Speed of the light and dilation of time
  • #51
Point of order: GAsahi, on PF, your arguments stand on their merits, not on condescension or sarcasm. ghwellsjr is disagreeing as strongly as you, but is managing to remain polite and address your arguments, not your person.
Carry on.
  • #52
Austin0 said:
I think in this instance ghwellsjr is correct.
The mutual red and blue shift you are referencing here is regarding the relationship of received signal frequency to emitted (proper) frequency. Obviously valid but it does not necessarily imply that the received signals are going to be shifted in that manner relative to their own proper rates.
To put it in context:
If we assume a gamma of 31.4 and a circular path of 314 ls then when the moving clock reaches the opposite side, the inertial clock will have emitted 157 1 second signals.
100 of those signals will still be in transit meaning that 57 signals would have been received by the accelerated system. The accelerated system at this point would have emitted 5 signals and have an elapsed time of 5 sec.
Obviously this is an approximation based on the assumption of angular velocity close to c.
but aside from that is there anything fundamentally wrong with this picture??
There's nothing wrong with your picture but I think it needs more explanation. You have covered the first half of the loop from the time the moving clock leaves the inertial clock until it gets half way around during which time it will have received 57 signals and emitted 5 which is an average red Doppler shift of 1/11.4 but now you should continue for the other half of the trip by saying that it will receive the 100 signals that were in transit, plus another 157 signals for a total of 257 while still only emitting 5 for a blue Doppler shift of 51.4. So the ratio per loop of the total signals received to the total signals emitted is 31.4 which is equal to gamma. But what is not obvious is that the maximum Doppler shift will occur at the closest approach of the two clocks where the Doppler shift will equal approximately two times gamma or 62.8 and then flip to the reciprocal as it passes. And the minimum Doppler shift occurs at the other side where it equals zero. These are all Dopplers as observed by the moving clock. The Dopplers as observed by the inertial clock are similar but reciprocals and skewed in time so they are not symmetrical as the moving clock goes around the circle and much more difficult to analyze and describe. Suffice it to say that the average is the reciprocal of gamma.
However, that scenario only serves to show that the red and blue shifts vary tremendously during the course of the loop with only the average equaling gamma for the moving clock and one over gamma for the inertial clock.
I think a better scenario would be similar to the one Einstein ended section 4 with which is to put the inertial clock in the center of the circle so that it is always 50 ls away from the circular path of the moving clock. This means that the number of signals in transit going from the inertial clock to the moving clock is 50 and has no bearing on the Doppler shift, it is merely gamma for the moving clock all the time. The number of signals in transit going from the moving clock to the inertial clock is 50/31.4 or barely more than 1 but again has no bearing on the Doppler and is the reciprocal of gamma for the inertial clock. In other words, the inertial clock sees the moving clock ticking slow all the time while the moving clock sees the inertial clock ticking fast all the time. This is the claim that Einstein made.
  • #53
Correct.
Incorrect, this is the claim that you mis-attribute to Einstein. Nowhere in his text does he make such a claim. Here is the complete quote:
"From this there ensues the following peculiar consequence. If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other which has remained at B by $\frac{1}{2}tv^2/c^2$(up to magnitudes of fourth and higher order), t being the time occupied in the journey from A to B.
It is at once apparent that this result still holds good if the clock moves from A to B in any polygonal line, and also when the points A and B coincide.
If we assume that the result proved for a polygonal line is also valid for a continuously curved line, we arrive at this result: If one of two synchronous clocks at A is moved in a closed curve with constant velocity until it returns to A, the journey lasting t seconds, then by the clock which has remained at rest the traveled clock on its arrival at A will be $\frac{1}{2}tv^2/c^2$ second slow. Thence we conclude that a balance-clock7 at the equator must go more slowly, by a very small amount, than a precisely similar clock situated at one of the poles under otherwise identical conditions."
