Motion with Time-Dependent Angular Acceleration
The discussion centers on understanding a problem involving motion with time-dependent angular acceleration. A participant expresses confusion about how to start solving the question. A hint is provided, suggesting the use of the equation α = -γω as a starting point. Another participant points out that the original information states α = -Aω and questions the relevance of substituting A with γ. The conversation emphasizes the importance of visualizing the problem and accurately representing forces and vectors.
Zoubayr
A sphere is initially rotating with angular velocity w_0 in a viscous liquid. Friction causes an angular deceleration that is proportional to the instantaneous angular velocity,α=-Aw, where A is a constant. Show that the angular velocity as a function of time is given by
w=w_0 exp(At)
w=w_0 +∫α dt
I am not understanding how to even start the question
BvU said:
write ##\alpha = -\gamma \omega##
The info in post #1 says ##\alpha = -A \omega##. Not sure how it helps to replace A with ##\gamma##.
@Zoubayr , since you are given the target solution, it is easier to work backwards from there.
Often it helps to draw a picture of the problem. Then represent forces on any objects as arrows as the are vectors. You can do the same with accelerations and velocities, just make sure you don't confuse the different vectors.
Oops, not thinking, too fast, etc...
Sorry about that.
Thanks for putting it right !
