- #71
cabraham
- 1,181
- 90
wbeaty said:OK, thanks! And yes, comparing narrow base to extremely wide base is an excellent teaching strategy of which I previously hadn't heard.
Regarding canon, earlier you stated that the Ebers-Moll model is a CC model, and their original paper employed current-controlled current sources. Correct?
Are you certain that you're not misinterpreting something? N.b. that your assertion regarding Ebers-Moll being a CC model goes entirely contrary to numerous undergrad Uni books which give the following CV (large signal transconductance) equation as the central feature of Ebers-Moll model:
Ic=Is*(exp(Vbe/Vt)-1) (for large hfe of course, alpha ~=1)
Is this not canon? If the above CV equation isn't "Ebers-Moll model," then you've discovered a vast flaw in an enormous number of textbooks.
Send me a message, & I'll email you the Ebers-Moll 1954 paper. It shows the bjt collector current being controlled by emitter current, i.e. a CCCS. Alpha is the parameter which determines the Ic value from Ie. They show a schematic w/ a CCCS controlling Ic.
The exp( ) relates the Vbe to Ic, but alpha is all important. The exp( ) covers the relation between Vbe & Ie. To get Ic we need alpha. The diode equation for the b-e jcn is Ie = Ies*exp((Vbe/Vt) - 1)> But Ic = alpha*Ie. So Ic = alpha*Ies*exp( ). The collector current is controlled by alpha*Ie. But Ie has a direct relation w/ Vbe as well as Ib.
All 3 eqns are relevant. A bjt offers both current gain as well as voltage gain. To compute current gain we use eqn 1) for the common emitter & emitter follower topologies. For the common base current gain, we use eqn 3). To compute voltage gain we use eqn 2). Again, all 3 eqns come into play when thoroughly analyzing bjt behavior.
We cannot make more than one quantity the controlling quantity. We generally control Ie, & Ic = alpha*Ie. Sometimes we control Ib, w/ Ic = beta*Ib. Usually this is not good due to beta dependency. We want networks that rely on well defined parameters like alpha & resistor values. Resistors have tight tolerances.
Send me a message, & I'll email you the E_M paper, the horses' mouth on the E-M eqns. BR.
Claude