Besides , you keep changing scenarios, sometimes your inertial observer is in the center of the circle, resulting into a transverse Doppler effect of \tau=\frac{t}{\gamma}, other times your inertial observer is located on the Equator, resulting into a Doppler effect due to rotation (you will need to learn how the Doppler effect operates in accelerated frames) of \nu_{observed}=\nu_{source}\sqrt{\frac{1-\omega R/c}{1+\omega R/c}} or
\nu_{observed}=\nu_{source}\sqrt{\frac{1+\omega R/c}{1-\omega R/c}} depending on direction.
To make matters even worse, you also co-mingle the Doppler effects with the calculation of total elapsed time (that is , what Einstein did in his paper) \tau=\frac{t}{\gamma} , hich happens to have the same formula as the one used by the transverse Doppler effect.
  • #54
GAsahi said:
Correct.
Well, although you finally agree with this statement, it is not what Einstein said. He said the equator clock goes slower than the pole clock.
But to say that the equator clock goes slower than the pole clock is to also say that the pole clock goes faster than the equator clock. So if you allow me to extrapolate what Einstein specifically said about the comparison of the rates at which the clocks tick to saying that one clock can see the other one ticking slower then you shouldn't have any problem allowing me to extrapolate in the other direction and to say that the other clock sees the one clock ticking faster.
I am well aware of what Einstein said and I am well aware that when you have two inertial clocks with a relative speed, then the time dilation effect is reciprocal and you cannot say that one clock is ticking slower than the other one without specifying the frame in which this is true. However, when you have one inertial clock and a second non-inertial one that moves in a circle and continually returns to the first one, then you can make a frame independent statement about how the clocks, on average, tick at different rates, with the non-inertial one ticking slower (and accumulating less time per lap) than the inertial clock which, of course, means that the inertial clock, on average, is ticking faster (and accumulating more time per lap) than the non-inertial one.
I'm only talking about these two different scenarios because Einstein talked about them. I agree that being able to define the Doppler in the first of Einstein's scenarios is extremely complicated and I never tried to do that. I said it fluctuates wildly but the average is easy to calculate.
I'm not co-mingling the Doppler effect with the elapsed time, I'm co-mingling it with the "time dilation" and that's because Relativistic Doppler is composed of two parts, the "time dilation" part and the part for the light transit time. For two inertial observers, that second part is continuously changing but specifically for Einstein's second scenario, that second part is unchanging and so has no bearing on the Doppler and so the Doppler and the "time dilation" factors are the same. But you seem unwilling or unable to see that it works both ways so that the equator clock can continuously see the pole clock as ticking faster than itself.
One thing about Doppler, since it is a local effect, you can calculate it using any frame and it will be the same in all other frames. I realize that I have not calculated it in a non-inertial frame in which the equator clock is at rest but I already know the answer from the frame in which the pole clock is at rest so I don't have to do all that extra work. But if you don't believe it, then I invite you to do the calculation in whatever frame would convince you rather than to just continually claim that the equator clock won't see the pole clock running faster than itself.
  • #55
Then, you should stop making up claims about what he said. I posted the complete paragraph, nowhere in the original paper does he say what you claim he says. You need to stop mis-attributting your erroneous claims to Einstein.
There is a simple way of putting an end to this, since you never put your claims in a mathematical form, why don't you write the mathematical formalism supporting your claims? For example, you claim:
This is , of course, false. The Doppler effect is a function of speed. Speed is frame-variant, so , the effect cannot be "the same in all frames". Write the math and you'll prove it to yourself.
  • #56
Isn't that interesting: "I invite you to do the calculation in whatever frame would convince you" but instead you challenge me to do the same thing. I already have done this numerous times on this forum. For example, see A&B moving in opposite directions @ 0.6 c comparison with sound, especially post #4.
Now, can you please show me any example where the relative speed between two inertial observers traveling inline comes out differently in different frames and then can you show me any example where the Doppler that these two observers see of the other one is different in different frames?
And since I have complied with your request, can you please comply with mine:
  • #57
Well of course it is your picture as per the conditions of the original scenario. I did not provide more explanation as I assumed the extrapolations were self evident.
