Orbital velocities in the Schwartzschild geometry
In summary: Yes, it is very wrong.From the correct equation \frac{d^2\phi}{ds^2}=0 you should obtain (no surprise):\frac{d\phi}{ds}=constant=\omegaThe trajectory is completed by the other obvious equationr=R=constantYou get one more interesting equation, that gives u the time dilation. Start with:ds^2=(1-r_s/R)dt^2-(Rd\phi)^2 and you get:\frac{dt}{ds}=\sqrt{\frac{1+(R\omega)^2}{1-r_s/R}}or:\frac{ds}{dt}=\sqrt{1-r_s/R}\sqrt{1-\frac{(R
  • #246
kev said:
We can however note that he has failed to explicitly state what he thinks [itex]d\phi/ds[/itex] should be, despite being asked to do so.
Why do you have difficulty deriving [tex]\frac{d\phi}{ds}[/tex] when you have been given [tex]\frac{d\phi}{dt}=\sqrt{m/r^3}[/tex] and [tex]\frac{ds}{dt}=\sqrt{1-3m/r}[/tex] in post 53? Do I need to do all the basic calculations for you?We could have saved 200 posts if you made the effort to understand post 53.
  • #247
Hello Starthaus.
I have been following this thread but most of the content is way above my level but I am learning something from it.
I do have a problem with some of the mathematical wrangling here so I will pose a question to clarify an issue which has been mentioned several times, the answer being for my own benefit and perhaps that of other non-involved spectators.
Even if you see the question as irrelevant could you please still answer it as it only requires a yes or no answer.
Leaving aside mathematical niceties, roughly speaking, talking of the graphical representaion, if the first derivative of a continuous function exists at a point on the graph of the function and is itself continuous and takes the value zero at that point, does this IN GENERAL imply that the second derivative, is zero at that point. More to the physical point if the velocity takes the value zero at some point, does the accelaration necessarily take the value zero at that point.
Matheinste
  • #248
No. For example, the parabola y = x^2 has first derivative y' = 2x and second derivative y'' = 2. At x = 0, the first derivative is zero and the second derivative equals two.
  • #249
Thanks for your reply. This correct answer I am sure most already know. I am absolutely OK with such basic calculus. My point was to try to get Starthaus to say whether he thought the answer was yes or no. Others on this thread have been telling him what you have just said but have, in my impression been fobbed off with non-commital or evasive answers.
Matheinste
  • #250
I haven't followed every twist and turn in this engaging thread, which seems to me to mainly constitute a warning about the dreadful ambiguities of using Leibniz notation in calculus, but starthaus originally pointed out that certain second derivatives were zero all the way back in post 5 (ah, the nostalgia...).
In that context, this was in response to the the OP's wish to analyse a certain kind of circular motion. Here's my understanding, but I wonder if it's correct: in the OP's case, the circular motion is modeled by a FUNCTION with constant radial coordinate r and (since it's circular) constant theta coordinate. When the function is a constant, the first derivative is everywhere zero and the second derivative is everywhere zero. And that's all he's relying on in that post. So, to me at least, at at this early point, it doesn't seem to be a hack, George Jones' point notwithstanding.
  • #251
matheinste said:
Hello Starthaus.
No, of course it doesn't but this is not the point of disagreement.
For the case of circular orbits, the radial coordinate [tex]r=constant[/tex], so
[tex]\frac{dr}{ds}=0[/tex] everywhere in the domain of definition of [tex]r[/tex] .
Therefore, by virtue of [tex]\frac{d^2r}{ds^2}=\frac{d}{ds}(\frac{dr}{ds})[/tex] it follows that [tex]\frac{d^2r}{ds^2}=0[/tex] .
So, when espen180 first set [tex]\frac{dr}{ds}=0[/tex] into the geodesic equation for circular orbits, that attracted immediately [tex]\frac{d^2r}{ds^2}=0[/tex] in the same equation.
When one makes [tex]\frac{dr}{ds}=0[/tex] into the Euler-Lagrange equation I gave eons ago , at post 53 (where this thread should have stopped since it gives the correct general answer to all orbits), this results immediately into [tex]\frac{d}{ds}(\frac{dr}{ds})=0[/tex], a simple fact that took kev about 200 posts to accept and a fact that Altabeh still has understood.
