Resultant force when a body is accelerating
A body with a mass of 500kg is accelerating at 2.5 m/s² while experiencing a constant frictional force of 1000N. The resultant force is calculated to be 1250N, indicating a net forward force of 2250N when accounting for friction. The discussion clarifies that if acceleration is constant, the net force must also remain constant, and the frictional force does not change in this scenario. It is emphasized that constant acceleration implies a changing velocity, while constant speed results in zero acceleration and net force. The key takeaway is that as long as the forces remain unchanged, the acceleration will also remain constant.
aadarsh9
There is a body of mass 500kg accelerating at 2.5ms^-2.
It experiences a frictional force of 1000N.
Resultant Force = ma
Resultant Force = (500)(2.5)N = 1250N
The body is moving forward with a net force of 1250N
A frictional force of 1000N is acting on the opposite direction.
The body must be moving with this forward force:
Forward Force - Frictional Force = Resultant Force
Forward Force = (1250 + 1000)N = 2250N
But what does all this mean?
The body is accelerating. Shouldn't the forward force as well as the frictional force be continuously increasing?
If the acceleration is constant, the net force must be constant. No reason to think that the frictional force is changing.
What an acceleration means is that the velocity is continuously changing, not the force.
yeah, in most real-world situations the friction force will increase in this scenario. But the question specifically states that the friction force is constant. So as always, you should do as the question says.
Here is the scenario:
At t=0s,
The body has a forward force of 2250N and a frictional force of 1000N
F res = 1250N
At t=1s or any time in the future,
The body will still have a forward force of 2250N and a frictional force of 1000N
F res = 1250N
Will it have a constant velocity or acceleration? How?
From what you said, if there is constant acceleration, there will be a resultant force. If there is constant speed, there would be no resultant force? How? Is there any equation?
##\vec{F}=m\vec{a}## :smile:
If there is a constant speed, acceleration is zero,therefore net force is zero
The same equation :##F=ma##. If the force and mass is constant, acceleration is constant and speed is changing(As acceleration is defined as the change of speed with respect to time. ##\frac{dv}{dt}##
F res = 1250N
Right. (Unless you are told otherwise, assume the givens stay the same.)
As long as the forces do not change, neither will the acceleration.
The equation is simply Newton's 2nd law:
∑F = ma
When the velocity is constant the acceleration will be zero. Thus the net force will be zero.
Ok. Thanks!
