- #36
Ken G
- 562
That is correct, it exists in every massive star whose iron core is not yet highly degenerate. For very high mass stars, that is quite common indeed. I suspect it holds all the way up to core collapse energies, if the mass is high enough, but at very high mass there are other instabilities also, like pair creation. So core collapse looks a bit different for the stars that just fall right into black holes, but I suspect they are ideal gases the entire time.PeterDonis said:If this configuration is actually possible, then it should exist in our actual world. In other words, even with electrons that obey the PEP, it should be possible in our actual world for an isothermal iron core to exist in thermal equilibrium with a surrounding silicon burning shell at a size large enough that the density is well below the density at which the PEP becomes significant.
Certainly. Massive stars have convective cores, which means they burn a whole bunch of silicon completely to iron, creating an iron core all at once. At that moment, the core has just finished nuclear burning, so it is a very good ideal gas. It takes time to lose enough heat to go degenerate. The highest mass stars should undergo core collapse before their cores ever go degenerate, just like we are talking about. But those core masses are way past the Chandra limit (which has no importance for them) from the outset. The case I'm focusing on is when the cores start out below the Chandra limit, and gain mass from the silicon burning shell. Those get rather degenerate before they reach the Chandra limit, but would stay ideal in our hypothetical situation here.PeterDonis said:Is that in fact the case? That is, do massive stars exist in our actual world that have such iron cores?
They get to that configuration as iron ash is added to them, which causes them to lose heat as they contract under that load. The standard current picture is you have a silicon core that is above the Chandra mass for the most massive stars, and less than the Chandra mass for the middle mass stars. It is only the latter group that have any chance of getting degenerate iron cores. They do so because the core loses heat as mass is added to it. You pointed out in another post that these stars will probably already be past the SC limit when they first create their iron cores, and that's a good point. So their cores will already have undergone a kind of mini collapse, which creates a temperature gradient but might not be enough to get to the full core collapse energy level. Then the temperature gradient will initiate heat loss, and the core will go degenerate. Look at the core of the 10 solar mass star in figure 1 of https://www.nature.com/articles/s41586-020-03059-w . That is already a very degenerate core, there's a very clear transition there. It is also somewhat close to the SC limit, so close that it's not clear if it is above it or not. Maybe it was above it when it first formed, and the resulting T gradient that the SC limit creates is the reason it is so degenerate now. Much more massive stars don't show that sudden transition, those cores will be much less degenerate, maybe closer to ideal. So I believe that graph is showing us both cases you are mentioning, the case of ideal iron cores and degenerate iron cores. Unfortunately it is very hard to find discussions of the structure of the stars prior to the supernova simulations, all the attention goes to what happens in the supernova itself!PeterDonis said:OTOH, if massive stars with large iron ideal gas cores do exist in our actual world, then it seems to me that the other case you describe, a massive star with an electron degenerate iron core at a much smaller size, should not exist in our actual world--because there should be no way to ever get to such a configuration.
Yes, correct. It can also be too massive to reach equilibrium at neutron star size, and make a black hole instead. If all cores collapsed when they got to the Chandra mass, we would not see mergers of 10 solar mass black holes.PeterDonis said:The ideal gas core should, according to you, remain in equilibrium until its mass is well above the Chandrasekhar limit, and when the ideal gas core finally does collapse, it will be too massive to reach an equilibrium at white dwarf size.
