Integration using Beta and Gamma Functions
In summary, Polya said that it is better to try an easier problem first. So let's try,$$\int^\infty_0 \frac{\log(1+x^2)}{1+x^2}\,dx$$This can be used to solve many problems, like\int^\infty_0 \frac{\log(1+x^2)}{1+x^2}\,dx
  • #106
The following sum diverges
$$\sum_{k\geq 1}\frac{H_k}{k}$$
Actually the Euler number $\gamma$ can be defined as
$$\gamma = \lim_{k\to \infty}H_k-\log(k)$$
So Harmonic number differ by a constant term as they approach infinity.
Hence we can write
$$\sum_{k\geq 1}\frac{H_k}{k} \sim \sum_{k\geq 1}\frac{\log(k)}{k} $$
The right integral diverges by the integral test.
You don't have to understand all of that but you have to know that diverges.
So the equation
$$\displaystyle \sum_{n=1}^\infty \frac{H_n}{n^q}= \left(1+\frac{q}{2} \right)\zeta(q+1)-\frac{1}{2}\sum_{k=1}^{q-2}\zeta(k+1)\zeta(q-k)$$
only converges for $q \geq 2$ and by definition for $q=2$ we have
$$\displaystyle \sum_{n=1}^\infty \frac{H_n}{n^2}=2\zeta(3)-\frac{1}{2}\sum_{k=1}^{0}\zeta(k+1)\zeta(2-k)$$
The sum is by definition equal to 0 so
$$\displaystyle \sum_{n=1}^\infty \frac{H_n}{n^2}=2\zeta(3)$$
For references you can search for Euler sums , you will find lots of papers.
  • #107
Hence we can write
So the equation
But the issue is we don't have an $n^2$ term when evaluating the $k+1$ sum. Please let me know if there is a work around for this.
Meanwhilw, I just had an idea.
We can consider the integral definition of the Harmonix number.
$$H_k = \int_{0}^{1} (1-x)^{k-1} dx$$
And convert the whole sum.
I used integral on the original geometric series formula and I got an intense formula involving several poly logarithms. Perhaps this is a way? Will you be interested on seeing that attempt?
  • #108
I don't understand what you mean .
Of course , let me see if you got any other attempts. It might be better than my approach , why not ?
  • #109
So we consider just
$$I = \sum_{k=1}^{\infty}\frac{\int_{0}^{1} (1-x)^{k-1} \,dx}{(k+1)(k+2)^3}$$
$$I = \int_{0}^{1} \sum_{k=1}^{\infty} \frac{(1-x)^{k-1}}{(k+1)(k+2)^3} \,dx$$
Now it is about to get extremely complicated. Principally, we know
$$\sum_{k=1}^{\infty} x^{k-1} = \frac{1}{1-x}$$
$$\sum_{k=1}^{\infty} (1-x)^{k-1} = \frac{1}{x}$$
$$\sum_{k=1}^{\infty} (1-x)^{k} = \frac{(1-x)}{x}$$
$$\sum_{k=1}^{\infty} \frac{(1-x)^{k+1}}{k+1} = x - \log(x)$$
$$\sum_{k=1}^{\infty} \frac{(1-x)^{k+2}}{(k+1)(k+2)} = \frac{x^2}{2} + x - x\log(x)$$
$$\sum_{k=1}^{\infty} \frac{(1-x)^{k+1}}{(k+1)(k+2)} = \frac{\frac{x^2}{2} + x - x\log(x)}{(1-x)}$$
I need help here:
I can't integrate because I checked on W|A and there is a dilogarithmic term involved.
How do you express polylogs as indefnite integrals? So that there is no upper or lower bound?
From what I know:
$$Li_2(x) = (-)\cdot\int \frac{\log(x)}{(1-x)}$$
$$Li_2(1-x) = (-)\cdot \int \frac{\log(1-x)}{x}$$
Perhaps we could use integration by parts to get this factor in there?
There is always a question I've had:
How can you define a function $f(a)$ such that $a$ is actually inside the integral? So:
$$f(a) = \int ax^2 dx$$
Usually, textbooks define integral functions as the variable being the upper limit of a definite integral.
So what property/rule of integral, or definition states you can have a function of a variable inside the integral itself? Thanks!
  • #110
Sorry , I missed the definition ... Why is that true ?
  • #111
Oh oh...
That's why it wasn't working.