Matheinste
No, of course not, yet, this is not the point (see above)
  • #252
starthaus said:
You are repeating the same errors , you just made [tex]L=1=constant[/tex], when you differentiate a constant, you get ...zero.
You have added new errors as well. If you want to obtain the lagrangian, then you shout divide by [tex]ds[/tex], not by [tex]dt[/tex]. If you do this, you get the correct Lagrangian:
[tex]L=\alpha (dt/ds)^2-\frac{1}{\alpha}(dr/ds)^2-r^2(d\phi/ds)^2 [/tex]
Once you get the Lagrangian, you can get one of the Euler-Lagrange equations:
[tex]r^2d\phi/ds=H_c[/tex] (compare against your incorrect expression).
The other Euler-Lagrange equation is:
[tex]\alpha (dt/ds)=K[/tex] (compare to your other incorrect expression).
I know that I have written this stuff for you before.
There is a third Euler-Lagrange equation, it is dependent on the other two, so it does not contain any extra information per se:
[tex]-d/ds(1/\alpha*2dr/ds)-(2m/r^2(dt/ds)^2-d/dr(1/\alpha)(dr/ds)^2-2r(d\phi/ds)^2)=0[/tex] (1)
If you make [tex]r=R[/tex] in the above, this means the cancellation of the terms in [tex]dr/ds[/tex] and if you giving you
[tex](d\phi/dt)^2=\frac{m}{R^3}[/tex] (2) (corrected typo)
i.e.
[tex]\omega^2=\frac{m}{R^3}[/tex]
I am quite sure that I have shown you this before as well.
Substitute [tex]d\phi/dt[/tex] and [tex]dr=0[/tex] into the metric expression and you get:
[tex]ds^2=(1-3m/R)dt^2[/tex] (3)
The above makes sense only for [tex]R>3m[/tex]
From (2) and (3) one obtains easily:
[tex]\frac{d\phi}{ds}=\sqrt{\frac{m}{R^3}}\frac{1}{\sqrt{1-3m/R}}[/tex] (4)
It should be noted that (1) is the general Euler-Lagrange equation for planar orbits ([tex]d\theta=0[/tex]) from which all other equations (radial motion, circular orbits, etc) can be easily derived. This thread should have stopped at post 53.
  • #253
Thankyou Starthaus.
The first part of your reply in post #251 answers my question.
Matheinste.
  • #254
starthaus said:
Since you obviously don't know how [tex]H[/tex] was derived (you don't understand the Euler-Lagrange) formalism), you don't understand that the corret statement is "H does not depend on s but it does depend on r, so kev's attempt of differentiating wrt r by considering H a constant is a mistake"
Start with understanding what [tex]H=r^2\frac{d\phi}{ds}[/tex]. It doesn't mean "H is constant". In any calculus book. OK?
You seem to think that a basic level of profiency in calculus (not withstanding some misconceptions you have in this department) is all you need to come in here and tell us how GR works, but you do not understand the physics.
For a free-falling particle that has both radial and orbital motion H is a constant. As it falls r^2 obviously gets smaller but at the same time the angular velocity [tex]d\phi/ds[/tex] increases in such a way that the changes cancel each other out and H has the same value for any value of r. H is therefore independent of r and if you take the derivative of H with respect to r, as if it was a function of r you will get the wrong answers. You would already know this is you really understood the Euler-Lagrange formalism as you claim you do.
  • #255
matheinste said:
Thankyou Starthaus.
Matheinste.
Yes, I knew you would understand.
  • #256
It is constant wrt [tex]s[/tex]. It is not a constant wrt [tex]r[/tex].
[tex]\frac{d}{ds}(r^2\frac{d\phi}{ds})=0[/tex]
so
[tex]r^2\frac{d\phi}{ds}=H[/tex]
where H is not a function of [tex]s[/tex]
Please plug in the value for [tex]\frac{d\phi}{ds}[/tex] in the above expression for [tex]H[/tex]. If you have difficulties, you can look at post 252.
I am not the one attempting such silly hacks in my derivation. In fact, my derivation uses only the third Euler-Lagrange equation. If you still have difficulties following, I rewrote post 53 a little into post 252. Try reading it.
  • #257
starthaus said:
It is your problem that you don't know that [tex]\frac{d}{ds}(\frac{dr}{ds})=0[/tex] for [tex]\frac{dr}{ds}=0[/tex]. I do not know why you have so much difficulty with this elementary subject.
