- #281
Antiphon
- 1,686
- 4
yungman said:Hey Antiphon
I want to clarify with you so there is no mis-understanding:
1) You imply the real circuit like what I did has real physical size. With physical size resistors and wires, electric and magnetic field come into play.
2)Where the professor only draw the circuit loop with two resistors, he automatically imply there is no physical size of the resistors and no length between the connections. He cannot just simply put it into a real circuit and hope that the real circuit is still only two resistor in a loop with no physical size. AND it just happen the method of measurement just happen to give the same result he was looking for.
3)Is that the reason in #2 above that you said the circuit model that the professor gave and his experiment don't match and he cross the line? That he mixed the theoractical circuit diagram ( with no physical size) and he did the experiment that the EM effect come into play.
I guess this is similar to what I said before that, if he want to use his experiment, he has to put in the extra "real life" circuit elements of the emf generator due to the transformer effect of the loop of wire that pick up the flux etc. AND his experiment was frauded with the EM interference.
Please reply point by point to my questions with different color fonds right below my questions so we have a clear understanding with each other. As I said so many time, I only challenge his experiment.
Thanks
PS: I think this is the first argument that make sense to me. Now we wait for the ones that disagree to come in and present their case.
Sorry, I don't know how to color the responses.
1) Yes. The assumptions of circuit analysis are that a circuit has zero physical extent and that the circuit elements types do not cross-couple. That means a capacitor only exhibits capacitance, not inductance or resistance. In a microwave circuit you assume that a capacitor has all three. In a field analysis of a physical capacitor you could construct an equivalent circuit that would have to have an infinite number of resistors, capacitors and inductors to model a physical capacitor.
2) Essentially, yes. It isn't just the two resistors but as you pont out also the wires and the voltage source, everything. Any time you draw a circuit it is implicit that it has zero physical size. The professor's sleight of hand was not precisely in assuming that the circuit was of zero size; all circuits in circuit theory are. His feint was in assuming that it was *not* of zero size by allowing a magnetic field to couple to it. He construced a hybrid circuit which was partly idealized as in circuit theory and partly an electromagentic induction loop, a field analysis.
3) Yes.
