- #176
- 8,615
- 4,649
Concerning the misconceptions in the interpretation of vacuum polarization in QED via virtual particles, see the discussion here.
Hi @A. Neumaier:A. Neumaier said:No. In a quantum field theory of gravity and matter, all massive physical particles also carry a gravitational field; everything is completely analogous. A static gravitational field behaves quantum mechanically in the same way, except that it can also produce two photons, because photons are their own antiparticles. Or two neutrinos, etc.. There is no energy barrier for photon production since photons are massless, but to achieve a noticeable effect, the field has to be extremely strong.
No. The loss of energy is encoded in the distortion of the metric of the 3-dimensional space when moving the time of slicing spacetime into 3D spaces at fixed times. Note that in a space-time view, the latter corresponds to dynamics!Buzz Bloom said:does this mean that when a particle pair is created, and the particles do not annihilate each other, the corresponding loss of energy in the field is manifested by a corresponding change in the distortion of space-time?
Hi @A. Neumaier:A. Neumaier said:No. The loss of energy is encoded in the distortion of the metric of the 3-dimensional space when moving the time of slicing spacetime into 3D spaces at fixed times. Note that in a space-time view, the latter corresponds to dynamics!
Of course, if the mass of a black hole is reduced, the gravitational field everywhere also weakens.Buzz Bloom said:the energy in the entire field outside the EH has been reduced by the energy of the created particle pair?
Hi @A. Neumaier:A. Neumaier said:Of course, if the mass of a black hole is reduced
The pair is initially created (spontaneously, according to Born's rule of quantum mechanics) near the horizon from the field of the black hole, which subtracts energy corresponding to two masses from the black hole. One of the particles returns into the black hole, while the other leaves. The balance is one lost particle mass. Maybe this link helps.Buzz Bloom said:he only thing that crosses the EH is one of the created pair particles going from the outside to the inside. How can this reduce the mass inside?
Hi @A. Neumaier:A. Neumaier said:The pair is initially created (spontaneously, according to Born's rule of quantum mechanics) near the horizon from the field of the black hole, which subtracts energy corresponding to two masses from the black hole.
Note that the black hole is the whole nonlocal object including the field - not just the mass concentration in its center. Even classically, the Schwarzschild metric defining a class of isolated black holes is an extended object, not just the singularity, and also not just ending at the event horizon. (An observer crossing the event horizon doesn't notice anything special!)Buzz Bloom said:the physical mechanism that causes a subtraction of energy corresponding to two masses from inside the EH when the particle pair is created outside the EH. Do these two events, one inside and one outside the EH, occur simultaneously?
You could try the forum Special and General Relativity, where specialists on general relativity might answer. (If you do so, please place here a link to the new discussion.) But your questions are of a kind nobody can answer to your satisfaction since they are based on the assumption that quantum field processes can be dissected into elementary pieces. If you are trying to do this you only end up in subjectively animating virtual reality. Thus you are likely to generate only more confusion. If you'd study the matter yourself (by going to the formal literature on the subject) you'd find that as you get more insight you'll gradually change your view of which kind of questions one can reasonably expect to answer.Buzz Bloom said:Do you think it might be useful for me to start a new tread specifically on this question which might attract some additional PF participants into the discussion?
Hi @A. Neumaier:A. Neumaier said:If you'd study the matter yourself (by going to the formal literature on the subject) you'd find that as you get more insight you'll gradually change your view of which kind of questions one can reasonably expect to answer.
These are not classical events! Like everywhere in quantum field theory, one can interpret only the end result of complicated calculations. One cannot say more about the process than the analogy of flow mentioned in my previous post.Buzz Bloom said:a single event involves (1) changes at a distance from the center mass of the BH (particle creation outside the EH) and also (2) changes (the total vanishing of a matter particle and its mass) some distance away close to the center of the BH
A. Neumaier said:your questions are of a kind nobody can answer to your satisfaction
Hi @A. Neumaier:A. Neumaier said:Like everywhere in quantum field theory, one can interpret only the end result of complicated calculations.
A particle cannot self annihilate. Apart from that 1 and 2 are ok. But not 3. At the center of the black hole are no particles, only (semiclassically) a singularity corresponding to the gravitational field of a point mass. This mass is a parameter that will have decreased. What one has instead in full quantum gravity is unknown.Buzz Bloom said:Would it be OK to say that one "end result" of the Hawking Radiation phenomenon is the following?
