- #141
artis
- 1,481
- 976
I would also tend to think that even the base slab that rests on ground is connected by rebar to the columns but in a building with 12 stories I would suspect that the columns themselves actually start well below the base slab (the floor of the parking garage) and are actually built on top of piles driven into ground or some anchoring. If the columns actually ended on the base slab then they would puncture right through the slab and drop to ground a soon as the building is finished being built. Or you would need an extremely thick slab , I'm thinking like a meter thick or more. So I think the slab is thin it just does the floor function and some lateral bracing of columns while the columns themselves have to rest on some deeper anchoring, especially in a soft ground like that next to ocean.So continuing our online investigation , here is a video that I found quite randomly, it seems to show a large part of the underground garage. In the end you can see the exit ramp for cars that was filmed in the tourist video with the leaking water pipe. You can observe plenty of pipes on the ceiling from fire water ones to some other ones. If that pipe burst because of the yard slab failure being at the other side of the slab it would indicate that the rest of the slab underneath the structure was heavily compromised. The most likely damage to the pipe could have resulted from large heavy portions of the concrete slab dropping freely and hitting the pipes in the process.Astronuc said:The first slab is the floor of the underground garage, and the slab should be attached by rebar to the columns. If the rebar in those joints failed, then the columns could drop into the ground underneath, which would compromise the structure above.
As for the column thickness well it seems that they were the same thickness throughout the structure , at least at the basement level because the part of the parking garage with the exit ramp seen in the video is the very part that collapsed.
Truth be told apart from a few cracks here and there the slab doesn't seem to be in such an extremely bad conditions like it is told on news. Lastly I hope this is the video of the building in question but it definitely seems so from the floor plan and exit ramp.
Lastly take a look at this video , a short clip by someone from the rescue team as they are working under the collapsed section in the parking garage. Take notice of the ceiling slab, the one that I think could be responsible for the compromising of columns. Notice how the rebar has separated from the slab and left deep trenches in the half fallen slab piece under which the people are working. It could very well be that similar damage happened under the building as the yard slab portion fell, rebar being metal has high tensions capabilities and it could have exerted a large pull on all the adjacent structure.
Also at the very beginning of the video take a close look of one of the columns and see how the slab has separated from the column and fallen down yet the column is left standing.
This is a picture under the half part that was left standing , notice how the failure of the yard slab has carried on through the rebar into the slab underneath the building.
