The case for True Length = Rest Length
In summary, the conversation discusses Lorentzian length contraction and time dilation in the context of Special Relativity. The difference between spatial and temporal components of travel is emphasized and demonstrated through the example of a car moving at different speeds. The concept of Lorentzian length contraction is explained using the analogy of a Rubik's Cube, and it is argued that it is merely an illusion. The conversation also touches upon the relativity of simultaneity and the fact that there is no absolute truth about velocity. The limitations of the diagrams used in the conversation are also pointed out.
  • #71
ghwellsjr said:
Greg and rjbeery, and now maybe you too, want to use two different frames at the same time, one for each observer/object. They want to call the length of the first object the true length in one frame while the length of the second object is illusory and at the same time they want to call the length of the second object the true length in a second frame while the length of the first object is illusory. So they, and now maybe you too, want to have multiple lengths for each object, one they call true and the other one they call illusory.
This is not the way Special Relativity works.
Hey man, either you appreciate my analogy or you don't. Does a cube face have a true width, or does it vary depending on the angle from which we observe it? It ALL boils down to semantics, really, and this entire discussion is little more than navel-gazing, but I feel that the analogy is strong particularly due to the fact that the math is equivalent.
  • #72
rjbeery said:
Yes, I read the entire post. I'm not saying that length contraction has no consequences. That being said, I think there's a very valid reason to consider the rest-energy of a particle as its "true" energy...and that is because it's the only energy that is intrinsic to it. "Where" exactly does the additional energy of an object with relativistic velocity reside? Certainly not in the object itself!
rjbeery,
I think to be more consistent with your expressed views, you should have been talking about four-momentum rather than energy.
  • #73
That's an interesting proposition bobc2. Let me think about it...
  • #74
What is this fixation on the word "true". Again: why do you feel the need to change the term from "rest length" to "true length"? After all, your "true length" is exactly the same as the standard "rest length", so why do you feel the need to invent a new term when a standard one already exists.
  • #75
No, I do not appreciate your analogy. This is not semantics. It is not navel-gazing. The fact that your analogy has math that is equivalent to whatever does not make it strong if your conclusion is wrong. If that were the criterion for making a good analogy, you could prove anything.
You started your thread with this sentence:
rjbeery said:
I wanted to discuss Lorentzian length contraction (and time dilation, for that matter).
How about we talk about time dilation now since you said you wanted to. Do you have the same attitude about the rate at which clocks at rest tick versus moving clocks? Do you make the claim that the tick rate of a moving clock is an illusion and that the true tick rate is that of the rest tick rate?
  • #76
Mentz114 said:
For the purposes of this discussion, all I ask is this:
If an object is transported from one laboratory to another that is moving relative to the first laboratory, then if its length is measured in that lab, the outcome will be the same as the identical procedure that was carried out earlier in the first lab. So there is some property of the object that was unaffected by being moved between the labs. Sort of like "the laws of physics are the same in all inertial frames".
Allowed this premise, I assert that relativistic effects cause miscalibrated measurements to give wrong answers. However if the instruments are made so they can take into account these effects, then all inertial observers will actually be measuring the length, and agreeing. Using miscalibrated measurement procedures, one is not measuring anything.
A question for you, if there is no objective reality, what exactly is the nature of thing you call length, and is there any point in measuring it ?
I have to leave now, but I'll check in again in about eight hours.
Aren't you aware that if the rod while in the second laboratory is measured by someone in the first laboratory, the length will be measured as contracted? And aren't you aware that if someone in the second laboratory measured the rod while it was still in the first laboratory using an identical procedure, the exact same contrated length will be measured? So couldn't we then say, as you did before, "So there is some property of the object that was unaffected by being moved between the labs. Sort of like 'the laws of physics are the same in all inertial frames'"?
Bear in mind, this doesn't have anything to do with frames, it's just the facts of nature. If you do analyze either of these two measurements using any inertial frame of reference, you will get the same results, because all measurements are frame invariant. How could they not be? When I observe you making a measurement and I see 39.37 inches show up on your measuring device, how can it matter how fast I am going relative to you? (I'm talking about me observing you making a measurement, not me making the same measurement.)