I can give you millions of counter-examples to this "elementary" result which would smash it in the face and turn it into a "nonsense". So if you keep using such hacks in your derivations this means you're doing a double hack: first supporting a nonsense and second insisting on it being "correct". Use my interpretation and stand corrected. Such silly hacks are to only blame for the lack of capability to deral with elementary calculus unless you start getting on the right track.
AB
  • #258
Matheinste
Yeah, most of students learning basic calculus in high school know of such thing but unfortunately starthaus doesn't! If be lucky, more than 200 posts might be spent on making him understand that supporting the nonsense "[tex]dr/ds=0\Rightarrow d^2r/ds^2=0[/tex]" would not probably save his hacks from getting smashed.
AB
  • #259
Yes, for purely circular motion the Starthaus fallacy [tex]dr/sd=0 \Rightarrow d^2r/ds^2 =0 [/tex] happens to be true by luck in that special case, but Starthaus believes it applies to radial motion too. See for example post #209 quoted below where I am clearly talking about purely radial motion:
kev said:
[tex]\frac{\text{d}^2r}{\text{d}\tau^2} = -\frac{c^2 r_s}{2r^2} = -\frac{GM}{r^2} [/tex]
This result means that the acceleration using these coordinates is independent of the falling velocity dr/ds because we have made no assumption of dr/ds=0. It also means that the acceleration is non-zero for any value dr/ds and so it is proved that the claim by Starthaus that the acceleration is zero when dr/ds=0, is false.
And the response by Starthaus was:
starthaus said:
If you insist on hacking the metric by putting [tex]\frac{dr}{ds}=0[/tex] by hand as you've been doing, then, by virtue of elementary calculus, you'd get [tex]\frac{d^2r}{ds^2}=0[/tex].
Clearly Starthaus thinks [tex]dr/ds=0 \Rightarrow d^2r/ds^2 =0 [/tex] is a universal truth and that it also applies to purely radial motion. Since Starthaus claims to be a calculus expert any newcomers might think that he is correct and share his misconception. Starthaus needs to make it clear that he made a elementary calculus blunder here. It is not just a typo. He has been defending this claim for many posts. See all of page 4 of this thread for example (https://www.physicsforums.com/showthread.php?t=409241&page=4) (and surrounding pages) to see the strength of his conviction that the Starthaus fallacy [tex]dr/ds=0 \Rightarrow d^2r/ds^2 =0 [/tex] is a universal truth.
The above quote by Starthaus is also an example of his hypocrisy because he has been inserting [tex]\frac{dr}{ds}=0[/tex] by hand in plenty of his derivations.
  • #260
Actually the correct solution for circular motion (based on Espen's derivation in his document) was given by me 26 posts earlier:
kev said:
I have had another look at your revised document and checked all the calculations from (9) onwards and they all seem to be correct. Your final result can be simplified to:
[tex]\frac{rd\phi}{ds} = c \sqrt{\frac{GM}{rc^2 - 3GM}[/tex]
Divide both sides of the above equation by r and simplify and you obtain:
[tex] \frac{d\phi}{ds} = \sqrt{\frac{GM/r^3}{1 - 3GM/(rc^2)}[/tex]
Your solution for circular motion in #53 came later and contained a major error (which you have now corrected.) If you had checked your solution against my (and Espen's) solution in #27 you might have noticed your error earlier.
  • #261
Kev,
thanks for your helpful post and for taking the time to explain things to me.
To be fair, it seems to me that there's unclarity in the notation and it's not clear to me that starthaus is necessarily making that mistake, even in the posts you point to - though I admit, I may be misunderstanding things.
In some contexts, it's natural to read dr/ds as referring to a function rather than the value of the function at a point. Then dr/ds = k, or dr/ds = 0 can be read as saying that the *function* is k everywhere or 0 everywhere. Understood in this way, the inference from dr/ds = 0 to d^2 r/ds^2 = 0 is correct. So what (I take) starthaus to be getting at in, say, post 57 seems, at least as it stands, fine.
What would be mistaken is inferring anything about d^2 r/dx^2 from the value of dr/ds at a certain point. In this thread, when people have written dx/dt = 0, they've not always made it clear whether they're talking about the value of this function at some point, as in an initial condition, or whether they're making the whole function this value.
I think this is the source of a lot of confusion here.
