- 10,414
- 1,589
I have some general comments about the discrepancies between the geodesic congruence and the Born rigid congruence as far as its impact on distance goes. Finding the exact expression for the congruence whose expansion is exactly zero should be theoretically possible but I didn't do it, it would be a lot of work. I settled for an expression that I believe should be accurate to the second order. To be specific, since f(t) has a magnitude of 10^-21, I counted the "order" of the discrepancy by the number of times f or any of its derivatives were multiplied together. The lowest order term in the expansion by this criterion was one proportional to ##f \, df/dt##.
The geodesic congruence has an expansion of the first order in f, namely:
$$\frac{\frac{df}{dt}}{1 + 2\,f(t)}$$
Thus the expansion of the almost-rigid congruence is about 10^21 times lower than the expansion of the geodesic congruence, because it's proportional to ##f df/dt## and f is so small.
For the metric
$$-dt^2 + \left( 1 + 2 f(t) \right) ds^2 $$
the almost expansion-free congruence is given by:
$$\partial_t - s \frac{df}{dt} \partial_s$$
Actually one needs to normalize this first to calculate the expansion, but it's easier to write without the normalization.
Physically, we can interpret this as saying the geodesic congruence is approximately moving with some velocity ##v = -s \frac{df}{dt}## relative to the rigid congruence. Because of this relative motion, we expect discrepancies in second order in the relative velocity ##v = s\,df/dt## due to Lorentz contraction. We are assuming f is small, and we are assuming that s is small enough that s*f is still small, and we are assuming that f is changing slowly enough that df/dt is also small.
Because ##f(t) \approx 10^{-21}## in Ligo, agreement to the second order means that the two concepts of distance agree to about 1 part in 10^20 or so. (Possibly a little less, depending on how big s is, and how fast f changes - but still an excellent approximation).
For the metric