And aren't you aware that when a rod is accelerated from the first laboratory to the second laboratory it experiences an objective, real, actual, and true change in length? Did I leave out any words?
  • #77
No but I don't have a clue what you're trying to say, and you clearly don't understand what I'm saying.
I stand by my assertion that an object only has one length.
You quoted the barn-pole 'paradox' in an earlier post. Is the resolution of the 'paradox' not made by correcting for the relatvistic effects that caused the confusion in the first place ?
So you keep saying, but I don't know what it means.
  • #78
DaleSpam said:
What do you mean by 'objective reality' ?
'Objective' is a kind of antonym of 'subjective'. What it means in this context is that there are certain things which when measured in identical circumstances but at different times and places, will give the same answer. This is the nearest we can get to a test of 'reality' - that the outcome does not depend on the state of mind of the observer or idiosyncrasies of the measuring process.
It's the basis of physics. An objective property is not coordinate dependent, but measurements of it may be. But in the inertial frames of SR, all the local frames are the same so that is not the case here.
  • #79
Well, only if you wish to define "length" differently from how physicists normally define it, i.e. coordinate distance between the ends of an object at a single moment in coordinate time. You can make up any definitions you want and I guess it's OK if you're consistent about it, but why would you want to create confusion by ignoring mainstream terminology?
No, there is no "correcting", you simply show that each frame has their own view of things and that these different views translate correctly to one another by the Lorentz transformation, and lead to no contradictions in their predictions about localized events.
That distinction doesn't seem to make any sense. How could a property not be coordinate dependent if "measurements of it" were coordinate dependent? Our way of defining the values of any "properties" in physics is via measurements, no?
  • #80
Yes, I didn't express that very well. I'll rephrase it to : perceptions of the property will depend on the method used to measure it.
Regarding the barn-pole scenario. In the pole frame the barn is (incorrectly) measured to be shorter than the pole. If the pole guy corrects this to give the length of the barn, there's no suggestion of a paradox. As you say, the correction factors are given by the LT.
(Don't you ever sleep ? :smile:. I'm working today so I'll have to let it stand there.)
  • #81
That was me, not DaleSpam...and no, I don't sleep ;) But what are "perceptions of the property" as distinct from measurements of the property?
  • #82
Sorry, Jesse, I've amended it and added a bit it an earlier edit.
Of course measurements are a type of perception so the words could be interchanged in what I said.
(You should try sleep, sometime. It's great. I really do have to go ...)
  • #83
Why "incorrectly"? At any given moment in this frame, the coordinate distance between ends of the barn really is shorter than the coordinate distance between ends of the pole, and this frame makes no errors in its predictions of frame-invariant facts. Again, you are free to use your own definition of "length" in which the word only refers to rest length, but hopefully you acknowledge that this is nonstandard terminology, and that if you use the standard meaning of "length" it is totally correct that the barn is shorter than the pole in the pole frame.
Huh? I have no idea what you're referring to here, an analysis in the pole frame doesn't involve any "corrections" of the length of the barn. The usual resolution of the paradox is just to note that the two frames differ about simultaneity, which means they won't have any conflicts in their predictions about local events (like if the doors briefly close simultaneously in the barn frame when the pole is fully inside, in the pole frame neither door hits the pole because they close non-simultaneously) Perhaps tomorrow you could give a numerical example showing what this "correction" you're referring to would look like.
OK, but I'm still not clear on whether you are trying to make a distinction between "the property" and "perceptions of the property" in your statement "perceptions of the property will depend on the method used to measure it". If perception is just a synonym for measurement, then the value of a property is whatever value is measured, no? If different frames get different values for some property, that means that particular property is inherently frame-dependent.
  • #84
First off, I never quoted or made any mention of the barn-pole 'paradox'. You are referring to PAllen's post #39 where he described a similar 'paradox' that was later called the old "pole in the barn" example by bobc2 in post #66. JesseM answered your question to me already in post #79 so I won't comment further on it.
Now you think I don't understand what you are saying. I think you are saying that because of special relativity, observers can make incorrect measurements about the lengths of moving objects but they can always correct for these errors and if they did, the length of any object would always be the same as its rest length. Is this an adequate summary of your position?
