Integration using Beta and Gamma Functions
In summary, Polya said that it is better to try an easier problem first. So let's try,$$\int^\infty_0 \frac{\log(1+x^2)}{1+x^2}\,dx$$This can be used to solve many problems, like\int^\infty_0 \frac{\log(1+x^2)}{1+x^2}\,dx
  • #141
ZaidAlyafey said:
I don't understand how you got that. Moreover , S shouldn't be used twice since the first is definite and the second is indefinite integral.
I will need some help. Can you start me off on the integral? I can't think anything that will help right now.
  • #142
  • #143
ZaidAlyafey said:
Here is the approach.
Oh I see.
How is
$$\int_{0}^{1} \frac{\log(1-x)\log(x)}{x} \,dx = \int_{0}^{1} Li_2(x)/x \,dx$$
I believe $\log(1-x)\log(x) = -(Li_2(x) + Li_2(1-x)) + \zeta(2)$
  • #144
Olok said:
Oh I see.
How is
Try integration by parts where I used that
$$Li_2(x) =- \int^x_0 \frac{\log(1-t)}{t}\,dt$$
  • #145
I see.
But how does this all relate to the original sum?
  • #146
Olok said:
I see.
Which original sum ? Isn't the question how to solve
\(\displaystyle \sum_{n=1}^\infty \frac{H_n}{n^2}\)
without using the formula ?
  • #147
No, the one for the integral.
  • #148
It was just an exercise to know how to solve Euler sums without using the formula.
  • #149
How how can you solve:
$$\sum_{n=1}^{\infty} \frac{H_n}{(n+1)^2}$$
With the use of the formula?
Please, will you show me this example, and I can do the sum for the integral.
  • #150
Look at this answer.
  • #151
In the answer,
how is
$$\frac{H_n}{(n+1)^2} = \frac{H_{n+1}}{(n+1)^2} - \frac{1}{(n+1)^3}$$
$$= \frac{H_{n+1}}{(n+1)^2} - \frac{1}{(n+1)}\cdot\frac{1}{(n+1)^2}$$
$$= \frac{1}{(n+1)^2}\left(H_{n+1} - \frac{1}{(n+1)}\right)$$
  • #152
The replier used that
$$H_{n+1} = H_n +\frac{1}{(n+1)}$$
Hence
$$H_{n} = H_{n+1} -\frac{1}{(n+1)}$$
I think he made a mistake because the index should change when making the substitution in the second line.
  • #153
Hence
Wait, why would the index change?
$$\sum_{k=1}^{n} \frac{1}{k} = H_n$$
$$\sum_{k=1}^{n+1} \frac{1}{k} = \sum_{k=1}^{n} \frac{1}{k} + \frac{1}{n+1} = H_n + \frac{1}{n+1}$$
  • #154
The replier claimed that
$$\sum_{n=1}^\infty \frac{H_{n+1}}{(n+1)^2}-\frac{1}{(n+1)^3}= \sum_{n=1}^\infty \frac{H_{n}}{n^2}-\frac{1}{n^3}$$
But this is not correct , can you see why ?
  • #155
By the way , I got a question you might like. Find
$$\int^1_0 \mathrm{Li}_k(x)\,dx$$
  • #156
For the other post, yes I see why it is not correct.
If you let u= n+1, then when n=1, $u=2$, which should be the index.
$$Li_k(x) = \sum_{n=1}^{\infty} \frac{x^n}{n^k}$$
$$\int_{0}^{1} Li_k(x) \,dx = \sum_{n=1}^{\infty} \int_{0}^{1} \frac{x^n}{n^k} \,dx$$
From Fubini's theorem, I suppose we were allowed to interchange.
$$\int_{0}^{1} Li_k(x) \,dx = \sum_{n=1}^{\infty} [\frac{x^{n+1}}{(n+1)n^k}]_{0}^{1}$$
$$\int_{0}^{1} Li_k(x) \,dx = \sum_{n=1}^{\infty} \frac{1}{(n+1)n^k}$$
Let $S = \displaystyle \sum_{n=1}^{\infty} \frac{1}{(n+1)n^k}$
$$\frac{1}{(n+1)n^k}$$
I think we should decompose this.
$$ = \frac{A}{(n+1)}$$
But we cannot because of $k$. I am quite stumped.
  • #157
Ok, I will give you the starting point
$$\sum \frac{1}{(n+1)n^k} = \sum \frac{1+n-n}{(n+1)n^k} =\sum \frac{1}{n^k}-\frac{1}{(1+n)n^{k-1}}$$
Hence this can be written as
$$S_k = \zeta(k) -S_{k-1} \, \,\,\, k\geq 2$$
  • #158
So,
This goes in a continuous cycle.
$$L = \zeta(k) - L$$
$L = \zeta(k)/2$
What can we do?
