- #71
- 24,488
- 15,026
If you want to derive macroscopic behavior you also use Born's rule, using an appropriate statistical operator like the usual equilibrium operators (microcanonical, canonical, grand canonical).
zonde said:You apply Born rule to measurements only. You do not apply Born rule to other interactions. At least this is my understanding.
And my point is that Born rule treats microscopic reality differently too. Before you apply Born rule you don't describe particles. You describe modes not particles.
vanhees71 said:If you want to derive macroscopic behavior you also use Born's rule, using an appropriate statistical operator like the usual equilibrium operators (microcanonical, canonical, grand canonical).
vanhees71 said:The point is that the pointer states have very small (relative) standard deviations, so that you can treat them as if they were determined as in classical physics.
That is so only after the information update (not to use the dirty c-word). But update needs measurement, and measurement needs "classical" pointers states, so the whole explanation becomes circular.vanhees71 said:The point is that the pointer states have very small (relative) standard deviations
Demystifier said:That is so only after the information update (not to use the dirty c-word). But update needs measurement, and measurement needs "classical" pointers states, so the whole explanation becomes circular.
Collapse.Lord Jestocost said:As I am new in "PhysicsForum": What the heck is the "dirty c-word"?
Consider a Stern-Gerlach apparatus. It has two detectors, one in the upper position and the other in the lower position. When one particle is sent through the apparatus, only one of the detectors clicks. In this case, did the other detector also interacted with the particle (measured object)?vanhees71 said:If I measure something, of course the apparatus has interacted with the measured object, and you get a clear pointer reading.
So at what point did the particle decide that it will go to one detector and not to the other? Did it happen at the moment of interaction with the detector, or did it happen before that? Does the question even make sense to you?vanhees71 said:Obviously not, because then (taken it as a very good detector with close to 100% detection efficiency) you'd see 2 spots in any experiment with an intensity due to the ##|\psi|^2## distribution. The very fact that this is not the case rules out the original interpretation of the wave function as a classical field describing the (charge) density of the particles by Schrödinger.
The question was not "How?" but "When?"vanhees71 said:It doesn't make sense to ask, how the particle "made a decision".
As zonde observed, the question is when the decision is made, not how.vanhees71 said:QT tells us that this is just random with probabilities given by Born's rule. It doesn't make sense to ask, how the particle "made a decision".
Here is why it is problematic. You simultaneously assume thatvanhees71 said:It's of course made when the detector "clicks" (or writes the information to any kind of storage). I don't know, why this is in any sense "problematic" or "mysterious".
Right. It could even be necessary to give up both 1) and 3) to save 2).Demystifier said:Here is why it is problematic. You simultaneously assume that
1) The measured system (particle) exists even before measurement.
2) The dynamics is local.
3) The random decision happens when the detector clicks (not before).
Indeed, each assumption by itself seems reasonable. But the problem is that they cannot all be simultaneously true. At least one must be wrong. You must give up at least one of them.
Let me explain why they cannot all be true. From 3) and 1) it follows that, immediately before the click, the system exists not only near one detector, but near both of them. But then, puff, at the time of click, the system suddenly ceases to exist near the detector that didn't click. How did this part of the system knew that the click happened near the other part? Since the two parts are spatially separated, there must have been some non-local (even if random) mechanism, which contradicts 2). Hence assumptions 1) and 3) contradict 2), which implies that it is not possible that all three assumptions are true.
And yet, you seem not be ready to give up any of the three assumptions. That's the problem.
Not really. To save 2) it is sufficient to give up 3). Example is Bohmian mechanics, which, in absence of entanglement, is local.RockyMarciano said:Right. It could even be necessary to give up both 1) and 3) to save 2).
Demystifier said:Not really. To save 2) it is sufficient to give up 3). Example is Bohmian mechanics, which, in absence of entanglement, is local.
Nice number. Long ways from the biblical one but still.EDIT: This is my 7777th post.
I don't agree that standard QT ensures 1). The standard QT talks only about probabilities of measurement outcomes. In particular, the conservation of charge in standard QT says that if you measure charge at two times, then you will get the same number at both times. But it does not claim that charge will exist between the two measurements. It is an extra assumption which may or may not be true, but cannot be tested by experiment. It is a reasonable assumption indeed, but it cannot be strictly derived from principles of standard QT.vanhees71 said:Well, according to QT there's not more knowable about your particle than the probabilities for the outcome of measurements. The probabilities evolve from a given (prepared) initial to the state at the time of detection, and what we get (repeating the experiment with equal preparations) the distribution by measuring the observable we are interested in. According to the standard model of elementary particles the interactions are local. So your point (1-3) are all well included in the standard model: (1) is ensured by the conservation laws: If I prepare, e.g., some particle with a given charge, then at least this charge must exist all the time; (2) is implemented by construction in any local and microcausal relativistic QFT, (3) is just the only way to answer reasonable the "when" question. How else would you define the "time of detection"?
