B What is x' for Moving Rocket from P?
Lotto
TL;DR Summary
Observer S' is in a rocket that is moving relative to an observer S. Outside his rocket happened an event. How to construe the ##x'## of that event? Can be ##x'## negative?
I have a rocket and it is moving straight from a point P with a velocity ##v##. When I say that ##x'=0## is at the place we sit in the rocket, then when the event happened outside his rocket at the point P, can I say that the coordinate of the event is for him negative, so ##x'=-vt'##, although is it not in his stationary frame of reference?
It depends what the ##x## coordinate of ##P## is which you have not specified, and which frame you are considering ##P## to be at rest in. If ##x=0## and the point is at rest in the unprimed frame then your answer is correct. Generally, you need to use the Lorentz transforms.
Yes it can be negative
In the below space-time diagram enter .6 for velocity, 0 for x, 4 for t for event B.
You will see a negative x' for event B, x' = -3, t'=5
http://www.trell.org/div/minkowski.html
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