  • #159
Olok said:
So,
How is that true ?
  • #160
ZaidAlyafey said:
How is that true ?
Nevermind:
$S(k) = \zeta(k) - S(k-1)$
then
$S(k-1) = \zeta(k-1) - S(k-2)$
Then
$S(k-2) = \zeta(k-2) - S(k-3)$
So,
$S(k) = \zeta(k) - (\zeta(k-1) - S(k-2))$
$S(k) = \zeta(k) - \zeta(k-1) + S(k-2)$
$S(k) = \zeta(k) - \zeta(k-1) + \zeta(k-2) - S(k-3)$
I really don't understand how to sum the series.
  • #161
Olok said:
Nevermind:
then
Then
So,
You are on the correct path but you have to know the stopping criteria. That means the base case.
we know that
$$S(1) = \sum_{n\geq 1}\frac{1}{n(n+1)} = 1$$
So what is the general form for $S(k)$ ?
  • #162
we know that
As you said earlier,
$$S(k) = \zeta(k) - S(k-1)$$
$$S(2) = \zeta(2) - S(1)$$
$$S(3) = \zeta(3) - S(2)$$
$$S(4) = \zeta(4) - S(3)$$
I am not sure what you mean here?
  • #163
If you sum up these three formulas what do you get ? Can you generalize ?
  • #164
$$S(k) = \zeta(k) + \int_{0}^{1} Li_{k-1}(x) \,dx$$
  • #165
You already did it correctly , what is the problem , exactly ?
Each time you are subtracting a value from $k$ so eventually we will reach $S(1)$.
Olok said:
Nevermind:
then
Then
So,
This also can be written as
$$S(k) = \zeta(k) - \zeta(k-1) + \zeta(k-2) -\cdots -(-1)^n\zeta(k-(n-1))+(-1)^nS(k-n)$$
  • #166
Would you mind giving it away? I don't think I am getting anywhere.
  • #167
We have
Let $n=(k-1)$
$$S(k) = \zeta(k) - \zeta(k-1) + \zeta(k-2) -\cdots -(-1)^{k-1}\zeta(2)+(-1)^{k-1}S(1)$$
  • #168
ZaidAlyafey said:
We have
Let $n=(k-1)$
$$S(k) = \sum_{k=1}^{n} (-1)^{k+1} \zeta(n-k)$$
  • #169
No , that is not correct. Try writing the partial sums of your series. Is it the same ?
  • #170
$$S(k) = \sum_{z=0}^{k-1} \zeta(k - z)$$
  • #171
1- The sums should alternate , right ?
2- The last term is $\zeta(k-(k-1))=\zeta(1)$ which is divergent.
3- Where is the last term $(-1)^{k-1}S(1)$ ?
  • #172
Lets see.We had:
$$ S_k = \zeta(k) - S_{k-1} $$
$$S_{k-1} = \sum_{n=1}^{\infty} \frac{z^{n}}{n^{k-1}} = Li_{k-1}(x)$$
$$S_k = \zeta(k) - Li_{k-1}(x)$$
But I can't seem to get how to have a series representation...
  • #173
That should be the final answer
\begin{align}
\int_0^1\mathrm{Li}_p(x)\,\mathrm{d}x
&=\sum_{k=0}^{p-2}(-1)^k\zeta(p-k)+(-1)^{p-1}\sum_{k=1}^\infty\frac1{k(k+1)}\\
\end{align}
You can use induction if you wish.
  • #174
\begin{align}
\end{align}
How did you possibly derive that?
By the way, I looked at this page:
http://mathhelpboards.com/calculus-10/integration-lessons-continued-12240.html#post63930
The one you posted on 30 November. Did you think of those proofs such as the one involving $H_k^(p)$ yourself? Firstly, you are extremely smart, secondly, how do you think of these ideas?
Thanks!
  • #175
You start by noticing a pattern, then you finish by induction.
For example try to evaluate
$$\int^1_0 Li_3(x)\,dx$$
Do you see the pattern ? Try other values.
The one you posted on 30 November. Did you think of those proofs such as the one involving $H_k^{(p)}$ yourself? Firstly, you are extremely smart, secondly, how do you think of these ideas?
Thanks!
Basically , once you work with a problem for a long time , it becomes easier to establish some proofs. Usually when you read about these topics you get more ideas and techniques to solve similar problems.