Now, in, say, espen180's post 56, to which starthaus is replying, espen180 does say he'll `impose dr/d\tau = d\phi /d\tau = d\theta/d\tau = 0'
Now (and here I admit I am at my least certain) I can't see how to understand this condition in the context of this derivation other than as a condition on the *functions* - i.e. in a way which validates his argument at 57. This is not an initial condition-style problem, where we are given the values of the functions at a certain point, which we can then substitute in somewhere.
  • #262
I think we could spend another 100 posts discussing the misconceptions and errors in calculus, algebra and physics of Starthaus, but maybe it is time to move on and summarize what the vast majority of contributers in this thread have concluded about orbital motion in Schwarzschild geometry in terms of the proper time of the particle and then move on.
The following 3 general equations for radial and orbital motion are all equivalent:
(Eq1) Quoted from a textbook by Starhaus.
http://5554229043997450163-a-1802744773732722657-s-sites.googlegroups.com/site/espen180files/Schwartzschild.pdf?attachauth=ANoY7cq5YcjBEfWs9NLohb9pW4ZSy8PeA1mye4fi5O5a1gEGkYzDwlDazDnETq05RiOCkTZT8VXKhWuZqMuPeHbOXoRfYD9KsLXbZrCGovBLGPZZtajp8B-RE2DI945uVj6eaA_GW7DZajPzhP90N63csOTzgkYM4mbE0PVDyXqcOwZ2L40PYADGrKjBHcbmOFjqsVwwmfy7mUPChM0x_BVp5G_Fr_KFmg%3D%3D&attredirects=0" .
[tex]d^2r/ds^2 + m\alpha/ r^2 (dt/ds)^2 - m/(\alpha r^2)(dr/ds)^2 - r\alpha (d\phi/ds)^2 = 0 [/tex]
https://www.physicsforums.com/showpost.php?p=2781228&postcount=211".
[tex] d^2r/ds^2 + m/r^2 - (r-3m)(d\phi/ds)^2 = 0 [/tex]
From any of the above, it is easy to obtain the special case for a circular orbit:
[tex]\frac{d\phi}{ds} = \sqrt{\frac{ (m/r^2)}{(r-3m)}} [/tex]
and the special case for purely radial motion:
[tex] \frac{d^2r}{ds^2} = -\frac{m}{r^2} [/tex]
(Note: The above expression for acceleration in terms of proper time is not the proper acceleration as some people seem to think.)
To the above list we can add this gem obtained from Altabeh's calculations:
... the local velocity [itex]V_R[/itex] of a particle in a circular orbit (radius =R) according to a stationary/ hovering observer at R is:
[tex]V_R/c = \sqrt{1-\alpha (1-3M/R)} [/tex]
which correctly gives the expected result that the local velocity is c when R=3M.
with the warning that the above equation is not in terms of proper time of the particle, but in terms of the proper time of the stationary clock used by the hovering observer at r.
Now the OP (Espen) has expressed a desire to analyse the motion of the particle in terms of coordinate time and I will try and focus my efforts in assisting him with his quest in subsequent posts.
  • #263
Your counter-examples are based on the same elementary misunderstanding, so what is the point? You don't understand the difference between a function and the value of a function in a point.
  • #264
Of course it is, it is a fundamental property of functions. Like Altabeh, you are unable to tell the difference between a function and the value of a function in a point.
  • #265
Good , you finally realized your errors of misdirection, you could have accepted that my equation was correct as shown to you 200 posts ago, at post 53.
BTW, it isn't "quoted from a textbook", it is derived from scratch from the Euler-Lagrange equations. You should make the effort to learn the formalism sometimes.
Except that the equivalent derivations based on the geodesic or on the Euler-Lagrange formalism are correct whereas yours is based on a series of hacks. As to your post 26, you show no derivation whatsoever, you simply agree with espen180's result based on the geodesic formalism.
  • #266
kev said:
The above quote by Starthaus is also an example of his hypocracy because he has been inserting [tex]\frac{dr}{ds}=0[/tex] by hand in plenty of his derivations.
LOL , "hypocracy"?
