Speed of the light and dilation of time
  • #151
GAsahi said:
Correct.
Correct. If you paid attention, you would have noticed that the path is HALF circle, so you should have stopped here.
Try paying attention to the scenario, gjwellsjr had the two observers "looking at each other through a webcam". How do you think one connects webcams? Hint: through a fiberoptic cable.
You are assuming that the Earth is transparent, aren't you? Last I checked, it wasn't. :-)
I'm assuming the Earth isn't there as it is extraneous to the scenario. I described worldlines in empty (flat) spacetime.
As I recall, gwellsjr did, indeed, propose to consider the Earth transparent, so as to discuss doppler the way all the world except you does.
  • #152
But it is THERE. Please stop making up scenarios.
You are now making things up again. No person in his right mind would "make the Earth transparent". Why is it so difficult for you to admit you are wrong?
  • #153
Because I'm not. I have been pretty clear what my assumptions and definitions are, and draw correct conclusions from them. I have granted that in the peculiar (to me) scenario you insist on, you are also right. Measuring doppler through a curved tube removes all utility it has in accounting for differential aging, so I have no interest in this scenario.
  • #154
Good, because the "peculiar" scenario is the one that has been in discussion before you butted in and it is the realistic scenario. Your "transparent Earth", isn't.
  • #155
Obviously, we differ about the plausibility of such a tube. Beyond that, how is it instructive? All it shows is that finite signal times, if not accounted for, can lead to confusing results. If you pulled off the mirror tube scenario all the way to meeting time, what would be seen is:1) Stationary observer sees circular observer's clock right next to them behind theirs. Looking in the webcam, they an image of this clock even further behind.
2) Circular observer sees stationary clock right next to them ahead of theirs. Looking in the webcam, they see an image of this clock behind theirs.
Conclusion: webcams with long signal paths don't tell you much unless you compensate for signal delay. Any reasonable way of doing this suggests that time ran faster for the stationary clock over all, and there is no unuique way of locating the time differential along the different world lines.
  • #156
It is instructive because it teaches you to read before butting in. It also teaches you not to make up cockamamie scenarios that involve "transparent Earth(s)".
1) Stationary observer ... Looking in the webcam, they an image of this clock even further behind.
2) Circular observer ... Looking in the webcam, they see an image of this clock behind theirs.
...which contradicts the claim made by gjwellsjr in post 20. Thank you for coming up clean.
  • #157
My scenario had no Earth at all because it was extraneous to the main issues. Moving the world lines to empty space allows easier understanding of the central issues.
  • #158
Agreed. But it is not the original scenario that sparked the argument. You need to learn to pay attention to what is being discussed, rather than making up your own scenarios.
  • #159
Simplifying a proposed scenario is generally very instructive and normally done on these forums.
  • #160
I liked your idea of connecting two observers stationary at different points on the Earth through a fiberoptic cable but not when one of them is traveling on a very high speed train around the Earth thousands of times per second which is what the scenario is. I discussed in detail how this would work using radio signals transmitted through antennas in post #31.
  • #161
The fiberoptic cable doesn't have to be unrolled, you can simply have it placed around the Equator and send the pulses from the current position(s) of the observers. Same idea as using mirrors, using GPS or using antennas located along the Equator.
  • #162
Well then, why don't we say we have an electric train and we communicate through the third rail (or trolley line)?
  • #163
GAsahi said:
1. Observer A accelerates in a straight line away from observer B. The two observers send light signals towards each other. B sends a ray that chases after A and A sends a ray back, along the line connecting them. Do they measure the waves as being:
A1. Mutual Redshift
B1. Mutual Blueshift
C1. One Redshift while the other Blueshift
2. Same problem as above but the trajectory is a half circle. The rays exchanged follow the circular arc.
A2. Mutual Redshift
B2. Mutual Blueshift
C2. One Redshift while the other Blueshift
OK, we have two identical problems except that the first one is in a straight line and the second one is in a half circle.