I used the wrong definition. It is
$$H_k = \int_{0}^{1} \frac{1 - x^k}{1-x} \,dx$$
The $(1-x)$ isn't in brackets...
Please give me some time to think over this. Meanwhile... can you answer the other question I asked?
Question:
  • #112
Olok said:
Question:
You can do the following
\(\displaystyle f(a) = \int^{t_1}_{t_0} g(t,a)\,dt\)
where $t_0,t_1$ are constants.
Indeed , it is just a symbol to define the integral. For example we have
\(\displaystyle \Gamma(a) = \int^\infty_0 t^{a-1} \, e^{-t} \, dt\)
where in this case $f(a) = \Gamma(a) $ and $g(t,a) = t^{a-1} \, e^{-t} $.
Since $a$ is independent of $t$ we can define something like this
$$g(a) = a \int^1_0 f(t) \, dt $$
I don't recall a name for this property but is mainly used to differentiate w.r.t to the variable inserted.
  • #113
I suppose it is a property of integral functions. Anywho.
I worked on the problem, and found out how to do it... until a point.
We understand
$$I = \int_{0}^{1} \left(\sum_{k=1}^{\infty} \frac{1}{(k+1)(k+2)^3} + \sum_{k=1}^{\infty} \frac{x^k}{(k+1)(k+2)^2}\right) \, dx$$
Assuming both of these sums are convergent. I used the formula,
$$\sum_{k=1}^{\infty} x^{n-1} = \frac{1}{1-x}$$ to get a formula for a general $x^{k+2}$.
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)^3} = -Li_3(x) - Li_2(x) - \frac{x^2}{8} + 3x - x\log(1-x) + \log(1-x)$$
If you want to see the workings, I can try to scan it, because it took a few pages... (I used W|A for some integrals, instead of doing integration by parts).
Letting $x=1$, you get
$$\sum_{k=1}^{\infty} \frac{1}{(k+1)(k+2)^3} = -Li_3(1) - Li_2(1) - \frac{1}{8} + 3 - \log(0) + \log(0)$$
Here is the crises, $\log(0)$ is undefined, is it okay to subtract this: $\text{undefined} - \text{undefined}$ ?? Let me know of this property/theorem.
$$= -\zeta(3) - \zeta(2) + \frac{23}{8}$$
I am working on the other part, but was the logarithmic subtraction correct?
Thanks
  • #114
I don't seem to understand how you got that!
You used
$$H_k = \int^1_0 \frac{1-x^k}{1-x}\,dx $$
right ?
  • #115
You used
right ?
FIRST A QUESTION:
I asked this before, but can we do $\log(0) - \log(0) = 0$? Otherwise this idea doesn't work.
Now, the workings:
I'll try to do the best I can.
We had
$$(2)\cdot\int_{0}^{1} \frac{1}{1-x}\left(\sum_{k=1}^{\infty} \frac{1}{(k+1)(k+2)^3} - \sum_{k=1}^{\infty} \frac{x^k}{(k+1)(k+2)^3}\right) \,dx$$
Through Fubini's theorem, you interchange the sum and integral, then $1/(1-x)$ is just a constant for the sum, so you can "extract," that out. Then split the sum, ASSUMING both are convergent. Since I am too lazy to do a test. Actually I don't know how to test a series for convergence anyway...
Then the sum of
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)^3} = -[Li_3(x) + Li_2(x)] - x^2/8 + 3x - x\log(1-x) + \log(1-x)$$
Letting $x=1$, the sum is: $S_1 = -\zeta(3) - \zeta(2) + 23/8$
Dividing the sum of $x^{k+2}$ by $x^2$ we get.
$$\sum_{k=1}^{\infty} \frac{x^{k}}{(k+1)(k+2)^3} = -[Li_3(x) + Li_2(x)]/x^2 - [x^2/8 + 3x - x\log(1-x) + \log(1-x)]/x^2$$
We had
$$= (2)\cdot\int_{0}^{1} \frac{1}{1-x}\left(-\zeta(3) - \zeta(2) + 23/8 - \left(-[Li_3(x) + Li_2(x)]/x^2 - [x^2/8 + 3x - x\log(1-x) + \log(1-x)]/x^2\right)\right) \,dx$$
$$= (2)\cdot\int_{0}^{1} \frac{-\zeta(3) - \zeta(2) + 23/8}{1-x}\left( - \left(\frac{-Li_3(x) - Li_2(x) - \frac{x^2}{8} - 3x + x\log(1-x) - \log(1-x)}{(1-x)x^2}\right)\right) \,dx$$
$$ = (2)\cdot\int_{0}^{1} \frac{-x^2\zeta(3) - x^2\zeta(2) + \frac{23x^2}{8} + Li_3(x) + Li_2(x) + \frac{x^2}{8} + 3x - x\log(1-x) + \log(1-x)}{(1-x)x^2} \,dx$$
I think we should split this, but this integral product should give the final answer.