...except that when I do correctly insert [tex]\frac{dr}{ds}=0[/tex] in the general Euler-Lagrange equation, this attracts immediately [tex]\frac{d}{ds}(\frac{dr}{ds})=0[/tex] in the same equation. And it isn't "by hand", it is a consequence of the very basic condition[tex]r=constant[/tex]
My method is in direct contradiction to what espen180 was doing to his geodesic (he was retaining the term in [tex]\frac{d^2r}{ds^2}[/tex]. This is why I called him on it earlier. To this day, you still don't understand the difference. He understood. So do matheinste and yossell, after only one explanation.
  • #267
yossell said:
Kev,
Great, you understood it as well. Now, if only kev and Altabeh ever understood it, that would be a miracle.
  • #268
yossell said:
Kev,
Your welcome :smile: You are right that there is some ambiguity in the notation. It becomes tedious thinking thinking of new symbols (GR is already full of subscripts and superscripts) for acceleration at the apogee, acceleration in radial freefall, acceleration when orbiting, etc. so we sometimes use the same symbols to mean different things and clarify what we mean in the surrounding text. Starthaus is a mathematician and only focuses on the symbols and ignores the surrounding text and this causes a lot of the problems.
This is also true. Sometimes we mean dr/ds=0 at a point and sometimes we mean dr/ds=0 means a function which is true for all s. We (Espen, Altabeh and myself) usually make it clear which usage we mean in the surrounding text, but Starthaus seems to be unable to grasp this. You seem to uderstand this because you have ackowledged that there are two interpretations. Starthaus claims there is "no such thing as when dr/ds=0" when you using dr/ds as a function, but all we mean is that we are considering the special case and we are careful to be aware that any conculsions we draw from making that assumption, are only valid at that point in time.
In post #57 Starhaus is responding to an equation by Espen about purely radial motion (where the Starthaus fallacy [itex]dr/ds=0 \Rightarrow d^2r/ds^2[/itex] is false. Espen was in turn responding to a quote by me where I specified "the initial coordinate acceleration of a test mass released at r" where the word "initial" was the indication that we were talking about the motion at a point and not implying that dr/ds is 0 everywhere.
Take this series of exchanges between Espen and Starhaus:
espen180 said:
I corrected the error I made in my previous attempt and made a new derivation from scratch.
Please see section 4 (Pages 5&6) in this document for the derivation and result.
Download
starthaus said:
(30) is wrong.
(37) is as wrong as before.
espen180 said:
Going back to this post, do you disagree that [tex]\frac{dt}{d\tau}=\left(\frac{d\tau}{dt}\right)^{-1}[/tex] ?
starthaus said:
Of course not, I am simply saying that both (30) and (37) are wrong, you need to figure out why.
If we look at equation (30) in Espen's document we see that the equation given by Espen is:
[tex]\frac{d^2r}{dt^2} = - \frac{GM}{r^2} \left(1-\frac{2GM}{rc^2}\right) [/tex]
Now in the surrounding text Espen says "To simplify the case, we study the situation where we drop a test particle from rest at r and study it's acceleration immediately after dropping it "
The word immediately is Espen's indication that he talking about the motion at a point rather than at any arbitary time after releasing the particle. i.e. he is talking about the motion in the limit that s goes to zero if the particle is released at time s=0.
Espen further clarifies equation (30) by stating it is the "acceleration measured by a stationary observer at infinity" making it clear that he talking about coordinate acceleration. In the context given by Espen, equation (30) is correct. Starthaus says it wrong because he has not taken the time to read the surrounding text carefully.
The equation given by Espen is the same as the one given by myself in the first post of this old thread https://www.physicsforums.com/showpost.php?p=2710548&postcount=1 and Starthaus spent nearly 400 posts trying to prove it wrong and by common consensus he failed. The equation is correct in the context it was given in.
Although analysing the acceleration at a given point might not seem very useful, it is a very good starting point for determining the proper acceleration of a stationary particle at rest at r as measured by an accelerometer. The proper acceleration measured by an accelerometer of a stationary particle is equal in magnitude (and opposite in direction) to the initial acceleration of a particle released from r as measured by a local stationary observer at r, in the limit that s goes to zero, if the particle is released at time s=0.
The acceleration of a particle with purely radial motion is not zero at the apogee when dr/ds=0 and this is the important point Starthaus does not seem to get. Check post #264 and you will see he is still defending the Starthaus fallacy, despite counterproofs by myself, Altabeh and George.
  • #269
Kev,
thanks again.
