- #106
McQueen
- 256
Doc,
I presume that there would have to be a certain volume of water to be dispaced in the first place, otherwise nothing makes sense.
You assume wrong. The amount of water 'displaced' is a theoretical construct. That water need never have existed.McQueen said:Doc,
chingel said:why doesn't the extra mass cause extra force at the bottom of the tank?
cmb said:Because whatever restriction is in the way, limiting the aperture, it unloads the burden of the pressure above it. [wheras an aperture below it (if it expands again) re-applies the pressure back down on the water. The upper and lower parts of this aperture, that closes up then opens out again, must be in mechanical load-bearing contact to do this - else it'd leak!]
In the case of the uniform diameter cylinder, the walls exert no downward force. Thus you can imagine that the pressure on the bottom is just the weight of the water divided by the area. But in the case of the tank that gets narrower at the top, the walls do exert a downward force. This adds to the weight of the water--just enough to give you the same pressure at the bottom, independent of how much water is in the tank.chingel said:Why does pressure depend only on the height of the column?
If I have a cylindrical tank that gets narrower at the top and replace it with a cylindrical tank that is of uniform diameter of the same width that the first tank it at the bottom, and it is also as tall, it would take more water in it, but why doesn't the extra mass cause extra force at the bottom of the tank?
The height is the same, the area at the bottom is the same, but why doesn't the extra mass cause extra pressure?
Doc Al said:In the case of the uniform diameter cylinder, the walls exert no downward force. Thus you can imagine that the pressure on the bottom is just the weight of the water divided by the area. But in the case of the tank that gets narrower at the top, the walls do exert a downward force. This adds to the weight of the water--just enough to give you the same pressure at the bottom, independent of how much water is in the tank.
Walls exert force perpendicular to their surface. If the diameter of the tank varies, that means the walls must curve in, and thus will exert a component of force downward.chingel said:How do the walls exert a downward force?
Hi chingel. Maybe I could help explain what Doc Al is trying to say (not to put words in his mouth) but take a look at the picture OmCheeto posted:chingel said:How do the walls exert a downward force?
See: Artesian well: http://www.google.com/search?sourceid=chrome&ie=UTF-8&q=artesian+wellDaveC426913 said:Excellent diagram!
And if there's any doubt that the walls of B are applying downward pressure on the water near the edges, imagine what would happen if we removed that pressure that the wall is exerting!
I think a more direct example is a drydock. When you tow/sail a ship into a drydock, you can literally watch the water flow out of the drydock. But if you start with an empty drydock with a ship in it and open the gates, you fill it up to the same level to float the ship. The amount of water in the drydock when filled and with a ship in it is the same either way, regardless of if it started from empty or started with water and no ship.Doc Al said:You assume wrong. The amount of water 'displaced' is a theoretical construct. That water need never have existed.
Example:
jmmccain said:A fluid supporting an aircraft carrrier and a piston is that different? In a general sense?
DaveC426913 said:I've encountered a blip in my engineering idea.
Say our boat is a cube-esque block length 1m, width 1m, height 1.1m.
It weighs 1T, and so will float with .1m out of the water.
As a control, we float it in a calm pool and mark off where the waterline is, approximately .1m from the top.
And to prove it is indeed floating (this will become important later), we drop a 10kg cinder block on top. This causes the boat to sink into the pool by an additional 1cm, i.e. it is now floating a mere 9cm out of the water, our mark has sunk 1cm below the waterline. (The water level in the pool does not rise noticeably with the addition of 10kg.)
Agreed so far?
Now we want to demonstrate the exact same thing in our boat-hugging container. The container is 1.004m on a side, leaving a 2mm gap all around. It is as tall as we need it to be.
We drop the boat in and it floats to the exact same mark as above. So far so good.
Now for the pièce de resistance, we must prove that the boat is indeed floating above the bottom of the container (that it will rise and sink freely with only a change in weight).
We drop the 10kg cinder block on top and the boat sinks into the water by 1cm, just as before.
But wait - the water level in the container does not rise a mere 1cm, as before, it rockets out of the gap and climbs much higher because the 10L of water that the boat is now displacing must squeeze into the 2mm gap all around. It get a ridiculous figure when I try to calculate how high the water level in the tank must rise in the tank to accommodate 10L of water in a 2mm gap.
