- #36
TurtleMeister
- 896
- 98
Thanks for taking the time to interpret my ramblings Saw. I am a little lacking in math and communication skills, so you've made my day in being able to see what I have been puzzled over for so long. One of the questions involved in all of this is whether or not leptons have active gravitational mass. If you find this discussion interesting then you may also find this http://www.gravityresearchfoundation.org/pdf/awarded/2001/unnikrishnan_gillies.pdf" interesting.Saw said:Ah, yes, I see now the issue with active gravitational mass. Gravity is caused by the presence of matter, but this matter may have different compositions (different internal arrangements) and the question is whether different arrangements of the same quantity of matter (or at least the same inertial mass) might have different gravitational active capacities...
I believe that this test is invalid, because it is based on Newton's laws, which as you have already discovered, breaks down when there is an inequality between ma and mi.Saw said:I have not thought enough about the experiment with the Moon that DH mentioned and about which you argue that it does not exclude the possibility of the above discrepancy.
Yes, this has also been an area of confusion for me. I have stated in my previous posts that a test of the equivalence of ma is also a test of WEP. But I've never been sure of that. Since, as I've already stated, I have not studied GR, I'm not sure as to how this issue affects or threatens it.Saw said:Just a semantic comment for the time being: strictly speaking, what the WEP and the experiments that back it up require is that a given source accelerates all bodies in free fall at the same rate, that is to say, that the passive mass plays no role. This is not threatened by the above mentioned issue: if the passive mass is irrelevant, it’s so in all respects, quantity and composition.
I tend to disagree here. What is gravitational COM? The barycenter of two bodies is determined by their inertial mass. If that were not the case, then it would lead to the same result as the moon experiment, where the third law of motion is violated and the moon self accelerates. And that would open up a Pandora's box of nonsense, such as perpetual motion and unlimited free energy.Saw said:As to the need that the two bodies interacting gravitationally meet at the COM of the system… Well, if active gravitational mass were different from inertial mass, then the bodies would meet at their “gravitational” COM, eventually different from their “inertial” COM.
I agree that (i) is not the issue here. I think the issue is whether or not Newton's laws can be used to describe a non equivalence between ma and mp / mi. Either the non equivalence cannot exist, or we must have another equation, or theory, to describe it.Saw said:The big problem, as you point out, would be for Newton’s Third Law. Choosing units so that G/r^2 = 1, what the Law requires is that:
m0 (inertial) • m1 (gravitational) = - m1 (inertial) • m0 (gravitational)
So if the ratio inertial (m0/m1) <> gravitational (m0/m1), the equation breaks down…
But, that is my point, this and only this would be what is at stake. “Equivalence” can refer to two different things: (i) when faced with an attractive given mass, all objects are attracted with “equal” acceleration and (ii) the ratio of gravitational accelerations is “equal” to the ratio of inertial accelerations in the context of a collision. Only (ii) would be discussed here.