  • #85
If I am understanding you correctly then by "objective reality" you simply mean that the laws of nature exhibit time and space translation symmetry. If so I agree with that, but then "objective reality" does not contradict length contraction nor is it incompatible with other frame-variant or relative quantities.
  • #86
Jesse, this goes back to my rotated cube. "The property" is the width of the cube face; "perceptions of the property" is the apparent, foreshortened width due to a partial rotation. Are you suggesting that if a cube is rotated a full 90 degrees then its face width is actually zero?
  • #87
But the barn is not in at rest in this frame which is why comparing the coordinates of the pole with the coordinates of the barn lead to the apparent paradox. If the measurements are adjusted for the relative velocity this erroneous conclusion is avoided.
That's disingenuous - of course I mean the LT to change coordinates so you get a comparison 'as if' both objects are at rest in the same frame.
I think further discussion about 'objective reality' belongs elsewhere and I believe I have given a definition adequate for this discussion.
I'm not sure what you mean by 'compatible with frame-variant or relative quantities.' They certainly exist as uncorrected data, but they don't measure anything, really.
I apologise if I misattributed something to you. Your summary is close. SR allows us to change coordinates between frames so every inertial observer can measure the length that is found by using the same procedure in the objects rest frame.
I see no point in defining multiple lengths for the same physical manifestation because it leads to confusion ( viz. this and the other similar thread).
  • #88
Being at rest is not required in the definition of length.
No, doing that only reinforces the paradox since the rest length of the pole is longer than the rest length of the barn.
  • #89
By your ( standard ?) definition, yes.
We're looking at different paradoxes. In the one I'm talking about, the pole is shorter than the barn when they are compared at rest, but not so from the moving pole frame.
However, I'm doing some calculations and I might find that the one-length interpretation won't fly.
  • #91
I think the 'standard' pole in the barn 'paradox' is the analogous to the alternate formulation I gave in my post #39. That is a rod with a rest length of 100 meters is hurtling towards a barn whose width is 10 meters. Assuming very rapid doors, you can open one door, let the rod in, close that door. Then open the other door to let the rod out. So briefly your 'true length' 100 meter rod has been enclosed in a 10 meter barn.
As I explained in my post #39, this would, in principle be possible. In the rod's frame, it would all look different: a barn door opens, then another opens; the really squashed barn than traverses the rod; then the door that opened first, closes. So the ordering of opening and closing has changed due to simultaneity differeences. However, the containment of the 100 meter rod in the 10 meter barn is awfully 'real' to the barn observer.
  • #92
In my way of speaking, looking at how wide the face appears visually is not a valid method of measuring the property of "face width", though it is a valid way to measure separate properties like "apparent angular width" or "width of projection of face onto your visual plane". I would say that each property is defined in terms of how it is measured, if you use the wrong type of measurement for a given property you've just mixed up the definitions, you're not measuring your "perception" of the value of the property.
  • #93
Once again you have me confused with DaleSpam ;) Anyway, of course I understand the barn is not at rest in this frame, but why should that lead to any "apparent paradox"? In this frame the pole really doesn't fit entirely into the barn at any moment in time, as I said the seeming "contradiction" between what happens in the pole frame and what happens in the barn frame is resolved by realizing this is really just an issue of the relativity of simultaneity, that the order of the events "back end of pole enters rear of barn" and "front end of pole exits front of barn" is different in the two frames, thus there is no frame-independent truth about whether the pole was "really" ever entirely inside the barn. Perhaps you could be more specific about what you think the "apparent paradox" is here, and why you think the solution has anything whatsoever to do with "adjusting for the relative velocity"?
"Disingenuous" is a pretty strong word, are you suggesting I being intentionally deceptive and pretending not to know what you're talking about when I really do? I assure you that's not the case, I really have no idea what you mean by "correction" in this context, and your new clarification is equally confusing, I have no idea what it would mean mathematically to do "a comparison 'as if' both objects are at rest in the same frame". Again, if you can give me a numerical example perhaps I would understand what you're trying to say, but your verbal explanations don't correspond to any use of the Lorentz transform I can imagine.
