- which is why I have pointed out the holes in your logic.
Other interesting features in your post is I noticed you did not recant your preposterous claim that Bohr would not have been able to hold his correspondence principle had he known about electron and neutron diffraction, which of course he did know about. The rest of your post, as usual, was a criticism of some make-believe stance that you think I purported, but is just a cartoon caricature of what I actually said, so is pointless to refute. In particular, your "Grand Finale" missed completely the meaning of the very quote you bolded. I'd blame myself if I hadn't taken pains to spell it out so clearly, yet still you manage to see something different than what the words actually say: if a quantum theory and a classical theory made different predictions in the classical limit, one or the other would have to be replaced (for the simple reason that they couldn't both agree with experiment, obviously). Why you don't understand that I really can't guess.
  • #170
  • #171
I'm afraid that's the last refuge of someone who has not been able to present a logically correct argument. Here's the bottom line folks:
It is a fundamentally internally inconsistent argument to claim that diffraction is a strictly quantum phenomenon with no classical analog for several reasons:
1) photon diffraction was initially discovered, and described satisfactorily, purely classically, so to hold the above claim requires that one restrict it to saying that only the diffraction of particles with mass is a strictly quantum phenomenon. No one has presented or even justified that argument on this thread. Logical hole #1 in the claim.
2) the way particle diffraction is normally described as "strictly quantum" is by referencing the de Broglie wavelength, which is a strictly quantum mechanical entity but only if you correctly follow its logic: the deBroglie wavelength is a mapping from the wavelike attributes to the particlelike attributes when one needs to invoke wave/particle duality, but when does not need to invoke that (as for photon diffraction in a classical limit of a large ensemble), then the wavelength is still purely classical, and no quantum elements appear at all. In other words, de Broglie wavelength can be perfectly well viewed as a map from the classical-wave concept of wavelength to the quantum mechanical concept of particle momentum, rather than the other way around. The irony here is that only by referencing a classical stalwart, the concept of wavelength, is the argument even made that diffraction is strictly quantum in nature! Logical hole #2 in the claim.
3) If the claim is made that diffraction (of only the particles with mass, apparently) is a "strictly quantum" phenomenon, it behooves the claimant to suggest what it is about diffraction that jumps up and says "I'm a quantum." Saying "it comes from the Schroedinger equation" just doesn't cut it, because 100 years ago it "came from Maxwell's equations," and 100 years from now, it might "come from string theory" or from the "holographic field", who knows what. Logical hole #3.
In short, the claim that diffraction is a "strictly quantum phenomenon" is the only claim here that is not even wrong. Frankly, it's a failure to even understand what physics is. The actual truth of the situation is nicely described by the general logic of the correspondence principle: every time we come up with a more fundamental theory, it must agree with the previously successful but less fundamental theory in the domain of applicability of that previous theory. This implies two things:
1) the previous theory supplies constraints on the new theory
2) concepts from the previous theory may be already understood, and form a useful basis for understanding the concepts in the new theory that they are the analogs of.
That, my friends, is the point of the correspondence principle, as I have been saying all along. I will blame the faulty logic in the objections presented above on the difficulties of being heard and the ambiguities in the meaning of "the correspondence principle", as there certainly are plenty of ways to hear what I am saying differently than what I actually did say, and I think we saw almost every possible misconstrual that can be imagined in the above. Communication is always the hardest thing, but hopefully this simple summary makes it clear both what I am saying, and the flaws in the objections to what I am saying. Let that set the record straight, as concern was voiced for lurkers who might somehow be led astray by the "crackpottery" of my actually logically bulletproof position. Who knows, maybe even my detractors above will learn something if they can get themselves out of the way and actually listen to what I said.
  • #172
Ken G said:
It is a fundamentally internally inconsistent argument to claim that diffraction is a strictly quantum phenomenon with no classical analog ...
Nobody ever claimed that. YOU claimed in post #113 that, "There certainly is a classical explanation for the diffraction of electrons! It is called "wave mechanics", and it applies to a classical ensemble of electrons (and yes, it came as a large surprise that it applied, but it is still a perfectly classical version)." That claim is inconsistent with mainstream physics, and you have proved unable to provide either a mathematical derivation, or a literature reference to support it. Therefore it is a personal theory of yours.
1) ... the diffraction of particles with mass is a strictly quantum phenomenon. No one has presented or even justified that argument on this thread. Logical hole #1 in the claim.
Wrong. The claim that diffraction of massive particles is an exclusively quantum phenomenon has been explained and justified many times .. you either fail or refuse to understand it, and insist on promoting your personal mis-interpretations of both QM and the correspondence principle. This is the last reminder I will give you that PF explicitly forbids such actions.
That is a complete mis-interpretation of everything I have posted in regard to this question. No one has ever contested that there is an ANALOGY between wave-like behavior at the quantum and classical levels. This discussion is not about philosophical similarities between concepts, it is about physics. The PHYSICAL definition of the correspondence principle is completely irrelevant to the quantum-classical ANALOGY you are drawing. For example, QM tells us that individual water molecules can be made to diffract under the correct circumstances ... your version of the correspondence principle would apparently allow us to then derive classical descriptions of water waves by taking the classical limit of the quantum phenomenon. That is of course, complete nonsense. The point is that your specious arguments about classical descriptions of wave phenomena in plasmas (or whatever classical description of "continuous charge flux" you have been trying to define) being connected to electron diffraction involve the same MIS-application of the correspondence principle as my example above.
That is another false statement to add to the pile. Schrodinger's equation (and QM in general) was developed explicitly to explain such physical phenomena as diffraction of massive particles, specifically because there was no classical explanation for them. The thing that says "I'm a quantum" is the very fact that classically, there is no way for particles to diffract, because they have no wave character, and classically diffraction is a phenomenon restricted to waves. It is staggering that you refuse to acknowledge that, while still purporting to be expert enough in the area of physics to advise others about "the true meaning and value of the correspondence principle", or whatever it is that you have been going on about.
No .. that is a vague philosophical statement .. it is not the point of the PHYSICAL definition of the correspondence principle used in the context of quantum theory. Concepts that are ANALOGOUS between quantum and classical physics may or may not have a direct physical relationship (often they do not). Do the harmonic modes of a vibrating string have any direct relation to the states of a 1-D infinite square well? Of course they don't, and although the ANALOGY is useful pedagogically, it is completely unrelated to the correspondence principle. Bohr's correspondence principle is much more strictly defined. You would benefit from reading what the Stanford Encyclopedia of Philosophy has to say on the subject. In any case, the Bohr correspondence principle most assuredly does NOT say, (as you claimed in post #121) "any quantum theory gives birth to a classical theory in the limit of large occupation numbers". The issues with that statement have been pointed out to you by myself and by DevilsAvocado, but you have dismissed them without apparently understanding them. Also, you have failed to appreciate the distinction between occupation numbers and quantum numbers, although that has been explained to you more than once. It may be possible to draw a meaningful mathematical relationship between the the concepts of quantum numbers and "occupation numbers for sectors of phase space", but I have not seen it done. This is another facet of your personal theory for which you have failed to provide either a mathematical derivation, or a literature reference.
In any case, the bottom line is this: While there is no doubt that ANALOGIES can be drawn between different diffraction phenomena arising from quantum or classical theories, mainstream physics tells us that in the limit of large quantum numbers, the wave-like character of massive particles must disappear. Since diffraction phenomena are uniquely associated with wave-like character, the statement that "electron diffraction cannot be accounted for by a classical theory", is completely consistent with mainstream physics, and in fact is the logical conclusion drawn from the proper application of the Bohr correspondence principle. If you continue to claim otherwise without any literature references to support that claim, then you are just continuing to promote your own personal theory, in clear violation of PF guidelines.
  • #173
Then you didn't look at those papers I cited? There's a whole field of study called "scalar diffraction theory", it's all perfectly classical. Oh and yes, it has been applied to neutrons and electron diffraction, it's just that many times the quantum mechanics is all you need, and is more generally applicable. That's what I mean by the "accident of history"-- had neutron and electron diffraction been known about in 1880, instead of the 1930s, it would have been more important.
Actually, you have never once gave a single reason why you think only the diffraction of massless particles is classically describable, but that the diffraction of neutrons has no classical analog. Would you like to take that opportunity right now? Because I have no idea why you think that.
Excellent, then you actually agree with my central thesis all along (would you like to count the number of times I used the word "analog" in this thread?). I'm glad to discover this, I can then disregard all your objections to it because you apparently agree with it.
Many things get called the correspondence principle. I've been painstakingly clear about the meaning I've taken. I'm glad to find that if you just take my meaning, you agree with me.