For the first problem, we start with A and B mutually at rest in a common inertial Frame of Reference. They have identical synchronized clock/light systems. A quickly (let's agree on instantly to make life simpler for ourselves) accelerates to some speed away from B in a straight line for some distance as defined in our FoR. A and B will observe the same redshift in each others clock/light system for awhile. But during this time, A's clock/light system will be time dilated, meaning that it is running slower than it was before. When A reaches the target distance, he instantly stops. He immediately sees the clock/light system of B go back to normal (no Doppler) but B does not see the same thing. He continues to see the clock/light system of A to be redshifted for an additional length of time corresponding to the light transit time for the signal to go from A to B. After this time period is over, A and B will see the time on each others clock/light system as having accumulated different time deltas during the observed redshift periods. A will see B's clock as having accumulated more time than his own and B will see A's clock as having accumulated less time than his own. So even though they both observe the same amount of redshift, they observe the redshift for different periods of time and thus different amounts of accumulated time deltas and so none of your multiple choice answers is correct.
For the second problem, since the light is made to follow the same circular arc path that A traverses, it has the exact same analysis as the first problem and the same answer--which is none of the answers you provided.
Any more scenarios you'd like explained?
  • #164
The answers should be the same, in BOTH cases BOTH observers measure redshift . I simply introduced the first case as a warmup for the second case, in order to stop the nonsense about the "Transparent Earth".
. A and B will observe the same[/color] redshift in each others clock/light system for awhile.
Not "for a while", for the whole duration of the trip both observers measure redshift, contrary to your incorrect statement made at post 20 that started the whole thing.
Now, you are trying to sneak in words like "same", in order to have another crack at justifying your position. Of course that the observer in circular motion is not seeing the same[/color] amount of redshift, since he isn't perfectly equivalent to the inertial observer. The point is that BOTH observers measure redshift. Please don't try to move goalposts, I am very good at detecting such attempts.
You should have stopped while you were still ahead, the point is (and has always been) that your statement that one observer measures redshift and the other one measures blueshift is false.
Pass.
  • #165
GAsahi said:
The answers should be the same. Since you got different answers, you continue to make mistakes.
I don't know why you are saying this. I thought it was very clear that I got the same answer for both of your problems.
You didn't make the trip in your two problems the same as the trip in post #20. In your two problems, A only went half way around instead of all the way around as in post #20.
Well since we both agree on this half of the trip, I'd like to do the other half where A returns to B for both of your problems. I just need to know if these two new problems will end up having the same answer to each other or different answers. In other words, for your second problem, are you going to insist that A sends and receives signals along the total path length that A traversed, meaning that it ends up twice as long as in your original statement of the problems? Or are you going to have A send and receive the signals ahead of himself or will you allow A to turn around and come back on the same path he left on?
I should not stop until we have completed the same problem that we had in post #20, not some new scenario that you dreamed up and claimed is the same. After I analyze the return half of the trip, I'll put them together and then we'll see where we stand.
  • #166
I made it half circle in order to preclude further cheating. In the further posts, once I made sure there was no more cheating, I allowed it to be full circle.
It is really simple, the signals from A to B and from B to A are always sent along one path. So, when A completes the circle, the signal path is twice the length for the semi-circle. This precludes any attempt at moving goalposts.
Not allowed.
You stand that you were wrong and that you are trying to move some goalposts.
  • #167
Looking at #19, which introduced the webcam question, the OP said nothing about the signal path connecting the webcams. For any reasonable scenario (and I consider a forever growing signal path as not reasonable for a cyclic situation), e.g. using GPS sattellites, what Gwellsjr describe in #20 and #31 would be correct. Only for the (IMO absurd) case created by GAsahi and not by the OP would it be true that the webcams show mutual ever growing mutual time dilation.