GAsahi was claiming that your claim was incorrect because Doppler shift was reciprocal so I provided an example with your boundary conditions where this was clearly controverted.
The first half of the trip was the interval where the signals would be red shifted.
If in that interval the accelerating system received more signals than proper time it is clear that those signals were NOT red shifted relative to that systems proper time.
It is also clear that although the instantaneous relative velocity/gamma would vary with angle of motion wrt the inertial clock the same basic relationship would necessarily pertain. I.e. The accelerating system would receive more signals than sent. If those signals were video footage then as you say the motion of the inertial actors would appear sped up.
  • #58
You must mean this post. I have news for you, it does not prove that the RD (Relativistic Doppler effect) is frame invariant, quite the opposite, it is frame - variant. The fact that you doctored some elementary calculation, does not give creed to your point, quite the opposite.
Easy, in frame F, the realtive speed between source and receiver is v. In frame F', moving with speed u wrt F, the relative speed is w=\frac{u \pm v}{1 \pm uv/c^2}. So, your "proof" falls appart right from the start. You missed in your calculations that \beta=v/c is frame - VARIANT. Now, that I showed your mistake, redo your post 4 correctly, please.
  • #59
GAsahi said:
Easy, in frame F, the realtive speed between source and receiver is v. In frame F', moving with speed u wrt F, the relative speed is w=\frac{u \pm v}{1 \pm uv/c^2}. So, your "proof" falls appart right from start. What you did, is you missed in your calculations that \beta=v/c is frame - VARIANT. Now, that I showed your mistake, redo your post 4 correctly, please.
What do you think w represents?
Taken at face value from F' if u = velocity of F wrt F' then v would represent the velocity of the source wrt F' in the additions equation.
In which case w would represent the velocity of the source as measured in F =v
On the other hand if you are running the formula from F then w would be the velocity of the source as measured in F'
Which is it?
  • #60
Which is it?
Please stop butting in. If you do not know that speed is a frame variant quantity (this answers your question about the meaning of w), you should not interfere in this thread. Thank you.
  • #61
Is v frame variant?
Is u frame variant?
Is w frame variant?
Or is it just β that is frame variant?
  • #62
ghwellsjr said:
Is v frame variant?
Is u frame variant?
Is w frame variant?
All are frame variant.
  • #63
You are not applying the formula correctly. Here's what you should be saying:
In frame F, the source has speed u and the receiver has speed v. The relative speed between them can then be calculated using the formula for w.
If you want, you can transform the scenario into frame F' in which the source now has a new speed u' and the receiver has a new speed v' and you can calculate the relative speed between them using the formula for w but you will get the same answer as before.
I did use the formula for w in my post on the other thread and everything there is correct so you would please delete your post that it is flawed?
And please answer my request:
  • #64
ghwellsjr said:
If you want, you can transform the scenario into frame F' in which the source now has a new speed u' and the receiver has a new speed v' and you can calculate the relative speed between them using the formula for w but you will get the same answer as before.[/color]
Prove it. Use math. This is the best way to find your mistakes.
  • #65
Yes I understand the meaning of w and the additive velocities equation. I was unsure of which frame you were applying it from and what significance you were attaching to the result.
The velocity of anyone frame is obviously a relative quantity.
But as far as I know the internally measured relative velocity between any two frames S and S' is frame invariant.
Do you think this is incorrect?
  • #66
OK, I'll use the same scenario that I described in the other thread where speeds are expressed as fractions of c:
In frame F, the speed of the source is u=0.6 and the speed of the receiver is v=-0.6. The relative speed between them is:
w = (u-v)/(1-uv) = (0.6+0.6)/(1+0.6*0.6) = 1.2/1.36 = 0.882
Now let's transform the speeds into frame F' moving at j=0.365854 wrt frame F.
u' = (u-j)/(1-uj) = (0.6-0.365854)/(1-0.6*0.365854) = 0.234146/0.7804876 = 0.3
v' = (v-j)/(1-vj) = (-0.6-0.365854)/(1+0.6*0.365854) = -0.965854/1.2195124 = -0.792
Now we plug these two speeds into the formula for w to get w':
w' = (u'-v')/(1-u'v') = (0.3+0.792)/(1+0.3*0.792) = 1.092/1.2376 = 0.882
In both frames the relative speed between the source and the receive is 0.882.
