- #106
Chris Hillman
- 10
MeJennifer said:I must be missing something, please bear with me.
Suppose I have one single clock with a simple rocket and some computerized navigation system.
I programmed this system in such a way that the clock will accelerate with a proper constant acceleration and proper time interval and afterwards it will record the time.
Now would that be possible?
Yes, of course.
MeJennifer said:Assumming it is, suppose I build two of those.
Also possible, in principle!
MeJennifer said:Now I place one to the left of me and one to the right and make sure I stand in the middle and launch them at the same time.
"In the middle" could be a problem--- let's say the two craft are initially comoving inertial and then all notions of "distance in the large" should agree, and also "at the same time" should be unambiguous.
MeJennifer said:Then afterwards I fetch each clock and check their times.
Uh oh! First, you didn't specify how the craft accelerate after you begin the experiment. Second, you didn't specify how you try to compare the elapsed times after the craft have executed specified motions. One direct method would be to make them move some more until they are once again comoving inertial, whereupon we can try to check them via Einstein's synchronization procedure, and will presumably find that they are no longer synchronized, according to Einstein's procedure for comparing ideal clocks carried by comoving inertial observers.
Recall what we said about multiple operationally significant notions of distance. Likewise, there are multiple operationally significant notions of comparing times of clocks carried by distant observers.
MeJennifer said:What exactly is impossible here?
Please reread what I wrote in my earlier two posts, including the sentence you originally wrote, which I quoted and stated was trying to posit an situation which cannot arise in Minkowski geometry. Please try to very carefully draw the Bell and Rindler congruences and their euclidean analogs. I think you will see what I mean if you keep trying.