  • #168
PAllen said:
Looking at #19, which introduced the webcam question, the OP said nothing about the signal path connecting the webcams. For any reasonable scenario (and I consider a forever growing signal path as not reasonable for a cyclic situation), e.g. using GPS sattellites, what Gwellsjr describe in #20 and #31 would be correct. Only for the (IMO absurd) case created by GAsahi and not by the OP would it be true that the webcams show mutual ever growing mutual time dilation.[/color]
So, you are back to one last gasp attempt to prove that you are right, eh?
There is no mention of "ever growing" mutual time dilation, there is mention of mutual redshift. There is no "ever growing", so why do you try moving the goalposts again?
As to the way of connecting everything, the circum-equatorial "tube" is present from post 1.
  • #169
Who appointed you dictator of someone else's thread? Only you get determine what scenarios are allowed for discussion? Giving a correct description of a stated scenario is not wrong because it differs from the only scenario you want to allow. So far as I see it, basically everything I've said, and everything Gwellsjr has said, is correct.
I find your whole attitude strange, especially as you have made a number of clearly incorrect statements (not related to scenario confusion - just bad math, and false critique of Gwellsjr's math).
[edit: as to ever growing time dilation, if there is only ever red shift seen via webcams, each sees the clock image in the web cam fall ever behind theirs, having ever larger disprepancy compared to clock comparisons at points where they meet on each circuit.]
  • #170
The scenario introduced by the OP is what is being discussed. It is THIS specific scenario that ghwellsjr made the incorrect claim about what the two observers measure.
You have tried in vain to move the goalposts several times by introducing other scenarios. If you want to discuss your scenarios, open your own thread and I will be more than happy to discuss with you.
I was just pointing out that you keep trying to put words in my mouth. I never made the claim, so stick with what I wrote, don't move the goalposts, ok?
  • #171
Post #1 describe travel in a tube. The OP, so far as I've seen, never specified anything about how webcams got their signal. There are many possibilities, and I find yours the least plausible and meaningful - precisely because it erases the real the differential aging that occurs.
  • #172
The OP actually raised several variants in the first dozen threads, most of which are incompletely specified. You seem to claim that only you are allowed to specify the details of what the OP meant or was concerned about.
  • #173
You've stated that by your definition of how the webcam's operate, each always sees red shift and time dilation. Since the OP clearly stated multiple circuits by the train, that clearly implies that the discrepancy between the webcams and direct clock comparisons at meeting points is ever growing.
  • #174
Forgive me for all these questions, but I am just now learning all the rules for goalposts and I really don't want to cheat.
Well that does make it really simple--everything is doubled from your half-circle problems.
GAsahi said:
Not allowed.
That's why I asked first.
Sorry, I can't make sense of this statement but why do you think I'm trying to move any goalposts? Haven't I been playing fairly by your rules?
  • #175
Don't attribute to me what someone else said or you think that person said.
  • #176
OK, so now you have agreed that after A makes one complete loop around and has rejoined B, they both have observed the same redshift but A stops seeing it as soon as he stops but B continues to see the redshift for a longer period of time, in fact, the period of time that it takes for light to travel around the fiberoptic loop.
Now I don't want to cheat or be accused of moving any goalposts or even wanting to move any goalposts but I just don't have any idea how you make the transition to the actual scenario where A does not stop but rather passes by B and continues around the loop a second time. Could you please explain how the redshift works for both A and B and how it correlates to the actual time the A and B can see on each others clocks as they A passes by B?
  • #177
The above means that you realized your mistake in claiming that one observer measures redshift while the other measures blueshift. This is progress.
Huh? The situation repeats identically. The period of the phaenomenon is 2 \pi. Both A and B measure redshift as soon as A starts accelerating away from B.
  • #178
But it's only a tiny bit of progress. I still have a long way to go to learning all the goalpost rules. And thank you for not accusing me of trying to cheat this time. I really don't want any cheating going on.
