- #36
Dale
Mentor
- 35,535
- 13,852
Well, I would have a slightly different take. The circuit equations only hold under certain circumstances/assumptions. When those assumptions are violated then you run into trouble if you try to apply them. However, when those assumptions hold then you can use circuit theory just fine.Charles Link said:Perhaps @vanhees71 that this is the answer for @Dale that the circuit equations are always well defined (e.g. for the purpose of computing the current that flows), but you can't necessarily assign a potential to every point in the circuit.
I think that it is important to understand the underlying assumptions. Then you can avoid using circuit theory when it doesn't apply and avoid blaming circuit theory for not being able to solve problems that violate it's assumptions. It is a useful theory and by keeping its assumptions in mind then you can avoid over complicating things when it applies and you can avoid over simplifying things when it doesn't apply.
I feel that this thread is diving into the over complicating side.
