- #36
- 8,174
- 1,906
vanhees71 said:Concerning your example it's very simple. You have a spin-entangled state. Both A and B find completely unpolarized particles when measuring their spin. Due to the entanglement, when they compare their measurement protocol (taking carefully appropriate time stamps to know which of each spins are from one and the same entangled pair, they'll find 100% correlation, when measuring in the same direction ##\theta##. This is due to the preparation at the very beginning, before any further manipulations where done. It doesn't matter in which temporal order A and B make their measurements. If the measurement events are space-like separated it's for sure that A's measurement cannot have in any causally influenced B's spin nor can B's measurement have in any way causally influenced A's measurement. That's ensured theoretically by the validity of the microcausality property and the only conclusion is that the correlation found is simply due to the preparation in the spin-entangled state in the very beginning.
Here are points of departure:
1. If they evolved independently after state preparation, obviously they could be described by Product State statistics. This is the very definition of a Local Realistic explanation, and therefore flat out prohibited by Bell. Certainly you know all this, so why would you use this explanation?
2. Your explanation does not involve QFT. This same explanation was used in 1935 in EPR. The point of my question, phrased as it was, was to get an explanation of QFT's solution to the issue that works for a simple case (although obviously NOT using local hidden variables, which are excluded), and then you could walk me through how that is extended to a more complex case.
3. You assume: "If the measurement events are space-like separated it's for sure that A's measurement cannot have in any causally influenced B's spin nor can B's measurement have in any way causally influenced A's measurement." This argument is purely tautological, as this is the entire point in question.
In fact. that is almost verbatim what Bell started with and went on to disprove: "The vital assumption is that the result B for particle 2 does not depend on the setting a, of the magnet for particle 1, nor A on b." No theory, after Bell, and including QFT, can be local in the manner you describe (no FTL influences), with classic forward in time causality, without being contextual (i.e. observer/measurement dependent) in some non-classical manner. I am hoping you can explain how I am wrong about this point. I am definitely hoping to learn more from you, and if you have any specific quotes, that would be great too. Ah, and I just realized @bhobba shares your position (I'm sure others do too, but I never read them elsewhere).