I see, so you're say that A stops when he reaches B so that B can finish seeing the redshift coming from A traveling all the way around the fiberoptic loop and then A accelerates away from B a second time. Now I realize that as soon as A stops, the redshift that he sees coming from B also immediately stops (no more Doppler) but how does A know when B stops seeing the redshift so that he can start up again? Is he sneaking a peek at B's webcam? Wouldn't that be cheating?
  • #179
Yes, you are a slow learner.
A goes around in circles, nothing to do with B.
Where is this going? Are you just trolling now?
  • #180
If you quit teaching, then I'll never learn.
I have no idea where this is going. You have all the rules and until you disclose them, I can't know them.
Not me, must be someone else.
  • #181
Oops, you edited this in while I was composing my previous response.
So have you changed your mind, does A continue past B without stopping? I'm confused because before you said:
That "Huh?" in there implies that something is obvious to you that you think should be obvious to me but it isn't, I just don't understand what you have in your mind, you need to spell it out, don't take anything for granted.
  • #182
GAsahi said:
Huh? The situation repeats identically. The period of the phaenomenon is 2∏. Both A and B measure redshift as soon as A starts accelerating away from B.
I have been going back over all of your posts and I think maybe I have figured out what you have been saying all along and I have been missing. Tell me if this is right:
The OP in this thread asked about a father-son variant of the twins paradox in which the father took a 30-year long trip at a very high speed and after he returned, his son had aged 30 years while he aged only a few days. In the typical twins paradox scenario, each observer always determines the other observer's clock is time dilated, both going and coming and yet when they reunite, the traveling observer has aged less. So whether the observed Doppler is red shifted (as at the beginning of the trip) or blue shifted (as at the end of the trip), they both lead to the same time dilation (clocks running slow), never time contraction (clocks running fast). The difference between the typical twins paradox and this one is that instead of the path being straight out and back, the path follows a circle.
  • #183
Does this mean you have changed your mind about your conclusions regarding the direct communication scenario. either a transparent Earth or no earth?
  • #184
Actually, I disagree with this analysis of the regular twin paradox:
- If you are seeing images sent by direct light path (a la a webcam), the turnaround twin seed the stay at home clock running fast for half the trip, while the stay at home sees the traveling twin clock fast for much less than half the trip.
- There are an infinite number of way to try to separate Doppler or pure visual image from some hypothetical underlying time rate. As a result, there is no uniquely defensible answer. However, any method of pairing the world lines for simultaneity (so the assignment is a continuous monotonic function of position on each world line, and pairs events with space like separation) has the following features:
-- there will be simultaneous times when one sees blue shift and the other redshift
-- the traveler will interpret the time rate of the stay at home as faster, on average, than theirs.
Note that the simultaneity match up that is based on instantly co-moving inertial observers is the so called Fermi-Normal coordinates. For this, if you smooth the turnaround even the tiniest bit, then during the turnaround, the turnaround twin interprets the stay at home time rate as extremely fast.
The circular twin paradox has all the same essential elements as above if signals pass through empty space. It is also essentially the same for any signal path that isn't like GSahi's (IMO absurd) case of communication only through a mirrored tube matching the path, and all signals only travel one way, thus forcing light to behave as if there is no turnaround. For example, if the webcams communicate via a space platform placed way over the pole (while one twin travels rapidly around the equator and the other stays put), then the traveling twill will see the the stay at home always fast, and the stay at home will see the traveler always slow. This is consequence of the fact that this particular signal path length is constant - IMO the most informative because you are then purely comparing time rate at fixed delay, without effects from varying length of signal path.
  • #185
I think you have me confused with PAllen. I never made any argument about a transparent Earth or about no earth.
