What does temperature in mesosphere mean?
In summary: So, if the temperature of the air is high, but the thermal conductivity is low, then the temperature of the air as a whole is low.
jostpuur
2,116
I tried to check some atmosphere stuff from here: http://www.srh.noaa.gov/jetstream/atmos/layers.htm
It says
However, despite the high temperature, this layer of the atmosphere would still feel very cold to our skin because of the extremely thin air. The total amount of energy from the very few molecules in this layer is not sufficient enough to heat our skin.
I thought that the temperature is by definition a quantity which always becomes equal between materials which are in physical contact. So if a human body would get cold in the upper mesosphere, doesn't it mean that the air is cold there? Furthermore, if a human body gets cold there, don't temperature gauges get cold too? How are those high temperatures even measured?
update:
I already got one idea. The page explains the reason for high temperatures to be this:
The gases of the thermosphere are increasingly thinner than in the mesosphere. As such, only the higher energy ultraviolet and x-ray radiation from the sun is absorbed. But because of this absorption, the temperature increases with height and can reach as high as 3,600°F (2,000°C) near the top of this layer.
Does this mean that we should consider the system, consisting of both the electromagnetic radiation and the air molecules, to be the system which is in a high temperature? And if a human goes out there and doesn't protect him or herself in a shadow, he or she will get fried?
update 2:
I don't believe that the idea of the first update is the solution to the problem. A better sounding idea is presented in the post #7. Although the frying effect of the sun's radiation is probably notable too.
Science news on Phys.org
I think that in this case they're referring the average kinetic energy of the molecules as temperature. If so, the temperature can be quite high, but the thermal transfer to another body would be minimal because of the low population of molecules.
But they give the temperature in Fahrenheits and in Celsius. Those numbers must have some quantitative meaning.
This is a paradoxical statement, which IMO doesn't take into account the correct meaning of the terminology. If I understood this point correctly, this message should be said like this: "The average energy of the air molecules is high, but the temperature of the air as whole is low".
update:
I immediately understood another possibility. Did you mean that the temperature of the air is high, but the thermal conductivity is low? But that doesn't make sense really either. If the thermal conductivity of the air is extremely low, then it shouldn't feel cold, right?
Yes. Temperature means the average kinetic energy of the molecules.
Well, I don't think it's paradoxical, and your proposed rewrite doesn't seem on the mark. I think you might be confusing temperature with the thermal transfer. If the average kinetic energy is high, then the temperature is high. But the mesophere's ability to warm objects in contact with it is low because there are so few particles. An object's temperature and it's ability to release heat into objects aren't the same thing.
When you put a room temperature beer in a cooler of ice, you always try to put the can deep in, under the water. Why? Because you have a sense that the cold water can cool down the can faster than the air, even though both are the same temperature within the cooler.
And even more so, I like to use ice water. Essentially the same temperature, but with complete surface contact.
You don't give the average kinetic energy in Fahrenheits or in Celsius. The temperature of a system means the reading that a temperature gauge will give when it is in contact with the system (and is in shadow from outside energy sources).
Guys, I understand what you mean. I mentioned something about heat transfer (I used word conductivity) in the update part of my post #3.
I'm thinking more: It could be that the temperature of the air is high, but a direct measurement of it becomes difficult because the time it takes for a reading of a gauge (or a temperature of a human skin) to settle is so large, that the black body radiation of the gauge itself (or of a skin), which will cool the gauge (or skin) down, messes it up.
It's kind of like the question "which is heavier, a pound of feathers or a pound of rocks?"
Which will cook you faster, 1000 degree molten lead or 1000 degree hydrogen at 0.001 psia? :)
Why the ROCKS of course! Rocks are like... rocks, well heavier man. I mean come on, feathers float!
ZING! Tally of flame posts from people with no sense of humour to follow.
Related to What does temperature in mesosphere mean?
1. What is the mesosphere?
The mesosphere is the layer of the Earth's atmosphere that is located between the stratosphere and the thermosphere. It is the third layer of the atmosphere, with an altitude range of approximately 50-85 kilometers above the Earth's surface.
2. What is the temperature in the mesosphere?
The temperature in the mesosphere can vary depending on a number of factors, such as location, time of day, and season. On average, the temperature ranges from about -90°C to -120°C (-130°F to -170°F).
3. How is the temperature in the mesosphere measured?
The temperature in the mesosphere is typically measured using instruments known as radiosondes, which are attached to weather balloons and can record temperature, pressure, and humidity as they ascend through the atmosphere.
4. What factors affect the temperature in the mesosphere?
The temperature in the mesosphere can be influenced by a variety of factors, including solar radiation, atmospheric pressure, and atmospheric composition. Additionally, changes in temperature can also be caused by natural phenomena such as atmospheric tides and gravity waves.
5. Why is the temperature in the mesosphere colder than the temperature in the stratosphere?
The temperature in the mesosphere is colder than the temperature in the stratosphere because the mesosphere is located higher in the atmosphere and therefore experiences less atmospheric pressure, causing the temperature to decrease with altitude. Additionally, the mesosphere is also further away from the Earth's surface, which means it receives less warmth from the Earth's surface and is therefore colder.
  • Thermodynamics
  • Earth Sciences