I haven't been following every post on this thread, mostly just looking at the ones that were responses to my own comments, so can you tell me in which post you gave a definition of what you mean by "objective reality"?
  • #94
As I explained in my post #39, this would, in principle be possible. In the rod's frame, it would all look different: a barn door opens, then another opens; the really squashed barn than traverses the rod; then the door that opened first, closes. So the ordering of opening and closing has changed due to simultaneity differences. However, the containment of the 100 meter rod in the 10 meter barn is awfully 'real' to the barn observer.
I've been analysing diagrams of the pole-barn type scenarios, especially the ordering of events in the frames. Then I started adding light rays to work out what the obervers see and I was struck by how quickly the information reaching the observers gets out of date ( at relativistic speeds ). So, while I'm not so adamant about the 'one-length interpretation' it's not quite dead yet. I'm going to work on the diagrams and analysis rather than post here for now and maybe have something worth reporting later.
Thanks for your inputs.
  • #95
Once again, I apologise. Your remarks are apposite and for now I'll give the same response I give to PAllen in my previous post.
(the post you're looking for is #78, I think)
This "thus there is no frame-independent truth about whether the pole was "really" ever entirely inside the barn. " is pretty much what I was beginning to think, but I'm not sure yet. I'll have to draw some more light beams.
Rather than repeating my arguments I'd like to work on it. I'll get back to you, thanks for your inputs.
Also thanks to other respondees and the OP, I don't have the time to reply to all of them, unfortunately.
  • #96
That would be great! I've made some attempts at this without ever carrying it through to a conclusion; but enough to see that what a movie shows would be quite different from the same data interpreted by removing light delays with standard conventions. Also, note that you can remove issues of interpreting light signals (at least in thought experiments) by such direct means as a hypothetical sheet of detecting tissue across each door opening (separate from the doors), attached to recording clock 'right there' so no time delay. Then, irrespective of what an observer would 'see' from any single vantage point, they could put all their data together and find it hard to avoid concluding they had momentarily trapped the 100 meter rocket in the 10 meter barn.
However, be all this as it may, I actually favor the idea of rest length being special for a sufficiently rigid body, and that it is reasonable to treat it as a property of the object. For larger and larger bodies, sufficient rigidity breaks down both in the real world and in theory (1 light year born rigid rulers, anyone?). What I also think is that other lengths observed for the object are also real in the only way that matters to me: what you would measure and reasonably conclude from your measurements.
My analogy is to a cylinder with arbitrary cross section. If someone says, without qualification, 'what is the cross section of that cylinder?' , we all assume an orthogonal slice and discuss the resulting shape and area. We do this even though if we actually cut the cylinder at an angle, we don't pretend that the result we got is an illusion and not real. Furthering this analogy, the more irregular the shape (rather than a cylinder), the more it breaks down to talk about any standard cross section. The analogy to space time seems very direct to me. A rigid body is the analog of the cylinder (cylindrical world tube), while not rigid bodies are like messy objects.
  • #97
Rjberry, I'm still waiting for a response from you to my questions posed in post #75.
  • #98
I have a suggestion that might be of interest. Instead of pole/ barn, consider the following based on my equivalent variant in post #39; this provides several different types of measurements at once:
100 meter rest length rocket going near c left to right (close enough to c that its contracted length is less than 10 meters). Assume the rocket has fins signficant wider than the body of the rocket.
Imagine tissue like detecting membrane and associated clocks. These can directly measure the passage of nose and fins of the rocket. These are placed 10 meters apart.
Also imagine barriers shooting up and down as in post #39 adjacent to the tissue detectors, but with cameras on them positioned to take head on / tail on pictures of the rocket when the barriers are fully up.
So now we have the sense of containment from barriers, direct measurement of rocket nose tail passing, plus a very interesting pair of images.
I think these end on cameras or more relevant than side cameras, though that would be interesting too.
(The right image would show the rocket from well before it reached the left barrier. The left image would, all the same, show a distorted picture of the tail).