Now I've done everything you've asked, will you please do what I requested:
  • #67
Let's make things simpler, if the relative speed between source and receiver in frame F is v, so the Doppler effect in frame F is:
\frac{\nu_r}{\nu_s}=\sqrt{\frac{1-v/c}{1+v/c}}
The relative speed between source and receiver in frame F' is w=\frac{u-v}{1-uv/c^2} so the Doppler effect in frame F' is:
\frac{\nu'_r}{\nu'_s}=\sqrt{\frac{1-w/c}{1+w/c}}=\sqrt{\frac{1-u/c}{1+u/c}}\sqrt{\frac{1-v/c}{1+v/c}}Contrary to your repeated erroneous claims, the Doppler effect is not frame invariant.
As an aside, any quantity that depends on speed , such as total energy, kinetic energy, momentum, Lorentz force, relative speed between two objects is NOT frame invariant. This is textbook SR, if you get a result that shows frame invariance, you have done something wrong. I'll let you figure what you did wrong in your "proof".
  • #68
Yes. Please stop.
  • #69
The doppler effect is completely determined by the relative velocity of source and target. Both of these velocities are frame dependent, but the relative velocity between emitter at event of emission and receiver at event of detection is frame invariant. Thus all observers agree on the doppler measured by a given detector from a given source.
Mathematically, relative speed is defined by parallel transport of 4-velocity from one event to another (in SR, this is path independent, thus unique), then dot product of transported source 4-velocity with unit 4-vector 4-orthogonal to target 4-velocity. Dot products are invariant - period. (In a standard inertial frame in SR, parallel transport leaves a vector unchanged).
[Note: ghwellsjr's calculation is correct, and the above argument simply provides the general principles which guarantee it must come out this way].
  • #70
I gave a general argument that this is all wrong. The specific errors in the above math are as follows:
Given (for example) stationary (in unprimed frame) source, and target at speed v, you have relative velocity v.
In primed frame moving at u in the same direction as v, you now have:
target moving: (u-v)/(1-uv/c^2) = v' [as given by GAsahi ]
source moving at: -u
relative speed of source and target in primed frame is then:
(v'+u)/(1+uv'/c^2)
If one simply does the algebra, the result is v, validating gwellsjr's calculation.
  • #71
GAsahi said:
...the Doppler effect is not frame invariant...
To show that the Doppler effect is frame invariant you don't have to do any maths at all -- just look at the definition \nu_r / \nu_s.
\nu_s is measured by the source using the source's own proper-time clock.
\nu_r is measured by the receiver using the receiver's own proper-time clock.
All observers, whatever coordinates they are using, agree on what the source and receiver's proper times are (associated with a 2\pi phase change), therefore agree on the two frequencies, therefore agree on the Doppler factor.
  • #72
Even if the relative velocity between source and receiver were frame invariant, the Doppler effect is not frame invariant by virtue of the fact that:
\frac{\nu_o}{\nu_r}=\frac{1-\frac{v}{c} cos (\theta)}{\sqrt{1-(v/c)^2}}
\theta, the angle between the relative velocity and the wave vector is known not to be frame invariant (see the aberration formula).
Dot product of 4-vectors is indeed frame-invariant. Unfortunately, the vectors involved in the Doppler effect are THREE - vectors, not 4-vectors:
\frac{\nu_o}{\nu_r}=\frac{1-\frac{\vec{v}\vec{e}}{c}}{\sqrt{1-(v/c)^2}}
whre \vec{e} is the wave vector. The dot product of two 3-vectors is not frame invariant.