Let's apply your exact argument to photons. You're saying that if each photon has a lot of energy, then they won't diffract. No kidding! The correspondence principle applied to bright radiation fields is a theory that describes the diffraction of classical concepts like the Poynting flux. Which, by the way, has nothing at all to do with the energy per photon, as I"ve told you about a hundred times.
  • #174
I just want to withdraw a statement I made above that Ken G has a good understanding of QM. I read a few discussions that were on an elementary level which misled me.
  • #175
Strange, but I feel inclined to show you this equation derived as the energy of a shift between two planes of negative and positive solutions:
\Delta E \Psi= \sum_{i}^{\theta} M_{0i} \phi (\Lambda^{-1} x) \psi_i
based on a non-negligable, solutions for \phi', the shifted function.
you said
''had neutron and electron diffraction been known about in 1880, instead of the 1930s, it would have been more important.''
The equation also predicts accordingly the energy resolutions in \phi to allow a geometry of 180^o. Meaning the diffraction of light of a mirror, is predicted by this equation.
  • #176
but I should add, that at least Ken G makes arguments which are understandable and (thus) debateable, unlike Goldstone1 above^^
  • #177
Actually, nothing in this thread has anything to do with my understanding of QM, which is actually just fine thank you. This thread is all about classical analogs of QM, which has to do with other approaches to understanding similar concepts (like diffraction). I'm not even sure you quite understand how physics works in the first place, so let's start at the beginning.
In physics, we do observations, see phenomena that seem strange-- whether it be acceleration, diffraction, or entanglement. We then design theories to help us understand and predict. At what point do those theories take ownership of the observed phenomena, such that we could correctly say that phenomena is "strictly classical" or "strictly quantum mechanical" or "strictly field theoretic?" Never. At no time do those claims make any sense at all, because the phenomena are just phenomena, owned by themselves, not by any theory. Yes, theories can explain them to some degree, but all theories have their domains of applicability, like classical physics, like quantum mechanics. Eventually, a new theory comes along that is more fundamental, and everything that used to be "strictly classical" or "strictly quantum mechanical" is now not so strictly those things, because they never actually were in the first place.
This is the point of the correspondence principle, to understand the connections between these different theories and the observations they help understand, and why a phrase like "diffraction of particles that have mass is strictly quantum mechanical" is really just a mistake about how physics works. That you see it in many places is just because people get a bit lazy about it, but when you look at the endeavor of physics from a safe height, it's obvious what I'm saying here is true. Forest for the trees, I'm afraid.
  • #178
That is just a bunch of sophistry, obfuscation, and general gobbledy-gook. I doubt you have any idea what scalar diffraction theory is, and I doubt you read those papers you linked. I couldn't access the second one, but the first one provides strong support for the point of view I have expressed on this thread.
Also, please give a reference for your claim that CLASSICAL scalar diffraction theory has been applied to neutrons and electrons.
Your arrogance is exceeded only by your cluelessness. First, what I actually said was (post #114) "there is no explanation in all of classical physics (mechanics or electrodynamics) for the wave nature of electrons. There is no way to predict or model their wavelike properties using classical physics." In other words, you cannot use the correspondence principle to develop a classical theory of electron diffraction from the quantum theory in the limit of large quantum numbers. You kept confusing basic physical concepts (like distinguishing between photons, electrons and neutrons) and we eventually ended up talking about neutron diffraction. Second, I have explained the reasoning behind the correctly phrased version of that statement several times, in different contexts. I refuse to let your failures at reading comprehension prompt me to repeat myself again. If you really want to know, you should go back and carefully read and consider my earlier posts that you dismissed so casually.
That is just beyond the pale .. you do not get to roll your own version of the correspondence principle. If all you had done was claim that electron diffraction was ANALOGOUS to classical examples of diffraction, I would have agreed immediately and this whole ridiculous conversation would never have gotten off the ground. But you made multiple incorrect statements about physics, revealing a fundamental lack of understanding of (at least) the basic principles of quantum mechanics. I tried to help you see your mistakes, but your obtuseness kept you from understanding my explanations, and you just kept repeating (and occasionally compounding) your errors.
That's the general idea, but to avoid further confusion, I explain in more detail below how diffraction depends on photon energy, and on wavelength in general.
That sentence makes no sense as written ...
Yes, you have ... apparently because you enjoy repeating yourself, because I have never disagreed for the case of photons. We have been debating diffraction of massive particles, and the ANALOGY does not hold true, as I have explained (not just claimed) many times.
In order to avoid further confusion, let's make clear the general concepts of diffraction. Diffraction phenomena are most evident when the target has regularly spaced physical features, and the spacing of those features is on the same order as the wavelength of impinging wave. Thus for a given problem, normal diffraction phenomena occur only for a given range of wavelengths. If you make the wavelength too long, you still get some diffraction, but only in the near field where it decays exponentially with distance and thus is hard (but not impossible) to detect. If you make the wavelength too short, the diffraction phenomena get less and less evident, until they fall below the resolution and sensitivity of any measurement technique. So in the *theoretical sense*, if you keep increasing your photon energy arbitrarily, eventually it will reach the point where there will be no detectable diffraction (although I am not sure what that scale would be, certainly at wavelengths much smaller than an Angstrom). That is EXACTLY what happens for massive particles. As you increase the momentum, the de Broglie wavelength shrinks until it reaches the scale where it is so small that diffraction phenomena are undetectable .. that pretty much defines the classical limit for massive particles, which is what makes your claim that a theory of diffraction can be obtained in the classical limit so absurd.
Furthemore, your argument above about brightness is EXACTLY what I have been saying about why a classical theory of electron diffraction is not possible. If you increase the electron current without changing their energy, their wavelength stays the same. The only wavelength that can be associated with massive particles themselves is the de Broglie wavelength. Do you really think the de Broglie wavelength doesn't vanish in the classical limit? If you do, then you are really a crackpot and don't belong on these forums at all. If you don't think so, then please explain, with literature references, the physical origin of the wavelength that can cause electrons to diffract "in the classical limit". You have considered one sort of classical limit, as you claim to be doing by increasing the electron current until it is continuous (or whatever you meant by "large ensembles of electrons"), but you have not considered the other. If you are considering a classical limit for one property, but still allowing for quantum features in other properties, then you simply do not have a classical theory. In some cases, such a theory could be called "semi-classical", as is typical in fields like in my field of molecular spectroscopy, where we normally consider quantum states of massive particles interacting with classical EM fields. However, your treatment of electron diffraction doesn't even qualify as semi-classical in any sensible way, because the qualitative features of the theory don't change as you increase the electron current, you just build up the same pattern predicted by the quantum theory more quickly, except in the limit where space-charging causes inter-particle interactions to start affecting the results, as I mentioned ages ago.
  • #179
Well, as I've repeated many times by now, supporting things you said doesn't make any difference at all, because the vast majority of them had nothing whatsoever to do with what I said. For example, you've mentioned many times that high-energy particles don't show wave effects, which is perfectly obvious and I may have known that since longer than you've been alive for all I know, so is just another example of all the things you can claim "support" for that are totally irrelevant to anything I said.
Let's cut right to the heart of this. We all know that diffraction is a phenomenon that connects with interference, so it connects with a concept of phase and periodicity and propagation, so it connects with a concept of wavelength. That's just the nature of the phenomenon, whether classical or quantum mechanical or string theoretical. So if any time I note that neutrons diffract, you say "aha, neutrons are particles, so that's wave/particle duality, so that's quantum mechanics", then immediately you have just missed the boat entirely. I already know everything you've said in this thread, it is all irrelevant to the issue, which is this: there is nothing fundamentally quantum mechanical about the concept of either wavelength, or phase, or interference, or diffraction-- of a photon or a neutron or anything else. The only thing that makes it quantum mechanical is that for some set of questions we wish to know about, we need to use quantum mechanics. For other sets of questions, we might be able to invoke a classical understanding, and it is often an accident of history the actual order that these things get discovered. What the correspondence principle does, writ large, is insure that it is all right that we are subject to these accidents of history-- physics works even though we don't always start with the most fundamental theory, or even if there is no such thing. That's what I'm saying, that's the correspondence principle, and it also says that we can gain insights into more fundamental theories by looking for analogs from less fundamental theories, regardless of which historical order they came out. Not a single thing you've said contradicts that, nor was even relevant to that, I don't have any idea what you think I'm talking about.
An excellent example of what I am talking about is Bragg scattering. Discovered and explained with classical diffraction theory in 1913, it led to a Nobel prize. It was later found that Bragg's law also applied to neutrons and electrons, but by then we already had quantum mechanics. We also had the photoelectric effect well before Bragg, but Bragg didn't need it, he used a classical model anyway, even though it was known that photons were particles. "So what if photons are particles", he might have said, "I'm just using a classical theory to understand how light can probe crystals." Maxwell's equations didn't disappear when Shroedinger came around.