But how come $\displaystyle \int_{0}^{1} \frac{Li_3(x) + Li_2(x)}{(1-x)x^2} \,dx$ does NOT converge?
  • #116
Let us go step by step first. How did you prove the above formula ?
  • #117
I will post it the second I get home. But for now,
How can I check if an integral converges or not?
I tried the integral
$$\int_{0}^{1} \frac{-Li_3(x) - Li_2(x)}{(1-x)x^2} \,dx$$
But it does not converge. How can I know if the integral, will converge or not BEFOREhand.QUESTION 2: Which types of integrals involving Polylogs converge?
Thanks =)
  • #118
$$\int^1_0 \frac{\mathrm{Li}_2(x)}{1-x}\,dx$$
Does not converge. This can be see using
$$\int^1_0 \frac{\mathrm{Li}_2(x)}{1-x}\,dx = \int^1_0 \frac{\mathrm{Li}_2(1-x)}{x}\,dx$$
Then
$$\mathrm{Li}_2(1-x) = \zeta(2) -\mathrm{Li}_2(x)-\log(x)\log(1-x)$$
$$\int^1_0 \frac{\mathrm{Li}_2(x)}{1-x}\,dx = \int^1_0 \frac{\zeta(2) -\mathrm{Li}_2(x)-\log(x)\log(1-x)}{x}\,dx $$
First integral
$$\int^1_0 \frac{\log(x)\log(1-x)}{x}\,dx = \int^1_0 \frac{\mathrm{Li}_2(x)}{x}\,dx $$
The following integral
$$\int^1_0 \frac{\mathrm{Li}_2(x)}{x}\,dx$$
converges since , function to integrate is continuous so the integral converges.
It remains
$$\int^1_0 \frac{\zeta(2)}{x}\,dx$$
is clearly divergent.
There are many ways to apply , but generally you have to do some change of variable or integration by part to see why the integral diverges. Sometimes , you have to do some computations.
In other cases , you can bound the integral. For example
$$\int^\infty_1 \frac{e^{-x}}{x^2}\,dx$$
How to prove that the improper integral converges ?
$$|\int^\infty_1 \frac{e^{-x}}{x^2}\,dx| \leq \int^\infty_1 | \frac{e^{-x}}{x^2}| \,dx \leq \int^\infty_1 \frac{1}{x^2} < \infty$$
Since the area of the integral is less than a finite area , the integral converges.
  • #119
Then
First integral
It remains
Here's the proof
$$\sum_{k=1}^{\infty} x^{k} = \frac{x}{1-x}$$
$$\sum_{k=1}^{\infty} \frac{x^{k+1}}{k+1} = -x - \log(1-x)$$
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)} = \frac{-x^2}{2} + x - x\log(1-x) + \log(1-x)$$
$$\sum_{k=1}^{\infty} \frac{x^{k+1}}{(k+1)(k+2)} = \frac{-x}{2} + 1 - \log(1-x) + \frac{\log(1-x)}{x}$$
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)^2} = \log(1-x) - x\log(1-x) + 2x - \frac{x^2}{4} - Li_2(x) $$
$$\sum_{k=1}^{\infty} \frac{x^{k+1}}{(k+1)(k+2)^2} = \frac{\log(1-x)}{x} - \log(1-x) + 2 - \frac{x}{4} - \frac{Li_2(x)}{x} $$
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)^3} = -Li_2(x)+ x - x\log(1-x) + \log(1-x) + 2x - \frac{x^2}{8} - Li_3(x) \blacksquare$$
  • #120
Olok said:
Here's the proof
Seems correct. Let us verify it by taking the limit as $x \to 1$.
What do you get ?
Does it agree with the value returned by wolfram.
  • #121
What do you get ?
The issue is with taking the limit.
$\displaystyle lim_{x\to1} \log(1-x)$ does not exist.