  • #73
Let us consider observer A circling around observer B, and one instantaneous moment of this situation. It looks like A is just passing B at high speed, so we can guess A and B see a mutual time dilation.
  • #74
This is wrong too. The angle here is the angle as measured in the comoving inertial frame of the detector. This is frame invariant.
Let me ask this: Do you really think the measurement on a given instrument depends on who looks at the instrument?
GAsahi said:
E
This is incorrect. The doppler is determined by the source 4-velocity (at emission event) represented in the basis of the target frame at event of detection. This is determined by dot products of the source 4-velocity with the target basis unit vectors, as I previously explained. This result is manifestly frame invariant.
  • #75
I totally understand how moving at the speed of light can make you travel into the future, but how does it make you go back in time?
  • #76
...measured from an arbitrary frame in motion wrt the frame of the detector this angle changes (via the aberration formula).
Wrongly formulated question, not "who looks at the instrument" but "from what frame is the measurement made". This is the essence of judging frame invariance.
This is incorrect.
Look up p.62, formula (90), "The theory of relativity", C. Moller.
Look up p.114, formula (311a) , Theory of relativity", W. Pauli,
Look up...
  • #77
The only measurement that matters for Doppler is the angle measured from the detector's frame.
The measurement is made by a detector. Any measurement by any detector is frame invariant.
GAsahi said:
.Look up p.62, formula (90), "The theory of relativity", C. Moller.
Look up...
I read Pauli 40 years ago. I think I understand what he wrote perfectly well.
  • #78
From the perspective of another frame, moving wrt. the detector, the angle changes.
This is not a valid answer, the formula I cited can be found in both Moller and Pauli, and in any standard textbook, perhaps it is time for you to read Pauli again.
  • #79
That is not relevant. You misinterpret the physics of the Doppler formula. The angle in the formula is the angle as measured from the detector frame.
The formula for Doppler is not the issue. The issue is your misinterpretation of the variables in the formula. I certainly don't need to re-read Pauli. I have a copy and enjoy it regularly. The issue, again, is physical understanding of the formulas in it.
  • #80
No one denies that. How does the formula transform from the perspective of a moving frame , this is the issue being discussed.
The "variable" in the formula is , contrary to your claim, a 3-vector, not a 4-vector. While the dot product of two 4-vectors is invariant, the dot product of 3-vectors is not. I suggest that you re-read Pauli. While you are at it, read (or get) Moller. His book is better than Pauli's.
  • #81
The "variable" in the formula is , contrary to your claim, a 3-vector, not a 4-vector. I suggest that you re-read Pauli. While you are at it, read (or get) Moller. His book is better than Pauli's.
The 3-vector in the formula is constructed by taking a 4-vector's dot products with the basis vectors of the detector frame. These dot products are frame invariant.
Let's focus on physics. If you say two detectors in different states of motion measure different Doppler, of course, this is true. It is also true that a given detector's measurement of Doppler is invariant. This is about all there is to the physics of the situation. Do you dispute any of this? If so, you are simply wrong.
  • #82
There is no 4-vectors in any of the two derivations I cited. You can check your copy of the Pauli book. Even better, get the Moller book, it is a better book.
So, are we done here?
  • #83
I don't know. Gwellsjr was simply stating that the relative velocity and doppler between a given source and detector was frame invariant, and calculated a specific example showing this. Everything about his calculation and interpretation is correct. You disputed this. So I don't know if we are done. Gwellsjr said nothing about two different detectors in different states of motion measuring the same thing.
[as for 3-vectors versus 4-vectors: an event at a world line has an associated tangent 4-vector. If you express this in a particular basis, you get a 3-vector (3-velocity). The way to get this expression is to form dot products of the 4-velocity with a frame's basis vectors. The basis vector's of a detector's frame are unit 4-vectors, and the dot products are invariant. I would readily state that Pauli does not use this more modern language, but (unlike you) he makes no mistakes at all about the physics of the situation under discussion. He understands that the variables in the Doppler formula relate to measurements in the detector frame, and thus are determined purely by the motion of detector and source, and not by the motion of some other observer.]
