- #106
RUTA
- 488
vanhees71 said:Nonrelativistic QT is an approximation of relativstic QFT, valid under certain assumptions. If nonrelativistic QT is applicable, it depends on the accuracy you check it, whether you realize that there are relativistic corrections. E.g., the hydrogen atom spectrum as treated in QM 1 (neglecting relativity as well as the magnetic moment of the electron) is pretty accurate, but you see fine structure, hyperfine structure and radiative corrections like the Lamb shift when looking closer. The relativistic theory so far has not been disproven. To the contrary, it's among the best confirmed theories ever.
Right, but the OP was asking specifically about the mystery of entanglement in experiments analyzed accurately with QM (yes, even when using photons). So, my point is simple: In any theory of physics that may or may not make correspondence with a more general theory, whenever you do an experiment that is accurately analyzed with that theory (accurate in experimental terms, not to be confused with precise), there is nothing more the general theory can add — that’s what correspondence means. If there was something amiss between the experimental outcomes and theoretical predictions, i.e., the theory failed to analyze it accurately, then that would point to something missing in the approximate theory that requires the more general version. But, that is not at all the case with the experiments accurately analyzed with QM that violate Bell’s inequality for example. Therefore, in such experiments when someone says, “You need to use QFT to understand the mysterious outcomes of that QM experiment,” they are saying, “You need to use QM to understand the mysterious outcomes of that QM experiment.” Which brings us right back to where we started.