Now, from the above, we can conclude you are thinking "he's confusing photons with neutrons". No, I'm not, you just don't understand what I'm saying. Electron diffraction was discovered in 1927, neutron diffraction shortly afterward. To understand what I'm saying, you need to imagine that the photoelectric effect had not yet been discovered, nor Planck's law, nor any of quantum mechanics, yet we have Bragg scattering of X-rays in 1913, and electron diffraction in crystals. How would the edifice of physics handle this situation? Throw up its hands because it doesn't have quantum mechanics? No, absolutely not-- Bragg's law, a classical law, simply gets applied to neutrons and electrons, because it is seen to help understand diffraction in crystals! That would have been a simply classic example of applying a classical theory, with all its classical-wave analogs, to a problem that we now know is better treated with quantum mechanics. Did Bragg use the knowledge that light was made of photons? No, he would have done everything the same without a photoelectric effect by Einstein. And would he have generalized it to neutrons and electrons when it was found they diffract in crystals too? Certainly, it would have been the most obvious of all generalizations, even if he never knew that neutron beams can be resolved into individual quanta. This is all because of the correspondence principle, it's just how physics works.
Indeed, if you look at the Wiki on Bragg's Law, you find this quote:
"Bragg diffraction (also referred to as the Bragg formulation of X-ray diffraction) was first proposed by William Lawrence Bragg and William Henry Bragg in 1913 in response to their discovery that crystalline solids produced surprising patterns of reflected X-rays (in contrast to that of, say, a liquid). They found that these crystals, at certain specific wavelengths and incident angles, produced intense peaks of reflected radiation (known as Bragg peaks). The concept of Bragg diffraction applies equally to neutron diffraction and electron diffraction processes."
So now you are ready for what I've actually been saying all this time. Even if the accidents of history are such that we already have quantum mechanics when electron diffraction is found (and indeed anticipated), we can still benefit from that same classical analogy that we would have been forced to use had electron diffraction been discovered before quantum mechanics! All it says is we would recognize that the classical concept of wavelength was relevant to diffraction of an electron beam, and that would be true whether we knew the beam had particles in it, or even if we didn't know that. Whatever we know, we still find value in these analogs, over and over, and that is just exactly how the correspondence principle serves us constantly in physics. I can't say it any clearer than that.
The rest of your post is an ode to misunderstanding this point, so constitutes a bunch of physical facts I've known for a long time and have no bearing on this issue at all.
ETA: Perhaps some examples of how the logic of the correspondence principle is used routinely in physics would help where just explaining the idea didn't. Do you know how Shroedinger came up with his famous equation, the backbone of all those "strictly quantum" effects with "no classical analog" you keep talking about? I'll tell you. He constructed a wave equation that could tell a particle where to go, such that it would be consistent with a classical plane-wave solution. He reverse-engineered quantum mechanics right from it's classical analog! Do you know how people routinely visualize the shape of the wings of a resonance line? They imagine a classical harmonic oscillator in that atom, with a damping at a rate necessary to provide the scattered energy, and analyze the Fourier modes of the dynamics of that oscillator, and get the quantum mechanically correct lineshape. Examples of classical analogs just go on and on, the Zeeman effect, the quantum Hall effect (where do you think that one comes from?). And here's one of the most classical analogs of all time, the record-breaker: the "quantum Zeno effect." Yes, I'm afraid that classical analogs are vastly useful in many kinds of physics, but especially quantum mechanics-- but only for those who understand their value, and don't insist on seeing only a world of "strictly quantum" behavior. Which has been my point all along-- so basic, so necessary to physics, was this point that I was really surprised so many seemingly knowledgeable people had so little clue about it. Maybe you can get past your closedmindedness and see the potential of classical analogs, or maybe you just won't be able to avail yourself of them, but then my comments are for anyone who can.
  • #180
No ... you just can't understand what they have to do with what you said .. the difference is significant. On the other hand, I note that you have still not been able to support any of the contested claims that you have made.
... there is nothing fundamentally quantum mechanical about the concept of either wavelength, or phase, or interference, or diffraction--
fine up to here
Whoops, not fine anymore .. strictly speaking there is no classical physics context in which it makes sense to talk about particles like photons, electrons and neutrons *at all*, let alone the fact that massive bodies have wavelengths associated with them. Classical laws of physics treat space, time and matter as infinitely divisible, and as such there is no way in classical physics for massive bodies to have wave-like properties. Once you are talking about space (or phase space) as having a fundamental limit of divisibility, or about matter as consisting of discrete subatomic particles with associated wavelengths, then the concepts you are invoking are strictly quantum mechanical. These distinctions undeniably have historical origins, but they also have fundamental significance, and understanding them and applying them correctly is absolutely essential if you want to communicate effectively with physicists (which you apparently want to do, since you are here).
Whoops! What makes Bragg's law a *classical* law? Absolutely nothing .. it is a *physical* law describing wave phenomena that was simply first discovered in a classical context. It describes classical phenomena when applied to classical systems, and quantum phenomena when applied to quantum systems. The fact that it applies for diffraction of EM radiation described classically, as well for neutron and electron diffraction, has precisely ZERO to do with Bohr's principle about about quantum-classical correspondence. It may have great relevance in terms of Ken's correspondence principle of analogies, but that is not what I have been talking about ... ever.
On the other hand, Heisenberg's Uncertainty Principle is a *quantum law* of physics, in that it applies exclusively to the phenomena of quantum systems. The de Broglie wavelength is also a purely quantum concept. Both the HUP and the de Broglie wavelength may be ANALOGOUS to concepts found in classical physics, but the specific concepts don't themselves apply to classical physics. Can't you see the distinction there? It is NOT a purely semantic distinction, as you appear to believe.
Finally, since these are purely quantum concepts, the phenomena they predict (such as diffraction of massive bodies) must be "averaged out" in such a away that they are undetectable in the classical limit .. that is what is required by Bohr's principle of quantum-classical correspondence. Note that there is no such requirement that diffraction of massless photons be "averaged out" in the same fashion, because photons are just a way of counting up the population of the harmonic modes of the underlying field, which ends up having the same basic description in both (quantum) QED and (classical) E&M. So the quantum character of photons has nothing to do with the wavelength of the field, but only it's intensity, which means that the wave-like character persists even in the classical limit.
If you had said what you wrote in the quoted paragraph above in the first place, then I never would have disagreed with you. But you didn't say that, you made incorrect claims about physics, which I corrected. You refused to accept my corrections for a while, but if you now accept that I was right all along, and that you were wrong to claim (among other things, but this is the biggie) that it is possible to formulate a classical theory that can predict electron diffraction (which you did in post #113, and several times thereafter), then fantastic! We can finally put an end to this debacle.
If you want to use your fuzzy philosophical definition of the correspondence principle that is based in analogies, then fine .. feel free. Just be clear about it and don't confuse others by pretending that it is equivalent to the physical correspondence principle laid out by Bohr to help relate and distinguish quantum and classical theories.
You may have "known" the facts I have used to explain my arguments, but your posts make it quite obvious that you have never understood many of them in the proper context.
  • #181
Once again, you have gone off into left field, telling me perfectly obvious things that have nothing to do with what I said. I'm not saying you are stupid, you obviously aren't. There is just something blocking you from actually hearing what I'm saying, so you keep telling me things that any first-year student knows. It's irrelevant, what I'm saying is that Bragg did not need to know that light was quanta to get Bragg scattering, and he wouldn't have needed to know that electrons or neutrons were quanta to extend his classical insights to electron and neutron diffraction. He might not have obtained quantum mechanics, but he would have gotten insights into it-- classically. Or maybe he would have gotten quantum mechanics, using those insights, just as Schroedinger himself did.
I just don't know how else to get this across to you. Only after it was discovered that electrons and neutrons were particles, had the Braggs not known that (or just choosed not to use it, like they didn't use the knowledge with photons), could someone have taken adantage of the classical-wave analog to say "hey, we must have wave/particle duality here." Indeed, wave/particle duality itself, the cornerstone of what is "strictly quantum", is a perfect example of the value of classical analogs. So although you have gone on and on about wave/particle duality of electrons and how there can't be any useful classical analog there, the ultimate irony is: that is a classical analog, in that very language. Yes, it is, we are invoking a classical analog to understand quantum behavior, as is so extremely common in all of physics (consider the examples I gave above in that addendum to my last post, you might have missed it).