  • #84
Post #24:
GAsahi said:
ghwellsjr said:
Yes, on average, your son would see you in slow motion and you would see all the people in fast motion, but I wouldn't say "thousands of times actual Earth speed", just thousands of times your speed.
This is false, time dilation is symmetrical, each observer sees the other in slow motion.
Post #54:
We're not done until GAsahi performs my simple request to show that Einstein's claim that the equator clock is going more slowly than the pole clock also applies to the pole clock that it is going more slowly than the equator clock and that
  • #85
You are trying to move the goalposts, I posted a formula for the Doppler effect in terms of 3-vectors (post 72), you claimed that it was wrong (post 74). I gave you two references that show the formula to be correct (post 76).
There is no reference to the invariance of the Doppler formula in the Pauli text. Nor is it any reference in the Moller text.
  • #86
No, I said your interpretation of the variables in it was wrong. In a different post, I showed where you made an error computing relative velocity between source and target in different frames, and that after correcting the error, the result is that it is the same.
  • #87
ghwellsjr said:
We're not done until GAsahi performs my simple request to show that Einstein's claim that the equator clock is going more slowly than the pole clock also applies to the pole clock that it is going more slowly than the equator clock and that.
It is very simple really: Have the observer traveling around the Equator unroll a fiberoptic cable connecting him with the stationary observer. From time to time, each observer sends a pulse towards the other observer (not at the same time). Each observer will measure the other's frequency redshifted by : \sqrt{\frac{1-\omega R/c}{1+\omega R/c}}. The Doppler effect is mutual, the roles of the source and the receiver are interchangeable. You are mixing the Doppler effect with Einstein's calculation of total elapsed time. In that experiment, the roles of the inertial and the non-inertial observer are not interchangeable.
  • #88
PAllen said:
No, I said your interpretation of the variables in it was wrong..
Here is exactly what you said:
  • #89
My explanation is referring to how the 3 vectors in the formula are actually frame invariant because they are referred to the basis determined by the 4-velocity of the detector. I may not have been clear as I should have been, but the thrust of my statement was this: the definition of the variables in the formula make the result frame invariant.
  • #90
The Doppler effect is mutual between two inertial world lines (each acting as source and target relative to the other). Between an inertial world line and a non-inertial world line it is not mutual. A light source in forced circular motion around an inertial target is always red shifted. A target in forced circular motion about an inertial light source will see its light always blue shifted. The simplest way to derive this latter fact is to compute, in the inertial frame, the proper time interval for the circular target between arrival of successive circular wave fronts emitted by the central source.
  • #91
Sure, it is a pure form of transverse Doppler effect. This is NOT what my post is about, it is about the Doppler effect between an observer stationary on the circumference and one traveling along the circumference. There is no central "target". Both source and receiver are on the circumference (one is stationary wrt the circumference, the other one isn't).
There is no "central source", please pay attention to the scenario.
  • #92
Sure there is. Under discussion (at least the discussion I was responding to) was polar clock or light source, and an equatorial clock or light source, under the assumption of removing the Earth (so as to remove gravitational effects not known to Einstein or anyone else in 1905), while keeping the motions the same and noting that the polar clock/source is the inertial one (they can't both be). In this scenario, light from a polar source will be always seen blue shifted by an equatorial detector. Light from an equatorial source will be seen always red shifted by a polar detector.
  • #93
PAllen said:
Sure there is. Under discussion (at least the discussion I was responding to) .
Once again, you are responding to the wrong scenario, the scenario in discussion has both observers on the circumference.
  • #94
I was responding to the discussion of the scenario introduced in post #34, not the earlier, more complex scenario. However, on that one, I agree with Gwellsjr that while both observers would see a periodic pattern of red and blue shift, the inertial observer would see, on average, more red shift, and the non-inertial obaserver would see, on average, more blue shift.