But since GAsahi has gotten himself banned and will not be able to answer my question, I will assume that my assessment of his position is accurate. I was then going to point out that even though in the typical twins paradox scenario (where the traveler goes away in a straight line and then turns around and comes back) and they both observe the same redshift at the start of the trip and the same blueshift at the end of the trip, the percentage of time that they observe redshift and blueshift is not the same. The traveler observes redshift for exactly the first half of the trip and blueshift for exactly the second half of the trip whereas the stay-at-home observer observes redshift for just about the entire time the traveler is gone and only observes blueshift during the very end of the trip. Therefore we can say that for both observers during most of the second half of their observations, the non-inertial traveler observes blueshift and the inertial observer observes redshift. I finally got GAsahi to admit that their observations of redshift are different in post #164 but then communication stopped:
GAsahi said:
Of course that the observer in circular motion is not seeing the same amount of redshift, since he isn't perfectly equivalent to the inertial observer. The point is that BOTH observers measure redshift. Please don't try to move goalposts, I am very good at detecting such attempts.
He was only able to defend his stance of both observers measuring the same redshift by focusing only on the first half of their observations and pretending that the second half of the trip didn't exist.
I have no idea whether GAsahi would admit to this explanation but if he would, I was then going to point out that each trip around the Earth is an individual twin paradox scenario and we could analyze it once and then multiply it by some huge number to get the full effect. Unfortunately, when GAsahi insists on using his fiberoptic link in his one-way scheme, he makes it impossible to link multiple trips together because it isn't over when the traveler gets back to his starting point.
The nice thing about the usual twin paradox scenario is that since the traveler spends most of his time inertial, the observed redshifts and blueshifts are steady and easy to analyze but when the traveler takes a circular path, they are continually changing for line of sight observations which of course is not possible in this scenario so the whole issue is how do we provide a communication scheme that will allow continual communication. I proposed in post #31 radio links via antenna(s) and stated that an antenna at or above the Earth's pole would allow for steady Dopplers, steady redshift Doppler observed by the son and steady blueshift Doppler observed by the father but even if they weren't steady because of the antenna locations, they would average out the same. Unfortunately, GAsahi made several wrong statements regarding this and now we will never have a chance to iron them out.
But rest assured, I have not changed my mind about anything on this thread.
  • #186
I was composing my previous response while you were posting yours but I think you can see that we are in complete agreement as long as you understand that I was framing the twin paradox as a paradox which states that both twins always determine the other twin as being time dilated. This of course works fine for the stay-at-home twin since he remains inertial but the traveling twin requires two separate inertial reference frames in order to create the apparent paradox. I just thought that this might be the point that GAsahi was making but now we'll never know.
  • #187
glad to hear it
Originally Posted by ghwellsjr View Post
But in this thread, the stationary clock is not at the pole but at the equator which complicates things. For one, each clock will only be able to see the other one during a small portion of the time when they are close together. During this brief period of time, you can approximate the relative motion as mutual and they each see the other ones clock as ticking faster while approaching then slower while retreating but the time dilation, based on two different approximately inertial frames for each clock will determine that the other clock is ticking much more slowly (I presume this is what HallsofIvy meant in post #21). And if they could see through the earth, they would each continue to see the other ones clock fluctuating in its tick rate, but on average, the zipping clock would see the station clock as going faster than its own and the station clock would see the zipping clock as going slower than its own. That's why I said in post #20 "on average".
Actually it was this that got me interested in the scenario. And though both PAllen and myself simply eliminated the superfluous Earth the concept clearly came from you.
That's too bad,how could that happen? :confused:
ghwellsjr said:
I will assume that my assessment of his position is accurate. I was then going to point out that even though in the typical twins paradox scenario (where the traveler goes away in a straight line and then turns around and comes back) and they both observe the same redshift at the start of the trip and at the end of the trip, the percentage of time that they observe redshift and blueshift is not the same. The traveler observes redshift for exactly the first half the trip and blueshift for exactly the second half of the trip whereas the stay-at-home observer observes redshift for just about the entire time the traveler is gone and only observes blueshift during the very end of the trip. Therefore we can say that for both observers during most of the second half of their observations, the non-inertial traveler observes blueshift and inertial observer observes redshift. I finally got GAsahi to admit that their observations of redshift are different in post #164 but then communication stopped:
Yes this is clear. An alternative but equivalent perspective is:
Exactly half the signals received by the inertial twin are redshifted.