Of course there is, you just put it into a classical wave theory. You might not even know you are dealing with massive bodies, and do the classical physics anyway-- that was the point of that student experiment I mentioned. Physics has lots of different theories, and we will have a lot more. We might get a working string theory, we might unify gravity and quantum physics, we might understand what intelligence is, who knows. They'll all look a lot different from the previous theories, but the clever physicist will always look for the analogs from the previous theories, like classical analogs-- that's the correspondence principle. Read the whole thread again, realizing that this is what I have been saying, and recognizing that I know quantum mechanics, and I know classical mechanics, and I see the value of classical analogs-- and you can too.
There's that language again, that's just baloney. In Newton's day, did they say "acceleration is a strictly Newtonian concept" simply because they had F=ma and no one else had a theory to make sense of dynamics? Would we say today that acceleration is strictly Newtonian? Physical theories are just that-- theories. They never own the phenomena they describe-- never. There is no such thing as any phenomenon that is "strictly classical", or "strictly quantum", there are just concepts, and the concepts have analogs very often, and it's useful to know those analogs, because they help you understand the concepts, and they help you form the new theories. As they did for Bragg, as they did for Schroedinger, as they certainly did for Bohr.
Whoops? Are you kidding? Are you aware that Maxwell's equations are classical laws? Bragg's law is a consequence of Maxwell's equations applied to a regular lattice interacting with a classical E&M field. If your argument rests on the idea that Bragg's law was not obtained via classical reasoning, I think that sums up the quality of your argument.
Ah, so now we see that your argument rests solely on a tautology: you simply define electrons as quantum systems, so any law that electrons obey is automatically a quantum law, so there can be no correspondence to electron diffraction because electrons are doing it. Well, I can't argue against a tautology, but I can sure question its information content.
Which is exactly what I have been telling you all along. Nothing that you are talking about has anything to do with the point I raised, and clearly described, and told you that your comments were irrelevant to it, yet still somehow you thought you were proving me wrong.
Obviously, and again because of a semantic tautology: the HUP is a classical analog of how classical waves behave, applied, to our surprise, to particles-- but since it applies to particles, you get to label it a "quantum law"! And in so labeling, you miss my entire point: the HUP is a perfect example of the value of a classical analogy, the Fourier analysis of classical waves. As I said about a zillion posts ago.
Yes, again tautologically true, because you think what matters is the quantum label, not noticing that what actually matters about the de Broglie wavelength is the classical analog. That's why it is called a "wavelength" in the first place, it's invoking a classical analog that is of great value in understanding it. And like I said above, it does relate to a classical treatment in the limit of a huge ensemble of particles all with that deBroglie wavelength-- just as it did for Bragg's derivation of Bragg's law.
Well this is progress-- you now see that those "strictly QM" concepts benefit from classical analogs! That's what I've been saying, by the way-- just read the thread. Obviously they don't apply to classical physics in your mind, because you simply haven't yet taken the classical limit of lots and lots of particles, in which case they do apply to classical wave mechanics, which is why Bragg's law is useful for diffraction of beams of electrons and neutrons. That was the whole point of that "student experiment" I explained that I thought would make this all immediately clear.
Diffraction is undetectable in the classical limit? Then we must revoke the Bragg's Nobel prize, that's a pity. (Oh yes, once again you will think I mean the classical limit of large particle energies, though we all know that would eliminate the diffraction and I have said so many times I know that and I am talking about the limit that Bragg was actually involved in-- the limit of large particle fluxes, such that indeed there was no need to know there were even particles there to get Bragg's results. Read that again if needed.)
No, the reason you think it works for photons but not electrons is simply that a high quantum number for a photon field is the same as a high occupation number, so we have just one classical limit instead of two separate ones. I made perfectly clear which classical limit I'm talking about, whether photons or electrons-- the limit of large enough fluxes that you can measure them as classical energy fluxes, and use a classical wave theory to interpret that as Poynting flux. I don't know how many times I need to say that this is the classical limit I have been referring to in regard to the correspondence principle for both electrons and photons, just look back at that "student experiment" post again, if you can find it in all the misconstruals I've had to suffer.
I'm not sure why you would make such a false statement, that "the quantum character of photons has nothing to do with the wavelength of the field." I'm going to presume you had a momentary lapse and let that go, no doubt you will immediately see your error.
I tried very hard to tell you that your objections were not relevant to what I was saying. I thought I was being pretty clear-- the problem is that you still don't recognize a classical limit of high phase-space density, even after I explained exactly how purely classical experiments can be done on such systems, and how one can generally avoid invoking particle concepts, as is done in hydrodynamics, wave mechanics, and continuum mechanics of all kinds. I said all that, many times. Which finally brings us back to the OP-- the correspondence principle I was talking about, right from the very start, was about interpreting Bohmian trajectories in terms of large ensemble averages of weak measurements, and I claimed, and still do, that was tantamount to taking exactly the kind of "averaging out" classical-wave limit that we are just now talking about. That was the motivation right from the start.
No. There is not one single incorrect claim I made that isn't basically a technicality, like issues with quantum chaos. In every case, your "corrections" were telling me basic physics I've known for decades. Every time, you told me nothing I didn't already know, and it was always just plain irrelevant to the correspondence principle applied to ensemble averages of weak measurements.
We certainly see that Bragg's approach is purely classical and can be applied to electron diffraction. So that's a pretty good start. Whether we wish to count that as a "theory" is less clear, you may want more from it than just its ability to probe the structure of a lattice. There are many types of diffraction theories, and they all work to various degrees in different situations-- such is the nature of physics, we make idealizations to get somewhere. So we would not ask a classical theory of electron diffraction to do more than help us understand what is going on when we have large ensembles of diffracting electrons, and that's what Bragg's approach, and scalar diffraction theory in general, can do for us. It's just that we have quantum mechanics, so we only use classical concepts as analogs to help us understand the quantum mechanics, that is often the main point of classical analogs. Bragg's law is a perfect example of a classical analog helping us understand how electrons and neutrons diffract in a crystal.
Excellent, then we are actually in a position to get the whole point here: classical analogs are a useful way to understand phenomena that closedminded people tend to brand as "strictly quantum." And that was the whole point, in particular about using Poynting fluxes to understand streamline diagrams like the one in the OP.
Bohr's correspondence principle is itself a fuzzy philosophical rule, and it is the reason that physics is successful, in a nutshell. I'm sure Bohr understood that, but the point seems to have been rather lost to the years.
Correction, your interpretation of them made you believe that. It's just not true. For fear of making you think you completely wasted your time telling me things I already knew, the course of the discussion has helped me hone some of the stickier issues, and certainly has helped me see the areas that are most easily misconstrued. Really the only thing I said that I have not backed up is the extent to which quantum theories can be used to generate classical ones-- that remains a bit vague, though I think it's mostly that there just isn't much payoff for doing it when all one really wants is the classical analog concepts (and there is a nice payoff for those, like the Lorentz wings of a resonance line, like the Thomson cross section, like the concept of a "classical radius of the electron", the list just goes on and on). My real point is to look for classical analogs, which in the case of Bohmian trajectories may well just be Poynting flux streamlines.
  • #182
Slightly off topic.. can anyone point me to a thread on Physics Forums where any contributor with more than - say - 10 posts changes their mind about anything, ever? Just curious.
  • #183
That'll be hard to find-- communication is always the hardest thing. What's really amazing is how long a thread got spawned from how completely misunderstood was a very simple concept: that averaging lots of weak measurements together over an ensemble creates a classical limit for understanding "average trajectories", yielding something very akin to a classical concept like Poynting flux streamlines. The pity is that had we spent the energy actually analyzing the connection between Bohmian trajectories and classical Poynting fluxes, we might have actually arrived at a conclusion relevant to the OP. Because Poynting fluxes in a two-slit experiment must generate, by symmetry, streamlines that connect the left slit to the left side of the wall, and right to right, yet people still tried to argue that somehow the "average trajectories" can be used to conclude that photons passing through the left slit have to hit the left wall, even when there's an interference pattern. My entire motivation for discussing the correspondence principle was to expose how empty that logic was.
  • #184
We certainly see that Bragg's approach is purely classical and can be applied to electron diffraction. So that's a pretty good start. Whether we wish to count that as a "theory" is less clear, you may want more from it than just its ability to probe the structure of a lattice. There are many types of diffraction theories, and they all work to various degrees in different situations-- such is the nature of physics, we make idealizations to get somewhere. So we would not ask a classical theory of electron diffraction to do more than help us understand what is going on when we have large ensembles of diffracting electrons, and that's what Bragg's approach, and scalar diffraction theory in general, can do for us. It's just that we have quantum mechanics, so we only use classical concepts as analogs to help us understand the quantum mechanics, that is often the main point of classical analogs. Bragg's law is a perfect example of a classical analog helping us understand how electrons and neutrons diffract in a crystal.Excellent, then we are actually in a position to get the whole point here: classical analogs are a useful way to understand phenomena that closedminded people tend to brand as "strictly quantum." And that was the whole point, in particular about using Poynting fluxes to understand streamline diagrams like the one in the OP.