I've looked at espen180's paper, your reference. In his opening paragraph, of that section, he says that, in the case of radial motion, d\theta/d \tau = d \phi /d tau = 0. I understand this a constraint on the functions. But then, when he says,
`we study the situation where we drop a test particle from rest at r and study it's (sic) acceleration immediately after dropping it relative to a stationary observer at r. Therefore dr/d\tau = 0'
that second equation is in fact to be understood as not about the function, but as true only at a particular coordinate, (t, x, y z)? (I recognise this may be too restrictive, that it may just one coordinate which is fixed - but the point is, it is not the general function that is being talked about here). So (??) we can only infer the truth of the equations that he goes on to derive in this section as being true *at* a particular point (t, x, y z) (or set of points) - it's just that mention of this point or points is implicit?
That makes sense to me - but again, the notation in the paper seems inconsistent. In section 4, on pure radial motion, similar equations are written, but here the equations can be interpreted as referring to the functions, rather than being implicitly restricted.
Is this correct?
  • #270
Your nonsense here means that the fallacy [tex]dr/ds=0\Rightarrow d^2r/ds^2=0[/tex] refers to the values of the second derivative of [tex]r[/tex] in every point, or in your sense to a function, while you refuse to believe that this function may not follow the fallacy at some point(s) contained in its domain. What a mess! LOL.
AB
  • #271
yossell said:
Kev,
thanks again.
Is this correct?
Hi there.
Let first get it out of the way that I'm not a mathematician. I am more concerned about the underlying physics than the mathematical notation. Therefore, most of the details are in the text. This might have made the document confusing to some. Sorry about that.
Where I wrote [tex]\frac{dr}{d\tau}=0[/tex] a matematician might have written something like [tex]\left{}\frac{dr}{d\tau}_{\tau=0}=0[/tex]
In both cases, the angular restrictions are made on the functions. They always hold. Radial restrictions are temporary, except in the case of pure circular motion, but I think I make it clear there. If not, I will make sure to do so in the future.
  • #272
yossell said:
Kev,
thanks again.
Yes, I think you have that right. The equation is only true *at* that point. Since at this point dr/dt=0 and [itex]d^2r/dt^2 \ne 0 [/itex] then an infinitesimal interval of time earlier or later dr/dt=0 can no longer be *exactly* true by definition. The greater the time lapse (and distance) after dropping the particle the greater its inaccuracy, but in the context it was given it is fine. Possibly Espen could have made this clearer.
yossell said:
Kev,
Is this correct?
Yes, I think you are right again and I agree the notation is a problem, but as I said before, it can be a problem finding new symbols for every conceivable situation and bearing this in mind, the surrounding text and context has to be read carefully. Perhaps the likes of Espen and myself (I am just as guilty of depending on the surrounding text) should give more consideration to our use of symbols in future to try and avoid any confusion.
EDIT. Then again.. maybe not. I'm too lazy :-p
  • #273
starthaus said:
Of course not
Then, by virtue of (34), derived from the metric, (37) is correct.
  • #274
Doesn't make sense at all. I'd be glad if you cite any source showing this that if the first derivative of a function vanishes, the so does the second derivative of it. The problem is that he assumes the first derivative is constant but yet there is no talk of the original function whose second derivative is to be considered, not the derivative of the derivative of it. Let [tex]y=x^3-x^2.[/tex] Now take [tex]y'=0[/tex] which is of course a constant function. Yet if I want to find [tex]y''[/tex] I don't look at [tex]y'[/tex] and where it satisfies my assumtion above so I go find the second deravative by calculating [tex](3x^2-2x)'[/tex]. Here another point must be recalled: when he assumes [tex]dr(s)/ds=0[/tex] this only holds for a special set of [tex]s[/tex]'s if not specify that [tex]r[/tex] is constant everywhere which is my interpretation given in post #235.* All he does is to support the fallacy [tex]dr/ds=0\Rightarrow d^2r/ds^2=0[/tex] blindly and this gives me the feeling that he's not aware of the situation as per usual.
* This is completely verified by looking at my post where I say:
We don't know what form [tex]r[/tex] would have as a function of some (affine) parameter so that we are not allowed to generally start talking about all values of [tex]s[/tex] and that whether your hack works or not.
In response he asnwers by a silly post:
starthaus said:
Let's try again, since you have been given that the function [tex]\frac{dr}{ds}=0[/tex] FOR ALL VALUES OF s, what can you infer about [tex]\frac{d^2r}{ds^2}[/tex]?