Whereas the traveler only receives redshifted signals prior to turnaround which is necessarily much less than half the total number of signals for the full course.I.e. more blueshifted signals
Exactly how did you derive the gamma factor from these relationships?
How did you turn these percentages into elapsed times?
  • #188
Fine, yes.
  • #189
I wasn't arguing for a transparent Earth here, in fact I continued with:
ghwellsjr said:
I believe uniqueland wanted to avoid all these complications, especially of not being able to see the other one during the entire orbit and so he introduced a couple webcams. Now it will depend on where the mutual antenna is located as to how much fluctuation would be seen by each observer. I mentally put this antenna above the Earth's pole to eliminate any fluctuation but to be more general, I allowed for the antenna or antennas to be located anywhere and so I included "on average".
I was trying to show that even though they couldn't see through the earth, any kind of continuous radio transmission would provide the same average Doppler as seeing through the earth. And by average, I mean over each trip of the father around the earth.
This is not an alternative perspective nor is it equivalent. The non-inertial traveler sees redshift exactly the first half the trip and blueshift the last half. The inertial twin sees redshift almost all the time with just a little blueshift at the very end.
Note that we are not concerned with the number of signals but with the interval of time as measured by each observer's clock.
I thought I explained this in post #52 using your example. If you don't understand it, could you pinpoint the area of confusion?
I'm not sure what you are looking for here. I really thought you had a good handle on this from your example and I'm afraid I might be stating the obvious. The easiest way would be to look at the traveling twin who sees redshift half the time and blueshift the other half. You could take the formula for Relativistic Doppler factor based on speed and average it with its reciprocal and that will give you gamma. This represents the ratio of the elapsed time of the inertial twin to the elapsed time of the traveling twin for any given speed. Is that the sort of thing you were looking for?
  • #190
If there is no absolute movement, moving at close to light speed has no meaning. If you are moving at the speed of light relatively to a reference frame, than anything moving with that frame is moving at the speed of light relatively to your frame. So, measured on the Earth frame you're not "ageing"; but measured on your frame your son is not "ageing" either.
Let's now imagine that your son embarks on a similar train which synchronizes his march with yours. You are both now on the same frame (yours) and your son should still be 1 year old (because in your frame no time has passed). But than he should go on a process of de-ageing, like Mr. Button, because when he embarked he was 30!??!?
Speculative discussions just lead to nowhere!
Let's look at an everyday experiment: satellite clocks.
Satellite clocks slow down relatively to Earth clocks (in fact they speed up because the effect of distance to the centre of mass (GR) is stronger at satellite altitudes). The slow down effect is quite correctly calculated by SR formulas.
This could mean that clocks slow down due to relative movement; but then, for this to be consistent, Earth clocks would slow down when measured by the satellite observer (the on-board computer).
But, everyday experience shows that this is not the case: for the on-board computer, Earth clocks also speed up due to relative movement, not slowed down.
This demonstrates that the slow down is not an effect of relative movement but only of movement relatively to the Dominant Mass. Dominant Mass (in this case Earth's mass) plays a dominant role: clocks slow down with their speed relatively to it and speed up with distance to its centre.
This is a point of view totally compatible with SR as it is applied: always relatively to Earth's reference frame. But, when applied to the satellite reference frame, it gives totally different results. Contrary to SR, this will predict that satellite clocks will slow down even on its own frame; like they really do.
Divirtam-se
Heitor
PS: The term "dominant mass" is not very precise and scientific; it's just a simplification not to deviate the discussion from it's propose: speed of light and time dilation.
  • #191
This is incorrect. If we treat this purely as a question in Special Relativity and ignore gravitational effects, the explanation is that the satellite is following a circular path and therefore accelerating: it is not permanently at rest in an inertial frame so you cannot apply results that were derived for inertial frames.