So basically, what happened is that you came on a physics website, and started posting unsubstantiated claims based on your personal definitions and interpretations of well-established physical concepts, like the distinction between quantum and classical, the distinction between occupation numbers and quantum numbers, and Bohr's principle of quantum classical correspondence. When challenged by actual physicists who require precise definitions, you could not clearly translate your theories into mathematical equations (i.e. translate them into the language of physics), or substantiate them with references. So you softened your claims by emphasizing the vagueness of your ideas, and the fact that you don't use the standard physical definitions for common concepts.
There is no real problem with any of that, EXCEPT for that fact that you presumed to advise and educate others that your personal ideas about how the connections between these concepts have a deeper physical significance than the mathematical similarities that are already well-known and commonly used in pedagogical settings. It is not helpful for you to continually claim that just because two concepts share a mathematical similarity, that there is a meaningful physical relationship between them. This is what has blinded you to the reason why your statement that there can be a classical theory of electron diffraction not only misleading, but is wrong when analyzed in the proper physical context. This is also why you failed to produce an equation that assumed a continuous distribution of mass and charge, yet could predict diffraction of that mass-charge distribution off a double slit scaled to produce electron diffraction.
  • #185
No, that is what you imagined happened. What actually happened is what I just said to zenith8-- I pointed out that the people who were claiming that averaging lots of weak measurements could demonstrate that photons going through the left slit had to hit the left wall were making a preposterous argument, which can be understood by simply understanding the information that gets lost when one takes a classical limit over a large ensemble. Then a few people who seemed unable to grasp that very clear truth went off on it. My main mistake was in imagining that people understood the classical analogs of wave diffraction and Poynting fluxes, and why the correspondence principle assures that those notions are going to be relevant when you do an ensemble average over individual quantum measurements. This is also why Bragg's law, discovered for X-rays, would have also been tried as an application to electron and neutron diffraction, even if the Braggs had not known that electrons and neutrons were particles, and even if there had been no quantum mechanics. It's simply the way physics is done-- we find concepts and look for places to apply them, and classical limits admit to classical analysis-- just like the "average trajectories" in the two-slit experiment. Analysis doesn't mean you can answer all the questions, it means you have made useful discoveries and gained useful insights, using classical approaches like Maxwell's equations and Huygen's principle. I wonder if you even understand this now.
ETA:
What's more, the way I characterized the correspondence principle was perfectly mainstream, and actually insightful if you can just get over yourself. The correspondence principle is the reason the way we do physics works-- it is why we don't have to completely throw out a classical theory every time a more fundamental description comes along, or why we won't have to throw out quantum mechanics when string theory comes along, and so forth. It is the reason our approach to physics works. You could also say it that whatever is the reason that physics works is the reason for the correspondence principle, and in support I cite basic logic and a rudimentary understanding of the history of science.
  • #186
Yes but as I've explained the correspondence principle was just a wishy-washy prelude to the much more specific Decoherence argument, which your hero Bohr never managed to quite formulate.
The correspondence principle is just an out-dated, though sometimes useful, aid to thinking.
Decoherence has a precise (and pure quantum mechanical) formulation.
The only thing decoherence doesn't solve is the "measurement problem", it otherwise explains the macroscopic world "strictly quantum mechanically" as you say.
  • #187
Ken G said:
Blah.. Blah.. Blah.. Blah.. Blah.. Blah blah blah blah blah.. Blah.
Not the answer I was looking for, Kenny..
  • #188
The correspondence principle goes way past Bohr and classical/quantum. It is the reason we can do physics, even though we don't get the fundamental theory out of the blocks, we have to muddle along with better and better theories that nevertheless work quite well in their domains of application. That's all Bohr was saying, I think his point there was pretty obvious and will be just as true for quantum/string as it was for classical/quantum.
Useful aids to thinking are rare and valuable-- and never out-dated.
Yes, more fundamental theories can always describe the less fundamental ones, plus more.{EDIT} But the physicist tailors the theory used to the depth of the question at hand, not to the most fundamental theory available. That's why Newton's gravity still gets used far more often than Einstein's{EDIT}. So that's why the issue here is, we should not fool ourselves into thinking we are making a quantum-mechanical argument when we do so much averaging of the quantum data that we end up with nothing but the classical limit.
  • #189
Then I guess you'll just miss the point of the thread. No problem for me there.
  • #190
General warning to laymen:
[PLAIN]http://www.governamerica.com/images/animated_siren.gif [/URL][SIZE="7"][B][/URL] Ken G [/B][PLAIN][PLAIN]http://www.governamerica.com/images/animated_siren.gif[/URL]
[PLAIN]http://en.wikipedia.org/wiki/Not_even_wrong"[/URL][/CENTER]
It’s a long time since I saw this much crap on PF. Either Ken G is very very old ([I]born around 1900?[/I]) and maybe missed the last 40+ years in physics, or he is very very religious ([I]creationist?[/I]). Either way, he is trying to turn the clock back to the glorious and divine days of Sir Isaac Newton and Classical physics.
He’s jumping back and forth among different levels of completely preposterous and home-cooked 'arguments' & 'claims'. He mixing apples and oranges so widely and without shame, that it all becomes hilarious in the end. In fact he reminds me of [URL]http://www.youtube.com/watch?v=ZN5PoW7_kdA"[/URL]...
Therefore, let’s sort things out:
[QUOTE][SIZE="1"] [url]http://en.wikipedia.org/wiki/Analogy[/url]
[B]Analogy[/B]
Analogy (from Greek "ἀναλογία" – analogia, "proportion") is a cognitive process of transferring information or meaning from a particular subject (the analogue or source) to another particular subject (the target), and a linguistic expression corresponding to such a process. In a narrower sense, analogy is an inference or an argument from one particular to another particular, [B]as opposed to deduction[/B], induction, and abduction, where at least one of the premises or the conclusion is general.
[SIZE="1"] [url]http://en.wikipedia.org/wiki/Physical_law[/url]
[B]Physical law[/B]
A physical law or scientific law is a scientific generalization [B]based on empirical observations of physical behaviour[/B] (i.e. the law of nature). Laws of nature are observable. Scientific laws are empirical, describing observable patterns. Empirical laws are typically conclusions based on repeated scientific experiment and observation, over many years, and which have become accepted universally within the scientific community. The production of a summary description of our environment in the form of such laws is a fundamental aim of science. These terms are not used the same way by all authors. Some philosophers e.g. Norman Swartz use "physical law" to mean what others mean by "natural law"/"law of nature".
[SIZE="1"] [url]http://en.wikipedia.org/wiki/Natural_law[/url]
[B]Natural law[/B]
Natural law or the law of nature (Latin: lex naturalis) has been described as a law whose content is set by nature and is thus universal. As classically used, natural law refers to the use of reason to analyze human nature and deduce binding rules of moral behavior. The phrase natural law is opposed to the positive law (meaning "man-made law", not "good law"; cf. posit) of a given political community, society, or nation-state, and thus can function as a standard by which to criticize that law.
[SIZE="1"] [url]http://en.wikipedia.org/wiki/Philosophy_of_science[/url]
[B]Philosophy of science[/B]
The philosophy of science is concerned with the assumptions, foundations, methods and implications of science. It is also concerned with the use and merit of science and sometimes overlaps metaphysics and epistemology by exploring whether scientific results are actually a study of truth. In addition to these central problems of science as a whole, many philosophers of science also consider problems that apply to particular sciences (e.g. philosophy of biology or philosophy of physics). Some philosophers of science also use contemporary results in science to reach conclusions about philosophy.
Philosophy of science has historically been met with mixed response from the scientific community. Though scientists often contribute to the field, many prominent scientists have felt that the practical effect on their work is limited: [B]“Philosophy of science is about as useful to scientists as ornithology is to birds,” according to physicist Richard Feynman[/B].[/QUOTE]
These are the 'cornerstones' of Ken G’s home-cooked messy 'thesis':
[LIST]
[*][I]"many quantum effects do have classical analogs that we take advantage of all the time, especially when testing quantum mechanics"[/I]
[*][I]"any quantum theory gives birth to a classical theory in the limit of large occupation numbers"[/I]
[*][I]"the correspondence principle is a law of nature"[/I]
[/LIST]
Right away we can see that the fist "analogy claim" could be okay, if used the right way. The intimation that quantum experimentalist generally are depending on "classical analogs" to successfully perform their tasks, is completely hooey. Ask Dr. Anton Zeilinger about http://www.nature.com/nature/journal/v390/n6660/full/390575a0.html" for god’s sake!
The other two points, is a mix of home-cooked speculations and completely crackpot madness.