1. One particle of a pair created by the HR phenomenon near the outside of the EH, which does not self annihilate, will have escaped from the vicinity of the BH.
2. The other particle of the pair will have crossed to the inside of the EH.
3. One or more particles which are constituents (quarks and/or gluons?) of the BH mass near the center of the BH will have disappeared without having had its/their mass converted to corresponding energy.
Hi @A. Neumaier:A. Neumaier said:A particle cannot self annihilate.
Well, I am feeling that I am finally making some progress. 2 out of 3 ain't so bad. ;-)A. Neumaier said:1 and 2 are ok
Is the above description based on QG, or might it also be a correct description based on a combination of particle physics together with GR, or perhaps based on just GR alone?A. Neumaier said:At the center of the black hole are no particles, only (semiclassically) a singularity corresponding to the gravitational field of a point mass.
It never will. The two particles created will have opposite momentum, hence fly in opposite directions and are very unlikely to meet again.Buzz Bloom said:the pair did not self annihilate.
The singularity corresponds to the classical GR description. Particles will fly into the singularity in a very short (external) time and disappear. The quantum version is unknown until we have a proper theory of quantum gravity plus matter.Buzz Bloom said:Is the above description based on QG, or might it also be a correct description based on a combination of particle physics together with GR, or perhaps based on just GR alone?
Thus here.Buzz Bloom said:The thread is:
Qs re Hawking Radiation – Part I
I copy the target link from the ''bookmark'' position at the bottom of each post into the clipboard, then mark the text for the link using the chain symbol in the edit toolbar, paste the text from the clipboard into the free space for the link address, and remove the trailing text ''/bookmark/''.Buzz Bloom said:How do you create a link like that?
Hi @A. Neumaier:A. Neumaier said:the ''bookmark'' position at the bottom of each post
So there are no particles as "force carriers", correct?mfb said:The fields.
https://en.wikipedia.org/wiki/Force_carriermfb said:Depends on your interpretation of "force carriers".
ftr said:https://en.wikipedia.org/wiki/Force_carrier
It seems in one place it can be said that the field is a mathematical description of the particle and does not exist if an ACTUAL particle is not there.
Talk about physics is indeed done in whatever way it seems convenient.ftr said:It seems physics is done which way is convenient at the time.
That is certainly wrong.ftr said:It seems in one place it can be said that the field is a mathematical description of the particle and does not exist if an ACTUAL particle is not there.
That is right.ftr said:Then again it seems that the field can exist EVEN if a particle does not show up, as in Higgs for example.
Physics is not about "reality", it is about making good predictions, if different models can make the same good predictions then they are equally fine. In particular, the predictions are from quantum field theory, and QFT does not care about our words "particles" and "fields".ftr said:It seems physics is done which way is convenient at the time.
jtbell said:Where exactly did you find what I put in bold face?
mfb said:That is certainly wrong.
The first sentence is nonsense. The field always exists (in the sense that one can in principle measure the field expectations anywhere). In the special case where the field primarily consists of one or more elementary excitations of the vacuum state it can be described approximately in terms of particles. For interacting fields, the particle interpretation is strictly valid (without approximation) only in an asymptotic sense - for times ##t\to\pm\infty##.ftr said:It seems in one place it can be said that the field is a mathematical description of the particle and does not exist if an ACTUAL particle is not there. Then again it seems that the field can exist EVEN if a particle does not show up, as in Higgs for example.
If you refrain from too much speculation, aka "interpretation", the QM wave function (appropriate for a part of non-relativistic physics, where the particle numbers are strictly conserved) has a very clear meaning, providing the probabilities for the outcome of measurements via Born's Rule. From a physics point of view there's not more but also no less to it than that, and there's nothing controversial about it since this "minimal interpretation" is very well confirmed by all the very accurate experimental tests of QM we have available these days.ftr said:How I understand QFT is that it is a generalization of QM wave function which itself has an unwieldy and controversial existence. Certain computations FROM the wavefunction can be interpreted as a physical outcome. And yet in QFT some of those are also become controversial like position. EVEN then the single particle state is only an approximation, DR A. Neumaier will tell you that. The uninterpretable "virtual particles" also point to the mathematical nature of fields.
I am not saying that it is wrong using them I just think there should be something that has a better picture.
A. Neumaier said:The first sentence is nonsense. The field always exists (in the sense that one can in principle measure the field expectations anywhere).
vanhees71 said:There's one electron field (Dirac field) in the standard model of elementary particle physics. Why should there be more than one? Perhaps I don't understand your question right...