  • #122
Olok said:
$$\sum_{k=1}^{\infty} \frac{x^{k+2}}{(k+1)(k+2)^3} = -Li_2(x)+ x - x\log(1-x) + \log(1-x) + 2x - \frac{x^2}{8} - Li_3(x) $$
Take limits of both sides. Don't distribute the limit until you are sure the limit exists.
  • #123
$$\lim_{{x}\to{1}} -Li_2(x)+ x - x\log(1-x) + \log(1-x) + 2x - \frac{x^2}{8} - Li_3(x)$$
$$= \lim_{{x}\to{1}} -Li_2(x) +(\log(1-x))(1 - x) + 3x - \frac{x^2}{8} - Li_3(x)$$
The more interesting case is $\log(1-x)\cdot(1-x)$
$$y = \lim_{{x}\to{1}} (\log(1-x)\cdot(1-x))$$
Let $u = 1-x$ as $x\to1$ we have $u \to 0$
$$y = \lim_{{u}\to{0}} \log(u)\cdot(u) = \lim_{{u}\to{0}} \log(u\cdot e^u)$$
$$e^y = \lim_{{u}\to{0}} 0$$
But then we are back to where we started with $\log(0)$
  • #124
$$\lim_{u \to 0} u \times \log(u) = \lim_{u \to 0} \frac{\log(u)}{\frac{1}{u}} $$
By L'Hospital rule the limit goes to 0.
  • #125
That is very nice, but the denominator is not indeterminate is it? $1/0$ is not indeterminate is it?
$$= \lim_{{x}\to{1}} -Li_2(x) + \frac{23}{8} - Li_3(x)$$
$$= -\zeta(2) + \frac{23}{8} - \zeta(3)$$
Then
$$ \sum_{k=1}^{\infty} \frac{x^k}{(k+1)(k+2)^3} = -\frac{Li_2(x)}{x^2}+ \frac{1}{x} - \frac{\log(1-x)}{x} + \frac{\log(1-x)}{x^2} + \frac{2}{x} - \frac{1}{8} - \frac{Li_3(x)}{x^2}$$
Then we need to integrate:
$$\int_{0}^{1} -\frac{Li_2(x)}{(1-x)x^2}+ \frac{1}{(1-x)x} - \frac{\log(1-x)}{x(1-x)} + \frac{\log(1-x)}{(1-x)x^2} + \frac{2}{(1-x)x} - \frac{1}{8(1-x)} - \frac{Li_3(x)}{(1-x)x^2} \,dx$$
This is the most difficult part of all. Especially because if this is split up, a lot of it does not converge.
out of curiosity: could we use complex analysis to solve the sum we had? Also, can you also help me through some complex analysis, and contour integration? I am quite interested, but I don't have means to learn it except MHB. Help will be appreciated! =)
  • #126
The limit is of the form $\frac{\infty}{\infty}$. which can be solved by L'Hospital rule.
I guess this will be complicated , at least you tried :) . Why don't we stick to the solution using Harmonic numbers ?
Of course.I 'll answer this question in the other thread.
  • #127
But how do we use that formula?
$$\sum_{n=1}^\infty \frac{H_n}{n^q}= \left(1+\frac{q}{2} \right)\zeta(q+1)-\frac{1}{2}\sum_{k=1}^{q-2}\zeta(k+1)\zeta(q-k)$$
Lets consider $n = \displaystyle \sqrt{k+1}$
Then the lower limit will be
$k = 0$
Nevermind, I just realized the $H_n$ won't fit properly... Wow, this is difficult.
  • #128
Ok , I will give you quick exercise
Find
\(\displaystyle \sum_{k\geq 0}\frac{H_k}{(k+1)^2}\)
  • #129
Find
Ok.
Let $n = j+1$
$$\sum_{j=0}^\infty \frac{H_{j+1}}{(j+1)^2}= \left(1+\frac{2}{2} \right)\zeta(3)-\frac{1}{2}\sum_{k=1}^{0}\zeta(k+1)\zeta(3-k)$$
$$\sum_{j=0}^\infty \frac{H_{j+1}}{(j+1)^2} =
\sum_{j=0}^\infty \frac{H_{j} + \frac{1}{j+1}}{(j+1)^2} = \sum_{j=0}^\infty \frac{H_{j}}{(j+1)^2}+ \sum_{j=0}^{\infty} + \frac{1}{(j+1)^3}$$
Originally, the formula states:
$$\sum_{n=1}^\infty \frac{H_n}{n^q} = \sum_{n=0}^\infty \frac{H_n}{n^q} - 1$$
Then
$$\sum_{n=1}^\infty \frac{H_j}{(j+1)^2} = \sum_{n=0}^\infty \frac{H_j}{(j+1)^2} - 1 = (2)\zeta(3) - \frac{1}{2}(indeterminate)$$
I checked W|A, the sum involving the $q-2$ is indeterminate, which is bad news.