  • #192
Dr. Greg
Lots of effects are taken to correct GPS systems everyday: one of them is SR relative movement; another, GR distance to the centre of mass or the weaker gravitational field if you want.
I think it was quite clear that I was referring to those two effects ignoring all others. If I was not clear I apologize.
Regarding the SR effect it is not at all relative: it's the same for the observer on the clock's frame (the on-board computer) and the observer on Earth frame. The acceleration effect is something else.
Diverte-te
Heitor
  • #193
There is no absolute movement but we can meaningfully define moving at any speed up to the speed of light.
We cannot move at the speed of light and we cannot have one frame moving at the speed of light relatively to another frame.
Of course the father is ageing, but at a very slow rate in the Earth frame due to his very high speed. And of course the son is aging at a very fast rate according to the father's (non-inertial) frame.
Not "no time", just very little time. And the son was 5 at the start of this scenario, not 1. And just like the father, the son also would age a little bit if he took the trip but he didn't, so why introduce this totally irrelevant twist?
De-ageing?? What in the world does that mean? And the father was 35, not 30, when he got on the train. The trip lasted for 30 years. You're getting the details mixed up. The whole point of this thread is that at the start, the son is 5 and the father is 35. At the end, they are the same age, slightly over 35. But that requires that the son remain stationary and not take the trip. Since you disagree with this, you need to learn Special Relativity, not be trying to teach it.
Then why are you doing it?
Divirtam-se
Heitor
In this thread, we have ignored the effects of gravity so why introduce it now? Your point of view sounds speculative to me if it is contrary to SR. The tick rate of a clock is dependent only on its speed within a frame. The Earth clocks are stationary and tick at the same rate as any clock used to define co-ordinate time within the frame. The moving clocks tick at a slower rate. The effect is not reciprocal because the moving clocks are not stationary in any inertial frame. All frames (inertial or non-inertial) will agree that the clocks moving in a circle will tick slower than the stationary inertial clocks. And they will agree that the moving clocks will observe that the stationary clocks are ticking faster than they are. That is one of the major points of this thread. I'm sorry that you disagree with this and want to come up with your own, incorrect point of view.
  • #194
No *absolute* meaning, yes, because you have to refer the motion to something. But that's not the same as "no meaning", period.
As ghwellsjr pointed out, massive objects can't move at the speed of light; you should rephrase this to say "if you are moving at close to the speed of light..." etc. With that correction, yes, the "rate of aging" is symmetric, your son will seem to you to age slower, and you will seem to your son to age slower. But that's dependent on the fact that your relative motion doesn't change; if it changes, things get more complicated, as in the various "twin paradox" type scenarios, one of which you go on to propose:
This needs to be corrected as above; but even with the corrections, you are missing a critical element: the relativity of simultaneity. You say "when he embarked he was 30", but "when he embarked" is frame-dependent. You need to step back and carefully define the actual events involved and which frame you are defining them relative to (yours or your son's).
  • #195
I'm afraid Simplyh's proposal was not a "twin paradox" type scenario. The original scenario proposed by the OP in post #1 was a "twin paradox" scenario repeated over and over again many times and with each loop of the father, the average rate of aging and thus the accumulated age difference is not symmetric. That's what this whole thread is about and I don't understand why it has generated so much confusion. It should have ended at post #23.
  • #196
I may well have been misunderstanding what he was proposing. I agree with you that the OP question is simple, and your analysis looks correct to me.
  • #197
"There is no absolute movement but we can meaningfully define moving at any speed up to the speed of light."
How can you do that unless you refer your movement to a reference frame arbitraryly chosen to be at rest? Let's call A the "moving" frame and B the frame at rest. Can't we switch the frames? Can't we call A the rest frame and B the moving frame. If A and B are moving relatively at |.5c|, then, for the observer in A, B is moving at |.5c| and he is at rest; but for the observer in B, he is at rest and A is moving at |.5c|.