Keep in mind that [tex]\frac{d^2r}{ds^2}=\frac{d}{ds}(\frac{dr}{ds})[/tex].
For example, in a circular motion we clearly put [tex]r=const.[/tex] for whatever parameter we take [tex]r[/tex] to be a function of; but yet solving [tex]dr/ds=0[/tex] gives [tex]r=C(\tau)[/tex] where [tex]\tau[/tex] is another affine parameter related to [tex]s[/tex] hence the constancy of [tex]r[/tex] can't be obtained. So as you see using the old hack supported only by its founder cannot ever stand for a criation of circular motion unless we make use of the interpretation given in post #235.
Clearly the source of confusion is starthaus' failure to understand simple impressions of math and physics. LOL
AB
  • #275
The problem is that you claim expertise at math and physics whereas I'm the one who has to correct you all the time. Be a gentleman and simply say "I made a mistake and never ever will make use of any fallacy in my derivations"! LOL.
AB
  • #276
starthaus said:
LOL , "hypocracy"?
Though I've kept this at a very low level of math, you're still following this hack of yours. Are you really that much unable to see how we can simply smash that fallacy in the face by a simple CP? You're outgunned on this.
AB
  • #277
General equation for coordinate acceleration
Moving on to the general case for coordinate acceleration as promised, this is the derivation based on the one I started in post #48.
Starting with Schwarzschild metric and assuming orbital motion in a plane about the equator such that [itex]\theta = \pi/2[/itex] and [itex]d\theta = 0[/itex]
[tex] ds^2=\alpha dt^2-dr^2/\alpha-r^2d\phi^2, (\alpha=1-2M/r)[/tex]
Divide both sides by [itex]\alpha dt^2[/itex] and rearrange so that the constant (1) is on the LHS:
[tex]L = 1 =\frac{1}{\alpha}\frac{ds^2}{dt^2} +\frac{1}{\alpha^2}\frac{dr^2}{dt^2}+\frac{r^2}{\alpha}\frac{d\phi^2}{dt^2}[/tex]
The metric is independent of [itex]\phi[/itex] and t, so there is a constant associated with coordinate angular velocity [itex](H_c)[/itex] which is obtained by finding the partial derivative of L with respect to [itex]d\phi/dt[/itex]
[tex]\frac{\delta{L}}{\delta(d\phi/dt)} = \frac{r^2}{\alpha} \frac{d\phi}{dt} = H_c [/tex]
The metric is independent of s and t, so there is a constant associated with time dilation [itex](K_c)[/itex] which is obtained by finding the partial derivative of L with respect to [itex]ds/dt[/itex]
[tex]\frac{\delta{L}}{\delta(ds/dt)} = \frac{1}{\alpha} \frac{ds}{dt} = K_c [/tex]
Substitute these constants into the equation for L
[tex] 1 =\alpha K_c^2 +\frac{1}{\alpha^2}\frac{dr^2}{dt^2}+\frac{\alpha}{r^2}H_c^2}[/tex]
and solve for (dr/dt)^2:
[tex] \frac{dr^2}{dt^2} = (1-2M/r)^2 -(1-2M/r)^3 (K_c^2 + H_c^2/r^2) [/tex]
Differentiate the above with respect to r and divide by 2 to obtain the general coordinate radial acceleration of a freefalling particle in the metric:
[tex]\frac{d^2r}{dt^2}= \frac{\alpha^2 H_c^2}{r^4}(r-5M) +\frac{M}{r^2}(2\alpha-3K_c^2\alpha^2)[/tex]
Re-inserting the full forms of [itex]H_c[/itex] and [itex]K_c[/itex] back in gives:
\frac{ds^2}{dt^2}
)[/tex]
Now the (ds/dt)^2 term is a little inconvenient, but we can find an alternative form by solving the Schwarzschild metric to directly obtain:
[tex] (ds/dt)^2 = (\alpha - dr^2/(\alpha dt^2) - r^2d\phi^2/dt^2)[/tex]
and substituting this form into the equation above it to obtain:
)[/tex]
which after a bit of algebra simplifies to:
[tex]\Rightarrow \frac{d^2r}{dt^2}= \alpha\left(
r \frac{d\phi^2}{dt^2}-\frac{M}{r^2}+
\frac{3M}{\alpha^2 r^2} \frac{dr^2}{dt^2}\right)[/tex]
This is the fully general form of acceleration in Schwarzschild coordinates in terms of coordinate time and gives Espen something to compare his results against in his latest document.
