- #106
- 5,615
- 2,937
A minor "typo" in post #103. In M.K.S. ## \ ## ## \mathcal{E}=-d \Phi/dt ##. The "c" in the denominator is only in c.g.s. units.
Then it is odd that you would repeatedly claim that it is circuit theory in the face of well reasoned objections. When I am in such a position (making a mistake on a topic that I don't care about) I just say "oops", learn, and move on. I have to say that this interaction with you has bothered me greatly.vanhees71 said:I don't care, whether it's circuit theory or not.
Yes, I agree.vanhees71 said:You only need Maxwell's equations in a very simple way
Again, you don't get to push personal definitions here. The fundamental assumptions of circuit theory are more than that and this has been explained and referenced in detail.vanhees71 said:the quasitationary approximation that the current is observed on every branching (this is what distinguishes for me circuit theory from the full Maxwell equations
The place pointed to by the line labeled "changing magnetic flux".vanhees71 said:Perhaps Dale could point to the place, where this analysis is beyond usual circuit theory
Yes, exactly!vanhees71 said:so Lewin's example obviously only misses item 3, i.e., that magnetic couplings are only within a single element of the circuit. I.e., for calling the problem one of "circuit theory" it's not allowed to have a "magnetic flux" within a loop of the circuit as here.
Yes, as I have agreed several times. His analysis is correct, the problem is exactly his semantics. The "for the birds" bit is just semantics, but it is such awful semantics that it needs to be objected to.vanhees71 said:Well, as I said, it's only semantics. Lewin's analysis, as expected, is of course correct although it goes beyond the strict definition of "circuit theory"
Yes, I think that is the take home message. I will try to post a little about assumptions tomorrow.OnAHyperbola said:I think one can go about pretending there really is a potential drop across the inductor as long as one knows what's really happening behind the scenes and the assumptions that one is going in with.
Repeating my post #25. Also @OnAHyperbola my post #68 I think you might find of interest. If you have figured out from all of this how changing magnetic fluxes can affect a circuit and can accurately predict what the voltmeter will read when there is a changing magnetic flux present, (and it will depend on how you string the wires from the voltmeter to the circuit), I think you have learned quite a lot.Charles Link said:One item that puzzled me here, [I think I have it figured out to my satisfaction, but it is somewhat complex and everyone (even the most astute ones) are likely to come up with interpretations that differ somewhat], is that the electric field E from the EMF points in the direction in the inductor (just like the EMF inside a battery) from the minus end to the plus end. For an electrostatic component, such as a capacitor, the electric field E points from plus to minus. A voltmeter (or oscilloscope) has no trouble reading the voltage of either of these components. For the inductor, ## V=\int E \cdot dl ## and is very well defined, but the sign is actually opposite what you would get if the E as a function of position were an electrostatic field. Thereby the EMF E is a somewhat different entity than an electrostatic field. The voltage V is however very well defined from an EMF. The sign actually gets reversed when computing the voltage (please check this carefully=I do think I have it correct), but in any case it can be written as a potential (voltage) even if the curl E is non-zero. When sensed with a voltmeter or oscilloscope, these devices are unable to distinguish whether they are reading an EMF or reading an electrostatic voltage.
I never ever use SI units in electromagnetism, if I can avoid it. I use exclusively rationalized Gaussian units (aka Heaviside-Lorentz units) as in HEP and high-energy nuclear physics.Charles Link said:A minor "typo" in post #103. In M.K.S. ## \ ## ## \mathcal{E}=-d \Phi/dt ##. The "c" in the denominator is only in c.g.s. units.
Me too, because it's just a misunderstanding between a physics and engineering definition. I'll try to avoid the label "circuit theory" from now on, because it seems to have another meaning than what I learned in the E&M lecture. Sorry for any confusion this might have caused in this discussion.Dale said:Then it is odd that you would repeatedly claim that it is circuit theory in the face of well reasoned objections. When I am in such a position (making a mistake on a topic that I don't care about) I just say "oops", learn, and move on. I have to say that this interaction with you has bothered me greatly.
Then it isn't a typo. My mistake. 95% of the time or more, the voltage equations of the electrical engineer will be in SI units. The conversion from gauss to Webers/m^2 is an easy one, but the voltage, current/charge, and resistance can be rather cumbersome in converting from c.g.s. to SI. Maybe this might partly explain the different viewpoints between @Dale and @vanhees71 =a EE vs. someone doing more theoretical work. In E&M calculations, I also favor the c.g.s. units, since we used the book by J.D. Jackson Classical Electrodynamics in graduate school. However, it always takes me a few minutes, (basically by comparing the two Coulombs law formulas ## v=q/r ## vs. ## V=Q/(4 \pi \epsilon_o R) ## and using e=q= 4.801 E-10 e.s.u.'s and e=Q=1.602 E-19 Coulombs., and letting R=1 meter so that r=100 cm) , to write out the conversion factors when I am looking for the voltage that I'm going to measure with my SI voltmeter. The difference in voltages is a factor of 300, but I can never remember if you multiply or divide. :-) :-) :-)vanhees71 said:I never ever use SI units in electromagnetism, if I can avoid it. I use exclusively rationalized Gaussian units (aka Heaviside-Lorentz units) as in HEP and high-energy nuclear physics.
But it isn't written for a physicist's point of view, it is written for electrical engineering students taking their first course on circuits with no background knowledge of Maxwell's equations. The assumptions are standard, although the wording does vary from text to text depending on the previous knowledge of the target audience.vanhees71 said:Just a note concerning this book by Nielsson. From a physicist's point of view, it's pretty inaccurate and even dangerous in its language concerning percisely our debate.
I wanted to go back and highlight this comment of yours. I think it is fantastic that you have this level of scientific clarity in high school.OnAHyperbola said:as long as one knows what's really happening behind the scenes and the assumptions that one is going in with