The first obvious question: What is the name of [I]any[/I] quantum theory that has given birth to a classical theory?? The [I]classical[/I] theory of Entangled Elephants?? The [I]classical[/I] theory of wave–particle duality in the Elephant-Anaconda?? The [I]classical[/I] theory of spin-½ Elephants?? The [I]classical[/I] theory of the Double-Elephant-slit experiment?? The [I]classical[/I] theory of Elephant teleportation??
This is completely hilarious.
Surely, one could probably entangle elephants if it was possible to completely get them 'screened off', but then they would not be 'classical elephants', but very cold 'quantum elephants' in their 'ground state'.
It’s very hard to get a grip on what Ken G is talking about, and Ken G himself probably has similar problems, because sometimes classical mechanics is [B][I]not[/I][/B] Newton's laws, and sometimes [B][I]it is[/I][/B]... Utterly confusing and completely illogical.
If we try to find any logic in this excessive gobbledygook of Ken G, we must come to the conclusion that if all quantum theories give birth to a classical theory, then must also every quantum effects have a classical analog. But this is not what the genius Ken G bring to table of home-cooked classical spaghetti...
He hasn’t even followed his own line of thinking.
He says the correspondence principle is a "law of nature"? Where and when stated Niels Bohr this? Any reference? No, of course not, because this something Ken G just made up. Niels Bohr would never say anything like this, and he would certainly not used the word "law of nature". What "law of nature" is Ken G referring to? A physical law? Or a natural law? Or some new 'invention' of Ken G’s "philosophical law"?
We don’t get any clear information from Ken G on this, only insinuations, because he knows it takes a lot more than mumbling a few words to establish a physical law. This is complete and totally ridiculous nonsense, and a sever violation of PF rules.
As if this wasn’t enough, Ken G manage to exchange the meaning of the correspondence principle, when he gets cornered with undisputable facts – from something that’s suppose to be the (final) view of Niels Bohr, to some fluffy philosophical speculation on "the reduction of a new scientific theory".
[QUOTE][SIZE="1"] [url]http://en.wikipedia.org/wiki/Correspondence_principle#Other_scientific_theories[/url]
[B]Correspondence principle – Other scientific theories[/B]
The term "correspondence principle" is used in a more general sense to mean the reduction of a new scientific theory to an earlier scientific theory in appropriate circumstances. This requires that the new theory explain all the phenomena under circumstances for which the preceding theory was known to be valid, the "correspondence limit".
For example, Einstein's special relativity satisfies the correspondence principle, because it reduces to classical mechanics in the limit of velocities small compared to the speed of light. General relativity reduces to Newtonian gravity in the limit of weak gravitational fields.[/QUOTE]
Wikipedia explanation is fine, but there is only problem – Ken G is [I]swapping[/I] the whole thing in his home-cooked mess... Thus we end up in a situation where [I]classical mechanics has to explain all the phenomena in quantum mechanics[/I], for these quantum phenomena to be valid!? This is TOTALLY nuts!
And this "correspondence limit" was certainly not something Bohr was advocating:
[QUOTE][SIZE="1"] [url]http://en.wikipedia.org/wiki/Correspondence_principle#Quantum_mechanics[/url]
[B]Correspondence principle – Quantum mechanics[/B]
Because quantum mechanics only reproduces classical mechanics in a statistical interpretation, and because the statistical interpretation only gives the probabilities of different classical outcomes, [B]Bohr has argued that classical physics does not emerge from quantum physics[/B] in the same way that classical mechanics emerges as an approximation of special relativity at small velocities. [B]He argued that classical physics exists independently of quantum theory and cannot be derived from it[/B]. His position is that it is inappropriate to understand the experiences of observers using purely quantum mechanical notions such as wavefunctions because the different states of experience of an observer are defined classically, and do not have a quantum mechanical analog.[/QUOTE]
Ken G has certainly created a great mess here. The most voluminous I’ve seen in years. He’s jumping back and forth, guessing and talking and changing 'arguments' on the run, without any clue whatsoever on where he’s going – except that classical mechanics has the answer to everything ([I]he believes[/I]).
It gets tragicomic when Ken G without any doubts concludes his baloney thoughts; [I]"the way I characterized the correspondence principle was perfectly mainstream"[/I] ...
Which way might that be?? :bugeye:
To make things even more 'amusing', from start, Ken G picked and intermediate version of Bohr’s Correspondence principle that has been completely obsolete for almost a hundred years - [B]The Weak form of the Correspondence principle[/B], with the 'classical limit' of quantum mechanics, which Niels Bohr abandon long time ago. The only "logical" explanation for this very weird behavior, is that Ken G is fond of 'old things' – really old. He’s probably the only 'cultivator' of the weak form of the correspondence principle still alive on this planet...
As said, Ken G is bungee jumping between the extremes. Sometimes he’s on an 'educational quest', helping laymen to 'understand thru analogies'. Next time, he’s mixing up the [PLAIN]http://en.wikipedia.org/wiki/Wave_equation"[/URL] could easily be replaced with a classical 'substitute'...?? :confused:
What could one say? :eek:
This is a graphical representation of the classical wave equation:
[PLAIN][URL]http://upload.wikimedia.org/wikipedia/commons/1/1f/Wave_equation_1D_fixed_endpoints.gif[/URL]
And the Schrödinger equation for a harmonic oscillator:
[URL]http://upload.wikimedia.org/wikipedia/commons/9/90/QuantumHarmonicOscillatorAnimation.gif[/URL]
A harmonic oscillator in classical mechanics (A-B) and quantum mechanics (C-H). In (A-B), a ball, attached to a spring, oscillates back and forth. (C-H) are six solutions to the Schrödinger Equation for this situation. The horizontal axis is position, the vertical axis is the real part (blue) or imaginary part (red) of the wavefunction. (C,D,E,F), but not (G,H), are stationary states (energy eigenstates), which come from solutions to the Time-Independent Schrödinger Equation.
I would recommend Ken G to play around with this 'simple' http://www.falstad.com/qm1d/"[/URL], and wait for the classical [B][I]mathematical[/I][/B] solution for that. How hard could it be...? :-p
[PLAIN]http://www.falstad.com/qm1d/"[/URL]
[I](Maximize the window for better resolution)[/I]
[ATTACH=full]197131[/ATTACH]
[PLAIN]http://www.falstad.com/qmatom/"[/URL]
[I](Click & drag to rotate in 3D)[/I]
[ATTACH=full]197132[/ATTACH]
What a thriller! Good luck! :biggrin:
[I]... Maybe it’s appropriate to inform Ken G that Niels Bohr once tried, and failed with a classical wave description of the electromagnetic field, in the [PLAIN]http://en.wikipedia.org/wiki/BKS_theory"[/URL] ...[/I]
[INDENT][I]"For Bohr the lesson to be learned from the disproof of the BKS theory was not that photons do exist, but rather [B]that the applicability of classical space-time pictures in understanding phenomena within the quantum domain is limited[/B]. This theme would become particularly important a few years later in developing the notion of complementarity."[/I][/INDENT]
Ken G says – [I]"we might understand what intelligence is"[/I]. That’s a very interesting and challenging thought... but we’ll probably not solve that particular question in this thread...
There has been a lot of inconsistent mumbling and words from Ken G, but almost no facts and references. How about some words from the man himself, Niels Bohr?
[I](I recommend everyone who is interested in the Bohr–Einstein debates to read the full text, it’s very interesting.)
(emphasis mine)[/I]
[QUOTE][SIZE="1"] [PLAIN]http://www.mpa-garching.mpg.de/~lxl/personal/images/science/BE.htm[/URL]
[B]DISCUSSION WITH EINSTEIN ON EPISTEMOLOGICAL PROBLEMS IN ATOMIC PHYSICS
NIELS BOHR[/B]
Originally published in Albert Einstein: Philosopher-Scientist, P. A. Schilpp, ed., pp. 200-41 The Library of Living Philosophers, Evanston (1949).
From the very beginning the main point under debate has been the attitude to take to the departure from customary principles of natural philosophy characteristic of the novel development of physics which was initiated in the first year of this century by Planck's discovery of the universal quantum of action. This discovery, which revealed a feature of atomicity in the laws of nature going far beyond the old doctrine of the limited divisibility of matter, [B]has indeed taught us that the classical theories of physics are idealizations which can be unambiguously applied only in the *limit* where all actions involved are large compared with the quantum[/B].
