- #71
Saw
- 18
Well, then, I tend to think that what needs a physical explanation is not your math but the standard math: why is gravity so different from any other interaction?
As commented, the standard math assumes that gravitational interaction is not really so but a sort of “sum of two actions”, which are unconnected to each other: due to the WEP, “M” causes on any “m” an acceleration that is independent from any characteristic of “m”, either inertial or gravitational mass, whether passive or active; the overall effect is affected by “m”, because the latter accelerates in turn “M”, but again at a rate that has nothing to do with M’s features. In view of this, one could perfectly apply the usual motto: “this is the way the universe is, as per experiments, whether you like it or not”. But I do not think it is intellectually unsound to highlight how much that approach is inconsistent with other well-established features of nature. One could even say that such approach does not truly satisfy Newton’s Third Law: on both sides we have an action without any REACTION of the passive object, without any opposition or softening of the effect due to resistance, due to inertia of the affected body.
In line with your own thought experiments (now that I better understand them), I would like to recall the example of collisions. Let’s see if I put it without many mistakes (I should say from time to time I am no expert):
In any collision:
[tex]
\frac{{m_1 }}{{m_2 }} = \frac{{a_2 }}{{a_1 }} = \frac{{\frac{{\Delta v_2 }}{t}}}{{\frac{{\Delta v_1 }}{t}}} = \frac{{\Delta v_2 }}{{\Delta v_1 }}
[/tex]
If the system formed by the two bodies is closed (no external force) and the collision is perfectly elastic (no internal dissipation of energy), then the relative speed of the two bodies does not change. For example, in the frame of m1, m2 was approaching at a certain v and after the collision it recedes in the opposite direction. This means that:
[tex]
\Delta v_1 + \Delta v_2 = 2v_{rel}
[/tex]
After some algebra:
[tex]
\begin{array}{l}
\frac{{m_1 }}{{m_2 }} + 1 = \frac{{\Delta v_2 }}{{\Delta v_1 }} + 1 = \frac{{m_1 + m_2 }}{{m_2 }} = \frac{{\Delta v_2 + \Delta v_1 }}{{\Delta v_1 }} = \frac{{2v_{rel} }}{{\Delta v_1 }} \to \Delta v_1 = 2v_{rel} \frac{{m_2 }}{{m_1 + m_2 }} \\
\frac{{m_2 }}{{m_1 }} + 1 = \frac{{\Delta v_1 }}{{\Delta v_2 }} + 1 = \frac{{m_2 + m_1 }}{{m_1 }} = \frac{{\Delta v_1 + \Delta v_2 }}{{\Delta v_2 }} = \frac{{2v_{rel} }}{{\Delta v_2 }} \to \Delta v_2 = 2v_{rel} \frac{{m_1 }}{{m_1 + m_2 }} \\
\end{array}
[/tex]
So we see that that the proportion between the two velocity increases is determined by the inertial masses (m1 accelerates in proportion to m2’s share in the total mass and vice versa), while their magnitude depends on the nature of the cause of the interaction (in this case, relative motion).
Thus, shifting back to gravity, one is inclined to expect that something similar happens: that the ratio between the accelerations is given by the (inverse) ratio of the masses, but also that the magnitude is affected by the nature of the interaction (the sum of the “gravitational masses”?). Ok, it’s not so, but it’s a pity, isn’t it? For us, students, it’d make our life easier… I would see a coherent system where now I find a juxtaposition of (in some case, mysterious) rules...
In any collision:
[tex]
[/tex]
[tex]
[/tex]
After some algebra:
[tex]
\begin{array}{l}
\end{array}
[/tex]