Some quick checks:
For the special case of circular motion, the radial acceleration is zero and dr/dt=0 and so:
[tex] 0 = \alpha\left(r \frac{d\phi^2}{dt^2}-\frac{M}{r^2}\right)[/tex]
[tex]\Rightarrow \frac{d\phi}{dt} = \sqrt{\frac{M}{r^3}}[/tex]
Passed the first test.
For the special case of a particle at apogee, dr/dt=0 (momentarily) and [itex]d\phi/dt=0[/itex] and:
[tex] \frac{d^2r}{dt^2}= -\frac{M}{r^2}\alpha[/tex]
Passed the second test.
For the special case of a particle in purely radial free fall [itex]d\phi/dt=0[/itex] and:
[tex] \frac{d^2r}{dt^2}= \alpha\left(-\frac{M}{r^2}+
[tex]\Rightarrow \frac{d^2r}{dt^2}= -\frac{M}{r^2}\left(\alpha -
\frac{3}{\alpha } \frac{dr^2}{dt^2}\right)[/tex]
Passed the third test.
See equations (4) and (5) of mathpages http://www.mathpages.com/rr/s6-07/6-07.htm for an alternative proof of this last equation.
  • #278
I have updated my paper with a conclusion regarding coordinate acceleration during radial free fall.
Please see section 4 for the derivation.
http://5554229043997450163-a-1802744773732722657-s-sites.googlegroups.com/site/espen180files/Schwartzschild.pdf?attachauth=ANoY7crvgkJaf2YSb9wipuKnvEoacyFDok-MWepVPK4tZrlLjK8If_HxjS_lzaZVPS-0StjbvJLQU3Bvx-t_oZcneyRG3Orj_V5UXTUFarMpmWYhgtEJNgxcRpypcyted9W0Qa7Re2gn-2ib6A0f-WJV5jukKhp_IfJhNoCnhscy-m2uBhjTO2cHlLX45JEfEI8kNFatSDfwlnBKGeus9Ufx5OdK13A-sw%3D%3D&attredirects=1"
The conclusion is
[tex]\frac{\text{d}^2r}{\text{d}t}=-\frac{GM}{r^2}\left(\alpha-\frac{2}{\alpha}\left(\frac{\frac{\text{d}r}{\text{d}t}}{c}\right)^2\right)[/tex]
Here is my (to some extent qualitative) analysis of the solution:
When dr/dt=0, we can observe that the expression reduces to the one we dound for a momentarily stationary particle, which is exprected (a special solution should be a subset of a more general one). As the particle nears the horizon, the acceleration becomes positive and it slows down, never passing the horizon. This is also a known result, and the fact that this expression implies this is a validating factor. I therefore believe it is correct.
EDIT: It seems my conclusion is in conflict with kev's by a factor. I will have to inspect my derivation.
  • #279
Thanks Altabeh,
I'm sorry by I'm not seeing the lack of sense in your quote from my post.
The argument that, if the first derivative of a function vanishes then so does the second, is this:
(1) Suppose the derivative of a function f vanishes (assumption)
(2) So f' is the constant function zero.
(3) The derivative of any constant function is zero.
(4) So f'', the derivative of f', is zero.
(5) So the second derivative of f vanishes.
Again, to stress, this argument works only if we're both clear that 'function f vanishes' means 'f(x) = 0 for all x' - that is, that we're talking about *functions*. I think that's what he's trying to stress with his quote. None of this goes if 'f vanishes' means 'f vanishes at point p' where point p is some fixed point we've implicitly agreed to focus on. As has already been shown, there are examples where f at p can be zero while f' at p is not zero.
I'm afraid I don't really understand what you're doing when you say `take y' to be zero which is a constant function.' As you've shown, y' = x^3 - x^2, and its values vary as x varies. You can't now just stipulate that it's a constant function. Of course, y' equals zero when x equals zero and when x = 1 - so we can talk of its values at various points. But it's not a constant function.
  • #280
yossell said:
Thanks Altabeh,
This is where the communication stops. When someone says "take dr/dt to be initially zero", starthaus seems to miss the "initially" part.