Sorry to get back to this but aren't precisely the symmetry principles-conservation laws what makes macro systems have (approximately) well defined values by preserving measurements(i.e. measurability)?stevendaryl said:Symmetry principles aren't the goal. The goal is modeling the world. If the world obeys certain symmetry principles, then of course, we should find out what they are, but finding out symmetry principles isn't the goal.
That is the heart of the measurement problem. Why do macroscopic systems have well-defined macroscopic values?
Another counterargument:vanhees71 said:(1) is ensured by the conservation laws: If I prepare, e.g., some particle with a given charge, then at least this charge must exist all the time
So you (seem to) introduce a step function. If probability of conservation is smaller than 1, then charge does not exist between measurements. If probability of conservation is strictly 1, then charge exists between measurements.vanhees71 said:Well, then you could measure that baryon number is not conserved and then you could indeed only give a probability for still finding the same baryon number as you started with.
Another reason why your reasoning doesn't make sense (to me).vanhees71 said:Well, then you could measure that baryon number is not conserved and then you could indeed only give a probability for still finding the same baryon number as you started with.
Let me put this point forward.Demystifier said:But the goal of dynamics is to describe the change, i.e. to describe the behavior of quantities which are not conserved.
How would you reconcile this with the fact that measurements must be possible in a dynamical world for science to make sense(for different local measurements to be coherent with one another) which seems to imply that at least there must be conservation laws for dynamical measuring tools?Demystifier said:Let me put this point forward.
As an extreme case, consider the Lagrangian
$$L(q,\dot{q})=0$$
This Lagrangian is invariant under any conceivable transformation, so by Noether theorem everything is conserved in this theory. In other words, in this theory, there is no dynamics at all.
This demonstrates my more general point that conservation laws show that some quantities are not dynamical. But the point of dynamics is to describe quantities which are dynamical. So conservation laws, although very useful, do not describe dynamics. Conservation laws describe non-dynamics; they tell us which of the potentially interesting quantities are not dynamical, so can be excluded from further dynamical considerations.
I've not said what you seem to have understood. All I said was what holds for any unstable particle: You prepare it, and then with some probability it's decayed after a given time. That's all you can know in such cases. I still don't get, what should be a problem with that. To the contrary thanks to Q(F)T we have a theory to describe such decays very well.Demystifier said:So you (seem to) introduce a step function. If probability of conservation is smaller than 1, then charge does not exist between measurements. If probability of conservation is strictly 1, then charge exists between measurements.
Don't you have a feeling that there should be a continuous transition, that the difference between 1 and 0.99999999 should not be so radical?
To my mind, assumptions 1) and 2) are misleading when thinking about quantum phenomena. These assumptions are based on classical conceptions.Demystifier said:Here is why it is problematic. You simultaneously assume that
Note that the argument above is even simpler than the Bell theorem, because the system studied above does not involve entanglement. The Bell theorem derives a contradiction by assuming 1), 2) and entanglement. The argument above derives a contradiction by assuming 1), 2) and 3).
I don't see how this implies a need for conservation laws.RockyMarciano said:How would you reconcile this with the fact that measurements must be possible in a dynamical world for science to make sense(for different local measurements to be coherent with one another) which seems to imply that at least there must be conservation laws for dynamical measuring tools?
I mean that something must be conserved for measurements being valid regardless where and when they are performed and how(at which energy, etc), i.e. for the physics not to depend on any special factor in a dynamical or changing context.Demystifier said:I don't see how this implies a need for conservation laws.
Well, to measure a distance with a meter, the length of meter should not change. But there is no law of conservation of length. What we need here is stability, not conservation laws.RockyMarciano said:I mean that something must be conserved for measurements being valid regardless where and when they are performed and how(at which energy, etc), i.e. for the physics not to depend on any special factor.
how do you maintain this stability without conservation laws in a dynamical context?Demystifier said:Well, to measure a distance with a meter, the length of meter should not change. But there is no law of conservation of length. What we need here is stability, not conservation laws.
