- 20,713
- 28,098
Or been about 10 at the time with a teenaged stereophile brother. Some of us youngests are head of our time.Baluncore said:You would need to have been aged about 17, and listening to Pink Floyd in 1973. That makes you about 70 now.
Really? How disappointingOrodruin said:Except step 8 being impossible …
Mythbusters managed 11. But started with a piece of paper that fit in an airplane hangar.Orodruin said:Except step 8 being impossible …
The assumption I think is standard A4 or letter.jbriggs444 said:Mythbusters managed 11. But started with a piece of paper that fit in an airplane hangar.
But if you're too fast you might use the doorway next to it!Ivan Seeking said:All doorways should have a warning sign: Walking through this doorway too slowly may cause you to diffract.
I think that's only if you have a split personality.fresh_42 said:But if you're too fast you might use the doorway next to it!
You could use both doorways, but only if nobody's looking.fresh_42 said:But if you're too fast you might use the doorway next to it!
Nope. I minimum of uncertainty is enough.phinds said:I think that's only if you have a split personality.
Hubble constant says hello.jack action said:
You mean ##2.2\cdot 10^{-18}## s-1?Bandersnatch said:Hubble constant says hello.
First of all, that should be in Hertz. But you know as well as I do, that in all literature it is given as 7.2 furlongs per fortnight per gigafathom.Orodruin said:You mean ##2.2\cdot 10^{-18}## s-1?
And regular computers rely on trans-istors. It's a woke minefield!BillTre said:From The Onion:
MAGA Enraged as Quantum Computers Come Out as Non-Binary
Yeah, but you have to remember that the times they are a changin'. Trans people aren't what they used to be.Ibix said:And regular computers rely on trans-istors. It's a woke minefield!
Cis people are all the same (side), but the para people are opposed.phinds said:Yeah, but you have to remember that the times they are a changin'. Trans people aren't what they used to be.
When I went to buy a plug and receptacle the other day, the signs said, "Identifies as male", and Identifies as female".BillTre said:From The Onion:
I couldn't find it on the Onion but it was on a reddit thread for Onion-like headlines:BillTre said:From The Onion:
I’m waiting for one that will settle the conflict between the Big-Endians and the Little-Endians (the real one about boiled eggs, not the byte-ordering tempest in a teapot).Swamp Thing said:How will the recent seismic changes in Washington affect the Frequentist vs Bayesian controversy and its partisans on either side?
Any Executive Orders regarding this?
| < 3.0 to 5.0 | Watching table tennis |
| 5.0 to 6.5[ | Doing "eye rolls" while watching table tennis |
| > 6.5 | Rapid Eye Movement (REM) |
I can count to 1023 on my fingers …Bandersnatch said:
59,048 if you can control the joints independently.Orodruin said:I can count to 1023 on my fingers …![]()
I cannot, unfortunately. Partly a result of being a football goalkeeper in my youth. (Balls hitting fingers at unfortunate angles is nothing I recommend.)Ibix said:59,048 if you can control the joints independently.
OK, I'll bite. How did you get that number?Ibix said:59,048 if you can control the joints independently.
I get ##10^9## if controlling each joint completely independently. 3 joints per finger except thumb, which has 2, but is opposable so that’s another degree of freedom. That means 15 joints per hand so ##2^{30}-1##.Tom.G said:OK, I'll bite. How did you get that number?
If you can control the joints independently you can have your finger straight or with one or two joints folded, so three states. The number is ##3^{10}-1##.Tom.G said:OK, I'll bite. How did you get that number?
Ah, but there are three different states in each of those categories depending on which one or two joints you fold!Ibix said:or with one or two joints folded
I think I can only fold the lower joint or both, not the fully-independent flexibility required for this!Orodruin said:I get ##10^9## if controlling each joint completely independently. 3 joints per finger except thumb, which has 2, but is opposable so that’s another degree of freedom. That means 15 joints per hand so ##2^{30}-1##.