These ideas, which were soon confirmed by the experiments of Franck and Hertz (I9I4) on the excitation of spectra by impact of electrons on atoms, involved a further renunciation of the causal mode of description, since evidently the interpretation of the spectral laws implies that an atom in an excited state in general will have the possibility of transitions with photon emission to one or another of its lower energy states. In fact, the very idea of stationary states is incompatible with any directive for the choice between such transitions and leaves room only for the notion of the relative probabilities of the individual transition processes. [B]The only guide in estimating such probabilities was the so-called correspondence principle[/B] which originated in the search for the closest possible connection between the statistical account of atomic processes and the consequences to be expected from classical theory, [B]which should be valid in the *limit* where the actions involved in all stages of the analysis of the phenomena are large compared with the universal quantum[/B].
The new progress in atomic physics was commented upon from various sides at the International Physical Congress held in September I927, at Como in commemoration of Volta. In a lecture on that occasion [8], I advocated a point of view conveniently termed "complementarity," suited to embrace the characteristic features of individuality of quantum phenomena, and at the same time to clarify the peculiar aspects of the observational problem in this field of experience. For this purpose, it is decisive to recognize that, [B]however far the phenomena transcend the scope of classical physical explanation, the account of all evidence must be expressed in classical terms[/B]. The argument is simply that by the word "experiment" we refer to a situation where we can tell others what we have done and what we have learned and that, therefore, the account of the experimental arrangement and of the results of the observations must be expressed in unambiguous language with suitable application of the terminology of classical physics
In the quantum-mechanical description our freedom of constructing and handling the experimental arrangement finds its proper expression in the possibility of choosing the classically defined parameters entering in any proper application of the formalism. Indeed, in all such respects quantum mechanics exhibits a correspondence with the state of affairs familiar from classical physics, [B]which is as close as possible when considering the individuality inherent in the quantum phenomena[/B]. Just in helping to bring out this point so clearly, Einstein's concern had therefore again been a most welcome incitement to explore the essential aspects of the situation.
As a more appropriate way of expression [B]I advocated the application of the word phenomenon exclusively to refer to the observations obtained under specified circumstances, including an account of the whole experimental arrangement[/B]. In such terminology, the observational problem is free of any special intricacy since, in actual experiments, all observations are expressed by unambiguous statements referring, for instance, to the registration of the point at which an electron arrives at a photographic plate. Moreover, speaking in such a way is just suited to emphasize that the appropriate physical interpretation of the symbolic quantum-mechanical formalism amounts only to predictions, of determinate or statistical character, pertaining to individual phenomena appearing under conditions defined by classical physical concepts.[/QUOTE]
I’m sorry Ken G, these are Niels Bohr’s own words from 1949, and unless there’s something wrong with my browser – he’s only mentioning the word (classical) [B]*limit*[/B] twice (2) and it originates from around 1914. From 1927 and later on, Niels Bohr has moved towards the experimental arrangement ([I]Strong form of the correspondence principle[/I]), and as you see – there’s of course no talk about a [I]"law of nature"[/I]. Bohr was too intelligent to make a simple blunder like that when dealing with epistemology.
It’s time for you to say: [I]– Okay guys, I was wrong. I’m sorry I don’t know what happened...[/I]
Anything else will only make it worse for you.
Finally, I have to mention your logical core meltdown when it comes to entanglement, which in a way is symptomatic for all your baloney claims lately. Your Catch-22 goes like this; every quantum theory gives birth to a classical theory in the limit of large occupation numbers. If a quantum theory doesn’t give birth to a corresponding classical theory, then that quantum theory is wrong, and therefore every quantum theory must give birth to a classical theory, the classical domain is default.
I’ve seen a lot on PF, but this must be the crankiest "idea" put forth in QM forums this far.
  • #191
Ken G, I urge you to leave the past, and welcome you to the future, err, the present!
http://en.wikipedia.org/wiki/Quantum_mechanics#Quantum_mechanics_and_classical_physics
Quantum mechanics and classical physics
Predictions of quantum mechanics have been verified experimentally to a extremely high degree of accuracy. According to the correspondence principle between classical and quantum mechanics, all objects obey the laws of quantum mechanics, and classical mechanics is just an approximation for large systems (or a statistical quantum mechanics of a large collection of particles). The laws of classical mechanics thus follow from the laws of quantum mechanics as a statistical average at the limit of large systems or large quantum numbers.
Quantum coherence is an essential difference between classical and quantum theories, and is illustrated by the Einstein-Podolsky-Rosen paradox. Quantum interference involves adding together probability amplitudes, whereas when classical waves interfere there is an adding together of intensities. For microscopic bodies, the extension of the system is much smaller than the coherence length, which gives rise to long-range entanglement and other nonlocal phenomena characteristic of quantum systems. Quantum coherence is not typically evident at macroscopic scales, although an exception to this rule can occur at extremely low temperatures, when quantum behavior can manifest itself on more macroscopic scales (see Bose-Einstein condensate and Quantum machine).
http://en.wikipedia.org/wiki/Quantum_machine
The first Quantum Machine
The first quantum machine was created on August 4, 2009 by Aaron D. O'Connell while pursuing his Ph.D. under the direction of Andrew N. Cleland and John M. Martinis at the University of California, Santa Barbara. O'Connell and his colleagues coupled together a mechanical resonator, similar to a tiny springboard, and a qubit, a device that can be in a superposition of two quantum states at the same time. They were able to make the resonator vibrate a small amount and a large amount simultaneously — an effect which would be impossible in classical physics. The mechanical resonator was just large enough to see with the naked eye — about as long as the width of a human hair. The groundbreaking work was subsequently published in the journal Nature in March 2010. The journal Science declared the creation of the first quantum machine to be the "Breakthrough of the Year" of 2010.
Photograph of the quantum machine developed by O'Connell. The mechanical resonator is located to the lower left of the coupling capacitor (small white square). The qubit is connected to upper right of the coupling capacitor.
Scanning electron micrograph of the film bulk acoustic resonator. The mechanically active part of the resonator is supported to the left by two metal leads which act as electrical connections.
The paper on nature.com http://www.nature.com/nature/journal/v464/n7289/full/nature08967.html".
TED – http://en.wikipedia.org/wiki/Aaron_D._O%27Connell"[/URL]: Making sense of a visible quantum object
[url]http://www.youtube.com/watch?v=dvYYYlgVAao&hd=1[/url]
https://www.youtube.com/watch?v=dvYYYlgVAao
There’s a lot of very interesting projects going on at [PLAIN]http://www.physics.ucsb.edu/~martinisgroup/"[/URL]:
Generation of Three-Qubit Entanglement Using Josephson Phase
[url]http://www.physics.ucsb.edu/~martinisgroup/theses/Neeley2010b.pdf[/url]
[ATTACH=full]143933[/ATTACH]
Finally an interview with Anton Zeilinger about QM now and in the future:
[MEDIA=youtube]kIzMZtQ9NwQ[/MEDIA]
https://www.youtube.com/watch?v=kIzMZtQ9NwQ
[B]TIME TO WAKE UP KEN G, IT’S 2011 – NOT 1911![/B]
  • #192
A very interesting flight of fancy. Obviously missed my point completely, you think I don't understand quantum mechanics, or don't believe in it, or some other baloney that only shows you really missed everything I said (my main point dates back to my pointing out the flaws in a claim that "average trajectories" are a quantum mechanical concept, but as you missed all that completely, I'm certainly not going to reprise it now). But I should correct one factual error-- I never claimed, nor thought, that the correspondence principle was a "law of nature." In fact, I don't believe there is any such thing as a law of nature. But there are quite a few "laws" that physicists have found great use from, and what we choose to call a law is a pretty irrelevant exercise in scientific sociology. But feel free to decide what you personally do and do not consider to be a law of nature, just don't expect anyone else to care.
What actually matters is what we use, and how it helps us, and we certainly use the correspondence principle, writ large, constantly in physics. I described what I meant by that principle-- that more fundamental theories that apply in wider domains of application must still be consistent with less fundamental theories in the domain of demonstrable success of the latter. And it is certainly of tremendous value in physics, being in fact the reason that physics works at all. It is certainly the reason that Newton's gravity is used after Einstein, that classical wave mechanics is used after quantum mechanics, that both continuum and fluid mechanics are used after the discovery of the atom, and that Bragg's law applies to ensemble averages of electron and neutron diffraction in crystals. And, more to the point, it is why a simple classical-wave treatment of photon diffraction can yield Poynting fluxes that look an awful lot like the "average trajectories" of the OP experiment, which also look a lot like deBB trajectories, which therefore tell us nothing conclusive about what individual members of the ensemble are doing. Which was the point all along, and I notice that in none of your pointless diatribes did you even mention or recognize this fact. Methinks though doth protest too much, there actually is a science matter on the table here.
  • #193
unusualname about 3 pages back said:
The correspondence principle is not a law of nature, it simply a rule for us dumb humans to check that our (quantum mechanical) model of reality is consistent.
