- #106
wolram
Dearly Missed
- 4,446
- 558
Argentum Vulpes said:The possibility of getting a working engine out of four possibly destroyed engines is near slim. The biggest problem is the high humidity and corrosive nature of the air in and surrounding the island. The seals should all be good, the problem is the weakened engine block and the large possibility of seized bearings.
If it were possible to get good parts off of a tear down of all four to make a working engine (it is vary easy to tear an engine down, I need a socket set, hammer, rubber mallet, and some high power solvent). The next big problem would be putting it back together, any sleave compression bearings would most likely need to be needed to be replaced, and a torque wrench is also an absolute necessity (if the gaskets and compression bearings aren't torqued to specs or evenly it whole thing will be large bomb worst case, completely destroyed best case when it was fired up).
Now if we manage to find all of the needed stuff for a teardown/rebuild the last major hurdle would be getting a good lubricant for the engine (something with a good thermal breakdown resistance and a medium viscosity at cold and operating temps of the engine. Also if we were to use alcohol for the fuel it would need to be pure (295 + prof) and the timings and carb jets would need to be changed.
There might also be a problem with running the engine at low altitude, they were built for high altitude moving through cold air, so the heavy warm air of the jungle floor might burn up the engine.
I totally agree, the idea of resurrecting one of these engines is slim to none
but perhaps we could use the parts for other things. sorry Brewy, Danger.