  • #130
Olok said:
Ok.
Let $n = j+1$
Then
By definition if the upper index of the sum is 0 then the sum is 0.
  • #131
Then why does W|A return it as indeterminate?
  • #132
W|A can't solve it because the lower index is greater than the upper index.
So we have to add the following constrains $q>1$ and when $q=2$ the series is equal to 0. It is just a constrain that we defined on that particular case.
Any way, Let us assume that we can't find the summation when $q=2$ so we have to find
$$\sum_{k\geq 1} \frac{H_k}{k^2}$$
Can you think of a way to evaluate it without using that formula ?
  • #133
Not really. I suppose the formula is the best way, and I suppose by definition the sum is $0$.
$$\sum_{n=1}^\infty \frac{H_j}{(j+1)^2} = \sum_{n=0}^\infty \frac{H_j}{(j+1)^2} - 1 = (2)\zeta(3) - 0 - 1 = 2\zeta(3) - 1$$
  • #134
Hint :
use that
$$\int^1_0 \frac{1-x^n}{1-x}\,dx = H_n$$
  • #135
ZaidAlyafey said:
Hint :
use that
That is what I did a while ago (with the other sum) and it became a mess as you saw.
$$\sum_{k=1}^{\infty} \frac{H_k}{k^2}$$
$$H_k = \int_{0}^{1} \frac{1-x^k}{1-x} \,dx$$
$$S = \int_{0}^{1} \frac{1}{1-x} \sum_{k=1}^{\infty} \frac{1-x^k}{k^2} \,dx$$
Assuming the parts of the sum are convergent we get:
$$S = \int_{0}^{1} \frac{1}{1-x} \left(\zeta(2) - \sum_{k=1}^{\infty} \frac{x^k}{k^2}\right) \,dx$$
$$S = \int_{0}^{1} \frac{1}{1-x} \left(\zeta(2) - Li_2(x)\right) \,dx$$
$$S = \lim_{{x}\to{1}} -\zeta(2)\log(1-x) - \int_{0}^{1} \frac{Li_2(x)}{1-x} \,dx$$
The Li_2(x)/(1-x) is the hard part. Integration by parts or some other strategy?
  • #136
The limit doesn't exist so you cannot separate the two integrals because they are divergent as I said previously.
$$Li_2(x)+Li_2(1-x) = \zeta(2)-\log(x)\log(1-x)$$
$$\zeta(2)-Li_2(x) = Li_2(1-x)+\log(x)\log(1-x)$$
  • #137
$$S = \int_{0}^{1} \frac{Li_2(1-x) + \log(x)\log(1-x)}{1-x} \,dx$$
Assuming this integral is convergent, I suppose can split this.
$$S = -Li_3(1-x)]_{0}^{1} - \text{problem}$$
Okay, this is depressing.
And very hard.
  • #138
Try integration by parts , don't quite so easily.
  • #139
NEW IDEA!
$\log(1-x)\log(x) = -Li_2(1-x) - Li_2(x) + \zeta(2)$
$$S = \int_{0}^{1} \frac{-Li_2(x) + \zeta(2)}{1-x} \,dx$$
First the antiderivative:
$$S = (\zeta(2) - Li_2(x)) + \int \frac{\log^2(1-x)}{(1-x)} dx$$
Let $\log(1-x) = u \implies du = \frac{1}{1-x}$
$$S_{antiderivative} = (\zeta(2) - Li_2(x)) + \frac{\log^3(1-x)}{3}$$
$$S = \lim_{{x}\to{1}} -Li_2(x) + \frac{\log^3(1-x)}{3}$$
Wait, does this limit exist?
  • #140
Olok said:
NEW IDEA!
I don't understand how you got that. Moreover , S shouldn't be used twice since the first is definite and the second is indefinite integral.
