Block Tipping Over [Torque and Forces]
  • Thread starter Thread starter fobbz
    Block Forces
The discussion focuses on calculating the force required to tip a rectangular block under the influence of an applied force at an angle. The block's dimensions and weight are specified, and a free body diagram is created to analyze the forces acting on it. The torque equations are set up, but there is confusion regarding the angle of the applied force and the correct method to calculate torque. Participants suggest using the cross product for torque calculations and emphasize the need to determine the perpendicular distance from the pivot point to the line of the applied force. Accurate calculations are essential for determining the tipping force effectively.
fobbz
A rectangular block 3m high and 1.8m wide weighing in at 7600N is pushed with a force 20.5° to the height of the block 1.6m from the bottom of the block.
Calculate the Force Required to tip over this block.
Torque = perpendicular force x distance or force x perpendicular distance
Firstly, I make a free body diagram of the block.
N force up
mg force down
F 69.5° [N o E]
Secondly, I write my ƩTorque eq, using the pivot point where the box will tip on an angle. I will call this P.
Ʃτp = 0
(0.9)mg = (Fsin69.5)(1.6)
F = 4564.0 N
I'm not certain I understand what angle the applied force is meant to be at... is it meant to be 69.5 degrees from the horizontal?
I don't think the equation is quite right. The torque due to gravity is correct, but I think the torque due to the applied force should be different.
The torque is the cross product of position (relative to the pivot) with the force. The position of the applied force will be on the other side of the block compared to the pivot point. And the fact that the force is applied 1.6m from the bottom makes the calculation a bit trickier.
To work out the torque due to the applied force, you could either calculate the distance which crosses the line of the force perpendicularly and times this with the full force F. (This will take a few calculations of angles).
Or you could do the cross product, which I think will be easier.
15K
  • · Replies 45 ·
  • · Replies 21 ·
