Argentum Vulpes
The possibility of getting a working engine out of four possibly destroyed engines is near slim. The biggest problem is the high humidity and corrosive nature of the air in and surrounding the island. The seals should all be good, the problem is the weakened engine block and the large possibility of seized bearings.
If it were possible to get good parts off of a tear down of all four to make a working engine (it is vary easy to tear an engine down, I need a socket set, hammer, rubber mallet, and some high power solvent). The next big problem would be putting it back together, any sleave compression bearings would most likely need to be needed to be replaced, and a torque wrench is also an absolute necessity (if the gaskets and compression bearings aren't torqued to specs or evenly it whole thing will be large bomb worst case, completely destroyed best case when it was fired up).
Now if we manage to find all of the needed stuff for a teardown/rebuild the last major hurdle would be getting a good lubricant for the engine (something with a good thermal breakdown resistance and a medium viscosity at cold and operating temps of the engine. Also if we were to use alcohol for the fuel it would need to be pure (295 + prof) and the timings and carb jets would need to be changed.
There might also be a problem with running the engine at low altitude, they were built for high altitude moving through cold air, so the heavy warm air of the jungle floor might burn up the engine.
Yep, that seemed sharp enough. Hypatia, just keep holding pressure on the wound. Evo, I need thread! Strip dduardo and shred his clothing to threads and soak them in the alcohol. Wolram, once we get the clothes off dduardo, take those leather straps and tie him up to that tree so he stays out of trouble!