  • #99
Depends what you mean by "illusion". You might take it to mean that the measurement itself is false, rather than simply differing from the true value of the property being measured, but that isn't right (or rather, that's not what I mean). When I say illusion I mean that the property of an object being measured isn't its "true" value, but that doesn't mean that the "illusion" has no physical consequences. As an example, I had to fit an ottoman through a door the other day which would not fit because the ottoman was wider than the doorway. I rotated the ottoman, such that its foreshortened length was able to fit. Did I actually change the length of the ottoman, or was its foreshortening "illusory"? The illusory effect of foreshortening has physical consequences.
Another example: analyze the color of a binary star and you'll find that it alternates between being redshifted and blueshifted as it orbits its partner. Is it "actually changing color", or is it "an illusion"? The answer that most people would give is that the apparent color change is an illusion...yet the blueshifted color has more energy than the redshifted color nonetheless. Therefore the illusory effect of wavelength shifting has physical consequences. Ask yourself why we feel it's proper to correct for Doppler induced red- and blue-shifting caused by relative motion but NOT to correct for SR-related length contraction caused by relative motion...
When we make measurements we must consider perspective before assigning "true" values to the object under consideration. The whole point of this thread for me is to point out that "perspective" includes relative speed, and that leads me to conclude that "true" length is that which is measured locally and inertially to an object. In the end it's nothing more than a (possibly unnecessary) semantic convention but I find the logic to be sound.
  • #100
I meant whatever you meant at the end of your first post:
rjbeery said:
Considering SR in this light, one could make the case that objects DO have an absolute length, that being their maximally-measured inertial length, and that any Lorentzian contraction is in fact an illusion.
Would you also make this claim:
Considering SR in this light, one could make the case that clocks DO have an absolute time, that being their minimally-measured proper time, and that any Lorentzian dilation is in fact an illusion.
You are using the words "true" and "false" and "illusion" and "actually" and "apparent" and "absolute" when applied to lengths of moving objects. I'm asking you to use whatever you mean by those words (and I don't care what you mean) and tell me if you believe those same words apply to times on moving clocks.
  • #101
Restricted to SR, which is the scope of what we're discussing, the appearance of moving clocks ticking slowly is an illusion. Proof of this is that the effect is reciprocal, in the same way that if you and I are not facing squarely to each other we could both make the claim that the other guy is narrower. It's a bit nonsensical to assign any true or intrinsic value to a measured property if it leads to a logical contradiction.
  • #102
rjbeery and mentz114, you seem to be looking for some aspect of a 3-D object that could be considered a "True" or objective property. Maybe a concept of 4-D objects (rod or beam) or properties such as 4-Vectors could work for you.
Consider again the pole and barn example that PAllen presented earlier. I've tried to sketch it below in a way that would emphasize the concept of 4-dimensional objects. Incidently, I've used a symmetric spacetime diagram (both objects moving in opposite directions at the same relativistic speed with respect to the black coordinates in order to obtain the same distance scaling for both red and blue coordinates.
It is clear that both observers (red and blue) witness very real phenomena, and when viewed in four dimensions there is no argument at all about whose observations are correct--they both are (and no need to make corrections for one's view, although blue could do a Lorentz transformation if he is curious about what the red guy is experiencing).
Notice you could raise other four dimensional questions such as, "what is the 4-Vector magnitude between events A and B (the blue and red guys would both get the same answer)?
  • #103
Why do you say "restricted to SR"? Are you leaving open a loop-hole through which you can explain the Twin Paradox?
  • #104
It's because SR effects produce measurements that are apparently contradictory and reciprocal (i.e. each party concludes the other's watch is slower), similar to mutual foreshortening. When you involve acceleration you break that reciprocity.
  • #105
You can analyze the Twin Paradox from any frame of reference. They all agree that each party views the other party's clock as running slower than their own during the entire trip and yet when they re-unite, the traveling twin's clock has progressed a lesser amount of time. The reciprocity is not broken just because one of them accelerated.
You can also analyze the Twin Paradox without using any frame of reference and without using Special Relativity. You can analyze it simply from the observations of each other's clocks during the trip using Relativistic Doppler. Again, they always see each other's clock as running slow compared to their own in a reciprocal manner and yet when they re-unite, the traveling twin's clock has progressed a lesser amount of time.
SR does not make or create the way nature works, it's merely one way to describe and analyze it.
