A What's the relationship between RMS framework and the Lorentz group?
  • A
  • Thread starter Thread starter pervect
    Lorentz group
pervect
Staff Emeritus
Insights Author
TL;DR Summary
What is the relationship between the Robertson-Mansouri-Sexl framework and the Lorentz group
The Robertson-Mansouri-Sexl framework, discussed in "Modern Tests of Lorentz Invariance", https://link.springer.com/article/10.12942/lrr-2005-5?affiliation, is "a well known kinematic test theory for parameterizing deviations from Lorentz invariance."
I'm a bit confused on the relationship between this framework, which tests experimentally for Lorentz invariance, and the group-theoretical theorems discussed in a recent thread that limit the theoretical possiblities for covariant formulations of physics, as discussed in this now-closed PF thread
https://www.physicsforums.com/threa...-postulate-or-assumption.1052965/post-6905619
in particular the (paywalled) paper "V. Berzi and V. Gorini, Reciprocity Principle and the Lorentz
Transformations, Jour. Math. Phys. 10, 1518 (1969)", https://doi.org/10.1063/1.1665000
I assume the RMS framework has some underlying group structure. The question is - is this underlying group structure the same or different than the Lorentz group? I've been perusing the Living Review article, which is rather long. Possibly it already contains the answer I seek, but I haven't been able to figure this out to my satisfaction. Unfortunately, I don't know enough group theory to answer the question myself from first principles :(.
A dumbed down version of the underlying and motivational question might be "If the Lorentz group and the Gallilean group are the only group-theoretical possibilities, what sort of test theory allows us to experimentally test for violations of Lorentz invariance?" The more specific question in the title of the thread is an attempt to answer this "fuzzier" question.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