So, speaking about speed has no meaning unless you refer it to a frame which you arbitraryly choosed to be at rest: we can not say "he's speeding at .5c"; we can only say: "he's speeding at .5c relatively to ... (whatever)". So the father is speeding at close to c relatively to the .son, but the son is also speeding at close to c, relatively to his father
Of course a circular movement is an accelerated movement, but that was not the point. If we were talking about acceleration, then we should not have said that the father was traveling at the speed of light (or close, not to cause nausea on the very delicate stomachs of some participants); we should have spoken about acceleration and its effect on the man's ageing, not about speed of light! If it was only about acceleration due to circular movement around the Earth, the calculations would not be, at all, the ones we were talking about and the guy would have arrived very close to 75; only the effect of relative speed could have make him stay 35. So, let's ignore the acceleration effect which is negligible compared to the speed effect. By the way, effects can be isolated and added: in this case the speed effect would have made the man stay practically at the same age and the acceleration would have made him ageing only an a bit more slowly.
Choosing the father's frame as to be at rest, the son is moving at close to the speed of light and, as so, ageing very slowly. For the father his son will always be 5 (isn't that true for all fathers?). So, if instead of puting the father meeting the son, we make the son embark on a train similar to his father's, then he should arrive to his father's frame at the age of 5. But as he was 35 (not 30, thanks for reminding me of that very, very important detail) when he embarked (on the Earth frame) how could he have gone backwards on his age (not de-ageing, forgive my bad, bad English!).
One can make speculative thinking just to prove it is absurd.
Divirtam-se
PS: tomorrow I'll talk about satellites.
  • #198
Reference frames are arbitrarily chosen, but not necessarily at rest, the state of motion of the frame itself is immaterial as you point out in your next sentence:
Both observers are in both frames. Sometimes we refer to a frame as being an observer's frame, meaning that he is at rest in that frame, but he does not hold exclusive rights to the frame, all other observers and objects are in the frame with him, it's just that they are moving in his rest frame.
That "whatever" is always a stated frame in Special Relativity, arbitrarily chosen, as you say.
But there's a difference because the son is stationary in the Earth's inertial frame and the father is not stationary in any inertial frame. It gets really messy if you want to consider the son's motion in the father's non-inertial frame.
There is no ageing effect caused by acceleration (unless it results in a change in speed). In this scenario, the speed of the father is constant. All his acceleration causes him to move in a circle and does not change his speed. Only speed (relative to our chosen frame) effects time dilation.
The father's rest frame is non-inertial which makes it very complex. If you want to carry this out, be my guest, but it cannot yield a different result than the son's rest frame.
No, this cannot be. On every trip around the earth, the father is co-located with the son and every frame will agree about their accumulated age difference.
Like I said before, if they are both traveling at the same speed (according to our arbitrarily chosen frame), then they will age the same but that's a new scenario having nothing to do with this thread. Why are you bringing it up?
Who's doing the speculative thinking?
Simplyh said:
Divirtam-se
English is required on this forum.
You shouldn't bring up satellites on this thread. It's off topic, just like your scenario of putting the son on a train. You should start your own thread if you want to do that.
  • #199
The father's circular (centripetal) acceleration doesn't affect the son's view that his father is ageing slowly (i.e., that his father's time is "dilated"), but it does affect the father's view about how fast his son is ageing. The father's centripetal acceleration causes him to say that his son is ageing very quickly (i.e., that his son's time is "contracted", or whatever term you want to use for the opposite of "dilated").
  • #200
When we're talking about time dilation, we're talking about what we, not the observers in our scenario, see according to the frame that we have selected. There is no opposite of time dilation. What you are calling "contracted" is merely the normal co-ordinate time of the selected frame. It's only because the father's time is dilated in that frame that he perceives his son's ageing to be faster than his own.