Ken G (in reply) said:
I'm afraid that's a pretty good definition of a "law of nature." Why you see a distinction there is certainly outside anything that could be called science.
Ken G, struggling with the logic really
  • #194
I’m afraid you’re making a fool of yourself again. You apparently missed the "First law of internet":
Never deny a statement of yours that’s only a few posts away and that can never be erased.
unusualname said:
The correspondence principle is not a law of nature, it's simply a rule for us dumb humans to check that our (quantum mechanical) model of reality is consistent.
(Edit: Ops, thanks unusualname for 'beating' me! :wink:)
And it doesn’t get any better...
Wow! Is this what you call an "irrelevant exercise in scientific sociology"?? :bugeye:
  • Archimedes’ principle
  • Kepler’s three laws of planetary motion
  • Newton’s three laws of motion
  • Euler's laws of rigid body motion
  • Newton’s law of universal gravitation
  • Newton’s law of heat conduction
  • Boyle’s law
  • Law of conservation of energy
  • Joule’s first and second law
  • The four laws of thermodynamics
  • Coulomb's law
  • Maxwell's equations
  • Special Relativity
  • General Relativity
  • Planck's law of black body radiation
  • Heisenberg Uncertainty Principle
  • Matter wavelength
  • Schrödinger equation
    ... etc ...
Thanks a lot Ken, finally something that looks like logical mainstream. The sole reason for this 'diatribe' is of course that you’re mixing apples and oranges wildly, and you’re bungee jumping between inconsistent standpoints of yours. On this very same page, in post #181 you said:
I hope you understand the contradiction in advocating two different and completely incompatible versions of the correspondence principle? One is old and obsolete (classical limit), and the other (backward compatibility) is rejected by Niels Bohr, since he argued that classical physics does not emerge from quantum physics in the same way that classical mechanics emerges as an approximation of special relativity at small velocities.
Get it? None of your versions works...
(On the other hand this is quite interesting... since this looks like some "psychological superposition" of "counterfactual thinking"... :biggrin:)
I think anyone reading this thread understands what’s "going on" here. I don’t have anything further to add.
Finally, a quote from Shakespeare’s Hamlet:
There are more things in heaven and earth, Horatio, than are dreamt of in your philosophy.
Take care!
  • #195
Sorry, but you once again failed to make your point. I did not claim it was a law of nature, I claimed that you were making an arbitrary distinction between what is and is not a "law of nature." As I just said, I personally don't think "law of nature" applies to anything that physics does, but it may apply to lots of things physics does, including the correspondence principle, using someone else's meaning of the phrase. My actual point was that your attempt to deny the value of the correspondence principle on the grounds that it was "not a law of nature" was ridiculous. Which it was. I might as well say Newton's laws are not laws of nature either, which they aren't-- but it would be an equally meaningless argument. We don't do physics by labeling things.
  • #196
See above. You failed to understand my point once again,which was that the whole "law of nature" hooey, not even brought up by me, was a complete red herring, because the term is completely nonspecific and can be applied to the correspondence principle or not applied to it, depending on how one defines it. I also pointed out that the important attributes of the correspondence principle could easily be construed as that, unless someone wanted to offer a more specific definition. Which they did not, of course. Pray tell, do you know what a law of nature is? Be sure to include references, of course, I'm sure the textbooks will be quite informative on the topic. Oh and, it would be nice if that completely arbitrary list that you seem to think are laws of nature would actually conform to the definition you dig up, but the correspondence principle does not. And it doesn't even matter if you can shoehorn a definition into that space, because my argument did not rest on what we call things, it rested on what is necessary for the endeavor of physics to actually work.
Getting back to the real science, and the OP, let me ask you one simple question. Do you think an "average trajectory" diagram, which makes weak measurements and combines them into a streamline picture, could ever be used as evidence that photons passing through the left slit hit the left side of the screen? Yes or no, this is the actual science question on the table here.
That the principle has many sides does not make them incompatible. Is your face incompatible with your posterior? Is it different?
  • #197
A law of nature is something we humans conceive to be the way nature works .The correspondence principle is a now not very important philosophical principle, since we have a much more sophisticated understanding of how the macroscopic emerges from the microscopic.
Your argument on this thread amounts to this - the flux lines for single photons can be (qualitatively) classically constructed (thanks to my references) so there is no quantum mystery here, so let's just move on. However you then claim that if a two-photon entangled trajectory was "measured" you would still find a classical flux analog (nope, you won't)
You also ignore the recent measurement of a QM wavefunction article, dismissing it as some silly people who can't understand the correspondence principle or similar (you need to be specific why you dismiss this experiment otherwise I have to portray you dismissing it for this reason)
And you have also claimed that delayed choice experiments can be explained by maxwell's equations
  • #198
So your argument is that when we have a more sophisticated understanding of something, the more basic principles disappear? We have a more sophisticated understanding of gravity, but Newton's gravity has not disappeared from scientific journals. We have a more sophisticated understanding of the statistical mechanics of van der Waals forces, but the ideal gas law has not disappeared. We have a more sophisticated understanding of quantum mechanics, but classical mechanics has not disappeared. This is all the beating heart of the correspondence principle, writ large-- science is an endeavor that routinely matches the complexity of the description to the domain of interest of the outcome. None of that has disappeared, no.
Completely wrong. That is not at all what I said, thought, or advocated in any way. As I've told you over and over, that is some make believe version of what I said, that you invented so you could attack it. I frankly have no idea where you got that from. Oh, and I pointed this out prior to your reference, so the point was not "thanks to" your reference, it was merely supported by your reference. A fact which seems to have escaped you here, but thank you.
What I actually said is that since the average flux trajectories are ensemble concepts, not individual particle concepts, expressly because they are averaged over an ensemble, it means they are the same concepts that are addressible in a more classical ensemble treatment of the phenomenon (where once again, by "classical" I mean classical wave treatment, not classical mechanics treatment), similar to how the Braggs analyzed X-ray diffraction in crytals, and how it also applied to diffraction of ensembles of electrons and neutrons. Therefore, the average trajectory diagram does not tell us squat about what any individual particles are doing, because we could generate a similar figure with the techniques I described, without even knowing that we were ever dealing with individual particles (just as the Braggs could do everything they did without knowing they were dealing with individual photons). So this is what I actually said, and since I see little resemblance to your caricature, not a single one of your many objections has even the least relevance to what I actually said.
Another make-believe idea in your head, never said, or even thought, by me. I understand two-particle entanglement, and I understand classical limits, and I understand the difference. It is you who do not, and that is why you cannot understand, yet must instead insert your klunky caricatures in place of what was actually said.
More make believe on your part. What thread have you been reading? Didn't someone just quote a rule of the internet that it is silly to make claims about what was said when it's right there in black and white? What I actually said about that experiment is:
1) it is not the subject of this thread
2) I have not analyzed it, but I can say right off the bat that part of their claim is unsubstantiated. They claimed they could measure the real and imaginary parts of the wave function independently, but I pointed out that no wave function can be measured, or even attributed meaning, to within an arbitrary global complex phase. So yes, I know with complete certainty that they did not actually measure the real and imaginary parts of the wave function independently, but if one chooses to view that as a nitpick, I can only say that I did not dismiss the article nor reach any other conclusions about it at all. Why you have to imagine I did is a question only you can know the answer to. Why do you think that is?
No, actually I did not ever say that either. I do wonder what can be learned about them from a judicious understanding of the classical analogs Maxwell's equations might provide, and I suspect that there are indeed useful analogs there, but I certainly never said the experiments could be "explained" by them. Indeed, all I"ve ever claimed is that classical limits of such experiments can be understood classically, but you've never really appreciated that nuance, or indeed almost any nuance of my argument.
  • #199
I don't understand you because there is no classical limit related to entanglement, the wavefunction or delayed choice experiments.
So what on Earth are you talking about?
The whole point of QM is that it is a spectacularly non-classical theory of nature, why would anyone want to emphasize classical limits?
I suspected you got carried away with a partly reasonable anti-bohmian stance which seems to have developed over several threads into an "everything has a classical analog if you look at it from a certain point of view" argument.
  • #200
Whether or not there are classical analogs of entanglement that could be informative is not yet clear. But there certainly are classical analogs to the wavefunction, indeed that's the whole reason it is called a wavefunction in the first place (and classical analogs is exactly how Schroedinger arrived at his celebrated equation in the first place). There certainly is a long history of using insights from classical analogs in quantum mechanics.
Just ask Schroedinger, it worked for him.
Let's agree that the usefulness of classical analogs is something that is better demonstrated than postulated. I really was only using classical analogs to show that average trajectories are not strictly quantum mechanical objects because they don't apply to quanta, they apply to ensembles of quanta and so are amenable to being understood with classical-wave analogs.
