Understanding the phrase "simultaneity convention"
  • Context: Undergrad
  • Thread starter Thread starter Freixas
    Convention
The discussion revolves around the concept of "simultaneity conventions" in the context of special relativity (S.R.). Participants explore various ways to define simultaneity, particularly in relation to the timing of events in spacetime, and the implications of these definitions on physical measurements and interpretations.
  • One participant questions how to set the clock on a mirror in a thought experiment involving a photon, proposing various functions for time settings based on distance.
  • Another participant emphasizes the need for clarity in defining "time" and "distance" in relativity scenarios, suggesting that proper specifications are essential.
  • It is proposed that any division of spacetime into subsets that meet certain criteria can be considered a valid simultaneity convention.
  • Concerns are raised about the arbitrary nature of simultaneity conventions and their implications for defining physical quantities like length and velocity.
  • Some participants argue that certain requirements must be met for a simultaneity convention to be valid, such as ensuring that times along timelike worldlines are strictly increasing.
  • There is a mention of David Malament's theorem regarding simultaneity conventions, with differing opinions on its validity and implications.
  • One participant notes that while Einsteinian synchronization is common, it is not the only choice for simultaneity conventions.
Participants express differing views on the nature and implications of simultaneity conventions, with no consensus reached on the extent of their arbitrariness or the validity of certain proposed conventions.
Some discussions involve assumptions about the definitions of time and distance, as well as the requirements for valid simultaneity conventions, which remain unresolved.
  • #121
PeterDonis said:
In polar coordinates the metric coefficient ##g_{rr}## vanishes at ##r = 0##. That means the metric has a vanishing determinant, but it doesn't make it undefined.
At ##r=0##, however, the polar coordinates/map is not defined.
PeterDonis said:
In Schwarzschild coordinates, the metric coefficient ##g_{rr}## is undefined at ##r = r_s## (zero in the denominator). That's not the same thing as the above.
I believe the point is the following: is ##r = r_s## actually part of the Schwarzschild map/coordinates ? If not it is more o less alike polar coordinates for Euclidean plane, I believe.
  • #122
If you insist on a one-to-one mapping of both coordinates, yes, that's true, because there is not a unique value of ##\theta## assigned to the point ##r = 0##.
That doesn't change the fact that the coordinate behavior in the metric (line element) is not the same for this case as for Schwarzschild coordinates at ##r = r_s##.
Strictly speaking, no, it's not. There are several ways to look at why:
(1) No finite value of ##t## can be assigned at ##r = r_s##.
(2) In the underlying spacetime geometry, the locus ##r = r_s## is more than one 2-sphere, but no other coordinate in Schwarzschild coordinates can distinguish the different 2-spheres at ##r = r_s##; the natural candidate to do that would be the ##t## coordinate, but it doesn't work.
(3) Surfaces of constant ##t## in Schwarzschild coordinates intersect at ##r = r_s##.
Not really, since the reasons are quite different. See above.
  • #123
You mean all the loci of ##t=const## in spacetime intersect each other in a set that is characterized by ##r=r_s##, right?
  • #124
Not in a "set"--in a point of ##t##, ##r## space. (Or a single 2-sphere in the full spacetime.)
  • #125
Ah ok, so actually this intersection point/event in 2D Schwarzschild spacetime model (or the single 2-sphere in full spacetime) is characterized by ##(r_s, t)## where ##t## takes uncountable many values.
Therefore, since they intersect, hypersurfaces of constant Schwarzschild coordinate time ##t## do not foliate the entire Schwarzschild spacetime.
  • #126
It does not have well-defined Schwarzschild coordinates at all. ##r = r_s## is on the horizon, so we cannot even say that it has "uncountable many" finite values of ##t##. Read item (1) of my post #122 again.
This is correct. But note also that we cannot even say that all such surfaces are spacelike.
  • #127
I believe it is much easier to look at/grasp such Schwarzschild coordinate singularities in Kruskal–Szekeres (KS) coordinates ##(T,X)##.
Schwarzschild coordinate singularities are actually two folded: all spacetime hypersurfaces that map to ##t=c## for any constant ##c## intersect at a single point/event (or 2-sphere in full spacetime) that has KS coordinates ##(T = 0, K = 0)## -- it is alike ##\theta = c## polar coordinate lines for the euclidean plane that all intersect at the common origin O.
The other kind of Schwarzschild coordinate singularity is due to the fact that the set of events/points (or set of 2-spheres) that make up the horizon, all share the same values (##r=r_s, t= \pm \infty##). There is no "equivalent behaviour" for polar coodinates in the plane, though.
  • · Replies 51 ·
  • · Replies 16 ·
  • · Replies 47 ·
  • · Replies 20 ·
  • · Replies 25 ·
