- #71
- 8,173
- 1,903
No, it claims it makes the same predictions. Again, the below statements are uncontroversial (or should be):PeterDonis said:No, in MWI, no change. MWI makes the same predictions as QM. Just as any QM interpretation does.
Start with an ordinary EPR pair, measure the polarization of photon 1.
In MWI, there is a splitting and there is an H> branch for photon 1. The paired photon 2 is H> always, even if it is distant at the time of measurement of photon 1, right? Note sure in the MWI world if that is proof of nonlocality (AAD). But let's skip that for the moment. What is unquestioned is that photon 2 is H> in the H> branch of photon 1, and continues to evolve deterministically in that branch. Further, it's polarization is DEFINITELY H> in that branch, there is nothing remaining to be settled about that point. Similar reasoning applies to the V> side. See this description from Blaylock (2009), explaining locality in MWI:
"For instance, two photons with entangled polarizations might be produced from the decay of a parent particle. In this case the entangled state is produced at one location, where the parent decays, and its immediate effects are limited to that one spacetime point. Thereafter, the photons may go their separate ways, and as they separate they carry the correlation to separate locations. It is the original correlation produced at a single location that guarantees measurements will always match in any experiment in any branch where observers compare notes. In this respect the spread of the correlation to distant locations is akin to the delivery of newspapers, where a common story is generated at a central location and disseminated all over the neighborhood. In the many-worlds context, however, different branches (which originally split at a common location) carry different editions of the newspaper."
There is nothing indefinite in this or any explanation of MWI regarding entangled pairs: Matching settings on photons 1 and 2 always produce matching results. In the H> branch, Photons 1 and 2 are both H> and evolve deterministically as such. (Ditto for the V> branch of course.) It couldn't be otherwise, as the H> photon 2 is going its separate merry way.
So if you place an H> filter in the path, then there should be no change to the results in the H> branch. But you acknowledge that no swap is later possible if that is done (which is what QM predicts of course). But QM predicts that for a completely different reason. In QM, it is the context that matters - a future context, and the full future context at that. But that cannot be the case in MWI, because no future nonlocal context can EVER be the basis for a deterministic theory's earlier evolution.
Deutsch 2011 on MWI (agreeing with Einstein): "Einstein's (1949) criterion for locality is that for any two spatially separated physical systems S1 and S2, ‘the real factual situation of the system S2 is independent of what is done with the system S1’."
Vaidman 2014 on MWI: Quantum theory is correct, but determinism is correct too. ... Consequently, Heisenberg Uncertainty Relations, Robertson Uncertainty Relations, Kochen Specker theorem, the EPR argument, the GHZ setup, and the Bell inequalities are all irrelevant for analyzing fundamental properties of Nature.
Clearly the tension between locality, determinism is present and recognized by authors. But nowhere do they address the obvious requirements of MWI that conflict with experiment. Photon 2 is H> if Photon 1 is H>. That means a choice by a distant experimenter to swap entanglement can't lead to new correlations between photons 1 and 4 (Deutsch via Einstein). And it means that the deterministic (Vaidman) evolution of photon 2 cannot lead to the swap needed for the Zeilinger et al experiment (which Vaidman denies is even relevant, although he did have a hand (hand-waving) at GHZ in one paper).
Every MWI proponent touts the benefits of determinism in MWI) a la Vaidman. Even those proponents of MWI who acknowledge some element of nonlocality agree with the essentials of Deutsch on locality. And I have yet to see the full MWI treatment on swapping and GHZ as I am trying to get here.
If you think that after the measurement of photon 1 as H> that MWI and QM have matching explanations, that is your opinion. But that is a matter of faith, not logic nor experiment. I reject the MWI claims unless the specifics can be explained to someone familiar with these new modern experiments. Basically, in the past 20 years, MWI proponents have struggled to get a grip on those experiments and have had to deny their relevance in order to maintain any degree of credibility.
