- #71
loislane
- 134
- 6
If you assume minimal couplig from the start you are assuming the EP in exact(not just approximate) form. The problem with that assumption is that as commented by PeterDonis it leads you to a completely coordinate dependent formulation of the geodesic equation.stevendaryl said:Well, if you know what happens in every local inertial frame, then doesn't that imply what happens globally? Under the assumptions that:
Nonminimal coupling can never be ruled out except experimentally, but I would say that if there are nonminimal couplings, that to me means that the EP does not hold for situations in which nonminimal coupling is relevant. Or to put it another way, to me, the impact of the EP is the claim that there is minimal coupling of matter and fields to gravity.
- We're talking about test particles and weak fields whose effect on gravity is negligible, and
- There are no direct couplings of the equations of motion to curvature or higher-order derivatives of the metric.