10L of water, distributed in a 4m x 2mm area works out to a ridiculous height of 125cm. That is obviously stupid because it means a 10kg addition makes the boat-and-water-level rise up in the container by 1.25m.
Where is the flaw in my logic?
DaveC426913 said:Where is the flaw in my logic?
Yes. If my logic is not flawed, the inevitable conclusion is that the act of dropping a 10kg cinder block on top of the boat would cause the boat-and-water-level-together to rise in the container by 125cm.Borek said:Is there one?
Absolutely. Which I too state, and have no qualms with. Regardless of the water level in the tank, the boat will float 9cm above the water and 101cm below it.AlephZero said:The level of the water relative to the boat changes by the same amount in both situations.
The displaced 10L is distributed throughout the lake. Lake water level rises a tiny amount. No prob.AlephZero said:measured relative the the bottom of the lake, the boat sinks (1-x) cm and the water rises x cm, where x is very small.
The displaced 10L is distributed into only a tiny gap, resulting in a calculated water level rise in the tank of 125cm. (Gap is 4.016m x 2mm = 80cm^2. A 10L volume on an 80cm area must be 125cm in height.) The inevitable conclusion is that the water level in the tank rises 125cm.This is not just intuitively ridiculous, it actually results in a paradox. (How can the water level in the tank rise 125cm? That would mean the boat (which is happily remaining floating 9cm out of the water and 101cm into the water at all times) is now physically sitting 125cm higher above the bottom of the container than it was before - meaning there's room for 1,250L of water underneath it - meaning it can't sit that high.)AlephZero said:In the tank, measured relative the bottom of the tank, the boat sinks x cm and the water rises (1-x) cm where x is very small.
Why do you treat these scenarios differently? Why does the same math not apply?AlephZero said:When you add the 10kg weight in the lake, then measured relative the the bottom of the lake, the boat sinks (1-x) cm and the water rises x cm, where x is very small.
It is the same math. I just renamed the variables, so "x" was the small quantity in both cases. If you prefer, call the movement of the boat down and water surface up b and w, both measured relative to the bottom, and where where b+w = 1cm. The relative size of b and w depends on the relative surface areas of the boat and the water.DaveC426913 said:Why do you treat these scenarios differently? Why does the same math not apply?
I think that is the key point of your mistake. "The displacement increases by 10L" doesn't say anything directly about where the water goes. What it means is "The volume of the boat which is below the water level increases by 10L". In the lake, you need to move very nearly 10L of water to make that happen. In the tank, you only need to move a small amount of water to get the same effect.Is 10L of water not displaced from under the boat? That's a specific volume that has to go somewhere.
DaveC426913 said:This causes the boat to sink into the pool by an additional 1cm,
Hm. I concede, though I do not quite yet get the logic.AlephZero said:I think that is the key point of your mistake. "The displacement increases by 10L" doesn't say anything directly about where the water goes. What it means is "The volume of the boat which is below the water level increases by 10L". In the lake, you need to move very nearly 10L of water to make that happen. In the tank, you only need to move a small amount of water to get the same effect.
nasu said:(the original block did not have to displace/move 1000 L of water to float).
chingel, please start a new thread.chingel said:Another problem I have
DaveC426913 said:Hm. I concede, though I do not quite yet get the logic.
Counter-intuitively the movement of a mere 4m x 2mm x 1cm of (80mL/80g) of water is enough to support a 10kg load.
DaveC426913 said:Counter-intuitively the movement of a mere 4m x 2mm x 1cm of (80mL/80g) of water is enough to support a 10kg load.
Not really. The buoyancy is not involved in the functioning of the hydraulic press (if this is what you have in mind).Per Oni said:That’s the principle of a hydraulic ram.
No, as an owner of swimming pools and fish tanks, I'm comfortable with the concept that pressure varies with depth, not with shape or area.AlephZero said:I agree, Pascal's law of hydrostatics (pressure varies with depth of fluid, independent of the shape of the container) is counterintuitive till you "get used to it".
AlephZero said:Here's another scenario that might help.
This is what I want to do, except most ideas I have for the inner vessel will experience deformation under pressure. We're talking < mm tolerances here for the experiment to work.AlephZero said:I think you could make a first version of the experiment with something as simple as a glass aquarium tank and a suitable sized watertight box (e.g. make a wooden box and cover the outside with plastic film). Weight the box with sand so it floats at a suitable depth. With a glass tank, you can (literally) see what is happening.
