I saw something unexplainable while soldering
  • Thread starter Thread starter Jarfi
    Soldering
A beginner soldering with a chapo solder iron observed a silver metal ball turning a white goldish color while soldering circuit connectors. Upon touching it with a needle-shaped tip, the white layer turned to smoke and dissipated. This phenomenon may be related to flux vaporization, as the flux in the solder can condense on cooler surfaces. The user noted that this event occurred only once and could not be replicated. The discussion highlights the interaction between soldering fumes and heated metal surfaces.
Jarfi
I am looking for physical explanations for an event I observed.
I am a beginner in soldering, bought some chapo solder iron, random solder tip and a soldering material with "Sn", "Pb" and "Cu" it seems. It's called "Elektronik Löndraht".
Now, when I was soldering tiny 2mm spaced circuit connectors, I noticed a strange thing, one of the silver colored metal balls next to the one I was soldering turned white goldish. It was a strange color, I touched it with the tip which is needle shaped and suddenly the "white layer" turned into smoke and dissipated.
It seems that fumes from soldering, accumulated and were attracted to the previously hot metal peral(maybe 1mm diameter) next to the one I was soldering.
I actually saw this happen, It just happened this one time and I have not been able to replicate the event.
Has anyone here ever experienced a similar thing, what exactly was I observing? Why would toxic fumes be attracted to and form a layer around a hot but solid metal pearl?
There is most likely a flux core in your solder. Flux helps the solder to flow on the parts being soldered. When it is heated, it vaporizes. Some of the flux condenses on the cooler solder pad.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Someone who shows interest in science is initially a welcome development. So are fresh ideas from unexpected quarters. In contrast, there is a scientific community that is meticulously organized down to the last detail, allowing little to no external influence. With the invention of social media and other sites on the internet competing for content, unprecedented opportunities have opened up for...
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