  • #95
That's not what you responded to earlier:
GAsahi said:
ghwellsjr said:
We're not done until GAsahi performs my simple request to show that Einstein's claim that the equator clock is going more slowly than the pole clock also applies to the pole clock that it is going more slowly than the equator clock...
I thought you were proposing that the "observer traveling around the Equator" was actually at a fixed location on the Equator and "traveling" due to the rotation of the Earth which is what Einstein was talking about. And I thought the stationary observer was at one of the poles which is what Einstein was talking about. And I thought you proposed a fiberoptic cable connecting the two to take care of the problem due to the curvature of the earth.
Did you actually have something else in mind?
  • #96
There is no rotation, the "traveller" moves along the Equator and unrolls a fiberoptic cable as he travels. The "stay at home" observer is just stationary on a point on the Equator.
Yes, see above.
  • #97
So the Earth is not rotating?
Does the "traveller" finally get back to the "stay at home" observer and if so, are they communicating via a fiberoptic cable that goes around the earth?
  • #98
The "earth" is a non-rotating flavor.
The "traveller" gets back to the "stay at home".
The "twins" exchange signals via the fiberoptic cable unrolled by the traveller.
The "traveller" transmits the data only in the direction contrary to his direction of motion.
The "stay at home" sends data "chasing" the traveller".
  • #99
Austin0 said:
What do you think w represents??
Which is it?
It is also now clear that I was unsure of what you thought you were doing with the Additions equation because you were trying to apply it incorrectly. As demonstrated by ghwellsjr and his correct application.
I came by an understanding that relative velocities between two frames was invariant simply through the meaning and use of the additions formula. This of itself necessarily implies frame invariance of calculated velocities ,which coupled with the understanding that Doppler was a simple function of relative velocity necessarily implies that measured Doppler is invariant.
GAsahi said:
Yes. Please stop.
Well here you are not only rude but simply factually wrong
SO now we have come full circle back to my post #44
GAsahi said:
This is further compounding the confusion, the Doppler effect on frequency follows a different set of rules in accelerated frames. The revolving observer is continuously accelerating , so you cannot extrapolate from the Doppler effect in inertial frames. The only thing that you got right is the fact that, quantitatively, the observers notice a mutual blueshift when they approach each other. When they are separating from each other, they are experiencing a mutual redshift.
In both cases the effect is mutual i.e. you cannot have:.
#44
Obviously this is an approximation based on the assumption of angular velocity close to c..
Here I provided a clear appraisal of your position and the basis of your erroneous assumption. I.e. That the reciprocal aspect of linear Doppler shift would apply in this context.
I also gave a simple demonstration of specific conditions which clearly showed the error of your assumption.
Rationally you had two options:
1) Show that my calculations were wrong or 2) recognize that your position was in error.
That you did not effect option 1) , I view as tacit admission that you could not.
It is also clear that although the instantaneous relative velocity/gamma would vary with angle of motion wrt the inertial clock the same basic relationship would necessarily pertain. I.e. The accelerating system would receive more signals than sent. If those signals were video footage then as you say the motion of the inertial actors would appear sped up..
Apparently my assumption of logical facility and self evident extrapolation was misplaced in your case because
you also did not choose option 2) but instead proceeded to ignore this evidence and continue with a course of obfuscation and false premises. Not to mention your rude arrogance towards me without refuting or even addressing anything specific i offered.
Do you seriously think the needless complication of your fiberoptic cable could possibly alter the fundamental relationship of clock rates in this scenario? Or that the results of any alternative conditions could negate the conclusions derived from my or ghwellsjr's scenarios where you are clearly in error?
  • #100
A fiber optic cable will add significant complications:
- speed of light is not c and not invariant in a fiber optic
- refraction is frame dependent in rather complex ways (see, e.g. http://www.mathpages.com/rr/s2-08/2-08.htm)
The scenario without a cable is not hard to analyze in the inertial frame. Then, you can rely on the frame invariance of measured Doppler. The clearest statement of why this is true was given by Dr. Greg way back in post #71.
