How Does the Right-Hand Rule Determine the Direction of Magnetic Force?
  • Thread starter Thread starter dekoi
    Magnetism
The right-hand rule is essential for determining the direction of magnetic force, where the thumb represents the velocity of a positive charge, the index finger indicates the magnetic field direction, and the palm shows the force direction. If a positive object moves North with a magnetic field directed Northeast, the resultant force can be determined using this rule. In the context of Earth's magnetic field, which points downwards at a steep angle in Canada, the magnetic field lines are oriented toward the geographic North Pole, implying that the magnetic polarity at the North Pole is actually south. When a charged particle moves parallel to a magnetic field line, it experiences no force. Understanding these principles is crucial for applications involving magnetic forces and charged particles.
dekoi
Suppose I use the direction of my hand to be velocity, the curling of my fingers to be the magnetic field, and my thumb to be the magnetic force.
1.) Then, if a positive object is moving North, and the magnetic field is NE, where is the resultant force?
2.) How about the Earth's magnetic field? If the velocity is South, where is the force? The bigger question: where is the magnetic field? Is it from the South pole to the North pole?
Whoa, Whoa Whoa!
For the "Lorenz FOrce" right hand rule, do not curl your fingers.
Your thumb is the direction of velocity of the positive charge,
your index finger is the direction of the magnetic field,
your palm points in the direction of the force.
Your thumb can be at any angle from perpendicular with your finger, to almost parallel with your finger and the rule still works; the force will be greatest when B and v are perpendicular though.
2) In Canada, the magnetic field is actually pointing nearly straight into the ground at an angle of about 70 degrees. The horizontal componant is pointing toward the north geographic pole.(THis of course means that the magnetic polarity of the geographic north pole is "south")
By "curling fingers" i meant pointing your fingers (or your index finger) toward a specified direction.
thanks.
Regarding the second answer: So Earth's magnetic field is... north? I don't quite understand. If i had a velocity which is northwards, where is my force?
Compasses allign themselves with teh magnetic field that they are in. So if a compass needle points north, then the magnetic field lines point north.
When moving in the same direction as a magnetic field line, a charged particle will feel no force.
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
  • · Replies 40 ·
  • · Replies 31 ·
