- #36
Dale
Mentor
- 35,604
- 13,944
That is a good way to put it (better than my number 3). If you had written this then I would not have objected.cabraham said:I meant time varying fields present in the circuit loop. Time varying fields on the interior of the inductor is modeled by circuit theory, w/o the need to consider fields.
Yes, I read it. In the paper, despite how he drew it, he is considering the field inside an inductor. The example in the video is better on that count.cabraham said:The Lewin paper explicitly stated the field inside the circuit loop, not that on the interior of an inductor. Did you read the paper by Dr. Lewin?
It is not my own semantics, it is the standard meaning of the term "net charge". Your objection here is a little excessive.cabraham said:As far as a cap having " no net charge", this is very semantical. "Charge" as used by the science community implies "differential". An "uncharged cap" has lots of charge, but zero difference. A "charged cap" has the same total absolute charge but is displaced forming a differential. If you define "net charge" as total charge on both plates, then of course there is no "net charge" in either case, energized or not. Whan I say "charge" in ref to a cap, I infer the differential quantity, not the absolute total which you define as "net charge".
Dr. Lewin is correct on all counts. He simply illustrated how non-conservative fields differ from conservative. You're trying to look for reasons to poke holes in his case by bringing in arbitrary arguments based on your own semantics.
Yes, they are wrong for the same reason as above. As written they would apply to the apply to the fields within the interior of an inductor and not only to fields in the circuit loop.cabraham said:In the final analysis Dr. Lewin states the following.
1) With conservative E fields, KVL holds, & the potential from a to b is independent of the path.
2) With non-conservative E fields, KVL does not hold, & the potential from a to b is dependent on the path.
Introducing hyperbole does not alter this basic tenet. Is there any issue with the above 2 statements?
