- #18,061
- 22,346
- 13,995
Florida is smaller than 15 light minutes …topsquark said:All in a 15 minute time span.
I'll give it a try. I was able to do it on my previous one.Ibix said:Can you not just long touch the image and select Save image? That's how it works on my 'droid.
Then vegan should include all coal-fired boilers, locomotives and power stations.jtbell said:IIRC there have been wood-burning steam locomotives. Would those count as vegan?
Gas and Diesel are vegan, too, if you think about it.jtbell said:IIRC there have been wood-burning steam locomotives. Would those count as vegan?
Depends what you consider a plant.fresh_42 said:Gas and Diesel are vegan, too, if you think about it.
Phyto means plant IIRC. However, let me tell you a story about what can be called vegan.BillTre said:Depends what you consider a plant.
Aren't oil deposits from marine phytoplankton. Although they have chloroplasts, I don't think they are plants.
The derivation of the prefix syllable does not determine how an organism is classified scientifically.fresh_42 said:Phyto means plant IIRC. However, let me tell you a story about what can be called vegan.
Good for Sheldon.BillTre said:The derivation of the prefix syllable does not determine how an organism is classified scientifically.
May work for colloquial or ancient conversations, but not accurate.
Would be evolutionarially misleading.
Not plants:
algae
floating single cells that can photosynthesize (both eukaryotic (algae) and prokaryotic (including cyanobacteria (from which chloroplasts are thought to have been derived))).
