- #71
Topher925
- 1,566
- 7
xxChrisxx said:The reason that is becuase American car manufacturers have been horribly backwards with engine design. American manufacturers like cheap, with no regard to environmental cost.
One of the links you posted said its only the European manufacturers that use the turbo strategy. Every American AND Asian manufacturer currently are taking the NA route in general. And I wouldn't say American manufacturers are backward at all. The Ford EcoBoost is a fantastic engine that uses state of the art technology including a turbo. Its just very expensive and the NOx emissions can be high.
Turbocharged cars are complex and therefore are disregarded. They are stuck in a rut, American consumers hove your attitude to turbo motors, so manufacturer will make them for fear of not selling. The consumer can't buy them if no one sells a good turbo motor.
Engines in general are complex, with or without turbos. And I don't think most consumers are afraid of turbos. I always thought that was a big selling point for Saab's was that most of their models could come with a turbo.
This however is changing. Get with the times. Engine downsizing is the trend within the industry to provide the power and meet emissions standard , you will find it in the vast majority of cars world wide. If not this generation, then the next generation of cars.
I'm hoping the next generation of cars won't have turbo's because they won't have ICEs.
Ford is putting a 2.0L Turbo over it's V6 in the new Explorer. Similar power output with a boost in economy of aprox. 30%...
Yes, all very good examples, especially the Ford Ecoboost engine. However, you're not comparing apples to apples. All the engines in the links you posted include a lot more than turbo's to aid in fuel efficiency. I believe just about all "downsized" engines that use turbos also use direct injection or DISI which in itself accounts for huge efficiency improvements, I would argue much more than a turbo.
I think engine downsizing is going to occur which will include the introduction of turbos and direct inject into cars. Both technologies compliment each other extremely well. But I didn't think that's what we are talking about? I thought this thread was about more classical engine tech that used port injection like your average car. If this isn't the case, then you should also be comparing NA engines that use the Atkins cycle, variable valve technology, and direct inject.
The advantage comes from the fact that you are running the turbo (ie compressing the air) with something you would otherwise just throw straight out the exhaust and not something you want to use. It's like adding an LP turbine to a power plant to take advantage of the energy still left.
No it isn't. A turbo doesn't use any wasted power with the exception of power that is extracted from exhaust gas expansion. When you add a turbo to an engine, the pistons have a greater exhaust gas pressure due to the obstruction that the turbo creates. In other words, the engine has to work harder to push out the combustion products on the exhaust stroke. This is by no means "free" power which a lot of people like to believe.
The power extracted from the thermal expansion of exhaust gases can be determined by measuring the temperature difference before and after the turbo. However, heat transfer needs to be taken into account as well. That impeller spinning at over 100K rpm has a very very good convective heat transfer coefficient.
Not only that, turbo cars a far easier to drive. As they have fat torque from the minute they come on boost. Leading to a wider power band.
http://autospeed.com/cms/title_Turbod-for-Fuel-Economy/A_109931/article.html
I would say turbo lag makes them more difficult to drive but to each his own. I'm not a race car drive, so such things don't really matter to me when choosing a car.
If you want something with good mpg and emissions, it's time to get yourself a new downsized turbo then isn't it.
My 05 Civic is rated for 26/35mpg and is classified as a ULEV. What downsized turbo ICE that's available in the US can provide the same emissions and fuel economy for around the same price?
